4 Replies Latest reply on Jun 29, 2010 1:44 PM by bocode3
    adding a new row in between existing rows of datagrid
    bocode3 Level 1
      Hello All,
      I'm noob and trying to create a custom datagrid. Here is my code (am working in FB4/flex 3.5):
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
         creationComplete="employeeService.send()">
      <fx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.events.ListEvent;
      private function addRow(event:ListEvent):void{
      if(event.columnIndex==0){
      </fx:Script>
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      <s:HTTPService id="employeeService" url="http://abc.com:7500/emp.xml"/>
      </fx:Declarations>
      <mx:DataGrid  dataProvider="{employeeService.lastResult.employees.employee}" width="300" editable="true"
      itemClick="addRow(event);">
      <mx:columns>
      <mx:DataGridColumn headerText="Reportees" editable="false" >
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox>
      <mx:Image source="http://abc.com:7500/add.png"/>
      <s:Label text="{data.loginid}"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
      <mx:DataGridColumn headerText="Projects" editable="false">
      <mx:itemRenderer>
      <fx:Component>
      <s:MXDataGridItemRenderer>
      <s:DropDownList dataProvider="{data.projects.project}" labelField="name"/>
      </s:MXDataGridItemRenderer>
      </fx:Component>
      </mx:itemRenderer>
      </mx:columns>
      </mx:DataGrid>
      </s:Application>
      The remote xml is as follows:
      <?xml version="1.0" ?>
      <employees>
      <employee>
        <loginid>rambo</loginid>
        <name>ramboman</name>
        <projects>
         <project>
          <name>ATN</name>
          <id>34</id>
         </project>
         <project>
          <name>DTN</name>
          <id>43</id>
         </project>
         <project>
          <name>XTN</name>
          <id>54</id>
         </project>
        </projects>
        </employee>
      </employees>
      I've two columns in the datagrid, the first column has the login name with a small image of "plus" sign. The second column has a drop down list of projects associated with each login id.
      So currently i've enabled click only for the first column cells and when somebody clicks a cell in this column, i would like to add a new row just below the clicked column. This row should contain the same dropdownlist in the second column and empty text in the first column.
      How do i do this?
      Thanks in advance for the help,
      Bo
        • 1. Re: adding a new row in between existing rows of datagrid
          VRPDeveloper Level 3
          You can refer the following link which will give you similar kind of functionality done...
          http://www.switchonthecode.com/tutorials/adding-dynamic-rows-to-flex-datagrid
          • 2. Re: adding a new row in between existing rows of datagrid
            bocode3 Level 1
            Hello VRPDeveloper,
            Thanks for looking at my current problem. I've achieved the solution to insert a new row in between existing rows. Now the problem is i've created mxml component that needs to be inserted into a new row. The component is simple and here is the code:
            Component (wkmnth.mxml):
            <s:MXDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
            autoDrawBackground="true">
            <s:NumericStepper minimum="0" maximum="100"/>
            DataGridCode:
            <fx:Script>
            <![CDATA[
            import components.EmpRowClass;
            import components.empname;
            import components.empprojrow;
            import components.weekMonth;
            import components.wkmnth;
            import spark.layouts.RowAlign;
                     empdg.dataProvider.addItemAt(new EmpRowClass(new empname(),new empprojrow(), new wkmnth(), new wkmnth(), new wkmnth(), new wkmnth()), event.rowIndex+1);
            </fx:Script>
            <fx:Declarations>
            <s:HTTPService id="employeeService" url="http://abc.com/emp.xml"/>
            </fx:Declarations>
            <mx:DataGrid  id="empdg"
              width="40%" editable="true"
            <mx:columns>
            <mx:DataGridColumn headerText="Reportees" editable="false" itemRenderer="components.empnamerow" width="40"/>
            <mx:DataGridColumn headerText="Projects" editable="false"  width="30"/>
            <mx:DataGridColumn headerText="Jul,Wk1" width="27"  rendererIsEditor="true"/>
            <mx:DataGridColumn headerText="Jul,Wk2" width="27"  rendererIsEditor="true"/>
            <mx:DataGridColumn headerText="Jul,Wk3" width="27"  rendererIsEditor="true"/>
            <mx:DataGridColumn headerText="Jul,Wk4" width="26"  rendererIsEditor="true"/>
            </mx:columns>
            </mx:DataGrid>
            </s:Application>
            empname, empprojrow are components are other simple components. But my problem is why does the numericStepper does not come in the new row?
            Can you please have a look into it?
            Thank you for your help,
            Bo
            • 3. Re: adding a new row in between existing rows of datagrid
              Where are you assigning wkmnth renderer in datagrid ... I think you have not assigned it anywhere so it is not coming
              itemRenderer="myComponents.wkmnth"
              • 4. Re: adding a new row in between existing rows of datagrid
                bocode3 Level 1
                if i assign itemrenderer property then i'll get numeric stepper for all the columns (from 3rd to 6th column). I want the numericstepper to appear only on the new rows. That is why in the addRow() method, am adding a new row with wkmnth method calls but it does not seem to work.
                any ideas?
