1 Reply Latest reply on Jun 29, 2010 9:18 AM by the_wine_snob
    Adjusting Audio levels on the timeline
    vooray1
      In Final Cut I could just grab the audio line and adjust the volume of the clip. Is this possible to do in Premier without going to soundbooth? I can use the audio transitions but I just want to go up and down with the interview I have.  Please advise. Thanks.
        • 1. Re: Adjusting Audio levels on the timeline
          the_wine_snob Level 9
          Yes, you can grab the Volume "rubber band," which is shown by default. You can also Rt-click, and chose to modify the Gain.
          For adjusting up/down in an interview, I would strongly recommend using the Effects Control Panel, and then setting Keyframes for the fixed Effect>Volume. One can also "ride Levels" in Audio Mixer, but that will apply Track Keyframes, so should only be done when all Video editing is done.
