4 Replies Latest reply on Jul 1, 2010 1:44 AM by Jhon Carlo
    Increase the number of sprite buy clicking over a button
    Jhon Carlo Level 1
      Hallo I need an help about the following problem.
      I have several sprite out of the stage and a need to bring this sprite, one at time, inside the stage, without  write a long script like this:
      on mouseUp me
          If sprite(5).locH = 512 then
            sprite(6).locH = 512
      and so on ...
      I must use the script several time with several sprite, so I'm looking for another solution.
      Is there a way (more efficent)  to increase by one number of the sprite for every click over a button?
      For more information: I need of another button that decrease the number of sprite, but I supose if there is the solution of increase I can arrange the script.
      I've tried with my very little lingo knowlege, but from now I'm without solution.
        • 1. Re: Increase the number of sprite buy clicking over a button
          Production Monkey Level 3
          Generally when you want to share information across multiple objects you use a global variable. To keep the code clean I also suggest using movie level functions to handle bounds checking and any other details that might crop up.  A movie script would be:
          --  movie script
          global gCurSpriteNum, gMinSpriteNum
          on prepareMovie
            gMinSpriteNum = 10 -- use the starting sprite number minus 1.
            gCurSpriteNum = gMinSpriteNum
          end prepareMovie
          on getNextSprite
            gCurSpriteNum = gCurSpriteNum + 1
            if gCurSpriteNum > _movie.lastChannel then
              gCurSpriteNum = _movie.lastChannel
              put "getNextSprite() attempted to exceed maximum available sprite channels."
            end if
            return sprite(gCurSpriteNum)
          end getNextSprite
          on decrementNextSprite
            gCurSpriteNum = gCurSpriteNum - 1
            if gCurSpriteNum < gMinSpriteNum then gCurSpriteNum = gMinSpriteNum
          end decrementNextSprite
          You then create two behavior scripts that call the two functions:
          -- Increment behavior
          on mouseUp me
            NextSp = getNextSprite()
            put NextSp
          end
          And...
          -- decrement behavior
          on mouseUp me
            decrementNextSprite()
          end
          • 2. Re: Increase the number of sprite buy clicking over a button
            Jhon Carlo Level 1
            Thanks, Thank you  very much.
            I am completely surprised by my novice perspective of your  elegant solution.
            But you must be patient because for me it's still hard  to imagine the extensions of your script.
            How can I turn the  current script to another that inserts in a button the following  behavior?
            on mauseUp me
                 (Sprite 2). LochH = 512
            end
            that with the second  click will be
            mauseUp on me
                 (Sprite 3). LocH = 512
            end
            Or something that serves to this  purpose.
            Still Many, many thanks.
            • 3. Re: Increase the number of sprite buy clicking over a button
              In the Movie script you set the global variable "gMinSpriteNum" to "1"...
              on prepareMovie
                gMinSpriteNum = 1  -- use the starting sprite number minus 1.
              end prepareMovie
              Then you modify the increment behavior...
              on mouseUp me
                NextSp.locH = 512
              end
              If you want to be slick, then you can write it thus..
              on mouseUp  me
                getNextSprite()
              .locH = 512
              end
              • 4. Re: Increase the number of sprite buy clicking over a button
                Jhon Carlo Level 1
                Many thanks
                Your help is magic for me.
                Now  everything runs smoothly as slick and I'm more slick too.
                Really Really many thanks
