0 Replies Latest reply on Jun 28, 2010 6:51 AM by ChefRamsey
    Can't Find Running NativeProcess
    ChefRamsey
      When I debug the following code in Flash Builder 4, it appears the process is running but I can't find it in the Windows Task Manager. Does it run under a different name or something?
      var exePath:String = "E:/test/myProcess.exe";
      var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
      var file:File = new File(exePath);
      nativeProcessStartupInfo.executable = file;  //No error here
      var processArgs:Vector.<String> = new Vector.<String>();
      processArgs.push(
      "-n");
      processArgs.push(
      "2");
      processArgs.push(
      "in.txt");
      processArgs.push(
      "out.txt");
      nativeProcessStartupInfo.arguments = processArgs;
      process = new NativeProcess();
      process.start(nativeProcessStartupInfo);
      if(process.running)  //Breakpoint here; resolves as true.  Does OS see as a new running process with PID?
