18 Replies Latest reply on Jul 2, 2010 6:27 AM by pinnamur
    Flash Builder 4 standalone on win7 64bit is broken after update
    Miracula.42 Level 1
      Today Adobe Updater promted that there are updates for Adobe Flash Builder 4 and Photoshop CS5. The update downloaded and installed without any errors and Photoshop is still working fine for me. But when I open Flash Builder I get a bunch of error messages and can't use Flash Builder any more. Here are screenshots of what the errors looks like:
      Sadly not only the Flash Builder perspective is affected but all other perspectives (SVN, Debugging, Profiling) are throwing errors too.
      These are the steps I tried to fix these errors - without success:
      - switching back to my personal workspace (after the update another workspace was selected)
      - opening Flash Builder with the "-clean" parameter (this worked for me several times when plugins didn't want to install properly)
      - opening Flash Builder with administration rights
      - checking inside Flash Builder for any updates
      None of these steps worked for me and I don't know how to fix this problem. Has anyone experienced the same errors after the 4.0.1.-update or are there any infos I missed?
      Any help would be appreciated!
      Miracula
        • 1. Re: Flash Builder 4 standalone on win7 64bit is broken after update
          wicket971 Level 1
          I'm on a mac and getting this same problem. I'm currently trying to run the updater again.
          • 2. Re: Flash Builder 4 standalone on win7 64bit is broken after update
            Miracula.42 Level 1
            Yes, I tried this too but it didn't help. I manually downloaded the update installer from this url: http://www.adobe.com/support/flex/downloads_updaters.html - nothing changed...
            • 3. Re: Flash Builder 4 standalone on win7 64bit is broken after update
              wicket971 Level 1
              I've filed a ticket with Adobe, but this is really aggrivating!
              http://bugs.adobe.com/jira/browse/FB-27100
              • 4. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                C. Agruss (Adobe) Level 3
                Thanks for posting the bug with detailed info about the error. We'll certainly treat this with the highest priority today, and are sorry this has broken your installation.
                The error is mystifying, because this update received an enormous amount of testing (both internal and external) before it was released. We'll get to the root of it as quickly as possible.
                For those of you experiencing this problem, will you please send any additional info you have available, that might speed up the triage:
                - full workspace log, from the root of your .metadata folder
                - amt3.log from your tmp folder
                - latest installation log
                You can find the installation logs in these locations:
                Mac - /Library/Logs/Adobe/Installers/
                Win - \Program Files\Common Files\Adobe\Installers\
                You can send any info to this address:
                cagruss [at adobe dot com]
                -Chris
                • 5. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                  wicket971 Level 1
                  I posted this over at http://forums.adobe.com/thread/671680?tstart=0 and someone there thinks it might be teamprise related. I've uninstalled teamprise from my copy, but still seem to be getting this error.
                  Interesting enough I don't have the Installer folder located within Library/Logs/Adobe/   - seems there is no log of my update of my flash builder. Could this be stored elsewhere?
                  • 6. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                    Miracula.42 Level 1
                    I don't have teamprise installed, so I don't think it is a problem with this specific plugin. I sent my log files as requested - hopefully it helps.
                    • 7. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                      Thanks a lot for cross-posting that, and identifying the Teamprise conflict.
                      Since you've narrowed that down already, there's no longer a need for sending the installer or amt3 logs mentioned earlier - just wanted to rule out install-time and licensing problems. Sending the full workspace log would still be helpful though, as it might contain additional clues about the runtime conflict.
                      -Chris
                      • 8. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                        wicket971 Level 1
                        I went ahead and just deleted flex and then reinstalled 4.0 choosing not to do the update for 4.0.1.
                        • 9. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                          @Miracula.42
                          Thanks for send me your full workspace log. The root error in the most recent entry there was different from the one at the top of this thread, so I attached your log to the bug report.
                          At the end of the error stack trace of "caused by" entries is this particular one:
                          Caused by: java.lang.NoSuchMethodError:
                          flex2.compiler.mxml.lang.StandardDefs.getStandardDefs(Ljava/lang/String;)Lflex2/compiler/m xml/lang/StandardDefs;
                          at com.adobe.flexbuilder.codemodel.internal.parsing.mxml.MXML3ToASConverter.<init>(MXML3ToAS Converter.java:55)
                          I wonder if this error is a result of loading a Flex 2 project that didn't get converted/upgraded normally? That's a wild guess, but if so, I also wonder why the error doesn't happen with FB 4.0?
                          Please let me know if I'm all wet about the Flex 2 project format.
                          -Chris
                          • 11. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                            Miracula.42 Level 1
                            Chris, I didn't read all these errors in detail, because everytime I am clicking somewhere there is a new one
                            But I don't have any Flex 2 project in my workspace. In fact I am using mostly ActionScript projects and one or two flex 3.5 projects. But I am quite sure I never had any Flex 2 project opened on my machine.
                            Thank you.
                            Miracula
                            • 12. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                              pinnamur Level 1
                              I couldn't reproduce the installation failure on my desktop - the upgrade went smoothly without any problems. For further investigation, would it be possible to attach the configuration data of the installation ?
                              Help -> Product Details -> Installation Details -> Configuration tab.
                              Copy the content from the Configuration tab and attach the file/content here.
