5 Replies Latest reply on Jun 29, 2010 10:59 AM by jmw107
    Reading tab delimited data from a text file (JS CS3)
    jmw107 Level 1
      Hi --I am working on a script to read data from a text file and use within a dialog. But I have hit a wall.
      I have used a script from a previous post that sets a variable from the text document when the script user chooses it from a dropdown.
      var myDialog = app.dialogs.add({name:"Map",canCancel:true});
      with(myDialog){
          with(dialogColumns.add()){
              with(borderPanels.add()){
      staticTexts.add({staticLabel:"Choose location:"});
      var file = File("~/Desktop/myPlacesfile.txt");
      file.open("r");
      var str = file.read();
      file.close();
      var myPlaceList = str.split(/[\r\n]+/);
      var myPlaceMenu = dropdowns.add({stringList:myPlaceList, selectedIndex:0});
      var myResult = myDialog.show();
      if(myResult == true){
      if (myPlaceMenu.selectedIndex == 0){
      var myPlace = "- Not Defined -";
      }else{
      var myPlace = myPlaceList[myPlaceMenu.selectedIndex];
      alert(myPlace);
      myDialog.destroy();
      This is what I need to do now:
      The text file is in this format:
      value1 [TAB] value2
      value1 [TAB] value2
      value1 [TAB] value2
      I need to have the dialog pulldown only show value 1, and after the user selects it, the script returns only value 2. (The alert is just there for testing -- I am doing something else with the variable).
      Is there a way to display the first part of a tab delimited line in the pulldown and return the second half as a variable?
      Any help would be greatly appreciated.
      thanks
        • 1. Re: Reading tab delimited data from a text file (JS CS3)
          Peter Kahrel Adobe Community Professional & MVP
          One of the possibilities is this. Create an array with values left of the tab for the dialog. Then create an object which you use as a look-up table. Roughly as follows:
          // same as what you have
          file.open("r");
          file.close();
          var array = str.split(/[\r\n]+/);
          // "pairs" is the look-up table
          var pairs = {};
          // as before, "myPlaceList" will be used for the dropdown
          var myPlaceList = [];
          var v;
          for (var i = 0; i < array.length; i++)
            v = array[i].split ("\t");
            pairs [v[0]] = v[1];
            myPlaceList.push (v[0]);
          // add the dropdown as before:
          // the look-up table "pairs" is used as follows: pairs ["value1"] returns "value2"
          // so in your script that would be:
          var myPlace = pairs [myPlaceList[myPlaceMenu.selectedIndex]];
          Peter
          • 2. Re: Reading tab delimited data from a text file (JS CS3)
            Harbs. Level 6
            Very nice!
            I didn't know you can use a RegExp as an argument for split()!
            Very good to know!
            Harbs
            • 3. Re: Reading tab delimited data from a text file (JS CS3)
              jmw107 Level 1
              Thanks Peter -- that worked great.
              Terrific solution.
              Jim
              • 4. Re: Reading tab delimited data from a text file (JS CS3)
                jmw107 Level 1
                I was hoping I could prevail on you for one more issue:
                I am now adapting this script into scriptUI.
                Here's a snippet:
                //This correctly displays my drop down list.
                myDialog.myPlaceMenu = myPanel.add('dropdownlist', [230,58,630,78], myPlaceList);
                myDialog.myPlaceMenu.items[0].selected = true;
                //This is where I run into a problem. The 'if' seems to be doing what is is supposed to but I cannot figure out the correct wording in the "else" part for the myPlace variable when the user chooses something other than the first item.
                if (myDialog.myPlaceMenu.items[0].selected == true){
                }else{
                var myPlace = pairs [myPlaceList[myDialog.myPlaceMenu.selected]];
                alert (myPlace);
                thanks
                • 5. Re: Reading tab delimited data from a text file (JS CS3)
                  jmw107 Level 1
                  Hi -- Nevermind -- I figured it out (found an earlier post where you answered the same question).
                  var myPlace = pairs [myPlaceList[myDialog.myPlaceMenu.selection.index]];
                  thanks again,
                  Jim
