1 Reply Latest reply on Jun 26, 2010 5:37 AM by William Marchetto
    Using Soap Headers
    William Marchetto Level 1
      Hello everibody.
      I wrote a .Net C# web service, that's working fine.
      A method M of my web service can treat a Soap Header sent by a client.
      Here's the soap header's structure:
      class Marker
      { int Counter;
        string Remark;
      One client is a simple Flex application, FlexApp.
      It uses the tag
      <mx:WebService id="ws" wsdl="http://mySite/myWS.asmx?wsdl" useProxy="false"
      result="AnswerOK(event);" fault="AnswerNOK(event);" />
      Here's the AS code which calls the method M (when a button is pressed):
      var q1:QName=new QName("NamespaceWS","Marker");
      var header1:SOAPHeader = new SOAPHeader(q1, {Counter:"0",Remark:"FlexApp Client"});
      ws.M.addHeader(header1);
      ws.M();
      Then, the routine that treats the web service's answer:
      private function AnswerOK(event:ResultEvent):void
        var ac:ArrayCollection = (ArrayCollection)(event.result);
        dg.dataProvider = ac;
      where dg is a <mx:DataGrid> object.
      Everything goes right: dg gets filled with the correct data sent by myWS; the web service receives the soap header sent by FlexApp (another client, an ASPX page, shows it).
      But my job isn't completed.
      In fact the web service method M modifies the soap header, incrementing the Counter sent by the client and appending a suffix to Remark.
      In the case of the ASPX page, it works: the client shows the new values of Counter and Remark without any problem.
      But, in FlexApp case, I don't know HOW show the return values of the soap header's fields Counter and Remark.
      I tried to use myWS.M.getHeader into AnswerOK code:
      var q1:QName=new QName("WSVirgo","MarkerPlus");
      var hea:SOAPHeader = LibWS.BooksDnListByAuthor.getHeader(q1);
      but it shows the initial values of Counter and Remark, and not the different values returned by the web service !
      Can anyone help me, possibly with a code snippet ?
      Thanks in advance
      William
