1 Reply Latest reply on Jul 3, 2010 5:35 PM by Noel Carboni
    dng and CR2 files display as icons in CS5
    jan_lemmy
      Now I have installed CS5 on three machines - a new installation on WIN7, and here everything is alright - no problem!
      Two machines running XP wth a previous CS4 installation uninstalled show up in Bridge with this problem:
      dng and CR2 files display as icons!!
      Everything is updated, ACR plugin placed as should be, and Camera RAW is working fine when OPENING the file. It is only a display problem, but this is serious enough - you cannot go through your downloaded pictures.
      I have tried to follow a solution close to the one given for CS4:
      http://kb2.adobe.com/cps/407/kb407945.html
      but I am out of luck.
      Is it an XP problem, or has it something to do with the previous installation of CS4?
      Any suggestions will be great! I have searced, read, tried, searched, tried.... some share this problem, but I haven't seen any soloution.
      Thanks, Jan
        • 1. Re: dng and CR2 files display as icons in CS5
          Noel Carboni Level 8
          Disclaimer:  The following applies to WINDOWS EXPLORER.  I don't use Bridge so I don't know if it's applicable at all to Bridge.
          Adobe does not provide a codec for viewing Canon raw files as thumbnails.  Canon has one for free but it only works on a 32 bit Windows system.
          Early this year I found a free download for displaying raw file thumbnails that works on an x64 Windows system.  Since that time the author realized there's a real demand for this software and has started charging for it.  In any case, I find it works very well.
          http://www.fastpictureviewer.com/codecs/
          -Noel
