13 Replies Latest reply: Mar 31, 2011 11:42 AM by ToubMor RSS
    Distributing objects, layers
    gu_026 Community Member
      Hi!
      I am having trouble with Photoshop to distribute objects. I want to distribute 10 squares by 40px of distance between them. Is there a way to do that in Photoshop, like in Illustrator or Fireworks?
      I appreciate any help!!
        • 1. Re: Distributing objects, layers
          Jeffrey Tranberry Employee Hosts
          Trevor Morris has a couple of scripts for distributing space:
          http://morris-photographics.com/photoshop/scripts/index.html
          • 2. Re: Distributing objects, layers
            Hi Jeffrey!
            Thank you very much for you answer, it helped me a lot!
            But I didn't figure out how to specify a particular distance for distributing objects...Is there any way to do that?
            Thanx!!
            • 3. Re: Distributing objects, layers
              Hmm. Not an easy way. It's on a list of possible feature requests for a future version.
              • 4. Re: Distributing objects, layers
                Ok Jeffrey, thank you for explanations!
                Cheers
                • 5. Re: Distributing objects, layers
                  Paul Riggott Community Member
                  What version of Photoshop do you have? If CS3 or better I may have a solution.
                  • 6. Re: Distributing objects, layers
                    Reynolds (Mark) Community Member
                    Without Trevor Morris scripts there is an easy way to set a 40px selection and accurately MEASURE the distances between objects. Using Snap and either Guides or Smart Guides.
                    Paul Riggott - I would love to hear your magic solution - since as far as I can Its makes no difference CS3 or after. Since there have been no changes in these features for years. In case you are talking about Smart Guides, they came in CS2.
                    • 7. Re: Distributing objects, layers
                      No, its a script of my own design and has nothing to do with guides, but requires CS3 or better. It's not magic, its logic.
                      • 8. Re: Distributing objects, layers
                        Hey Guys! Thank you for the answers! I will try smart guides!
                        Paul, my version is CS4, do you have a better solutio? Please, share with us!
                        Best
                        • 9. Re: Distributing objects, layers
                          Ok, copy and paste the binary code into a plain text document and save as filename.jsx into app presets/scripts folder.
                          To use select all the layers with the objects in Photoshop, and run the script, it will ask for pixel spacing for horizontal and vertical spacing as it will try to space the layers in both directions IE: you can have one row of objects, or a grid of objects.
