4 Replies Latest reply on Jun 24, 2010 3:40 AM by Emanuele Radaelli
    [CS3 - JS - Mac] Problem with encoding
    Emanuele Radaelli Level 1
      I made a script that perform a lot of actions on ID.
      Everytime this script performs an action it writes a line on a global variable and at the end of the script write this var into a text file ( in the Document folder).
      Yes, it's a log file...
      While I was testing this script through the Toolkit everything went right.
      Then I added a menu action inside the script to call the script from the application and something strange happened, in the log file (wich is a text file UTF8 encoding) and also in the alerts ID shows. Both display text from this:
      "È necessario effettuare una selezione" (running the script from the toolkit)
      to this:
      "È necessario effettuare una selezione" (running the script from ID menu)
      So I think it's an encoding problem...
      I just added this code:
      #targetengine "Lele";
      var Lele_menu = app.menus.item("Main").submenus.add("Lele");
      //     Menu
      var main_action = app.scriptMenuActions.add("Update");
      var main_event_listener = main_action.eventListeners.add("onInvoke", function(){main();});
      var main_menu = Lele_menu.menuItems.add(main_action);
      //     Functions
      What's the point?
      Hope you understood.
