1. Re: Problem with Custom Components
Tara Jane Feener Jun 28, 2010 2:10 PM (in response to TimothyWhalin)Hey Timothy,
I'm trying to understand how your project is set up.
Is it something you can deploy on acrobat.com so that I can take a look at it and help?
Tara
2. Re: Problem with Custom Components
TimothyWhalin Jun 28, 2010 2:13 PM (in response to Tara Jane Feener)Hi Tara,
I send you a private message with the link to the flash catalyst file. Thanks for your help!
3. Re: Problem with Custom Components
Tara Jane Feener Jun 28, 2010 3:08 PM (in response to TimothyWhalin)Hey Timothy,
The easiest way to achieve what you're looking for, is to convert the scroll panel to a custom component (it might be already, I can't remember if it was when I got the project or if I converted it), and to create enough states for each city.
You will have to duplicate the scroll panel, and place a new one in each state, such that there is a scroll panel for each city you'd like to have text for.
Then you'll have to edit the text of each scroll panel to contain the content you'd like for each city.
Unfortunately, since the text is buried in the scrolling content part of the scroll panel, and the scrolling content is not stateful, it's not possible to have one scrolling content component, with one text area, whose text changes in each state.
Does this solution make sense?
Let me know if it works for you, and keep posting feedback.
Tara
4. Re: Problem with Custom Components
TimothyWhalin Jun 28, 2010 3:20 PM (in response to Tara Jane Feener)So it will be a
Custom Component
Text Field with the name of each country
Scroll Panel
Scroll Bar
Custom Component
Text field
Can you send me the file you were playing with back so I can see how you had to do it to set it up? Will it work changing a custom component inside of the custom component? Not sure if it will work how I need it to or not...
5. Re: Problem with Custom Components
Tara Jane Feener Jun 28, 2010 3:48 PM (in response to TimothyWhalin)Sure no problem!
Just sent a PM requesting an email address for share.
Thanks!
Tara
