4 Replies Latest reply on Jun 30, 2010 11:17 AM by cdsvvxv
    Changing stylesheets at runtime
    cdsvvxv
      I am not using Flex Builder but the command line mxmlc compiler instead. I have two css.swf files that I don't seem to be able to access within my code. The code in the mxml file that attempts to access the stylesheet is:
      StyleManager.loadStyleDeclarations("theme/purple.css.swf" , true);
      but I get an error:
      Error: Unable to load style(Error #2035: URL Not Found. URL: theme/purple.css.swf): theme/purple.css.swf.
              at MethodInfo-936()
              at flash.events::EventDispatcher/dispatchEventFunction()
              at flash.events::EventDispatcher/dispatchEvent()
              at ModuleInfoProxy/moduleEventHandler()
              at ModuleInfo/errorHandler()
      I have not managed to get the mxmlc compiler options to be of any use to me and am unsure how to compile the css.swf files into my Flex app so I can access them.
      My folder structure is:
      src
          locale
          resource
          theme
              purple.css.swf
              white.css.swf
          uk
          Main.mxml
      and everything else compiles in correctly.
      I have tried embedding the stylesheets but although they do get compiled in when embedded (I can tell as the file size increases) I can't access them as the loadStyleDeclarations takes a String and not a Class as its first argument. They do not get compiled in if I do not embed them. My mxmlc command line is:
      mxmlc --strict=true
                 --file-specs ${project.home}/build/src/Main.mxml
                 --output ${project.home}/build/flex-client.swf
      Can anyone help?