                          If the object are too far out of alignment it won't be able to do the spacing and it will let you know.
                          @JSXBIN@ES@1.0@MyBbyBnADMAbyBnABMhRbyBn0ADOyhSZhSnAFegdiOjPhAiIjPjSjJjajPjOjUjBj
                          MhAiTjQjBjDjJjOjHhAiFjOjUjFjSjFjEACzChdhdBXzEjUjFjYjUCXzKjIjPjSjJjajPjOjUjBjMDX
                          zGjQjBjOjFjMhREXzGjQjBjOjFjMhQFjzDjXjJjOGnneAnOyhTZhTnAFegbiOjPhAiWjFjSjUjJjDjB
                          jMhAiTjQjBjDjJjOjHhAiFjOjUjFjSjFjEACBXCXzIjWjFjSjUjJjDjBjMHXEXFjGnneAnZhUnAFct0
                          DzIjWjBjMjJiEjBjUjFIAhVJJBnASzDjEjMjHJAne2meDjEjJjBjMjPjHjbjUjFjYjUhahHiTjDjSjJ
                          jQjUhAiJjOjUjFjSjGjBjDjFhHhMjCjPjVjOjEjThaibhRhQhQhMhRhQhQhMhVhQhQhMhThQhQidhMj
                          QjBjOjFjMhQhaiQjBjOjFjMjbjCjPjVjOjEjThaibhRhQhMhRhQhMhThZhQhMhRhZhQidhAhMhAjUjF
                          jYjUhahHhHhAhMjQjSjPjQjFjSjUjJjFjThajbjCjPjSjEjFjSiTjUjZjMjFhahHjFjUjDjIjFjEhHh
                          MjTjVhRiQjBjOjFjMiDjPjPjSjEjJjOjBjUjFjThajUjSjVjFjdhMjUjJjUjMjFhaiTjUjBjUjJjDiU
                          jFjYjUjbjCjPjVjOjEjThaibhVhQhMhRhQhMhThVhQhMhUhQidhAhMhAjUjFjYjUhahHiQjBjVjMjTh
                          AiTjQjBjDjFjShHhAhMjQjSjPjQjFjSjUjJjFjThajbjTjDjSjPjMjMjJjOjHhajVjOjEjFjGjJjOjF
                          jEhMjNjVjMjUjJjMjJjOjFhajVjOjEjFjGjJjOjFjEjdjdhMjQjBjOjFjMhRhaiQjBjOjFjMjbjCjPj
                          VjOjEjThaibhRhQhMhVhQhMhThXhQhMhRhUhQidhAhMhAjUjFjYjUhahHhHhAhMjQjSjPjQjFjSjUjJ
                          jFjThajbjCjPjSjEjFjSiTjUjZjMjFhahHjFjUjDjIjFjEhHhMjTjVhRiQjBjOjFjMiDjPjPjSjEjJj
                          OjBjUjFjThajUjSjVjFjdhMjTjUjBjUjJjDjUjFjYjUhRhaiTjUjBjUjJjDiUjFjYjUjbjCjPjVjOjE
                          jThaibhRhQhMhShQhMhShVhQhMhUhQidhAhMhAjUjFjYjUhahHiQjJjYjFjMhAiTjQjBjDjJjOjHhAi
                          IjPjSjJjajPjOjUjBjMhHhAhMjQjSjPjQjFjSjUjJjFjThajbjTjDjSjPjMjMjJjOjHhajVjOjEjFjG
                          jJjOjFjEhMjNjVjMjUjJjMjJjOjFhajVjOjEjFjGjJjOjFjEjdjdhMjIjPjSjJjajPjOjUjBjMhaiFj
                          EjJjUiUjFjYjUjbjCjPjVjOjEjThaibhShYhQhMhShQhMhThVhRhMhUhQidhAhMhAjUjFjYjUhahHhR
                          hQhHhAhMjQjSjPjQjFjSjUjJjFjThajbjNjVjMjUjJjMjJjOjFhajGjBjMjTjFhMjOjPjFjDjIjPhaj
                          GjBjMjTjFhMjSjFjBjEjPjOjMjZhajGjBjMjTjFjdjdhMjTjUjBjUjJjDjUjFjYjUhShaiTjUjBjUjJ
                          jDiUjFjYjUjbjCjPjVjOjEjThaibhRhQhMhVhQhMhShWhQhMhXhQidhAhMhAjUjFjYjUhahHiQjJjYj
                          FjMhAiTjQjBjDjJjOjHhAiWjFjSjUjJjDjBjMhHhAhMjQjSjPjQjFjSjUjJjFjThajbjTjDjSjPjMjM
                          jJjOjHhajVjOjEjFjGjJjOjFjEhMjNjVjMjUjJjMjJjOjFhajVjOjEjFjGjJjOjFjEjdjdhMjWjFjSj
                          UjJjDjBjMhaiFjEjJjUiUjFjYjUjbjCjPjVjOjEjThaibhShYhQhMhVhQhMhThVhQhMhXhQidhAhMhA
                          jUjFjYjUhahHhRhQhHhAhMjQjSjPjQjFjSjUjJjFjThajbjNjVjMjUjJjMjJjOjFhajGjBjMjTjFhMj
                          OjPjFjDjIjPhajGjBjMjTjFhMjSjFjBjEjPjOjMjZhajGjBjMjTjFjdjdjdhMjCjVjUjUjPjOhQhaiC
