7 Replies Latest reply on Jun 30, 2010 6:36 AM by nikos101
    image path expression in item renderer
    nikos101 Level 2
      I'm not having success with this in my item renderer
              <mx:Image id="imgVideo" source="{'nikos\icons\twotinyexpansion' + !data.wasVideoRecorded?'\screen-delete.gif':'\screen-add.gif'}" toolTip="Video has been created for this row" >
                             </mx:Image>
      see anyting I'm doing wrong?
        • 1. Re: image path expression in item renderer
          David_F57 Level 5
          hi,
          change your backslashes to forward slashes...
          David.
          • 2. Re: image path expression in item renderer
            nikos101 Level 2
            Thanks Dave,
            I still get the same result:
            <mx:AdvancedDataGridColumn showDataTips="true" headerText="Status" dataField="staffName" width="160">
                                        <mx:itemRenderer>
                                            <fx:Component>
                                                <s:MXAdvancedDataGridItemRenderer focusEnabled="true" height="22" >
                                                    <s:states>
                                                        <s:State name="normal" />
                                                        <s:State name="hovered" />
                                                        <s:State name="selected" />
                                                    </s:states>
                                                    <s:HGroup left="0" right="0" verticalCenter="0">
                                                        <s:Label text="{'nikos/icons/twotinyexpansion/' + !data.wasVideoRecorded?'screen-delete.gif':'screen-add.gif'}">
                                                        </s:Label>
                                                        <mx:Image id="imgVideo" source="{'nikos/icons/twotinyexpansion/' + !data.wasVideoRecorded?'screen-delete.gif':'screen-add.gif'}" toolTip="Video has been created for this row" >
                                                        </mx:Image>
                                                        <mx:Image id="Comment" source="nikos\icons\twotinyexpansion\document-edit.gif" toolTip="Comment:\n\n{data.comment}" visible="{data.wasVideoRecorded}" includeInLayout="{data.wasVideoRecorded}">
                                                        </mx:Image>
                                                    </s:HGroup>
                                                </s:MXAdvancedDataGridItemRenderer>
                                            </fx:Component>
                                        </mx:itemRenderer>
                                    </mx:AdvancedDataGridColumn>
            • 3. Re: image path expression in item renderer
              David_F57 Level 5
              hi,
              see if this works
              source="{'nikos\icons\twotinyexpansion' + (!data.wasVideoRecorded?'\screen-delete.gif':'\screen-add.gif')}"
              David.
              • 4. Re: image path expression in item renderer
                nikos101 Level 2
                Nope, but this works, do you like it?
                override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
        if (data != null)
        super.updateDisplayList(unscaledWidth, unscaledHeight);
        if(data.wasVideoRecorded){
        imgVideo.source = 'nikos/icons/twotinyexpansion/screen-add.gif';
        else{
        imgVideo.source = 'nikos/icons/twotinyexpansion/screen-delete.gif';
        toolTip="No video"
                • 5. Re: image path expression in item renderer
                  David_F57 Level 5
                  hi,
                  That was my next thought but in a datachange event
                  It must be a renderer thing as the logic works in a normal nonbound situation.
                  David.
                  • 6. Re: image path expression in item renderer
                    nikos101 Level 2
                    Ok datachange event it is
                    • 7. Re: image path expression in item renderer
                      nikos101 Level 2
                      I wish that event wouldn't get fired when the data is null so I dont have to do this check:
                              <s:dataChange>
        <![CDATA[
                                                         if(data){
                                                              Comment.toolTip = "Extra summary information\n\nComment: " + data.comment;
                                                              </s:dataChange>
