4 Replies Latest reply on Apr 18, 2012 4:45 AM by er453r
    Unable to connect to BlazeDS server destination (get "┴└" Server Error)
    jaizkibel
      I'm trying to connect on Flash Builder 4 to my BlazeDS RDS server, and after being prompted for RDS username/password (which I mark as not required) I get a Server error window with the useless following error text "┴└". (or some characters that look like those).
      I'm pretty sure I've everything well configured because if I go to my browser and try to reach:
      https://localhost:8443/myServer/CFIDE/main/ide.cfm
      I get the "HTTP Status 405 - HTTP method GET is not supported by this URL" which is supposed to be telling you things are up and working.
      My JEE configuration is: JBoss 5, Spring 3, spring-flex 1.0.3, blazeds 3.2.0.3978
      I think my configuration pretty much follows all manuals I found in the internet, including this one:
      http://www.jamesward.com/2010/01/11/flash-builder-4-data-wizards-with-java-spring/
      When I set the flex server, server location, I''ve set:
      Root folder: c:\jboss-5.0.1.GA\server\default\deploy\myServer.war   ( <---- is an exploded war)
      Root URL: https://localhost:8443/myServer
      Context root: /myServer
      Output folder: c:\jboss-5.0.1.GA\server\default\deploy\myServer.war\apk-debug
      My services-config.xml on JEE has the following conf, in case it is relevant:
         <channel-definition id="my-amf" class="mx.messaging.channels.SecureAMFChannel">
              <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
              <properties>
                  <add-no-cache-headers>false</add-no-cache-headers>
              </properties>
          </channel-definition>
      Any idea of what that this error means? What shall I do to connect my Flex project to the services? I've been googling for three days, but didn't find anything...
      Thank you very much indeed for your time
