4 Replies Latest reply on Jun 22, 2010 10:08 PM by BhaskerChari
    Using Itemrenderer to do simple stuff
    armalock
      Hi all,
      For simple stuff like concat (e.g. {data.author}: {data.title}), it is better to use labelFunction. The problem is this kind of functionality is not available on all tags. E.g. for data grid columns, I can only specify dataField, which will cause the grid to do a lookup like data[dataField] to determine the value. My main problem is internationalization. When I have a number, date etc in my raw data, I need to convert these for display. I do not want to change the array itself since that is in my model layer. I found using item renderers and label functions to be the quickest solution. However, for simple stuff like calling convertDate( ) on the data, an item renderer sounds heavy weight. Is there another way or is this a legitimate use of item renderer?
        • 1. Re: Using Itemrenderer to do simple stuff
          Flex harUI Adobe Employee
          I'd probably still use labelFunction.
          • 2. Re: Using Itemrenderer to do simple stuff
            armalock Level 1
            Thanks. But how do you use labelFunction within a data grid? I have something like this:
                <mx:DataGridColumn headerText="{Localizer.i18n(RSConstants.timestamp)}" dataField="timestampColumn">
                    <mx:itemRenderer>
                      <mx:Component>
                        <mx:Label text="{Localizer.convertDateFromEpoch(data["timestampColumn"])}">
                          <mx:Script>
                            import myproject.locale.Localizer;
                          </mx:Script>
                        </mx:Label>
                      </mx:Component>
                    </mx:itemRenderer>
                  </mx:DataGridColumn>
            How can this be written without using the itemRenderer?
            • 3. Re: Using Itemrenderer to do simple stuff
              BhaskerChari Level 4
              Hi armalocak,
              You can do the following using the labelFunction...in itemrenderer..
              private function healthTotalLabelFunction(item:Object, column:DataGridColumn):String
                 return convertDate(item.date);
              private function convertDate(date:Date):String
              var dateString:String = //write your logic here;
              return dateString;
              <mx:DataGrid>
                 <mx:columns>
                  <mx:DataGridColumn headerText="BenefitType" width="222" color="#747474" dataField="BenefitName"/>
                  <mx:DataGridColumn headerText="Total" textAlign="right" width="87" labelFunction="healthTotalLabelFunction"/>
                 </mx:columns>
                </mx:DataGrid>
              Note: You can even display the data in a column by making use of labelFunction without specifying the dataField property for DataGridColumn.
              If you observe clearly I havent specified dataField proprty for second column...but still it will display data..because of labelFunction..
              If this post answers your question or helps, please kindly mark it as such.
              Bhasker Chari
              • 4. Re: Using Itemrenderer to do simple stuff
                armalock Level 1
                Excellent. I was unaware that labelFunction can be used that way within a data grid . I am guessing the sorting will still work if I provide the dataField correct? (Sort on raw data is okay). Thanks!
