3 Replies Latest reply on Jul 3, 2010 8:38 AM by jack182
    ComboBox prodiver affects 2nd ComboBox provider
    jack182
      Hello,
      I have this problem: I have 2 ComboBox with different provider but with same list of values. Now, when I select a value from a 1st ComboBox, the value I selected will be remove from 2nd ComboBox list value.
      [Bindable]
                  private var _stationOrigin:ArrayCollection;
                  [Bindable]
                  private var _stationDestination:ArrayCollection;
      _stationOrigin = stnService.allStationNames; // this station name came from DB through remoting
      _stationDestination = stnService.allStationNames;
      <mx:FormItem label="Origin:" required="true">
                                          <mx:ComboBox id="origin" prompt="[--- SELECT ---]" dataProvider="{_stationOrigin}" close="handleCloseEvent(event);" />
                                      </mx:FormItem>
      <mx:FormItem label="Destination:" required="true">
                                          <mx:ComboBox id="destination" prompt="[--- SELECT ---]" dataProvider="{_stationDestination}" close="handleCloseEvent(event);" />
                                      </mx:FormItem>
      ...and actionscript:
      private function handleCloseEvent(e:DropdownEvent):void
                      if(e.target.id == "origin" && e.currentTarget.selectedItem != null)
                          if(_stationDestination.contains(origin.selectedItem.toString()))
                              var idx:int = _stationDestination.getItemIndex(origin.selectedItem.toString());
                              _stationDestination.removeItemAt(idx);
      ..Now when I do that both the origin and destination value was remove from the combobox. It's weird because I only remove it in a destination not in origin. And also the selected value from the origin dropdownbox was gone.
      Any ideas on how to solve this?
      Thanks a lot.
      cheers.
