1. Re: Need help moving text
learn n leverage Jul 1, 2010 6:04 AM (in response to talbot)Hi,
Since the text animation is done using the timeline in this file you have to manually edit the positioning of the each symbol element in every keyframe i.e
You have to go in to the editing mode for txt_c instance of txt_2 > Layer 8 where the required elements are placed
1. You have to position the Layer 1(under Layer 8) items at every key frame for the display text
you may have problem while positioning second text onwards as you will not be seeing them on stage. For this you may want to duplicate the symbol(txt_5) at key frame 37 and edit it to have only the second text and remove everything else. And you can swap the existing symbols at key frame 44 and key frame 54. You can repeat this for the rest of the text.
2. Next you have to position the numbers which spread across three layers (txt_3, txt_4 and Layer 6) under Layer 8. They are for prefix number, suffix number and the dot respectively
Thanks!
2. Re: Need help moving text
talbot Jul 1, 2010 3:53 PM (in response to learn n leverage)like I said, I am clueless.I just don't know how to move around and what view I should be in. Usually I can back or reverse engineer things but I'm just lost. I know PS and a tiny bit of AI but this has me baffled. The last word is can I get rid of all the text and change the images? SO I went in and deleted all the text and then went and swapped an image and it's working. But I wish I knew how to get around in it better and then maybe I could figure out things...
Thanks very much for your help but I just am not following.