                              • 13. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                Miracula.42 Level 1
                                @pinnamur:
                                here is the log you requested. I am not allowed to attach text files, so here is the content:
                                *** Date: Friday, July 2, 2010 9:42:59 AM Germany Time
                                *** Platform Details:
                                *** System properties:
                                awt.toolkit=sun.awt.windows.WToolkit
                                eclipse.application=com.adobe.flexbuilder.standalone.FlexBuilderApplication
                                eclipse.commands=-os
                                win32
                                -ws
                                win32
                                -arch
                                x86
                                -showsplash
                                -launcher
                                C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
                                -name
                                FlashBuilder
                                --launcher.library
                                C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
                                -startup
                                C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
                                -nl
                                en_US
                                -vm
                                C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
                                eclipse.home.location=file:/C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/
                                eclipse.launcher=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
                                eclipse.p2.data.area=@config.dir/../p2/
                                eclipse.p2.profile=profile
                                eclipse.product=com.adobe.flexbuilder.standalone.product
                                eclipse.startTime=1278056489353
                                eclipse.vm=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
                                eclipse.vmargs=-Xms256m
                                -Xmx512m
                                -XX:MaxPermSize=256m
                                -XX:PermSize=64m
                                -Djava.net.preferIPv4Stack=true
                                -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
                                -Djava.class.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
                                file.encoding=Cp1252
                                file.encoding.pkg=sun.io
                                file.separator=\
                                java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
                                java.awt.printerjob=sun.awt.windows.WPrinterJob
                                java.class.version=50.0
                                java.endorsed.dirs=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\endorsed
                                java.ext.dirs=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
                                java.home=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre
                                java.io.tmpdir=C:\Users\Tine\AppData\Local\Temp\
                                java.library.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin/client;C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPow erShell\v1.0\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Windows\Microsoft.NET\Framework\v2.0.50727;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Common Files\DivX Shared\;C:\Program Files\TortoiseSVN\bin
                                java.runtime.name=Java(TM) SE Runtime Environment
                                java.runtime.version=1.6.0_16-b01
                                java.specification.name=Java Platform API Specification
                                java.specification.vendor=Sun Microsystems Inc.
                                java.specification.version=1.6
                                java.vendor=Sun Microsystems Inc.
                                java.vendor.url=http://java.sun.com/
                                java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
                                java.version=1.6.0_16
                                java.vm.info=mixed mode
                                java.vm.name=Java HotSpot(TM) Client VM
                                java.vm.specification.name=Java Virtual Machine Specification
                                java.vm.specification.vendor=Sun Microsystems Inc.
                                java.vm.specification.version=1.0
                                java.vm.vendor=Sun Microsystems Inc.
                                java.vm.version=14.2-b01
                                line.separator=
                                org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
                                org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurat or/bundles.info
                                org.eclipse.update.reconcile=false
                                org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2 ,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
                                org.osgi.framework.language=en
                                org.osgi.framework.os.name=Windows7
                                org.osgi.framework.os.version=6.1.0
                                org.osgi.framework.processor=x86
                                org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,jav ax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp, javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,jav ax.management,javax.management.loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.manag ement.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.at tribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.k erberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled ,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swi ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html ,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.anno tation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml .crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream. events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml. ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg .CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming. NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.I OP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPa ckage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.d om.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
                                org.osgi.framework.vendor=Eclipse
                                org.osgi.framework.version=1.5.0
                                org.osgi.supports.framework.extension=true
                                org.osgi.supports.framework.fragment=true
                                org.osgi.supports.framework.requirebundle=true
                                os.arch=x86
                                os.name=Windows 7
                                os.version=6.1
                                osgi.arch=x86
                                osgi.bundles=reference:file:org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar,reference:file: org.eclipse.equinox.ds_1.1.1.R35x_v20090806.jar@1:start,reference:file:org.eclipse.equinox .simpleconfigurator_1.0.101.R35x_v20090807-1100.jar@1:start
                                osgi.bundles.defaultStartLevel=4
