4 Replies Latest reply on Jul 5, 2010 2:05 AM by SimonATS
    Error 1328 at installation AdbeRdrUpd933_all_incr.ms
    gora2
      Error at installation AdbeRdrUpd933_all_incr.msp
      I create an administrative point and I use following batch a file:
      msiexec /a "%cd%\AdbeRdr930_ru_RU.msi" /qb! TARGETDIR="%cd%\AdobeRdr"
      msiexec /p "%cd%\AdbeRdrUpd932_all_incr.msp" /a "%cd%\AdobeRdr\AdbeRdr930_ru_RU.msi" /qb!
      msiexec /p "%cd%\AdbeRdrUpd933_all_incr.msp" /a "%cd%\AdobeRdr\AdbeRdr930_ru_RU.msi" /qb!
      At installation AdbeRdrUpd933_all_incr.msp I receive an error 1328.
      The same error I receive at installation AdbeRdrUpd933_all_incr.msp on installed Adobe Reader v9.3.2
      OS: Windows XPSP3 x86 and Window 7 x64
        • 1. Re: Error 1328 at installation AdbeRdrUpd933_all_incr.ms
          Neaderthaler
          In here the same problem on XPSP3 and W2K3SP2.
          I thought that it might be the virusscanner, turned it off but no succes.
          I ran the command AdbeRdr930_nl_NL.msi -p E:\Dump\AdbeRdrUpd933_all_incr.msp  which is succesfull normally.
          From the log (translated from Dutch):
          Error while applying the patch to file E:\Config.Msi\PT222C.tmp. Probably the file has been changed in one or the other way and can not be changed anymore by the patch.
          System error: -1072807676
          Kind regards,
          Hennie.
          • 2. Re: Error 1328 at installation AdbeRdrUpd933_all_incr.ms
            mp3j3rk
            I am having this same problem.
            Question though, are you guys using an .msi that has already been slipstreamed with 9.3.2?
            That is what I am using, I have not yet tried using a 9.3.0 .msi.
            I will report any success (or otherwise) that I have.
            Dylan
            • 3. Re: Error 1328 at installation AdbeRdrUpd933_all_incr.ms
              mp3j3rk Level 1
              So far here is what I have found.
              Because the patch is an incremental patch, you have to patch the previous version which is 9.3.2.
              What was happening with me, is that I was trying to patch 9.3.0 with an msi slipstreamed with 9.3.2.  Thats what was causing the error.
              Try this.  Download the AdbeRdrUpd932_all_incr.msp patch, and do the following to create a valid 9.3.2 network install point.
              msiexec /a AdbeRdr930*.msi
              point the installer to your install point.
              after that is done, slipstream to version 9.3.2:
              msiexec /a AdbeRdr930*.msi /p AdbeRdrUpd932_all_incr.msp
              again, use the install point as the target. This will patch all files to 9.3.2.
              Now we can use the 933 patch to get to the newest version.
              msiexec /a AdbeRdr930*.msi /p AdbeRdrUpd933_all_incr.msp
              This should work, it did for me.
              Best Wishes from Kansas!
              Dylan
              • 4. Re: Error 1328 at installation AdbeRdrUpd933_all_incr.ms
                SimonATS Adobe Employee
                This is more aimed at the original poster of this thread.
                There is a small issue with the Eastern European laanguage versions of reader 9 when it comes to updating via AIP.
                See http://kb2.adobe.com/cps/853/cpsid_85367.html
                for more details.
                Again the above document is only for the language mentioned and doesn't apply to the Dutch version.
