2 Replies Latest reply on Oct 11, 2006 12:59 PM by spotsstang
    Web Service help
    spotsstang Level 1
      We are trying to use a web service to retrieve a recordset from a API on a remote server via COM. I created a CFC on the API server to handle the communication with the COM objects. It has been set up to act as a web service. I then have a script running on our web server that invokes the web service to retrieve the information requested. I am getting the following error and am stuck. I was wondering if anyone had any ideas. Below is the error and and the two code files. Thanks in advance for any help.
      Error:
      Exceptions
      14:22:08.008 - Application Exception - in C:\CFusionMX\wwwroot\test4.cfm : line 15
      Could not perform web service invocation "getCustGeneralInfo" because AxisFault
      faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.userException
      faultSubcode:
      faultString: org.xml.sax.SAXParseException: Next character must be ">" terminating comment .
      faultActor:
      faultNode:
      faultDetail:
      { http://xml.apache.org/axis/}stackTrace: org.xml.sax.SAXParseException: Next character must be ">" terminating comment .
      at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3339)
      at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3333)
      at org.apache.crimson.parser.Parser2.nextChar(Parser2.java:3255)
      at org.apache.crimson.parser.Parser2.maybeComment(Parser2.java:1051)
      at org.apache.crimson.parser.Parser2.maybeMisc(Parser2.java:1233)
      at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java:621)
      at org.apache.crimson.parser.Parser2.parse(Parser2.java:333)
      at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl.java:448)
      at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
      at org.apache.axis.encoding...
      Calling file:
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
      <html>
      <head>
      <title>Service</title>
      </head>
      <body>
      <cfinvoke webservice=" http://localhost:8500/components/CustInfo.cfc?wsdl"
      method="getCustGeneralInfo"
      returnVariable="rData">
      <cfinvokeargument name="companyID" value="100">
      <cfinvokeargument name="accountNumber" value="2839">
      <cfinvokeargument name="tankNumber" value="0">
      </cfinvoke>
      </body>
      </html>
      CFC:
      <cfcomponent>
      <cffunction name="getCustGeneralInfo" access="remote" returntype="any" output="false">
      <cfargument name="companyID" default="" hint="companyID" required="true" type="numeric">
      <cfargument name="accountNumber" default="" hint="Customer account number" required="true" type="numeric">
      <cfargument name="tankNumber" default="" hint="Customer tank number" required="true" type="numeric">
      <CFOBJECT ACTION="CREATE" NAME="getLogin" CLASS="EnergyAPI.cCustomerInfo">
      <cfset iCompanyID = 100>
      <cfset lAccountNumber = 2839>
      <cfset cSysUser = "WebUser">
      <cfset lRetCode = "">
      <CFSET resultSet=getLogin.GetGeneralInfo(iCompanyID, lAccountNumber, cSysUser, lRetCode)>
      <cfreturn resultSet>
      </cffunction>
      <cffunction name="getDelivGeneralInfo" access="remote" returntype="any" output="false">
      <CFOBJECT ACTION="CREATE" NAME="getLogin" CLASS="EnergyAPI.cDelivery">
      <cfset iCompanyID = arguments.comapnyID>
      <cfset lAccountNumber = arguments.accountNumber>
      <cfset iTankNumber = arguments.tankNumber>
      <CFSET resultSet=getLogin.GetGeneralInfo(iCompanyID, lAccountNumber, iTankNumber, cSysUser, lRetCode)>
      </cffunction>
      <cffunction name="getServiceGeneralInfo" access="remote" returntype="any" output="false">
      <cfargument name="serviceNumber" default="" hint="Customer tank number" required="true" type="numeric">
      <CFOBJECT ACTION="CREATE" NAME="getLogin" CLASS="EnergyAPI.cService">
      <cfset iServiceNum = arguments.serviceNumber>
      <CFSET resultSet=getLogin.GetGeneralInfo(iCompanyID, lAccountNumber, iServiceNum, cSysUser, lRetCode)>
      </cffunction>
      </cfcomponent>
        • 1. Re: Web Service help
          Level 7
          Since it sounds like you control both sides of this transaction. The
          first good test is to create a testing cfm page on the same server that
          calls the webservice cfc directly as a component. Make sure your
          functions are working and returning what you expect them to return
          locally, then try to access them remotely.
          • 2. Re: Web Service help
            spotsstang Level 1
            It works just fine if I call it as a component.
            <cfinvoke component="components/CustInfo"
            </cfinvoke>
            I get exactly what I expect. Is it possible that since I am returning a ADO recordset that the XML is having a issue with that?