                                osgi.bundlestore=C:\Users\Tine\.eclipse\com.adobe.flexbuilder.standalone.product_4.0.1_108 4004438\configuration\org.eclipse.osgi\bundles
                                osgi.configuration.area=file:/C:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.prod uct_4.0.1_1084004438/configuration/
                                osgi.framework=file:/c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/org.eclipse.osgi_3.5.1.R35x_v20090827.jar
                                osgi.framework.extensions=reference:file:org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
                                osgi.framework.shape=jar
                                osgi.framework.version=3.5.1.R35x_v20090827
                                osgi.frameworkClassPath=., file:c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
                                osgi.install.area=file:/C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/
                                osgi.instance.area=file:/D:/flashBuilder_workspace/
                                osgi.instance.area.default=file:/C:/Users/Tine/Adobe Flash Builder 4/
                                osgi.logfile=D:\flashBuilder_workspace\.metadata\.log
                                osgi.manifest.cache=C:\Users\Tine\.eclipse\com.adobe.flexbuilder.standalone.product_4.0.1_ 1084004438\configuration\org.eclipse.osgi\manifests
                                osgi.nl=en_US
                                osgi.nl.user=en_US
                                osgi.os=win32
                                osgi.sharedConfiguration.area=file:/c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/configuration/
                                osgi.splashPath=platform:/base/plugins/com.adobe.flexbuilder.standalone
                                osgi.syspath=c:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins
                                osgi.tracefile=D:\flashBuilder_workspace\.metadata\trace.log
                                osgi.ws=win32
                                path.separator=;
                                sun.arch.data.model=32
                                sun.boot.class.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\resources.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\rt.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\sunrsasign.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\jsse.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\jce.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\charsets.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\classes
                                sun.boot.library.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin
                                sun.cpu.endian=little
                                sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
                                sun.desktop=windows
                                sun.io.unicode.encoding=UnicodeLittle
                                sun.jnu.encoding=Cp1252
                                sun.management.compiler=HotSpot Client Compiler
                                sun.os.patch.level=
                                user.country=DE
                                user.dir=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4
                                user.home=C:\Users\Tine
                                user.language=de
                                user.name=Tine
                                user.timezone=Europe/Berlin
                                user.variant=
                                *** Features:
                                com.adobe.flexbuilder.feature.standalone (4.0.1.277662) "Adobe Flash Builder Standalone"
                                com.adobe.flexbuilder.feature.standalone.nl1 (4.0.1.277662) "Adobe Flash Builder Standalone"
                                com.collabnet.subversion.merge.feature (2.1.0) "CollabNet Subversion Merge Client"
                                com.sun.jna (3.2.3) "JNA Library Plug-in"
                                org.eclipse.cvs (1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16) "Eclipse CVS Client"
                                org.eclipse.datatools.connectivity.feature (1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q) "Data Tools Platform Connectivity Plug-in"
                                org.eclipse.datatools.connectivity.oda.designer.feature (1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU) "DTP ODA Designer UI Framework Plug-in"
                                org.eclipse.datatools.connectivity.oda.feature (1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK) "DTP Open Data Access"
                                org.eclipse.datatools.doc.user (1.7.2.v200909251450-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
                                org.eclipse.datatools.enablement.apache.derby.feature (1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI) "High-level Sybase Enablement Plug-in"
                                org.eclipse.datatools.enablement.feature (1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.hsqldb.feature (1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.ibm.feature (1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.ingres.feature (1.7.2.v200909251450-540AkF77g7VBLBPH7) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.jdbc.feature (1.7.2.v200909251450-4-29oB55W5P7G6RAH) "High-level Sybase Enablement Plug-in"
                                org.eclipse.datatools.enablement.jdt.feature (1.7.2.v200909251450-2-07w311A1A351453) "Data Tools Platform Connectivity JDT Extension Plug-in"
                                org.eclipse.datatools.enablement.msft.feature (1.7.2.v200909251450-542AkF78Y7SBU9UAB) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.mysql.feature (1.7.2.v200909251450-546AkF78Y7R9PAX87) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.oda.designer.feature (1.7.2.v200909251450-3328s7353356I4F53) "Eclipse Data Tools Platform XML ODA Designer"
                                org.eclipse.datatools.enablement.oda.feature (1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp) "Eclipse Data Tools Platform XML ODA Runtime Driver"
                                org.eclipse.datatools.enablement.oracle.feature (1.7.2.v200909251450-548aAkF77g7XAO9aBB) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.postgresql.feature (1.7.2.v200909251450-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.sap.feature (1.7.2.v200909251450-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.sqlite.feature (1.7.2.v200909251450-541AkF79P7N8NAQ97) "Eclipse Data Tools Platform Enablement"
                                org.eclipse.datatools.enablement.sybase.feature (1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
                                org.eclipse.datatools.modelbase.feature (1.7.2.v200909251450-77-5CcNBCtCcCQJYZl) "Eclipse Data Tools Platform SQLModel Plug-in"
                                org.eclipse.datatools.sqldevtools.ddlgen.feature (1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm) "Eclipse Data Tools Platform FE UI Plug-in"
                                org.eclipse.datatools.sqldevtools.feature (1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
                                org.eclipse.datatools.sqldevtools.parsers.feature (1.7.2.v200909251450-602BgJ99q9_9OGXFJ) "Eclipse Data Tools Platform SQL Parser Plugin"
                                org.eclipse.draw2d (3.5.2.v20100111-1352-4417w311A223702A19) "Graphical Editing Framework Draw2d"
                                org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework Runtime and Tools"
