0 Replies Latest reply on Aug 20, 2007 2:51 AM by thellersREM
    ExternalInterface, Firefox and Function.apply
    thellersREM
      I am having problems in Firefox with calling a Flash function from
      JavaScript using Flash 8's ExternalInterface.
      Basically, I can call the function just fine using the straight-
      forward method:
      myFlashMovie.doSomething(param1, param2, param3);
      ...that works fine.
      However, the functionality I am creating is slightly more complex and
      therefore calls for the use of the "apply" method of the Function
      object.
      What I therefore want to do is essentially this:
      var args = new Array(param1, param2, param3); //build my array of
      params (in the real code, it's not so simple as this, but you get the
      idea)
      var func = myFlashMovie.doSomething; // set variable func to
      reference my flash function
      func.apply(this, args);
      This then allows me to call different flash functions dynamically,
      with different numbers of params etc. As I've said, the actual setup
      is slightly different so no need to discuss whether or not this kind
      of approach is necessary or not (it is).
      The problem is, that using the Function.apply methood DOES NOT work in
      Firefox for executing Flash functions. I have tested various things,
      as follows:
      1) Does Function.apply work in Firefox for executing normal JS
      functions -- YES
      2) Does the JavaScript inside Firefox recognise
      "myFlashMovie.doSomething" as being a function -- YES (tested using
      "typeof()")
      3) Can myFlashMovie.doSomething be executed using the normal method
      of myFlashMovie.doSomething(p1, p2, p3) etc. -- YES, it works fine!
      So, my only solution currently is very inelegant indeed, and that is
      to do something like this
      switch(args.length){
      case(1):
      myFlashMovie.doSomething(args[0]);
      break;
      case(2):
      myFlashMovie.doSomething(args[0], args[1]);
      break;
      case(3):
      myFlashMovie.doSomething(args[0], args[1], args[2]);
      break;
      ...which works, yes, but isn't exactly great.
      So, I was wondering if anyone had managed to execute a Flash function
      from JS, in Firefox, and successfully done it using Function.apply.
      Alternatively, anyone got better alternative to my switch(args.length)
      method? Maybe one that's a bit less limiting?
      Many thanks in advance!!
      Andy.
