1 Reply Latest reply on Jun 23, 2010 10:28 AM by rtalton
    Selective lineChat itemRenderer
    yann_m Level 1
      Hi there,
      I'm encountering an issue representing data on a line chart. Precisely, I'd like to have some data points represented using an itemRenderer and others without any renderer. Having this piece of code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
           <mx:Script>
                <![CDATA[
                     [Bindable] var xml:XML = <root><point x="1" y="1" label="hello" /><point x="2" y="2" label="" /> </root>;
           </mx:Script>
      <mx:LineChart dataProvider="{xml.point}" height="100%" width="100%">
           <mx:series>
                <mx:Array>
                     <mx:LineSeries xField="@x" yField="@y" >
                          <mx:itemRenderer>
                                   <mx:Component>
                                         <mx:Canvas backgroundColor="blue" />
                                    </mx:Component>
                          </mx:itemRenderer>
                     </mx:LineSeries>
                </mx:Array>
           </mx:series>
      </mx:LineChart>
      </mx:Application>
      I'd like for instance to use my inline renderer for points that have a value for the attribute label. Is that achievable?
      Thank you in advance for your help.
        • 1. Re: Selective lineChat itemRenderer
          rtalton Level 4
          I don't know of any way of switching the LineSeries' itemRenderer based on the data provider's value.
          You can instead use a fillFunction to control how each LineSeries renders, returning different IFills depending on your data. Note that the fill you return can be a Solid Color with an alpha=0, which would effectively make it invisible, if that is what you want.
