1 Reply Latest reply on Sep 1, 2011 3:50 PM by Ricardo F. S. Cruz
    VideoPlayer, FMS, and application instances
    MichaelNoriega
      I am trying to playback recorded streams from a Flash Media Interactive Server using the VideoPlayer component in Flex  4/Flash Builder 4.
      If the stream is located in the <serverpath>/streams/vod/_definst_ directory then I can get to it by setting the 'source' parameter of the VideoPlayer to "<server>/vod/streamname" assuming streamname is an .flv file.  If the stream is located in an application directory (e.g. 'app1') in the _definst_ directory (i.e. <serverpath>/app1/streams/_definst_), then I can successfully play it back by setting the 'source' parameter to "<server>/app1/streamname".
      What I can't get to work is when I have a stream recorded to an instance within an application directory.  So if the application is "app1' and the instance name is "inst1" it would be literally located in <serverpath>/app1/streams/inst1 directory.  Setting the source parameter to this "<server>/app1/inst1/streamname" does not work.  It seams to be ignoring the 'inst1' part of the path because the server side log shows '_definst_' as the instance name being run.
      I know this is in part a Flash Media Server question, but manually writing a video player works.  I would just like to get the Flex 4 VideoPlayer component to play the video.
      Thanks for any help.
