1 Reply Latest reply on Jun 29, 2010 8:13 AM by JuneXiong
    Cann't load xml file in Adobe AIR Application
      Hi, I have a problem in loading xml file into my air application.
      I am using the following code to load xml file:
      <fx:XML id="mydata" source="../xml/events.xml" />
      The format of xml file is:
      <?xml version="1.0" encoding="UTF-8"?>
      <event date="2010-4-12 21:1:47.761" type="KB" tl="BASE" data="www." />
      <event date="2010-4-12 21:1:48.627" type="KB" tl="BASE" data="google." />
      <event date="2010-4-12 21:1:49.296" type="KB" tl="BASE" data="com" />
      <event date="2010-4-12 21:1:53.934" type="KB" tl="BASE" data="www." />
      <event date="2010-4-12 21:1:56.32" type="KB" tl="BASE" data="cnn." />
      <event date="2010-4-12 21:1:56.782" type="KB" tl="BASE" data="com" />
      <event date="2010-4-12 21:2:1.474" type="KB" tl="BASE" data="www." />
      <event date="2010-4-12 21:2:4.746" type="KB" tl="BASE" data="digg." />
      <event date="2010-4-12 21:2:5.913" type="KB" tl="BASE" data="cpm" />
      and using following code to use data into chart item.
      dataProvider={mydata.children}, xField = {date}, yField={type}
      As I use customized itemRenderer, I try to show "data" into items in the chart, so I rewrite the function like that:
      override public function set data(value:Object):void{
           super.data = value;
           if(value == null)
           trace("data=", value.attibute("*").toXMLString());
           //set the label's value
           dateDisplay.text = value["@date"] ;
           if(value["@type"] == 'KB'){
                dataDisplay.text = value["@data"];
                type.text = "Key Press";
                if(value["@type"] == 'MC'){
                     dataDisplay.text = value["@domain"];
                     type.text = "Mouse Click";
      There is no error in compiling, but when I run it as a windows desktop application, nothing is generated but with an increasing size in memory. I have to kill the program when the memory is up to 1,034,568K. Is it usual thing when running AIR application? I am using flex4 in eclipse
      Could you help me to check out the way I use to load xml file? Does anyone know better way to use xml file as a dataProvider in chart?
      Thanks so much.