                          jVjUjUjPjOjbjCjPjVjOjEjThaibhRhQhMhRhVhQhMhRhYhQhMhRhXhRidhAhMhAjUjFjYjUhahHiPj
                          LhHhAjdhMjCjVjUjUjPjOhRhaiCjVjUjUjPjOjbjCjPjVjOjEjThaibhShQhQhMhRhVhQhMhThXhQhM
                          hRhXhRidhAhMhAjUjFjYjUhahHiDjBjOjDjFjMhHhAjdjdjdhbftJMnASGBEjzGiXjJjOjEjPjXKRCV
                          JAFeTiDjPjNjQjMjJjNjFjOjUjThAjPjGhAiQjBjVjMftnftONbOn0ACJOnAEjzFjBjMjFjSjULRBFe
                          hbiTjPjSjSjZhAjUjIjJjThAjTjDjSjJjQjUhAjJjThAjPjOjMjZhAjWjBjMjJjEhAjGjPjShAiQjIj
                          PjUjPjTjIjPjQhAiDiThThAjPjShAjIjJjHjIjFjSffZPnAnACzBhcMEXzGjTjVjCjTjUjSNjzHjWjF
                          jSjTjJjPjOORCFdAEXzHjJjOjEjFjYiPjGPjORBFeBhOffffnndKnORbySn0ABJSnABXzEjGjPjOjUQ
                          XzIjHjSjBjQjIjJjDjTRXzFjUjJjUjMjFSXFVGBEXzHjOjFjXiGjPjOjUTjzIiTjDjSjJjQjUiViJUR
                          DFeHiHjFjPjSjHjJjBFeKiCiPiMiEiJiUiBiMiJiDFdgaffnfACzBheVEXNjORCFdAEXPjORBFeBhOf
                          fffnndJnJUnABXzKjPjOiDjIjBjOjHjJjOjHWXDXEXFVGBNyBnAMUbyBn0ABOVbyWn0ABJWnABXCezE
                          jUjIjJjTXEXzHjSjFjQjMjBjDjFYXCeXRCYJibieichNichOicjEidBjHFeAffnfAEXzFjNjBjUjDjI
                          ZXCeXRBYJibieichNichOicjEidAffn0DzAgaCYnfJZnABXWXHXEXFVGBNyBnAMZbyBn0ABOgabygbn
                          0ABJgbnABXCeXEXYXCeXRCYJibieichNichOicjEidBjHFeAffnfAEXZXCeXRBYJibieichNichOicj
                          EidAffn0DgaCgdnfJgenAEXzGjDjFjOjUjFjSgbVGBnfJgfnASzEjEjPjOjFgcCncfftlhAbhBn0ACJ
                          hBnASzBjYgdDEXzEjTjIjPjXgeVGBnfnftOhCbhDn0ACJhDnABXzIjDjBjOjDjFjMjFjEgfVGBnctfJ
                          hEnASgcCnctffAUzCjcjchACBVgdDnndACBVgdDnndCnnOhFbhGn0ADJhGnASgcCnctffJhHnASzGjS
                          jFjTjVjMjUhBEEjInfnftOhIbhJn0ACJhJnAEjLRBVhBEffZhKnAnACzChBhdhCVhBEnnctbyhNn0AB
                          JhNnAEjzKjTjQjBjDjFiNjBjTjLjThDRCEjzIjQjBjSjTjFiJjOjUhERBXCXDXEXFVGBffEjhERBXCX
                          HXEXFVGBffffACBVgdDnndBnAhzBhBhFVgcCAFgd4D0AiAJ40BiAgc4C0AiAhB4E0AiAG4B0AiAAFAz
                          EjNjBjJjOhGAhWMhXbyBn0AhKJhYnASzPjTjUjBjSjUiSjVjMjFjSiVjOjJjUjThHAXzKjSjVjMjFjS
                          iVjOjJjUjThIXzLjQjSjFjGjFjSjFjOjDjFjThJjzDjBjQjQhKnftJhZnABXhIXhJjhKXzGiQiJiYiF
                          iMiThLjzFiVjOjJjUjThMnfJhanAShBBEjzTjHjSjPjVjQiTjFjMjFjDjUjFjEiMjBjZjFjSjThNnfn
                          ftOyhbZhbnAnAhhFVhBBnJhcnASzLjHjSjPjVjQiMjBjZjFjSjThOCXzGjMjBjZjFjSjThPXzLjBjDj
                          UjJjWjFiMjBjZjFjShQjzOjBjDjUjJjWjFiEjPjDjVjNjFjOjUhRnftJhdnASzOjTjFjMjFjDjUjFjE
                          iMjBjZjFjSjThSDEjzFiBjSjSjBjZhTntnftahebyhfn0ABJhfnAEXzEjQjVjTjIhUVhSDRBQgaVhOC
                          VzBjJhVEffAVhVEAXzGjMjFjOjHjUjIhWVhOCByBMJiBnAEjzNjFjYjFjDjVjUjFiBjDjUjJjPjOhXR
                          DEjzOjDjIjBjSiJiEiUjPiUjZjQjFiJiEhYRBFeEjVjOjEjPffjzJjVjOjEjFjGjJjOjFjEhZXzCiOi
                          PhajzLiEjJjBjMjPjHiNjPjEjFjThbffOyiCZiCnAnACMXhWVhSDnndCnJiDnASzKjCjPjVjOjEjTiM
