0 Replies Latest reply on Jun 23, 2010 6:56 AM by ajdove
    Errors creating Avatar using MyAvatarEditor
    ajdove Level 1
      I am using MyAvatarEditor downloaded from http://www.myavatareditor.com/ however, when I compile the application I get runtime errors. There are a few .swc files I have included in the project, such as the airglobal.swc from the AIR 1.5 SDK but it will not compile. The requirements for the application to run include, which I also have:
      1. Flash CS4 (or better)
      2. AIR 1.5 SDK
      3. Flash Player 10.1
      When I run (CTRL +Enter) the app I am returned with a screen "You need Flash Player 10.1 or better ..." (which is included as an attachment). The "Compiler Errors" panel is empty, but the "Output" panel returns the following:
      Fonts should be embedded for any text that may be edited at runtime, other than text with the "Use Device Fonts" setting. Use the Text > Font Embedding command to embed fonts.
      VerifyError: Error #1079: Native methods are not allowed in loaded code.
      ReferenceError: Error #1065: Variable FileOptions is not defined.
      ReferenceError: Error #1065: Variable NavButtonDark is not defined.
      ReferenceError: Error #1065: Variable LargeButtonDark is not defined.
      ReferenceError: Error #1065: Variable ScrollBar is not defined.
      ReferenceError: Error #1065: Variable PageArrow is not defined.
      ReferenceError: Error #1065: Variable ScrollBarScroller is not defined.
      ReferenceError: Error #1065: Variable RampSlider is not defined.
      ReferenceError: Error #1065: Variable ColorSlider is not defined.
      ReferenceError: Error #1065: Variable ColorDragger is not defined.
      ReferenceError: Error #1065: Variable CheckBox is not defined.
      ReferenceError: Error #1065: Variable LogoLink is not defined.
      ReferenceError: Error #1065: Variable ToggleGender is not defined.
      ReferenceError: Error #1065: Variable ToggleMingle is not defined.
      ReferenceError: Error #1065: Variable Tab is not defined.
      ReferenceError: Error #1065: Variable ScreenButton is not defined.
      ReferenceError: Error #1065: Variable ControlButton is not defined.
      ReferenceError: Error #1065: Variable NavButtonLight is not defined.
      ReferenceError: Error #1065: Variable Alert is not defined.
      ReferenceError: Error #1065: Variable LargeButton is not defined.
      ReferenceError: Error #1065: Variable Icons_eye is not defined.
      ReferenceError: Error #1065: Variable Icons_face is not defined.
      ReferenceError: Error #1065: Variable Icons_glasses is not defined.
      ReferenceError: Error #1065: Variable Icons_hair is not defined.
      ReferenceError: Error #1065: Variable Icons_head is not defined.
      ReferenceError: Error #1065: Variable Icons_mole is not defined.
      ReferenceError: Error #1065: Variable Icons_mouth is not defined.
      ReferenceError: Error #1065: Variable Icons_mustache is not defined.
      ReferenceError: Error #1065: Variable Icons_nose is not defined.
      ReferenceError: Error #1065: Variable ColorSelected is not defined.
      ReferenceError: Error #1065: Variable ItemSelected is not defined.
      ReferenceError: Error #1065: Variable EditorSWF is not defined.
      I don't know how to fix this "Reference Error" although it appears to be telling me that it is missing something it needs to have.  Please see the attached screenshots of my application setup and preferences.
      Thank you
      Alex Dove
