2 Replies Latest reply on Jun 23, 2010 8:43 PM by Yuliaart
    Change layer's order   InDesign CS4 js
    Yuliaart Level 1
      Hi, I need to move layer below another layer and what I tried doesn't work:
      myDoc.layers.item("INSTRUCTIONS (TURN OFF)").move (locationOptions.AFTER(myDoc.layers.item ("Die")));
      Thank you for your help.
      Yulia
        • 1. Re: Change layer's order   InDesign CS4 js
          John Hawkinson Level 5
          You seem to have the syntax wrong:
          move(locationOptions.AFTER(myDoc.layers.item("Die")));
          locationOptions.AFTER is a constant, it is not a parametrized function. I don't have the syntax of the move() method in front of me [gasp!...], but I believe it it takes two parameters ,the locationOption and the destination [maybe the other order], so it should be:
          move(locationOptions.AFTER,myDoc.layers.item("Die"))
          or somesuch.
          • 2. Re: Change layer's order   InDesign CS4 js
            Yuliaart Level 1
            Oh, thank you, John. You were almost there: your line did work after I capitalized 'LocationOptions':
            myDoc.layers.item("INSTRUCTIONS (TURN OFF)").move(LocationOptions.AFTER, myDoc.layers.item("Die"));
            Thank you very much.
            Yulia