                          jJjTjUhcFAnnftJyiDnASzIjUjFjNjQjCjOjEjThdGAnnftJiEnASzEjSjPjXhRheHAnnftJyiEnASz
                          EjSjPjXhShfIAnnftJyiEnASzEjSjPjXhTiAJAnnftJyiEnASzEjSjPjXhUiBKAnnftJyiEnASzEjSj
                          PjXhViCLAnnftJiFnASzEjSjPjXhWiDMAnnftJyiFnASzEjSjPjXhXiENAnnftJyiFnASzEjSjPjXhY
                          iFOAnnftJyiFnASzEjSjPjXhZiGPAnnftJyiFnASzFjSjPjXhRhQiHQAnnftJiGnASzFjSjPjXhRhRi
                          IRAnnftJyiGnASzFjSjPjXhRhSiJSAnnftJyiGnASzFjSjPjXhRhTiKTAnnftJyiGnASzFjSjPjXhRh
                          UiLUAnnftJyiGnASzFjSjPjXhRhViMVAnnftJiHnASzFjSjPjXhRhWiNWAnnftJyiHnASzFjSjPjXhR
                          hXiOXAnnftJyiHnASzFjSjPjXhRhYiPYAnnftJyiHnASzFjSjPjXhRhZiQZAnnftJyiHnASzFjSjPjX
                          hShQiRgaAnnftaiIbiJn0AJJiJnABXhQjhREXzJjHjFjUiCjZiOjBjNjFiSXzJjBjSjUiMjBjZjFjSj
                          TiTjhRRBXzEjOjBjNjFiUQgaVhSDVzBjBiVgbffnfJiKnASzCiMiCiWgcXzGjCjPjVjOjEjTiXXhQjh
                          RnftJiLnABXzBhQiYVhdGXiUXhQjhRnfJiMnABXzBhRiZVhdGXzFjWjBjMjVjFiaXiYViWgcnfJyiMn
                          ABXzBhSibVhdGXiaXiZViWgcnfJiNnABXzBhTicVhdGXiaXibViWgcnfJyiNnABXzBhUidVhdGXiaXi
                          cViWgcnfJiOnAEXhUVhcFRBVhdGffJiPnAShdGAnnffAViVgbAXhWVhSDByBMJiRnAShcFEXzEjTjPj
                          SjUieVhcFnfnffJyiSnAEXieVhcFRBNyBnAMiSbyBn0ABZiSnACzBhNifXibViVAXibVzBjCjABnnAC
                          iV40BhAjA4B0AhAC0AgaCiSffJiTnASzLjBjSjSjBjZiOjVjNjCjFjSjBgdndBftJiUnAEXhUVheHRB
                          XiYVhcFffaiVbyiWn0ABOiWbyiXn0ABJiXnAEXhUEjzEjFjWjBjMjCRBCzBhLjDnVjBgdeDjSjPjXnf
                          fRBQgaVhcFVzBjGjEgeffAUzChGhGjFCVXibQgaVhcFVjEgeCifXibQgaVhcFCifVjEgenndBnndhSn
                          nCMXibQgaVhcFVjEgeCjDXibQgaVhcFCifVjEgenndBnndhSnnnnbiZn0ACJiZnATjBgdBtJianAEXh
                          UEjjCRBCjDnVjBgdeDjSjPjXnffRBQgaVhcFVjEgeffAVjEgeBXhWVhcFByBMaidbyien0ABJyienAE
                          XieEjjCRBCjDnCjDVzBjEjGgfnndBeDjSjPjXnffRBNyBnAMiebyBn0ABZienACifXiZViVAXiZVjAB
                          nnACiV40BhAjA4B0AhAC0AgaCieffAVjGgfAVjBgdByBMOjAbjBn0ADJjBnAEjLRBFehAiTjPjSjSjZ
                          hAiJhAjIjBjWjFhAjOjPhAjJjEjFjBhAjXjIjBjUhAjUjPhAjEjPhBffJjCnABXhIXhJjhKVhHAnfZj
                          DnAnAChCCzBhKjHXhWVheHVjBgdnnXhWVhcFnnnajFbjGn0ACJjGnASzKjMjFjGjUiBjOjDjIjPjSjI
                          hBEjhERBXicXiYEjjCRBCjDnCjDVzBjMjJhAnndBeDjSjPjXnffffnftajHbjIn0AFJjInABXhQjhRE
                          XiSXiTjhRRBXiYQgaEjjCRBCjDnCjDVjJhAnndBeDjSjPjXnffViVgbffnfJjJnASzFiXjJjEjUjIjK
                          hCCifEjhERBXicQgaEjjCRBCjDnCjDVjJhAnndBeDjSjPjXnffViVgbffEjhERBXiZQgaEjjCRBCjDn
                          CjDVjJhAnndBeDjSjPjXnffViVgbffnnnftJjKnASzLjTjIjJjGjUiQjJjYjFjMjTjLhDCifCjDVjIh
                          BVzIjTjQjBjDjJjOjHiBjMhGnnEjhERBXiZQgaEjjCRBCjDnCjDVjJhAnndBeDjSjPjXnffViVgbffn
                          nnftJjLnAEXzJjUjSjBjOjTjMjBjUjFjNXhQjhRRCVjLhDFdAffJjMnASjIhBCjDnCjDVjKhCVjMhGn
