2 Replies Latest reply on Jun 28, 2010 7:32 AM by Mike Peterson
    simple insert row without the generated forms
    adnan.m
      Hello,
      Is there a way to simply insert a row in a table without using the auto generated form from LCDS.
      I am already inserting data in one table thru the generated form, but I would like to add a row in my LOG table as well.
      If you can point me to a tutorial/example.
      Regards,
      Adnan
        • 1. Re: simple insert row without the generated forms
          AnilKrc
          I am not sure I understand your question.
          With Model Driven Development, the modeler generates a service for each entity e.g. the tool generates CustomerService, with CRUD methods, for the entity Customer. You are free to call create method from Flex to insert a row to your table.
          Alternatively, you can also override the generated Java assembler (http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WS4976f0ec3ef482461096f 38112701857408-8000.html)
          Hope this helps.
          Anil
          • 2. Re: simple insert row without the generated forms
            Mike Peterson
            You can definitely create a new row without using hte model-driven form. As an example, take a look at the addProductToOrder() method in following MXML component. This productsAdd MXML component is used in another MXML file (also shown below).
            <HBox
            =xmlns="http://www.adobe.com/2006/mxml" xmlns:orders="orders.*">
            <Script>
            <![CDATA[
            import orders.Orderline;
            import orders.Storeorder;
            import orders.Product;
            import orders.ProductService;
            import orders.OrderlineService;
            import mx.rpc.AsyncToken;
            import mx.collections.ArrayCollection;
            public var dgAllOrders:DataGrid;
            Bindable]
            private var productFillToken:AsyncToken;
            Bindable]
            public var formToHide:HBox;
            private function addProductToOrder():void
            var orderLine:Orderline = new Orderline();
            orderLine.quantity = quantOfProdToAdd.value;
            orderLine.product = (dgProducts.selectedItem
            as Product);
            orderLine.storeorder = (dgAllOrders.selectedItem
            as Storeorder);
            orderLineService.createOrderline(orderLine);
            as Storeorder).orderLines.addItem(orderLine);
            orderLineService.serviceControl.commit();
            formToHide.visible =
            false;
            </Script>
            <!-- <ChannelSet id="cs">
            <RTMPChannel url="rtmp://localhost:2037"/>
            </ChannelSet>
            <orders:OrderlineService id="orderLineService" channelSet="{cs}"/>
            <orders:ProductService id="productService" channelSet="{cs}"/> -->
            <orders:OrderlineService id="orderLineService"/>
            <orders:ProductService id="productService"/>
            <VBox>
            <HBox>
            <Button id="btnGetProducts" label="Filter Products By Name" click="{productFillToken = productService.getByNameLike('%' + searchProductName.text + '%')}"/>
            <TextInput id="searchProductName"/>
            </HBox>
            <DataGrid id="dgProducts" dataProvider="{productFillToken.result}">
            <columns>
            <DataGridColumn dataField="productname"/>
            <DataGridColumn dataField="description"/>
            <DataGridColumn dataField="price"/>
            </columns>
            </DataGrid>
            <HBox>
            <Button id="btnAddProductToOrder" label="&lt;&lt; Add Product To Order"
            click="addProductToOrder()" enabled="
            {dgProducts.selectedItem != null}"/>
            <NumericStepper id="quantOfProdToAdd" minimum="1" maximum="100" stepSize="1" enabled="{dgProducts.selectedItem != null}"/>
            <Button label="Cancel" click="formToHide.visible = false"/>
            </HBox>
            </VBox>
            </HBox>
            Here's the MXML app in which the MXML component is used:
            <Application
            xmlns="http://www.adobe.com/2006/mxml" backgroundColor="white" height="100%" width="100%"
            xmlns:local="
            *" creationComplete="initApp()" xmlns:orders="orders.*" xmlns:generatedForms="orders.generatedForms.*"
            xmlns:forms="
            orders.forms.*">
            <Script>
            <![CDATA[
            import orders.StoreorderService;
            Bindable]
            Bindable]
            private var orderFillToken:AsyncToken;
            private var orderService:StoreorderService = new StoreorderService();
            private function initApp():void
            orderService.serviceControl.autoCommit =
            false;
            orderFillToken = orderService.getAll();
            private function complete():void
            orderService.serviceControl.commit();
            </Script>
            <orders:Storeorder id="storeorder"/>
            <HDividedBox width="100%" height="100%" borderColor="#FFFFFF" backgroundColor="#FFFCFC">
            <VBox height="50%">
            <Button id="btnAddProduct" label="Create New Order"
            click="(dgAllOrders.dataProvider
            as ArrayCollection).addItem(new Storeorder())"/>
            <DataGrid id="dgAllOrders" dataProvider="{orderFillToken.result}" height="341">
            <columns>
            <DataGridColumn dataField="ordernumber"/>
            <DataGridColumn dataField="shipdate"/>
            <DataGridColumn dataField="status"/>
            </columns>
            </DataGrid>
            </VBox>
            <VBox height="100%">
            <HBox horizontalAlign="center" width="100%" >
            <Label text="Locale:"/>
            <local:languageSwitch />
            </HBox>
            <forms:StoreorderForm height="100%" id="orderForm" valueObject="{dgAllOrders.selectedItem as Storeorder}"/>
            </VBox>
            <VBox width="250">
            <Panel height="100%" width="100%" title="Order Details" label="Order Details" backgroundColor="gray"
            visible="
            {dgAllOrders.selectedItem}" includeInLayout="{dgAllOrders.selectedItem}">
            <local:orderLinesDetail dgAllOrders="{dgAllOrders}" visible="{dgAllOrders.selectedItem}"
            includeInLayout="
            {dgAllOrders.selectedItem}" formToShow="{productsAddForm}" width="100%"/>
            </Panel>
            </VBox>
            <local:productsAdd formToHide="{productsAddForm}" id="productsAddForm" dgAllOrders="{dgAllOrders}" width="100%" visible="false"/>
            </HDividedBox>
            </Application>
