2 Replies Latest reply on Jun 23, 2010 10:39 PM by vineet osho
    how to create record timer in flex ?
    vineet osho Level 1
      Hello Friends
         i  stuck in a problem...  i want to make an timer which starts as soon as i click a button .. i am not able to make program for this.
        The format will be
      00:00:00
      if it is runnuing from last 1 min and 22 seconds then the timer shows like this
      00:01:22
      like it keeps on running until i hit the stop button to stop it.
      Plz guide me how can i achieve this using flex...
        Regards Osho
        • 1. Re: how to create record timer in flex ?
          David_F57 Level 5
          hi,
          The following is a simple timer, you could get more complex by actually comparing the start time (date) with current time(date) but just to count secs this does the trick
          David.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
          <![CDATA[
          import mx.events.FlexEvent;
          private var timer:Timer = new Timer(1000);
          private var timeLapse:uint = 0;
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          timer.addEventListener(TimerEvent.TIMER,onTimer);
          private function onTimer(event:TimerEvent):void
          timeLapse += 1;
          tl.text = timeToString(timeLapse);
          public function timeToString(value:Number):String
          var seconds:Number  = value % 60;
          var minutes:Number  = Math.floor((value/60) % 60);
          var hours:Number  = Math.floor((value/3600) % 24);
          var s:String = seconds < 10 ? "0" + String(seconds) : String(seconds);
          var m:String = minutes < 10 ? "0" + String(minutes) : String(minutes);
          var h:String = hours < 10 ? "0" + String(hours) : String(hours);
          return h + ":" + m  + ":" +  s;
          protected function button1_clickHandler(event:MouseEvent):void
          timeLapse = 0;
          timer.start();
          protected function button2_clickHandler(event:MouseEvent):void
          timer.stop();
          </fx:Script>
          <s:Button x="58" y="34" label="Start" click="button1_clickHandler(event)"/>
          <s:Button x="136" y="34" label="Stop" click="button2_clickHandler(event)"/>
          <s:Label id="tl" x="58" y="89" width="148" fontSize="16" fontWeight="bold" textAlign="center" color="#102EE2"/>
          </s:Application>
          • 2. Re: how to create record timer in flex ?
            vineet osho Level 1
            Thanks David It works.....