                          nnnntfAViVgbBXhWEjjCRBCjDnCjDVjJhAnndBeDjSjPjXnffByBMAVjJhAAVjBgdByBMajPbjQn0AC
                          JjQnASzJjUjPjQiBjOjDjIjPjSjOhEEjhERBXidQgaVheHVjJhAffnftajRbjSn0AFJjSnABXhQjhRE
                          XiSXiTjhRRBXiYQgaEjjCRBCjDnCjDViVgbnndBeDjSjPjXnffVjJhAffnfJjTnASzGiIjFjJjHjIjU
                          jPhFCifEjhERBXidQgaEjjCRBCjDnCjDViVgbnndBeDjSjPjXnffVjJhAffEjhERBXibQgaEjjCRBCj
                          DnCjDViVgbnndBeDjSjPjXnffVjJhAffnnnftJjUnASjLhDCifCjDVjOhEVzIjTjQjBjDjJjOjHiEjQ
                          hHnnEjhERBXibQgaEjjCRBCjDnCjDViVgbnndBeDjSjPjXnffVjJhAffnnnftJjVnAEXjNXhQjhRRCF
                          dAVjLhDffJjWnASjOhECjDnCjDVjPhFVjQhHnnnnntfAViVgbBVjBgdByBMAVjJhAAXhWVheHByBMJj
                          ZnABXhIXhJjhKVhHAnfAhIiC4L0AiAiD4M0AiAiE4N0AiAiF4O0AiAhV4E0AiAiG4P0AiAiH4Q0AiAi
                          V4gb0AiAiI4R0AiAiJ4S0AiAiK4T0AiAiL4U0AiAiM4V0AiAiN4W0AiAiO4X0AiAiP4Y0AiAiQ4Z0Ai
                          AiR4ga0AiAiW4gc0AiAjB4gd0AiAjJ4hA0AiAjI4hB0AiAjK4hC0AiAjL4hD0AiAjO4hE0AiAjP4hF0
                          AiAjE4ge0AiAhB4B0AiAjM40BhAjQ4B0AhAhH40BiAjG4gf0AiAhO4C0AiAhS4D0AiAhc4F0AiAhd4G
                          0AiAhe4H0AiAhf4I0AiAiA4J0AiAiB4K0AiAChGAhDAjaMjcbyBn0AIJjdnASzEjEjFjTjDjRAEjzQi
                          BjDjUjJjPjOiEjFjTjDjSjJjQjUjPjSjSntnftJjenASzDjSjFjGjTBEjzPiBjDjUjJjPjOiSjFjGjF
                          jSjFjOjDjFjUntnftJjfnAEXzIjQjVjUiDjMjBjTjTjVVjTBRBEjzQjTjUjSjJjOjHiJiEiUjPiUjZj
                          QjFiJiEjWRBFeMjMjBjZjFjSiTjFjDjUjJjPjOffffJkAnAEXzMjQjVjUiSjFjGjFjSjFjOjDjFjXVj
                          RARCEjhYRBFeEjOjVjMjMffVjTBffJkBnASzEjSjFjGhSjYCEjjUntnftJkCnAEXzNjQjVjUiFjOjVj
                          NjFjSjBjUjFjEjZVjYCRDEjhYRBFeEiMjZjShAffEjhYRBFeEiPjSjEjOffEjhYRBFeEiUjSjHjUfff
                          fJkDnAEXjXVjRARCEjhYRBFeEiGjSjPjNffVjYCffgkEbyBn0ACJkFnAEjhXRDEjhYRBFeEiNjLhAhA
                          ffVjRAXhajhbffZkGnAFctABnzBjFjanbyBn0ABZkHnAFcfADjY4C0AiAjR40BiAjT4B0AiAADAhNAk
                          IBJjbnAEjhGnf0DgaByB
                          • 10. Re: Distributing objects, layers
                            c.pfaffenbichler Community Member
                            Cool Script, Paul!
                            • 11. Re: Distributing objects, layers
                              Thanks Christoph, I wonder if it worked ok for the OP?
                              • 12. Re: Distributing objects, layers
                                Thanks Paul!! Very nice!!
                                Cheers
                                • 13. Re: Distributing objects, layers
                                  ToubMor Community Member
                                  ehhh bro, how can we execute an *.JSX from PS
                                  i got it! thanks. but it gives an error on line 19
                                  Error 510; Invalid font name "Georgia"
                                  Line 19
