2 Replies Latest reply on Jun 25, 2010 11:10 AM by samsam06
    Password settings
    samsam06
      Hello all,
      I created a pdf form with Adobe LiveCycle Designer ES 8.2  . It works perfectly, but now I need to set a password to prevent users (from my company) to be able to read all the javascript code behind the form, for security matters. I mean, if you ever open the pdf form with LC Designer, the software has to prompt a password box for editing, otherwise the file does not open. In the same time, if you open the file with Acrobat Reader, all other functions must remain for users (printing/filling etc...).
      I know this is possible, as I found some interactive pdf forms protected this way on the internet. I tried to set a password within LCD, but this locks filling.
      So my question is : from which application do you set such a password : LCD or Acrobat Pro (I have the 9.0 version) ? and how do you proceed ?
      Many thanks in advance for your help.
        • 1. Re: Password settings
          pguerett Level 6
          Under the File/Form Properties you can choose PDF Security and set up the screen this way. You will be asked to create a password when you save the document and each time Designer opens it you will need to enter the password to gain access to it.
          Paul
          • 2. Re: Password settings
            samsam06 Level 1
            Thank you so much Paul for replying. It works but.... it disables the "save as" function. I've been trying several options with no success so far. There must be a solution anyway ?
            [Edit] My fault...I just had to return to Acrobat Pro, then extend rights for Reader.
            You made my day Paul, thanks again
