1 Reply Latest reply on Jun 30, 2010 3:20 AM by DazFaz
    Using variables: Statement must appear within on handler
    R7AF Level 1
      I would like to use variables in my flash app. The app is quite simple, has many buttons, and on each of those buttons I have a simple script: on-rollover and on-release. For both actions I use the same value, which I want to put in a variable. The following script results in an error message: Statement must appear within on handler. When I have to declare the variable inside the on-handler, I have to declare it twice, which makes it useless as I have to enter the value twice. How can I get this working?
      country = "uk"
      on (rollOver)
          gotoAndPlay(country)
      on (release)
          getURL("/"+country+"/", "_self");
        • 1. Re: Using variables: Statement must appear within on handler
          DazFaz Level 1
          try:
          Select a frame on the timeline where your buttons live and then move the buttons handlers there:
          e.g.
          myButton1.onPress = onPressFunction
          myButton2.onPress = onPressFunction
          myButton3.onPress = onPressFunction
          etc.etc.
          myButton1.onRelease = onReleaseFunction
          myButton2.onRelease = onReleaseFunction
          myButton3.onRelease = onReleaseFunction
          etc.etc.
          country = "uk"
          function onPressFunction(){
               this.gotoAndPlay(country)
          function onReleaseFunction(){
          If you use this approach you MUST remove the scripts from buttons themselves.
          I hope this helps.
