6 Replies Latest reply on Jun 25, 2010 3:48 AM by PankChat
    adding formatted text in frame
    Gerd2
      im trying to add text with differents formatting styles (e.g. font, size, color) which is not seperated by a space:
      An example:
      // "frame" is a given textframe
      frame.parentStory.insertionPoints.item(-1).contents = "text1";
      frame.parentStory.words.lastItem().appliedFont= "Arial";
      frame.parentStory.words.lastItem().pointSize = 10";
      frame.parentStory.insertionPoints.item(-1).contents = "text2";
      frame.parentStory.words.lastItem().appliedFont= "Times New Roman";
      frame.parentStory.words.lastItem().pointSize = 12";
      After this, "text1text2" is formatted in "Times New Roman., 12Pts".
      I tried to seperate "text1" and "text2" with "SpecialCharacters.hairSpace", but this did not help.
      Have someone an idea?
      Thanks!!
        • 1. Re: adding formatted text in frame
          Use character ranges rather than words:
          frame.parentStory.words.lastItem().pointSize = 10;
          endIndex = frame.parentStory.characters.item(-1).index;
          frame.parentStory.characters.itemByRange(endIndex+1, frame.parentStory.characters.item(-1).index).appliedFont= "Times New Roman";
          frame.parentStory.characters.itemByRange(endIndex+1, frame.parentStory.characters.item(-1).index).pointSize = 12;
          .. although in this case it's easier to first change the formatting of the last insertion point and then insert the text:
          frame.parentStory.insertionPoints.item(-1).appliedFont= "Arial";
          frame.parentStory.insertionPoints.item(-1).pointSize = 10;
          frame.parentStory.insertionPoints.item(-1).appliedFont= "Times New Roman";
          frame.parentStory.insertionPoints.item(-1).pointSize = 12;
          • 2. Re: adding formatted text in frame
            Marc Autret Level 4
            Try this:
            var ips = frame.parentStory.insertionPoints;
            ips.item(-1).properties = {
                 appliedFont: 'Arial',
                 pointSize: 10,
                 contents: "text1"
                 appliedFont: 'Times New Roman',
                 pointSize: 12,
                 contents: "text2"
            Marc
            [EDIT] Oups! Jongware was the first... as usual! ;-)
            • 3. Re: adding formatted text in frame
              Gerd2 Level 1
              Thank you Marc and Jongware, now it works fine!
              • 4. Re: adding formatted text in frame
                PankChat Level 1
                I've similar kind of situation though in my case the order gets changed.
                I am inserting some special marked text on top of each page. The frames
                are threaded though. For instance I iterate my document's  each page twice
                to insert a special marker, Something like below:
                1st go (Iterate all pages one by one)
                var myText="{\some text\}";
                myDoc.pages[1].textFrames.itemByName("threaded").insertionPoints.item(0).properties
                2nd go(Iterate all pages again one by one)
                var myText="{\some_other_text\}";
                Ideally I am expecting
                {\some text\}{\some_other_text\}
                But I get
                {\some_other_text\}{\some text\}
                I think I need to use itemByRange to find out the "\}" or might be end of
                the first word for 2nd go
                Any ideas.
                Best,
                --PC
                • 5. Re: adding formatted text in frame
                  Marijan Tompa [tomaxxi] Level 4
                  Hey!
                  Try changing item(0) to item(-1)
                  tomaxxi
                  • 6. Re: adding formatted text in frame
                    PankChat Level 1
                    Well I need to add marked text on top of story/page.
                    I rather need the END index of first word of text frame to to insert the
                    second marker after it.
                    {\sometext}FIND THE INDEX VALUE OF END OF WORD
                    and add second marker.
                    myDoc.pages[i].textFrames.itemByName("sections").words.firstItem().index
