5 Replies Latest reply on Jun 24, 2010 10:05 AM by Flex harUI
    Binding xml to datagrid
    Woka_Junior
      Hi all.
      I am new to Flex.
      I am trying to bind testxml variable to datagrid.
      testXML
      - <dataObj>
      <var n="_cmd" t="s">RowList</var>
      - <obj o="rows" t="a">
      <var n="338" t="s">Test1,322,3,20,2,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var>
      <var n="339" t="s">Test2,323,0,20,0,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var>
      <var n="332" t="s">Test3,345,0,20,0,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var>
      </obj>
      </dataObj>
      tried
          <mx:DataGrid width="786" id="odalar" dataProvider="{testXML.obj}">
              <mx:columns>
                  <mx:DataGridColumn headerText="Column 1" dataField="var"/>
              </mx:columns>
      </mx:DataGrid>
      this puts all xml data to one datagrid row.
      I
      Could you please help?
        • 1. Re: Binding xml to datagrid
          BhaskerChari Level 4
          Hi Woka_Junior,
          Check out the below code:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
          <mx:Script>
            <![CDATA[
             import mx.collections.ArrayCollection;
             import mx.rpc.xml.SimpleXMLDecoder;
             [Bindable]private var dataProvider:ArrayCollection = new ArrayCollection();
             private function init():void
              var xml:XML = testXML;
              var xmlDoc:XMLDocument = new XMLDocument(xml);
              var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
              var xmlObj:Object = decoder.decodeXML(xmlDoc);
              var resultObj:Object = xmlObj.dataObj;
              if(resultObj.obj.var1 is ArrayCollection)
               dataProvider = resultObj.obj.var1 as ArrayCollection;
              else if(resultObj.obj.var1 is Object)
               dataProvider.addItem(resultObj.obj.var1);
          </mx:Script>
          <mx:XML xmlns="" id="testXML">
            <dataObj>
            <var1 n="338" t="s">Test1,322,3,20,2,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var1>
            <var1 n="339" t="s">Test2,323,0,20,0,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var1>
            <var1 n="332" t="s">Test3,345,0,20,0,100,200,Challenge,,,40000,9,,,Public,,0,normal,0,,</var1>
            </obj>
            </dataObj>
          </mx:XML>
              <mx:DataGrid width="786" id="odalar" dataProvider="{dataProvider}">
                  <mx:columns>
                      <mx:DataGridColumn headerText="n" dataField="n"/>
                      <mx:DataGridColumn headerText="t" dataField="t"/>
                      <mx:DataGridColumn headerText="value" dataField="value"/>
                  </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          Note: I have changed var to var1 in your xml file just to differentiate it from predefined var keyword in flex(Used to declare a variable in Flex).
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Binding xml to datagrid
            Woka_Junior Level 1
            Thanks a lot BhaskerChar.
            One more question please.
            If I want to write the third row's "n" argument (which 332) to a textbox, what would be the syntax?
            Thanks in advance.
            http://forums.adobe.com/people/BhaskerChari
            • 3. Re: Binding xml to datagrid
              You can access the value using the datagrid's dataprovider or you can also use the datagrid's seectedItem property if you want the value when an item is selected in a grid.
              Using dataprovider you can do the following:
              var nValue:String = String(dataProvider.getItem(2).n);
              Bhasker Chari
              • 4. Re: Binding xml to datagrid
                Woka_Junior Level 1
                Thanks a lot.
                • 5. Re: Binding xml to datagrid
                  Flex harUI Adobe Employee
                  {testXML.obj.var} will get you three rows.  Because your data is not in
                  attributes or subnodes you will prbably need labelFunctinos or custom
                  renderers
