3 Replies Latest reply on Jun 24, 2010 6:41 AM by Francisc
    AMFPHP Error on Production Server
    Francisc Level 3
      Hello!
      I am using AMFPHP 1.9 (latest stable version at the time of this post) and it works fine on localhost.
      The problem is on the remote server, where I get this error:
      Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 406
      Any idea what needs to be setup differently?
      Thank you!
        • 1. Re: AMFPHP Error on Production Server
          David_F57 Level 5
          hi,.
          try going to the amfphp browser, that way you can see if your services etc are there, also are you configuring your endpoints to the remote server in the services-config file.
          http://mydomain.com/amfphp/browser/browser.html   <<====== replace mydomain.com with your host.
          David
          • 2. Re: AMFPHP Error on Production Server
            Francisc Level 3
            I'll give that a go, but I set it properly for the application itself - as the browser is not neccesary for AMFPHP to work - and it didn't do the trick.
            Thanks, I'll let you know.
            • 3. Re: AMFPHP Error on Production Server
              Francisc Level 3
              Nope, that didn't fix it.
              The error I get is this:
              (mx.rpc::Fault)#0
                errorID = 0
                faultCode = "Client.Error.MessageSend"
                faultDetail = "Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed"
                faultString = "Send failed"
                message = "faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed'"
                name = "Error"
                rootCause = (Object)#1
                  code = "NetConnection.Call.Failed"
                  description = "HTTP: Failed"
              I've been trying to get this fixed for 2 days now and I can only find the same question everywhere with no answer.
