9 Replies Latest reply on Jun 23, 2010 4:55 AM by JaxNa
    How i can add PNG image in custom component?
    JaxNa Level 1
      Hi Guys,
      This is my custom Component.
      <components:EmployeeDisplay imageFile="abrilliam.png"/>
      Can you help me please how to add png format image.
      when i add png format image that time this image not displayed.
      what can i do?
      JaxNa
        • 1. Re: How i can add PNG image in custom component?
          AdrianWiecek Level 3
          You can embed this file using @Embed(source='image.png') or load it at run-time  and pass a reference to loaded bitmap.
          • 2. Re: How i can add PNG image in custom component?
            BhaskerChari Level 4
            Hi Jaxna,
            Post your code in the EmployeeDisplay component...file.
            Bhasker Chari
            • 3. Re: How i can add PNG image in custom component?
              JaxNa Level 1
                  xmlns:mx="library://ns.adobe.com/flex/mx"
                  minWidth="1024" minHeight="2000"
                  xmlns:components="components.*">
                   <s:BorderContainer borderColor="#0b85b7"
                                     cornerRadius="8"
                                     borderWeight="4" width="489" height="491" y="100" x="107">
                      <s:Label x="20" y="10"
                               text="Mobiles"
                               fontWeight="bold" fontSize="20"/>
                      <s:Scroller height="500" width="500">
                          <s:Group x="7" y="4" width="485" height="484" id="MobileGroup">
                              <s:layout>
                                      <s:TileLayout/>
                                  </s:layout>
                          <components:EmployeeDisplay  x="75" y="110"
                               imageFile="W580i_52x104.png"/>
                      </s:Group>
                      </s:Scroller>
                      </s:BorderContainer>
              </s:Application>
              • 4. Re: How i can add PNG image in custom component?
                Hi Jaxna,
                I have asked to post your CustomComponent code:
                Bhasker Chari
                • 5. Re: How i can add PNG image in custom component?
                  JaxNa Level 1
                  Hi BhaskerChari,
                  This is Custom Component Code..
                  <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx">
                      <mx:Image x="0" y="0"
                          source="images/{imageFile}" />
                      </s:Group>
                  This code is in MXML
                      <!-- UI components ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
                                         cornerRadius="8"
                                   text="Mobiles"
                                  <s:layout>
                                          <s:TileLayout/>
                                      </s:layout>
                          </s:Group>
                          </s:Scroller>
                  </s:Application>
                  JaxNa
                  • 6. Re: How i can add PNG image in custom component?
                    Hi Jaxna,
                    In your custom component code below, I could see no imageFile variable declared ...
                    <s:Group xmlns:fx="
                        </s:Group>
                    Have you declared the variable imageFile in your component file above..verify it?
                    If not declared then declare a variable imageFile of Sttring datatype and make it Bindable...
                    [Bindable]private var imageFile:String="";
                    So your new component code should be:
                    <s:Group xmlns:fx="
                        </s:Group>
                    Also verify the path to the image once...whether it is given correct path from the hierarchy...
                    Bhasker Chari
                    • 7. Re: How i can add PNG image in custom component?
                      JaxNa Level 1
                      Hi Bhaskar Chari
                      Thanks a lot Bhaskar Chari  u solved my problem....
                      • 8. Re: How i can add PNG image in custom component?
                        Cheers
                        JaxNa...I am glad it solved your problem....
                        What was the mistake you did...?? Is it the same as I explained..?
                        Bhasker Chari
                        • 9. Re: How i can add PNG image in custom component?
                          JaxNa Level 1
                          Ya i did the same mistake as u explain..
                          Thanks Bhaskar