                                org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation"
                                org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code Generator"
                                org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code Generator UI"
                                org.eclipse.emf.codegen.ui (2.4.0.v200906151043) "EMF Code Generation UI"
                                org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common"
                                org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI"
                                org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter"
                                org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding"
                                org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data Binding"
                                org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore"
                                org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit"
                                org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor"
                                org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit"
                                org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI"
                                org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping"
                                org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping"
                                org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore Mapping Editor"
                                org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI"
                                org.eclipse.gef (3.5.2.v20100111-1352-777928194B66D5D476C33B2A) "Graphical Editing Framework GEF"
                                org.eclipse.help (1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD) "Help System Base"
                                org.eclipse.jdt (3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) "Eclipse Java Development Tools"
                                org.eclipse.jpt.eclipselink.feature (2.2.2.v200911250220-65A9AkF77g8OFL7BB7) "Dali Java Persistence Tools - EclipseLink Support"
                                org.eclipse.jpt.feature (2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je) "Dali Java Persistence Tools"
                                org.eclipse.jst.enterprise_ui.feature (3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq) "Eclipse Java EE Developer Tools"
                                org.eclipse.jst.ws.axis2tools.feature (1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe) "Axis2 Tools"
                                org.eclipse.pde (3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo) "PDE"
                                org.eclipse.platform (3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7) "Eclipse Platform"
                                org.eclipse.rcp (3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6) "Eclipse RCP"
                                org.eclipse.wst.jsdt.feature (1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb) "JavaScript Developer Tools "
                                org.eclipse.wst.web_ui.feature (3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3) "Eclipse Web Developer Tools"
                                org.eclipse.wst.xml_ui.feature (3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo) "Eclipse XML Editors and Tools"
                                org.eclipse.wst.xsl.feature (1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1) "Eclipse XSL Developer Tools"
                                org.tigris.subversion.clientadapter.feature (1.6.12) "Subversion Client Adapter"
                                org.tigris.subversion.clientadapter.javahl.feature (1.6.12) "Subversion JavaHL"
                                org.tigris.subversion.clientadapter.svnkit.feature (1.6.12) "SVNKit Client Adapter"
                                org.tigris.subversion.subclipse (1.6.12) "SVN Team Provider Core"
                                org.tmatesoft.svnkit (1.3.3.6648) "SVNKit Library Plug-in"
                                *** Plug-in Registry:
                                ActionscriptInfoCollector (0.7.4) "ActionscriptInfoCollector Plug-in" [Starting]
                                com.adobe.coldfusion.rds.client (1.0.272885) "RDS Core and Database Client Plug-in" [Starting]
                                com.adobe.coldfusion.rds.client.nl1 (1.0.1.v20100112266797) "Nl1 Fragment" [Resolved]
                                com.adobe.flash.codemodel.core (4.0.1.277662) "Adobe Flash CodeModel Core" [Active]
                                com.adobe.flash.codemodel.osgi (4.0.1.277662) "Code Model OSGI Support" [Active]
                                com.adobe.flash.profiler (4.0.1.277662) "Adobe Flash Profiler" [Active]
                                com.adobe.flash.profiler.nl1 (4.0.1.277662) "Adobe Flash Profiler Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.ajaxbridge (4.0.1.277662) "Adobe Flash Builder Ajaxbridge" [Active]
                                com.adobe.flexbuilder.ajaxbridge.nl1 (4.0.1.277662) "Adobe Flash Builder Ajaxbridge Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.as.editor (4.0.1.277662) "Adobe Flash Builder ActionScript Editor" [Active]
                                com.adobe.flexbuilder.as.editor.nl1 (4.0.1.277662) "Adobe Flash Builder ActionScript Editor Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.axis2 (4.0.1.277662) "Adobe Flash Builder AXIS 2" [Starting]
                                com.adobe.flexbuilder.axis2.nl1 (4.0.1.277662) "Adobe Flash Builder AXIS 2 Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.codemodel (4.0.1.277662) "Adobe Flex IDE CodeModel" [Resolved]
                                com.adobe.flexbuilder.codemodel.nl1 (4.0.1.277662) "Adobe Flash Builder CodeModel Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.crimson (4.0.1.277662) "Adobe Flash Builder Crimson" [Resolved]
                                com.adobe.flexbuilder.crimson.nl1 (4.0.1.277662) "Adobe Flash Builder Crimson Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.css.editor (4.0.1.277662) "Adobe Flash Builder CSS Editor" [Starting]
                                com.adobe.flexbuilder.css.editor.nl1 (4.0.1.277662) "Adobe Flash Builder CSS Editor Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.DCDService (4.0.1.277662) "Adobe Flash Builder DCDService" [Starting]
                                com.adobe.flexbuilder.DCDService.nl1 (4.0.1.277662) "Adobe Flash Builder DCDService Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.dcrad (4.0.1.277662) "Adobe Flash Builder Data Centric RAD" [Active]
                                com.adobe.flexbuilder.dcrad.derived (4.0.1.277662) "Adobe Flash Builder Data Centric RAD Derived Sources" [Starting]
                                com.adobe.flexbuilder.dcrad.nl1 (4.0.1.277662) "Adobe Flash Builder DCRAD Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.debug (4.0.1.277662) "Adobe Flash Builder Debug Model" [Active]
                                com.adobe.flexbuilder.debug.e33 (4.0.1.277662) "Adobe Flash Builder Debug Fragment for Eclipse 3.3" [Resolved]
                                com.adobe.flexbuilder.debug.nl1 (4.0.1.277662) "Adobe Flash Builder Debug Model Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.debug.ui (4.0.1.277662) "Adobe Flash Builder Debug UI" [Active]
                                com.adobe.flexbuilder.debug.ui.actions (4.0.1.277662) "Adobe Flash Builder Debug UI Actions Fragment" [Resolved]
