1 Reply Latest reply on Jun 23, 2010 11:56 PM by unc-astro
    Flex 4 custom component with children inserted directly into view stack
    unc-astro Level 1
      I give up. Hopefully I am just missing something easy, but I feel like I am pulling teeth trying to get this to work. All I want is a custom 'wizard' component whose children are placed within a ViewStack and beneath the ViewStack there is a next and back button. Here are some code excerpts to illustrate my approach:
      WizardGroup.as:
      [SkinPart(required="true")]
      public var nextBt:Button = new Button();
      public var backBt:Button = new Button();
      public var stack:ViewStackSpark = new ViewStackSpark();
      WizardGroupSkin.mxml:
      <s:VGroup width="100%" height="100%"
                paddingBottom="10" paddingTop="10" paddingLeft="10" paddingRight="10">
           <container:ViewStackSpark id="stack" width="100%" height="100%">
                <s:Group id="contentGroup" width="100%" height="100%" minWidth="0" minHeight="0"/>
           </container:ViewStackSpark>
           <s:HGroup horizontalAlign="right" width="100%">
                <s:Button id="nextBt" label="Next" enabled="{hostComponent.permitNext}" enabled.last="false"/>
                <s:Button id="backBt" label="Back" enabled="{hostComponent.permitBack}" enabled.first="false"/>
           </s:HGroup>
      </s:VGroup>
      While this comes very close to working, the major problem is that the children of the WizardGroup component are not added as children of the viewstack. Instead, they are added as children of the contentGroup. So the viewstack will always only have one child: contentGroup.
      I also tried the approach of binding the contents of the view stack to the children of contentGroup, but with Spark containers, there is no way to access an array of children or array of elements (ie, there is no contentGroup.getChildren() or contentGroup.getElements()).  Finally, I tried making the id of the ViewStackSpark "contentGroup" but since the ViewStackSpark inherits from BorderContainer, Flex complains at runtime that it can't cast the BorderContainer to Group.
      Help would be greatly appreciated.
      Thanks everyone.
      Josh
        • 1. Re: Flex 4 custom component with children inserted directly into view stack
          unc-astro Level 1
          I finally figured it out. The trick is to set the default property of the WizardGroup to a public member array I am calling "content"
          [DefaultProperty("content")]
          public class WizardGroup extends TitleWindow
              [Bindable]
              public var content:Array;
          And then within the skin, bind the content of the viewstack to the hostComponent's content array:
                      <container:ViewStackSpark id="stack" width="100%" height="100%" content="{hostComponent.content}"/>
                      </s:HGroup>
                  </s:VGroup>
