2 Replies Latest reply on Aug 10, 2010 12:52 PM by SiddharthaK
    Adobe Flash CS5 has encountered a problem and needs to close
    housea
      I have two laptops. I have installed Adobe Flash CS5 in my first laptop (Windows XP). When I start the application, it shows the following message:
      "Adobe Flash CS5 has encountered a problem and needs to close"
      I have installed the Flash CS5 in my second laptop and it worked fine.
      Error signature:
      AppName: flash.exe AppVer: 11.0.0.485 ModName: updaternotifications.dll
      ModVer: 1.0.0.64 Offset: 0006a8dc
      Can anybody help?
      Thanks.
      Housea
        • 1. Re: Adobe Flash CS5 has encountered a problem and needs to close
          Tejodhar Atreya U Level 1
          Check the folowing steps for XP PC
          Close all adobe applications
          Start the FlEXnet Licensing Service
          Click on start - Run - type services.msc enter
          It will open Services Windows - look for FLEXnet Licensing Service right click and go to properties .
          Start up type should be automatic
          Service status - started if not - click on " Start "
          Apply then OK
          Delete the preferences files, Flash creates new ones with default  settings the next time you start Flash. To re-create the preferences  files, delete the following items:
          Windows XP
          C:\Documents and Settings\<username>\Local Settings\Application Data\Adobe\Flash CS4\ (delete)
          C:\Windows\system32\Macromed\Flash\FlashAuthor.cfg (delete)
          Start the Program -
          Solution tested
          Regards
          Tejodhar Atreya Uppaluru
          • 2. Re: Adobe Flash CS5 has encountered a problem and needs to close
            SiddharthaK
            try this also
            1. Reset preferences:
            To reset on Windows, delete:
            • C:\Documents and Settings\username\Local Settings\Application Data Adobe\Flash CS4\
            • C:\Windows\system32\Macromed\Flash\FlashAuthor.cfg
            • To reset on Mac OS X, delete:
              • /Users/username/Library/Preferences/Flash CS4 Preferences
              • /Users/username/Library/Preferences/Flash 10 MRU
              • /Users/username/Library/Preferences/com.adobe.flsh-10.0.plist
              • /User/%username%/Library/Application Support/Adobe/Flash CS4/
              • /Library/Application Support/Macromedia/FlashAuthor.cfg
            2. Install the latest Flash update if available.
            3. Install the latest version of Flash.
            4. Install current Windows service packs and other updates.
            5.  Run Flash in a simplified mode (Windows). / Run Flash in safe mode (MAC  OS - Refer to http://kb2.adobe.com/cps/404/kb404936.html)
            Some  applications or services may cause system errors or freezes when  running concurrently with Flash. Services are specialized programs that  perform functions to support other programs. Before starting Flash,  disable other applications, including startup items (items that start  automatically), and services.
            To disable startup items and services, see "Disable startup items and services (Windows XP)" (TechNote kb404984).
            To re-enable startup items and services:
               1. Choose Start > Run, type msconfig, and click OK.
               2. Choose Normal Startup on the General tab, click OK, and restart the computer.
            Note: If unselected items were present on the Services or Startup tab, then you will need to unselect them again
            6. Install Flash from the desktop.
            7. Reinstall Flash in a simplified/safe (for MAC OS) mode.
            8. Run Flash in a new user account.
            9. Check for font problems.
            10. Optimize handling of temporary files by Windows XP.
            11. Set the virtual memory paging file to the default size.
            12. Repair and defragment hard disks.
            13. Scan the system for viruses.
            14. Identify the file that causes the problem.
            15. Install Adobe Flash CS4 on a different computer.