                                com.adobe.flexbuilder.debug.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Debug Model UI Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.designview (4.0.1.277662) "Adobe Flash Builder Designview" [Starting]
                                com.adobe.flexbuilder.designview.nl1 (4.0.1.277662) "Adobe Flash Builder Designview Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.editorcore (4.0.1.277662) "Adobe Flash Builder Editor Core" [Active]
                                com.adobe.flexbuilder.editorcore.nl1 (4.0.1.277662) "Adobe Flash Builder Editor Core Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.editors.derived (4.0.1.277662) "Adobe Flash Builder Editors Derived" [Active]
                                com.adobe.flexbuilder.editors.derived.nl1 (4.0.1.277662) "Adobe Flash Builder Editors Derived Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.exportimport (4.0.1.277662) "Adobe Flash Builder Exportimport" [Active]
                                com.adobe.flexbuilder.exportimport.nl1 (4.0.1.277662) "Adobe Flash Builder Exportimport Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.flashbridge (4.0.1.277662) "Flash IDE Plug-in" [Active]
                                com.adobe.flexbuilder.flashbridge.nl1 (4.0.1.277662) "Flash IDE Plug-in Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.flex (4.0.1.277662) "Adobe Flash Builder Flex SDKs" [Resolved]
                                com.adobe.flexbuilder.flexunit (4.0.1.277662) "Adobe Flash Builder FlexUnit UI" [Active]
                                com.adobe.flexbuilder.flexunit.derived (4.0.1.277662) "Adobe Flash Builder FlexUnit Derived" [Starting]
                                com.adobe.flexbuilder.flexunit.nl1 (4.0.1.277662) "Adobe Flash Builder FlexUnit Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.help (4.0.1.277662) "Adobe Flash Builder Help" [Starting]
                                com.adobe.flexbuilder.help.nl1 (4.0.1.277662) "Adobe Flash Builder Help - Localized" [Resolved]
                                com.adobe.flexbuilder.importartwork (4.0.1.277662) "Adobe Flash Builder Import Artwork" [Active]
                                com.adobe.flexbuilder.importartwork.nl1 (4.0.1.277662) "Adobe Flash Builder Import Artwork Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.json (4.0.1.277662) "Adobe Flash Builder JSON" [Starting]
                                com.adobe.flexbuilder.launching.ui (4.0.1.277662) "Adobe Flash Builder Launching UI" [Active]
                                com.adobe.flexbuilder.launching.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Launching UI Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.monitors.network (4.0.1.277662) "Adobe Flash Builder Network Monitor" [Starting]
                                com.adobe.flexbuilder.monitors.network.nl1 (4.0.1.277662) "Adobe Flash Builder Network Monitor Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.multisdk (4.0.1.277662) "Adobe Flash Builder Multi-SDK" [Active]
                                com.adobe.flexbuilder.mxml.editor (4.0.1.277662) "Adobe Flash Builder MXML Editor" [Active]
                                com.adobe.flexbuilder.mxml.editor.nl1 (4.0.1.277662) "Adobe Flash Builder MXML Editor Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.mxmlmodel (4.0.1.277662) "Adobe Flash Builder MXML Model" [Active]
                                com.adobe.flexbuilder.project (4.0.1.277662) "Adobe Flash Builder Project" [Active]
                                com.adobe.flexbuilder.project.e35 (1.0.0.201001080934) "Adobe Flash Builder Project for Eclipse 3.5" [Resolved]
                                com.adobe.flexbuilder.project.nl1 (4.0.1.277662) "Adobe Flash Builder Project Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.project.ui (4.0.1.277662) "Adobe Flash Builder Project UI" [Active]
                                com.adobe.flexbuilder.project.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Project UI Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.BlazeDSService (4.0.1.277662) "Adobe Flash Builder BlazeDSService" [Starting]
                                com.adobe.flexbuilder.services.CFService (4.0.1.277662) "Adobe Flash Builder CFService" [Starting]
                                com.adobe.flexbuilder.services.CFService.nl1 (4.0.1.277662) "Adobe Flash Builder CFService NL1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.HTTPService (4.0.1.277662) "Adobe Flash Builder HTTPService" [Starting]
                                com.adobe.flexbuilder.services.HTTPService.nl1 (4.0.1.277662) "Adobe Flash Builder HTTPService NL1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.J2EEService (4.0.1.277662) "Adobe Flash Builder J2EEService" [Starting]
                                com.adobe.flexbuilder.services.J2EEService.nl1 (4.0.1.277662) "Adobe Flash Builder J2EEService Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.LCDSService (4.0.1.277662) "Adobe Flash Builder LCDSService" [Starting]
                                com.adobe.flexbuilder.services.PHPService (4.0.1.277662) "Adobe Flash Builder PHPService" [Starting]
                                com.adobe.flexbuilder.services.PHPService.nl1 (4.0.1.277662) "Adobe Flash Builder PHPService NL1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.StaticContentService (4.0.1.277662) "Adobe Flash Builder StaticContentService" [Starting]
                                com.adobe.flexbuilder.services.StaticContentService.nl1 (4.0.1.277662) "Adobe Flash Builder StaticContentService Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.services.WEBService (4.0.1.277662) "Adobe Flash Builder WEBService" [Starting]
                                com.adobe.flexbuilder.services.WEBService.derived (4.0.1.277662) "Adobe Flash Builder WEBService Derived Sources" [Starting]
                                com.adobe.flexbuilder.services.WEBService.nl1 (4.0.1.277662) "Adobe Flash Builder WEBService NL1 Fragment" [Resolved]
                                com.adobe.flexbuilder.standalone (4.0.1.277662) "Adobe Flash Builder Standalone" [Active]
                                com.adobe.flexbuilder.standalone.nl1 (4.0.1.277662) "Adobe Flash Builder Standalone Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.tengine (4.0.1.277662) "Adobe Flash Builder Tengine" [Starting]
                                com.adobe.flexbuilder.tengine.nl1 (4.0.1.277662) "Adobe Flash Builder Tengine Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.ui (4.0.1.277662) "Adobe Flash Builder Global UI" [Active]
                                com.adobe.flexbuilder.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Global UI Nl1 Fragment" [Resolved]
                                com.adobe.flexbuilder.utils.osnative (4.0.1.277662) "Adobe Flash Builder OS Native Utils" [Active]
                                com.adobe.flexbuilder.utils.osnative.win (4.0.1.277662) "Adobe Flash Builder OS Native Utils Windows Fragment" [Resolved]
                                com.adobe.flexide.amt (4.0.1.277662) "Adobe Flash Builder AMT" [Active]
                                com.adobe.flexide.as.core (4.0.1.277662) "Adobe Flash Builder ActionScript Core" [Active]
                                com.adobe.flexide.as.core.nl1 (4.0.1.277662) "Adobe Flash Builder ActionScript Core Nl1 Fragment" [Resolved]
                                com.adobe.flexide.communityhelp (4.0.1.277662) "CommunityHelp Plug-in" [Starting]
                                com.adobe.flexide.communityhelp.nl1 (4.0.1.277662) "Adobe Common CommunityHelp Nl1 Fragment" [Resolved]
                                com.adobe.flexide.css.core (4.0.1.277662) "Adobe Flash Builder CSS Editor Core" [Active]
                                com.adobe.flexide.css.core.nl1 (4.0.1.277662) "Adobe Flash Builder CSS Editor Core Nl1 Fragment" [Resolved]
