Expand my Community achievements bar.
Converting PDF files to Doc or RTF
Avatar
Level 4
Hi all,
I am trying to configure the PDF to Doc watchfolder.
Create a process for PDF to Doc, when i invoke in workbench it showing error.
Please advice.
Shaji
Avatar
Level 2
This works in my environment. Try with the attached process and see if it converts ok. You should also try with some different pdf files. Make sure the pdf is not protected or such, as the conversion will then fail.
Daniel
Avatar
Level 4
Hi Daniel,
Thanks for the .lca file, when I import the .lca files it showing error of missing path.
I am not able to import the .lca file.
Please advice.
Shaji
Avatar
Level 4
Here is the error message.
Shaji
