4 Replies Latest reply on Jun 28, 2010 12:51 PM by jerry98225
    event.COMPLETE handler question....
    jerry98225
      Hi guys.
         I want to dispatch a custom event when the two files are downloaded or uploaded successfully. I use
      fileRef.addEventListener(Event.COMPLETE, completeHandler);
      fileBigRef.addEventListener(Event.COMPLETE, completeHandler);
      to listen the complete event with only 1 handler.
      function completeHandler(event:Event):void{
         fileBigRef.removeEventListener(Event.COMPLETE,completeHandler);
         fileRef.removeEventListener(Event.COMPLETE,completeHandler);
          var e:Event=new Event("addInfoDone");
          dispatchEvent(e);
      I want the event to be dispatched only once when both of the fileRef and fileBigRef are complete transfered. Any ideas?? My brain is fry now and can't think of anything.....  Thanks for the help.
        • 1. Re: event.COMPLETE handler question....
          VRPDeveloper Level 3
          You need to create 2 boolean variables for fileRef and  fileBigRef and by default they are false but as soon as file is uploaded or downloaded make it true.
          You can do something like this...
          var fileRefbol:Boolean =false;
          var  fileBigRefbol :Boolean =false;
            if(event.currentTarget==fileRef){
               fileRefbol=true;
          if(event.currentTarget== fileBigRef ){
                fileBigRefbol =true;
          if( fileBigRef && fileRefbol){
              dispatchEvent(e);
          Hope you got my point!!
          • 2. Re: event.COMPLETE handler question....
            jerry98225 Level 1
            Thanks a lot VRP. However, when I try to use the debug mode, the currentTarget is the object FileReference.
            Even if I go for event.currentTarget.name, it will refer to the image name....
            It won't be fileRef. so basically, the fileRefbol will never be true...I am not sure if I miss something...
              if(event.currentTarget==fileRef){  //currentTarget is the object FileReference
                 fileRefbol=true;
            • 3. Re: event.COMPLETE handler question....
              You can do in other way then
                if(FileReference(event.currentTarget).id==fileRef){
                   fileRefbol=true;
              if(FileReference(event.currentTarget).id== fileBigRef ){
                  dispatchEvent(e);
              I think it will work now....
              • 4. Re: event.COMPLETE handler question....
                jerry98225 Level 1
                nice! Thanks a lot!