                                com.adobe.flexide.designitems (4.0.1.277662) "Adobe Flash Builder DesignItems" [Starting]
                                com.adobe.flexide.editorcore (4.0.1.277662) "Adobe Flash Builder Editor Core" [Active]
                                com.adobe.flexide.editorcore.nl1 (4.0.1.277662) "Adobe Flash Builder Editor Core Nl1 Fragment" [Resolved]
                                com.adobe.flexide.embeddedplayer (4.0.1.277662) "Adobe Flash Builder Embedded Flash Player" [Starting]
                                com.adobe.flexide.exportimport (4.0.1.277662) "Exportimport" [Starting]
                                com.adobe.flexide.exportimport.nl1 (4.0.1.277662) "Export Import Nl1 Fragment" [Resolved]
                                com.adobe.flexide.externaleditors (4.0.1.277662) "Adobe Flash Builder External Editors" [Active]
                                com.adobe.flexide.externaleditors.nl1 (4.0.1.277662) "Adobe Flash Builder External Editors Nl1 Fragment" [Resolved]
                                com.adobe.flexide.fonts (4.0.1.277662) "Fonts" [Starting]
                                com.adobe.flexide.launching (4.0.1.277662) "Adobe Flash Builder Launching" [Active]
                                com.adobe.flexide.launching.nl1 (4.0.1.277662) "Adobe Flash Builder Launching Nl1 Fragment" [Resolved]
                                com.adobe.flexide.multisdk.nl1 (4.0.1.277662) "Adobe Flash Builder Multi-SDK Nl1 Fragment" [Resolved]
                                com.adobe.flexide.mxml.core (4.0.1.277662) "Adobe Flash Builder MXML Core" [Active]
                                com.adobe.flexide.mxml.core.nl1 (4.0.1.277662) "Adobe Flash Builder MXML Core Nl1 Fragment" [Resolved]
                                com.adobe.flexide.nativelibs (4.0.1.277662) "Adobe Flash Builder Native Libraries" [Active]
                                com.adobe.flexide.playerview (4.0.1.277662) "Adobe Flash Builder Playerview" [Starting]
                                com.adobe.flexide.refactoring.core (4.0.1.277662) "Adobe Flash Builder Refactoring Core" [Starting]
                                com.adobe.flexide.refactoring.core.nl1 (4.0.1.277662) "Adobe Flash Builder Refactoring Core Nl1 Fragment" [Resolved]
                                com.adobe.model.core (1.0.2.v20100315273147) "Adobe Data Model Core Wrapper" [Active]
                                com.collabnet.subversion.merge (2.1.0) "CollabNet Subversion Merge Client" [Starting]
                                com.crispico.flexbridge (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Flexbridge" [Resolved]
                                com.crispico.flower.mp (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Core" [Resolved]
                                com.crispico.flower.mp.dependencies.internal (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Internal Dependencies" [Active]
                                com.crispico.flower.mp.eclipse (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Eclipse" [Active]
                                com.crispico.flower.mp.eclipse.compare.base (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Compare Base" [Starting]
                                com.crispico.flower.mp.eclipse.compare.codesync (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Compare CodeSync" [Starting]
                                com.crispico.flower.mp.eclipse.uml4as (1.0.0.M0_2010-06-11) "Flower Modeling Platform - UML4AS" [Active]
                                com.crispico.flower.mp.metamodel.classmetamodel (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Class Metamodel" [Resolved]
                                com.crispico.flower.mp.metamodel.codesync (1.0.0.M0_2010-06-11) "Flower Modeling Platform - CodeSync Metamodel" [Active]
                                com.crispico.flower.mp.metamodel.codesyncas (1.0.0.M0_2010-06-11) "Flower Modeling Platform - CodeSync AS Metamodel" [Active]
                                com.crispico.flower.mp.metamodelset.uml4asfile (1.0.0.M0_2010-06-11) "Flower Modeling Platform - UML4AS File Metamodel Set" [Resolved]
                                com.crispico.flower.mp.propertieseditor (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Properties Editor" [Starting]
                                com.ibm.icu (4.0.1.v20090822) "International Components for Unicode for Java (ICU4J)" [Active]
                                com.idefactory.enterprisehelp (1.0.8.beta) "Enterprise IDE Help" [Starting]
                                com.idefactory.fxsdk (1.0.1) "Enterprise IDE Fx Sdk" [Active]
                                com.idefactory.rhino (1.0.0) "Enterprise IDE Rhino" [Starting]
                                com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
                                com.sun.jna (3.2.3) "JNA Library Plug-in" [Starting]
                                FlexASDocGenCommand (0.7.4) "FlexASDocGenCommand Plug-in" [Starting]
                                FlexPrettyPrintCommand (0.7.4) "FlexPrettyPrintCommand Plug-in" [Active]
                                java_cup.runtime (0.10.0.v200803061811) "Java Cup" [Resolved]
                                javax.activation (1.1.0.v200906290531) "Apache Geronimo Activation Plug-in" [Resolved]
                                javax.mail (1.4.0.v200905040518) "Javax Mail Plug-in" [Resolved]
                                javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
                                javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
                                javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
                                javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
                                javax.xml.rpc (1.1.0.v200905122109) "JAX-RPC" [Resolved]
                                javax.xml.soap (1.2.0.v200905122109) "SAAJ" [Resolved]
                                net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG" [Resolved]
                                org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
                                org.apache.axis (1.4.0.v200905122109) "Apache Web Services" [Resolved]
                                org.apache.bcel (5.2.0.v200803061811) "Apache BCEL" [Resolved]
                                org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec Plug-in" [Resolved]
                                org.apache.commons.collections (3.2.0.v200803061811) "Apache Commons Collections" [Resolved]
                                org.apache.commons.discovery (0.2.0.v200905122109) "Jakarta-Commons Discovery" [Resolved]
                                org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
                                org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
                                org.apache.commons.jxpath (1.2.0.v20080604-1500) "Apache Commons JXPath" [Resolved]
                                org.apache.commons.lang (2.4.0.v20081016-1030) "Apache Jakarta Commons Lang" [Resolved]
                                org.apache.commons.lang (2.1.0.v200803061811) "Apache Jakarta Commons Lang" [Resolved]
                                org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
                                org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in" [Resolved]
                                org.apache.log4j (1.2.13.v200903072027) "Apache Jakarta log4j Plug-in" [Resolved]
                                org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
                                org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis" [Resolved]
