4 Replies Latest reply on Jun 23, 2010 6:07 AM by djh88ukwb
    Pull data from database using php script, and input to datagrid.
    djh88ukwb Level 1
      Hello all,
      I intend to use the following php script to pull data from a database.
      I then want to display that data into a datagrid, the datagrid has the columns job ref, company and position.
      The php script i have is
      <?php
      $hostname_conn = "localhost";
          $username_conn = "";
          $password_conn = "";
          $conn = mysql_connect($hostname_conn, $username_conn, $password_conn);
          mysql_select_db("videochat");
          $query = "SELECT * FROM jobs";
          $result = mysql_query($query);
          $row=mysql_fetch_array($result);
          $ref = $row['jobref'];
          $company = $row['company'];
          $position = $row['position'];
          echo "<ref>$ref</ref>";
          echo "<company>$company</company>";
          echo "<position>$position</position>";
      Could anyone show me how i chuck this data into a grid ?
        • 1. Re: Pull data from database using php script, and input to datagrid.
          David_F57 Level 5
          hi,
          You should start using amf, either zendamf which is used by the data wizards in flashbuilder 4 or with amfphp which is probably better than zend but doesn't have all the nicities like creating value objects.
          http://flashhub.net/filter/
          this project uses amfphp, basically it uses remoteobjects so the php returned is in an arraycollection ready to put straight into a grid or datagroup.
          if you need help with this sort of thing pm me and I can do a connect session..
          the php services file for the calls used in the application
          <?php
          class pets
          var $db_host = 'localhost';
          var $db_name = 'flashhub_pets';
          var $db_user = 'flashhub_david';
          var $db_pwd = 'david';
          function pets()
          // Define the methodTable for this class in the constructor
          $this->methodTable = array(
          "getPets" => array(
          "description" => "Pets Database",
          "access" => "remote"
          function getAllPets()
          $mysql = mysql_connect($this->db_host, $this->db_user, $this->db_pwd);
          mysql_select_db( $this->db_name);
          $Query = "SELECT * from pet";
          $Result = mysql_query( $Query );
          return( $Result );
          function getTypeOfPets($category)
          $Query = "SELECT * from pet where CATEGORY=$category";
          return( $Result );
          function getCategories()
          $Query = "SELECT * from category";
          return( $Result );
          David
          • 2. Re: Pull data from database using php script, and input to datagrid.
            djh88ukwb Level 1
            While looking about on google i noticed alot of people where saying to use amf, is it easy to install ? I am trying to build out a project that is going to require alot of mysql connectivity so I suppose i should really install amf.
            • 3. Re: Pull data from database using php script, and input to datagrid.
              David_F57 Level 5
              hi,
              If you look at the code in the above web reference I gave you and the php thats all you need programmatically. amfphp is about 1.2mb of php classes that you have on your server it also includes a class browser that lets you test the php classes.
              If you have 5 minutes I can show you how to set it up.
              https://na2.connectnow.acrobat.com/davidfabris
              David.
              • 4. Re: Pull data from database using php script, and input to datagrid.
                djh88ukwb Level 1
                WOuld you be able to help with the amfphp install process?  I use a linux server that i haveSSH control over using putty.
