2 Replies Latest reply on Jun 29, 2010 10:51 AM by johngordon12
    PNG Transparency Fix for IE6
    johngordon12 Level 1
      Hope somone can help with this. Basically I have a PNG image with a transparancy to sit over a gradient background, like this :
      The little graphics next to campaign metrics are OK, but the main header image they sit in with the light blue gradient and hand graphic etc is not - the little areas around the curved corners should be transparent but are not (in IE6).
      I assume this is because that is a background image for the <div> being referenced in the CSS, rather than dropped into the page directly.
      So I guess my question is can this be overcome?
        • 1. Re: PNG Transparency Fix for IE6
          bemdesign Level 4
          IE 6 doesn't support transparent PNGs natively. You will either have to resort to Javascript hacks to force IE 6 to render it correctly (although these do not work for repeated background images in CSS), use a lowest common denominator image format (GIF), or use conditional commenting to give IE 6 it's own stylesheet with it's own image to get something somewhat like what the other browsers will see.
          Or just not worry what IE 6 sees as long as your site content is accessible and usable.
          • 2. Re: PNG Transparency Fix for IE6
            Cheers for that.
            I'm already using the fix for IE6 - it just doesn't seem to fix it for images in the CSS.
            But reading that, I think the easiest solution will be to use an image without the rounded corners for IE6.
