4 Replies Latest reply on Jun 27, 2010 1:14 AM by freizeitfotograf
    CS5 cannot export H.264 1920x1080, level 4.1, compatible to Tvix media box
    freizeitfotograf
      In the past I made videos by Premiere/Encore CS3. To get the best result with Media box Tvico Tvix M-7000, I defined the following parameters:
      Export
      - Format: H.264
      - Standard:
      HDTV 1080p 29.97 – High Quality   (25 is also accepted)
      Video-Codec
      - Video-Codec: Main Concept H.264 Video
      Basic video parameters
      - TV norm: NTSC   (PAL is also accepted)
      - Frame width: 1920 pixels
      - Frame height:  1080 pixels
      - Scan type:  progressive
      - Display aspect ratio: 16/9
      - Profile: high
      - Level: 4.1 (this is very important to run on media box, CS3 allowed this)
      Bit rate parameters
      - Bit rate coding: VBR, 2-Pass
      - target bit rate: 25
      - maximum bit rate: 30
      There has to be payed attention to change the automatically adjust level from 4.2 to 4.1. After this step, the CS 5 did automatically reduce the frame to 1280 x 720 pixels and it has to be changed manually back to 1920 x 1080 pixels.
      The rendering runs and the video were qualified very good to be played on the Media box M-7000.
      Now I changed the computer and Adobe software from CS3 to CS5 to have more performance. CS5 runs very well. But now I have a big problem. The parameters of the frame 1920 x 1080 pixels in connection with level 4.1, is not accepted by CS5.
      I can not change the frame from 1280 x 720 to 1920 x 1080 with level 4.1. CS 5 shows an error and tells me that, this frame is not possible with level 4.1.
      On the other side, level 4.2 doesn’t run on the media box. What can I do, to have the same parameters as I had by CS 3?
      Can anybod help?
