0 Replies Latest reply on Jun 24, 2010 11:07 AM by mtvedten
    CS5 XMP metadata make huge Flash F4V files
    mtvedten Level 1
      In CS4 i had MPEG2 files that I need to export as F4V for preview purposes.
      Four MPEG2 files side by side in one long F4V video.
      The MPEG2 files are exported from Premiere, with a lot av complicated After Effects Comps as source.
      Each MPEG2 file gets a corresponding XMP file that i just ignore.
      In CS4 it worked great. The F4V files came out at about 32MB, just as predicted by the encoder before I started.
      Now, with the same project in CS5, I did the same process.
      Only that the F4V files for some reason came out at about 57MB, with the same settings as before.
      I noticed that the corresponding XMP files for the MPEG2s now where 3.5 MB big. Before they used to be 7KB.
      Then I deleted the XMP files, and let Premiere generate new ones. These was only 4KB.
      I then exported a new F4V, and i came out at 32MB.
      So WHY ON EARTH would anyone want to embed 25MB of metadata in a 32MB F4V-file???
      A file that will go on the web, and you try to get as small as possible?
      And what is all this metadata?? I did not put any thing in there!
      4 x 3.5MB does not even add up to 25MB!!
      Morten
