5 Replies Latest reply on Jul 1, 2010 1:39 AM by Francisc
    Catching an Event
    Francisc Level 3
      Hello!
      In the main application I am dispatching a custom event:
      var e:Event=new Event("loggedinUserDataLoaded",true);
      dispatchEvent(e);
      In the itemRenderer component of another component hosted inside the parentApplication I am trying to catch it:
      addEventListener("loggedinUserDataLoaded",confirmCatch);
      However, this isn't working.
      What am I doing wrong please?
        • 1. Re: Catching an Event
          houseofadobe Level 1
          Apparently not on the display list path of the event.
          • 2. Re: Catching an Event
            saisri2k2 Level 4
            You have to create a custom event which is a nw class and extends Event and has a constructor. You can dispatch this custom event in this way.
            • 3. Re: Catching an Event
              Looks like you are not using a FlexEvent but a flash event.   Use FlexEvent instead and it will bubble thru the display list.
              • 4. Re: Catching an Event
                David_F57 Level 5
                hi,
                This might help a bit.......
                ok - main app
                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:ns1="*">
                <fx:Metadata>
                [Event("TransferReady", type="flash.events.Event")]
                </fx:Metadata>
                <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                <s:Button x="133" y="127" label="Button" click="dispatchEvent(new Event('TransferReady'));"/>
                <ns1:TestComponent x="556" y="162">
                </ns1:TestComponent>
                </s:Application>
                custom component.
                <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300" creationComplete="group1_creationCompleteHandler(event)">
                <fx:Script>
                <![CDATA[
                import mx.core.FlexGlobals;
                import mx.events.FlexEvent;
                protected function group1_creationCompleteHandler(event:FlexEvent):void
                FlexGlobals.topLevelApplication.addEventListener("TransferReady",onTransferReady);
                private function onTransferReady(event:Event):void
                ta.text="hello world";
                </fx:Script>
                <s:TextArea id="ta" top="0" left="0" bottom="0" right="0"/>
                </s:Group>
                • 5. Re: Catching an Event
                  Francisc Level 3
                  Thanks guys.