                                org.apache.oro (2.0.8.v200903061218) "Apache Jakarta ORO" [Resolved]
                                org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
                                org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
                                org.apache.xalan (2.7.1.v200905122109) "Xalan-Java" [Resolved]
                                org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
                                org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver" [Resolved]
                                org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons Serializer" [Resolved]
                                org.eclipse.ant.core (3.2.100.v20090817_r351) "Ant Build Tool Core" [Starting]
                                org.eclipse.ant.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ant.ui (3.4.2.v20091204_r352) "Ant UI" [Starting]
                                org.eclipse.compare (3.5.0.I20090514-0808) "Compare Support" [Starting]
                                org.eclipse.compare.core (3.5.0.I20090430-0408) "Core Compare Support" [Starting]
                                org.eclipse.compare.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.compare.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.compare.win32 (1.0.0.I20090430-0408) "Compare Support for Word" [Starting]
                                org.eclipse.compare.win32.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
                                org.eclipse.core.boot.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.commands (3.5.0.I20090525-2000) "Commands" [Resolved]
                                org.eclipse.core.commands.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.contenttype (3.4.1.R35x_v20090826-0451) "Eclipse Content Mechanism" [Active]
                                org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.databinding (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
                                org.eclipse.core.databinding.beans (1.2.0.I20090525-2000) "JFace Data Binding for JavaBeans" [Resolved]
                                org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.databinding.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.databinding.observable (1.2.0.M20090902-0800) "JFace Data Binding Observables" [Active]
                                org.eclipse.core.databinding.property (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
                                org.eclipse.core.expressions (3.4.100.v20090429-1800) "Expression Language" [Active]
                                org.eclipse.core.expressions.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.filebuffers (3.5.0.v20090526-2000) "File Buffers" [Active]
                                org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.filesystem (1.2.0.v20090507) "Core File Systems" [Active]
                                org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File System for Windows" [Resolved]
                                org.eclipse.core.jobs (3.4.100.v20090429-1800) "Eclipse Jobs Mechanism" [Active]
                                org.eclipse.core.jobs.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.net (1.2.1.r35x_20090812-1200) "Internet Connection Management" [Active]
                                org.eclipse.core.net.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.net.win32.x86 (1.0.0.I20080909) "Proxy for Windows" [Resolved]
                                org.eclipse.core.resources (3.5.1.R35x_v20090826-0451) "Core Resource Management" [Active]
                                org.eclipse.core.resources.compatibility (3.4.0.v20090505) "Core Resource Management Compatibility Fragment" [Resolved]
                                org.eclipse.core.resources.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.resources.win32.x86 (3.5.0.v20081020) "Core Resource Management Win32 Fragment" [Resolved]
                                org.eclipse.core.runtime (3.5.0.v20090525) "Core Runtime" [Active]
                                org.eclipse.core.runtime.compatibility (3.2.0.v20090413) "Core Runtime Plug-in Compatibility" [Active]
                                org.eclipse.core.runtime.compatibility.auth (3.2.100.v20090413) "Authorization Compatibility Plug-in" [Active]
                                org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.runtime.compatibility.registry (3.2.200.v20090429-1800) "Eclipse Registry Compatibility Fragment" [Resolved]
                                org.eclipse.core.runtime.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.core.variables (3.2.200.v20090521) "Core Variables" [Starting]
                                org.eclipse.core.variables.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.cvs (1.0.300.v200909170800) "Eclipse CVS Client" [Starting]
                                org.eclipse.datatools.connectivity (1.1.3.v201001230803) "Data Tools Platform Connectivity Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
                                org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.oda (3.2.2.v201001270833) "DTP Open Data Access" [Starting]
                                org.eclipse.datatools.connectivity.oda.consumer (3.2.2.v201001261113) "DTP ODA Consumer Helper Component Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.oda.design (3.2.2.v201001210350) "DTP ODA Design Session Model" [Starting]
                                org.eclipse.datatools.connectivity.oda.design.ui (3.2.2.v201001210350) "DTP ODA Designer UI Framework Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
                                org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
                                org.eclipse.datatools.connectivity.oda.profile (3.2.2.v201001210350) "DTP ODA Connection Profile Framework Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.oda.template.ui (3.2.0.v200906020553) "DTP ODA New Plug-in Template Wizard" [Starting]
                                org.eclipse.datatools.connectivity.sqm.core (1.1.1.v201001180200) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.sqm.core.ui (1.1.100.v200910270525) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200910270503) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.ui (1.1.5.v201001190218) "Data Tools Platform Connectivity UI Plug-in" [Starting]
                                org.eclipse.datatools.connectivity.ui.dse (1.1.3.v201001270323) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
                                org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
                                org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
                                org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.luw (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.3.v200906161800) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition (1.0.3.v200906161800) "DB2 UDB Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200906020900) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.3.v200906161800) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.ingres.ui (1.0.0.v200906111150) "Ingres DTP UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200909240342) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
                                org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
                                org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.mysql (1.0.2.v201002041110) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.oda.ws (1.2.2.v201001131420) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
