7 Replies Latest reply on Jun 28, 2010 7:59 AM by VRPDeveloper
    updationg data from datagrid to database
    dhifallah
      Hi ,
      I 'm searching an example of code to update data from datagrid to database using an HTTPService and calling a servlet java.
      I have a mxml file which connect to database to fill the datagrid ( this works for me), the the user modify this datagrid and send the modification to update the database using an HTTPService to call a sevlet java (this don't work for me) ,
      can you help me please or send me some links for that
        • 1. Re: updationg data from datagrid to database
          dhifallah Level 1
          In my HTTPservice I have a request like this:
          <mx:HTTPService
          id="MiseAJourTable"
          url="
          http://localhost:8080/SupportStarwebJ2EE/ServletMiseAJourDataBase"
          useProxy="
          false" method="GET" resultFormat="e4x">
          <mx:request xmlns="">
          <branche_SVN>{branche_SVN}</branche_SVN>
          <environnement>{environnement}</environnement>
          <tag_version>{tag_version}</tag_version>
          <revision_ihm>{revision_ihm}</revision_ihm>
          <revision_metier>{revision_metier}</revision_metier>
          <date_initialisation>{date_initialisation}</date_initialisation>
          <version_cible>{version_cible}</version_cible>
          <lot_cible>{lot_cible}</lot_cible>
          <liste_organisme>{liste_organisme}</liste_organisme>
          </mx:request>
          </mx:HTTPService>
          What can I add in my resquet to get what is put in the datagrid , because in my servlet I wanted to display the value of my columns but I have the following ansow:
          Environnement=[object DataGridColumn]
          Tag_version=[object DataGridColumn]
          Revision_ihm=[object DataGridColumn]
          Revision_metier=[object DataGridColumn]
          Date_initialisation=[object DataGridColumn]
          Version_cible=[object DataGridColumn]
          Lot_cible=[object DataGridColumn]
          Liste_organisme=[object DataGridColumn]
          • 2. Re: updationg data from datagrid to database
            dhifallah Level 1
            I'm waitting for your suggestion please
            • 3. Re: updationg data from datagrid to database
              VRPDeveloper Level 3
              What are these {branche_SVN}, {environnement} etc...
              I beleive that you want to send data from datagrid as a request in HTTPService, then in request you need to write {datagrid1.environment}. Also use debugging tool like fiddler or Charles to know exactly what is passing in request.
              Hope it will solve your problem!!!
              • 4. Re: updationg data from datagrid to database
                dhifallah Level 1
                {branche_SVN}, {environnement} etc... are dataField in my datagrid,
                I used an HTTPService as the following :
                <mx:HTTPService
                id="MiseAJourTable"
                url="
                useProxy="
                </mx:request>
                </mx:HTTPService>
                and here is my servlet java:
                protected void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
                String connectionURL =
                "jdbc:mysql://10.0.10.33:3306/Supportweb";
                Connection connection=
                null;
                response.setContentType(
                "text/html");
                PrintWriter out = response.getWriter();
                String branche_SVN = request.getParameter(
                "branche_SVN");
                String environnement = request.getParameter(
                "environnement");
                String tag_version = request.getParameter(
                "tag_version");
                String revision_ihm = request.getParameter(
                "revision_ihm");
                String revision_metier = request.getParameter(
                "revision_metier");
                String date_initialisation = request.getParameter(
                "date_initialisation");
                String version_cible = request.getParameter(
                "version_cible");
                String lot_cible = request.getParameter(
                "lot_cible");
                String liste_organisme = request.getParameter(
                "liste_organisme");
                System.
                out.println("branche_SVN= "+ branche_SVN);
                System.
                out.println("Environnement="+ environnement);
                System.
                out.println("Tag_version="+ tag_version);
                System.
                out.println("Revision_ihm="+ revision_ihm);
                System.
                out.println("Revision_metier="+ revision_metier);
                System.
                out.println("Date_initialisation="+ date_initialisation);
                System.
                out.println("Version_cible="+ version_cible);
                System.
                out.println("Lot_cible="+ lot_cible);
                System.
                out.println("Liste_organisme=" +liste_organisme);
                try
                // Load the database driver
                Class.forName(
                "com.mysql.jdbc.Driver");
                // Get a Connection to the database
                connection = DriverManager.getConnection(connectionURL,
                connection.setAutoCommit(
                false);
                String sql =
                "insert into gestion_environnement_bis values (?,?,?,?,?,?,?,?,?)";
                Statement stmt = connection.createStatement();
                stmt.executeUpdate(sql);
                connection.commit();
                out.println(
                " la base de donnée a était mise à jour ");
                catch(ClassNotFoundException e){
                out.println(
                "Couldn't load database driver: " + e.getMessage());
                catch(SQLException e){
                out.println(
                "SQLException caught: " + e.getMessage());
                catch (Exception e){
                out.println(e);
                finally {
                // Always close the database connection.
                try {
                if (connection != null) connection.close();
                catch (SQLException ignored){
                out.println(ignored);
                • 5. Re: updationg data from datagrid to database
                  According to me, You are not sending request parameters properly .. You should send {datagridname.dataprovider.datafieldname}.
                  Try it!!!
                  • 6. Re: updationg data from datagrid to database
                    dhifallah Level 1
                    I tried it
                    <branche_SVN>{itemDG.dataprovider.branche_SVN}</branche_SVN>
                    but I have the following error:
                    1119: Accès à la propriété dataprovider peut-être non définie, via la référence de type static mx.controls:DataGrid.
                    ==> that's mean it can not acced  to dataprovider
                    here is my datagrid :
                    <mx:DataGrid id="itemDG" dataProvider="{dpValue}" itemEditEnd="getCellInfo(event);" editable="true" width="1411" height="297" y="67.45" x="9.15">
                    and my dpValue is:
                    Bindable]
                    private var dpValue:Array = [
                    { label:
                    "C1-devel", data:"C1-devel" },
                    { label:
                    "C2-devel", data:"C2-devel"},
                    { label:
                    "C3-devel", data:"C3-devel"},
                    { label:
                    "C1-assbl", data:"C1-assbl"},
                    { label:
                    "C2-assbl", data:"C2-assbl"},
                    { label:
                    "C3-assbl", data:"C3-assbl"},
                    { label:
                    "C1-qualf", data:"C1-qualf"},
                    { label:
                    "C2-qualf", data:"C2-qualf"},
                    { label:
                    "C3-qualf", data:"C3-qualf"},
                    { label:
                    "Maintq", data:"Maintq"},
                    { label:
                    "Maintd", data:"Maintd"},
                    • 7. Re: updationg data from datagrid to database
                      Have you looked into Charles or fiddler... what request parematers are passing. if you get those then it would be more clear.
