2 Replies Latest reply on Jun 1, 2011 9:02 AM by ChunMeiChr!sta
    adding shape hints makes shape disappear in between frames
    petersrule
      Whenever I add shape hints to a shape tween the shape disappears in the between frames. I am using CS5 on Vista. I using files from lynda.com to practice.
        • 1. Re: adding shape hints makes shape disappear in between frames
          kfitfk Level 1
          This topic is so long ago.
          I encountered the same problem, following the lynda.com Flash CS5 Essential Training
          Looks like no one else here?
          • 2. Re: adding shape hints makes shape disappear in between frames
            ChunMeiChr!sta
            Oh man, I had the same problem!
            After searching online for an answer, I found NOTHING that actually helps.
            It wasn't until Flash crashed (which is 'another' wonderful feature courtesy of Adobe) and I had to restart my project
            that I realized how to fix this issue.
            Try just moving some of the points in between the two outer points.
            Some of the tutorials I've read say that if the tweens are too difficult, then the hints wont work as well, even if flash is saying they are lined up correctly and turn green/yellow like they are suppose to.
            I think by adjusting the inner shape hints' positions, it puts the animation in a slightly easier path to tween.
            I hope this helps, it sure helped me!
            Good luck!
