4 Replies Latest reply on Jun 29, 2010 7:32 PM by Todd_Kopriva
    Crashing on render
    alexreynish
      Every time I try and render out my sequence it fails. It happens at the 30 second mark, once it's happened all my renders fail instantly. It's not an overly complicated sequence but it is made mostly out of SWFs (Grabbed from screen captures using CamStudio)
      The Machine.
      iMac 3.06ghz Core 2 Duo
      4 gb of RAM
      Mac OS  10.6.3
      My "After Effects Log.txt" shows lots of stuff, I think this is the important bit.
      How can this be fixed? I'm on a bit of a deadline.
        • 1. Re: Crashing on render
          alexreynish Level 1
          Ticks = 7023      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7023      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1500855296 amt_to_purge: 16055328
          Ticks = 7026      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7026      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 41
          Ticks = 7026      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7026      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:1
          Ticks = 7040      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7040      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1504949532 amt_to_purge: 16055328
          Ticks = 7040      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7040      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 38
          Ticks = 7040      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7040      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:1
          Ticks = 7042      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15770
          Ticks = 7042      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1520579136 amt_to_purge: 16149056
          Ticks = 7042      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7043      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 29
          Ticks = 7043      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7043      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:1
          Ticks = 7081      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7081      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1502493768 amt_to_purge: 16055328
          Ticks = 7082      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7082      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 39
          Ticks = 7082      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7082      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7082      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1520485168 amt_to_purge: 16055328
          Ticks = 7083      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:9, numWalked:9, Total: 30
          Ticks = 7083      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7083      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:2
          Ticks = 7140      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7140      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1488580140 amt_to_purge: 16055328
          Ticks = 7141      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7142      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 48
          Ticks = 7142      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7142      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7142      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1504949532 amt_to_purge: 16055328
          Ticks = 7142      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7142      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 38
          Ticks = 7142      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1522949844 amt_to_purge: 16055328
          Ticks = 7143      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 28
          Ticks = 7143      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7143      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7143      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1539319236 amt_to_purge: 16055328
          Ticks = 7143      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7143      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:10, Total: 18
          Ticks = 7143      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:4
          Ticks = 7172      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15770
          Ticks = 7172      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1530389616 amt_to_purge: 16149056
          Ticks = 7172      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7173      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:9, numWalked:9, Total: 24
          Ticks = 7173      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7173      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15770
          Ticks = 7173      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1547585212 amt_to_purge: 16149056
          Ticks = 7173      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7174      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:10, numWalked:11, Total: 14
          Ticks = 7174      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7174      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:2
          Ticks = 7239      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15679
          Ticks = 7239      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1562231076 amt_to_purge: 16055328
          Ticks = 7241      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7242      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:12, numWalked:15, Total: 4
          Ticks = 7242      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7242      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:t, retries:1
          Ticks = 7274      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15770
          Ticks = 7274      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1545103008 amt_to_purge: 16149056
          Ticks = 7275      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7276      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:11, numWalked:11, Total: 16
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Under threshold.
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED Fragmentation or other resource constraint reqsize Kb:15770
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1562286028 amt_to_purge: 16149056
          Ticks = 7276      <2693387488> <LegacyALOG> <5> OpenGL PurgeRequest() Succeeded: FALSE
          Ticks = 7276      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:12, numWalked:15, Total: 4
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK Issuing Purge Request block_request: 1580283660 amt_to_purge: 16149056
          Ticks = 7276      <2693387488> <LegacyALOG> <5> MC PURGE_STATS numFreed:0, numWalked:4, Total: 4
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U MAKE_ROOM_FOR_BLOCK DONE. Purge not freeing anything
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U ALLOC_OP_FAILED_RECOVERY_STAT success:f, retries:2
          Ticks = 7276      <2693387488> <LegacyALOG> <5> U ALLOC_FAILED_UNABLE_TO_RECOVER what:Unidentified caller.
          • 2. Re: Crashing on render
            TimeRemapper Level 4
            Do you have Open Gl enabled (it looks like you might). If so, disable it, and if you're trying to hardware render via OpenGL, don't.
            Otherwise, your best bet may be to transcode the .swf files to a different format (such as Quicktime movies using the Animation Codec at full quality) before using them in your timeline. After you've transcoded your .swfs, then you can relink the footage in the project window, and it should update your timeline(s) accordingly.  As always, before trying anything of this scale, save a copy of your project first (work off of a new iteration).
            • 3. Re: Crashing on render
              alexreynish Level 1
              Thanks for the help.
              Turned off Open GL but still no joy.
              My MacBook has rendered a few of these before with no problems. I'm going to try it on there.
              • 4. Re: Crashing on render
                Todd_Kopriva Level 8
                What version of After Effects?
