CS4 Premiere Audio and Video Out of Sync Mac
Video My Life Jun 21, 2010 8:53 PMHi everyone. I import AVCHD assets from my Sony HDR SR8 into CS4 Premiere on my Macbook Pro 17. Upon playback the audio plays before the video, even to the extent that the audio is finished before the video. I am capturing to my one and only hard drive on my Mac using the USB port on the Mac. Are you able to help me figure out what I am doing wrong? I assume I have done something wrong during the set up process. Here are the particulars:
Camcorder and native clips:
Sony HDR-SR8
AVCHD format 1440 × 1080/60i
1,080 effective scanning lines and the interlace system
The MPEG-4 AVC/H.264 format is adopted to compress video data
Laptop:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.8 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Type: DDR3
Speed: 1067 MHz
Type: DDR3
Speed: 1067 MHz
Bus Speed: 1.07 GHz
Serial ATA:
NVidia MCP79 AHCI:
Vendor: NVidia
Product: MCP79 AHCI
Link Speed: 3 Gigabit
Negotiated Link Speed: 1.5 Gigabit
Description: AHCI Version 1.20 Supported
Hitachi HTS545050B9SA02:
Capacity: 500.11 GB Total, 312 GB Used
Model: Hitachi HTS545050B9SA02
Graphics/Displays:
Chipset Model: NVIDIA GeForce 9400M
Type: GPU
Bus: PCI
VRAM (Total): 256 MB
Chipset Model: NVIDIA GeForce 9600M GT
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 512 MB
Premiere CS4 Settings:
Project:
For editing AVCHD Formats recorded in anamorphic 1920x1080 (ex.1440x1080).
16:9 interlaced HD video at 29.97 frames per second.
48kHz audio.
Drop-Frame Timecode numbering.
Editing mode: AVCHD 1080i anamorphic
Timebase: 29.97fps
Video Settings
Frame size: 1440h 1080v (1.3333)
Frame rate: 29.97 frames/second
Pixel Aspect Ratio: HD Anamorphic 1080 (1.333)
Fields: Upper Field First
Audio Settings
Sample rate: 48000 samples/second
Sequence:
720 x 480
00;00;00;00, 29.97 fps
48000 Hz - Stereo
Captured Clips Settings:
Type: QuickTime Movie
Image Size: 720 x 480
Pixel Depth: 24
Frame Rate: 29.97
Source Audio Format: 48000 Hz - 16 bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:21:19:20
Average Data Rate: 3.6 MB / second
Pixel Aspect Ratio: 1.2121
Anything stick out in these specifications, folks? Thanks for your time!
