3 Replies Latest reply on Jun 29, 2010 12:08 AM by BhaskerChari
    How to set default textInput value for integer empty?
    ltambs
      <fx:Declarations>
        <vo:Thistorypurchase id="thistorypurchase"/>
      </fx:Declarations>
      private var _internal_ascty : int;
      private var _internal_bitrate : int;
      private var _internal_candidateServiceId : int;
      private var _internal_dscty : int;
      How to default textInput value set empty?
      in the above case the value of thistorypurchase is set 0 for integer value.
      I want to set them empty.
      Instead script for creationComplete set to empty, any other ways there?
      Thanks.
        • 1. Re: How to set default textInput value for integer empty?
          BhaskerChari Level 4
          Hi Itambs,
          Your question is not clear to me...Could you be a bit clear...??? Please elaborate on this..??
          Bhasker Chari
          • 2. Re: How to set default textInput value for integer empty?
            ltambs Level 1
            myApp.mxml===========
              <fx:Declarations>
            </fx:Declarations>
            <mx:Form defaultButton="{btnSave}" width="100%">
              <mx:VBox width="100%">
               <mx:HBox width="100%" horizontalAlign="right">
                <s:Button label="Save" id="btnSave" click="button_clickHandler(event)"/>
                <s:Button label="Close" id="btnClose" click="btnClose_clickHandler(event)"/>
               </mx:HBox>
               <mx:VBox>
                <mx:FormItem label="             SssId">
                 <s:TextInput id="sssIdTextInput" text="{thistorypurchase.sssId}"/>
                </mx:FormItem>
            Thistorypurchase.as ============
            private var _internal_sssId : int;
            when I alert the value of all integer type in myApp.mxml that shows "0".
            Am I clear?
            • 3. Re: How to set default textInput value for integer empty?
              Hi Itambs,
              I am sorry I am not clear this time also ...Please you can be a bit elaborate on this with clear explanation of your exact problem...
              I dint get by your problem......set default textInput value for integer empty?
              Bhasker
