16 Replies Latest reply on Jul 4, 2010 6:11 PM by aliandri
    search text on RTF with lingo
    aliandri
      dear all ...
      can help me?..
      I make glossary with RTF text because on RTF Text is easy to change content but can help me to make search text or word on RTF text with lingo..?
      Thankyou
        • 1. Re: search text on RTF with lingo
          Sean_Wilson Adobe Community Professional
          What is it you want to do that offset(member("name").text, "word) doesn't achieve? Have you tried using a JavaScript RegExp object to perform text searches?
          • 2. Re: search text on RTF with lingo
            aliandri Level 1
            thank you for your attantion but i don't know how to use them cause i'm beginner...
            can give me a sample because i try to learn about that and i try it but show error Command Note Define...
            Thank you
            • 3. Re: search text on RTF with lingo
              Please explain what you want to do with your search results. For example, what is it your search needs to do: display which text members contain a particular word; highlight words in a text member; scroll the text member to display the first instance of a word; ... ?
              • 4. Re: search text on RTF with lingo
                aliandri Level 1
                on my movie...
                i place input text field call text1 who concern about text/word searching and box shape for button to execute searching
                another text field fill a full text call text2 ....
                so... if i fill text1 with separate text/word and hit the button so ... that text or word will see on text2 if text2 consist of text1....
                if text1 nothing on text2 so will shoe message text/word not found...
                thankyou...
                • 5. Re: search text on RTF with lingo
                  You might attach something like the following to your button:
                  on mouseUp me
                    sMessage = "search text not found"
                    -- assume member names are "text1" and "text2"
                    sSearch = member("text1").text
                    sText   = member("text2").text
                    tOffset = offset(sSearch, sText)
                    if (tOffset > 0) then sMessage = "search text found"
                    alert sMessage
                  end
                  • 6. Re: search text on RTF with lingo
                    aliandri Level 1
                    Thankyou... it's work ....
                    can i help again  ?
                    if that text/word is found on text2 and i want show highlight on text2 too...
                    • 7. Re: search text on RTF with lingo
                      Please explain - with a picture if necessary - what you mean by "show highlight".
                      • 8. Re: search text on RTF with lingo
                        aliandri Level 1
                        like this ... (show highlight on yellow color)
                        • 9. Re: search text on RTF with lingo
                          Changing the BG colour of a chunk of text is not easy. It can be done with some imaging-lingo hoop-jumping, or by having a pool of shape sprites that can be dynamically allocated, sized and positioned.
                          Place the following in a JavaScript typed #movie script:
                          function jsSearch (aString, aMatch) {
                            var aPattern = new RegExp(aMatch, "gi");
                            var found;
                            var results = list();
                            while((found = aPattern.exec(aString)) != null) {
                              results.append(found.index);
                            return results;
                          and this in a "regular" Lingo #movie script:
                          on mHighlightMatches aMember, aString
                            -- error check inputs
                            if ilk(aMember, #member) = 0 then
                              aMember = member(aMember)
                                exit
                              end if
                            end if
                            if stringP(aString) = 0 then aString = string(aString)
                            if stringP(aString) = 0 then exit
                            -- will only work with #text nmembers
                            if (aMember.type <> #text) then exit
                            aMember.color = rgb(0, 0, 0)
                            len = length(aString)
                            lMatchPositions = jsSearch(aMember.text, aString)
                            if count(lMatchPositions) = 0 then
                              alert "Search text not found"
                            else
                              repeat with aStart in lMatchPositions
                                aMember.char[aStart..(aStart + len)].color = rgb(255, 255, 0)
                              end repeat
                            end if
                          end
                          and now your button script might look like:
                          on mouseUp me
                            mHightlightMatches(member("text2"), member("text1").text)
                          end
                          • 10. Re: search text on RTF with lingo
                            aliandri Level 1
                            thank you for your information...
                            i try this and corrected a error but i can't correct on line consist of
                              else
                                end repeat
                              end if
                            end
                            show message Handler not found in object and stop run on line aMember.char[aStart..(aStart + len)].color = rgb(255, 255, 0)
                            i change with static value like this aMember.char[0..3].color = rgb(255, 255, 0)
                            but still error...
                            i try to searching to corrected but i can't found it....
                            can explain me...?
                            Thankyou
                            • 11. Re: search text on RTF with lingo
                              Which version of Director on which platform?
                              What #type of member holds your text - #text, #field or something else?
                              • 12. Re: search text on RTF with lingo
                                aliandri Level 1
                                thank you....
                                i used Director MX Ver. 10.1 on platform Windows XP
                                i used #text with option for text1 is editable, framing fixed and text2 isn't editable, framing scrolling
                                i find on help about color() instruction n i try that code with a simple movie but still not work....
                                Please can explain that ?
                                or can i send my movie to your email...?
                                thank you..
                                • 13. Re: search text on RTF with lingo
                                  I am also using 10.1 on XP and I tested what I posted - I have no idea what's going wrong for you. Feel free to upload your movie file somewhere - and provide a URL -  so that I (or someone else) can take a look.
                                  • 14. Re: search text on RTF with lingo
                                    aliandri Level 1
                                    please download this file...
                                    http://www.ziddu.com/download/10539703/offse.zip.html
                                    that file is my project...
                                    it's my error...
                                    • 15. Re: search text on RTF with lingo
                                      The error was due to trying to access member.char[0]
                                      Try the updated handler below:
                                      on mHighlightMatches (aMember, aString)
                                            exit
                                          end if
                                        end if
                                        len = length(aString) - 1
                                        else
                                            aStart = aStart + 1
                                          end repeat
                                        end if
                                      end
                                      • 16. Re: search text on RTF with lingo
                                        aliandri Level 1
                                        a million Thank you...
                                        it's work....