                                org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201001260400) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
                                org.eclipse.datatools.enablement.oda.xml (1.2.1.v201001151620) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
                                org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201001191820) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
                                org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
                                org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.100.v200906161800) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
                                org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
                                org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041110) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041110) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
                                org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900) "Sybase ASA SQL Model" [Starting]
                                org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
                                org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
                                org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900) "Sybase ASE Model Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900) "Sybase Model Plug-in" [Starting]
                                org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
                                org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
                                org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200906022249) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
                                org.eclipse.datatools.modelbase.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
                                org.eclipse.datatools.modelbase.sql (1.0.3.v200912150851) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
                                org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200906022249) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
                                org.eclipse.datatools.modelbase.sql.query (1.0.2.v201002020730) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
                                org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
                                org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200906022249) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
                                org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-sensitive Help" [Starting]
                                org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.data.core (1.1.0.v200910161545) "Data Core Plugin" [Starting]
                                org.eclipse.datatools.sqltools.data.ui (1.1.2.v200912080845) "Data UI Plugin" [Starting]
                                org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
                                org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
                                org.eclipse.datatools.sqltools.editor.core (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200906022302) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
                                org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200906022302) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
                                org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
                                org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.result (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
                                org.eclipse.datatools.sqltools.result.ui (1.0.2.v201002011830) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.routineeditor.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.0.200810071) "Schema Object Editor Framework" [Starting]
                                org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v201001200600) "SQL Builder" [Starting]
                                org.eclipse.datatools.sqltools.sqleditor (1.0.1.v200912241345) "Eclipse Data Tools Platform SQL Editor" [Starting]
                                org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200906022302) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
                                org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200906022302) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
                                org.eclipse.debug.core (3.5.0.v20090526-1600) "Debug Core" [Active]
                                org.eclipse.debug.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.debug.ui (3.5.1.v20090811_r351) "Debug UI" [Active]
                                org.eclipse.debug.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.draw2d (3.5.2.v20091126-1908) "Graphical Editing Framework Draw2d" [Starting]
                                org.eclipse.ecf (3.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Active]
                                org.eclipse.ecf.filetransfer (3.0.0.v20090831-1906) "ECF Filetransfer API" [Active]
                                org.eclipse.ecf.identity (3.0.0.v20090831-1906) "ECF Identity API" [Active]
                                org.eclipse.ecf.provider.filetransfer (3.0.1.v20090831-1906) "ECF Filetransfer Provider" [Active]
                                org.eclipse.ecf.provider.filetransfer.httpclient (3.0.1.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Active]
                                org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Resolved]
                                org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20090831-1906) "ECF Filetransfer Provider" [Resolved]
                                org.eclipse.ecf.ssl (1.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Resolved]
                                org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
                                org.eclipse.emf.ant (2.4.0.v200906151043) "EMF Ant Tasks" [Starting]
                                org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation" [Starting]
                                org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code Generator" [Starting]
                                org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code Generator UI" [Starting]
                                org.eclipse.emf.codegen.ui (2.5.0.v200906151043) "EMF Code Generation UI" [Starting]
                                org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common" [Active]
                                org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI" [Starting]
                                org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter" [Starting]
                                org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding" [Starting]
                                org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data Binding" [Starting]
                                org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore" [Active]
                                org.eclipse.emf.ecore.change (2.5.0.v200906151043) "EMF Change Model" [Starting]
                                org.eclipse.emf.ecore.change.edit (2.5.0.v200906151043) "EMF Change Edit" [Starting]
                                org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit" [Starting]
                                org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor" [Starting]
                                org.eclipse.emf.ecore.xmi (2.5.0.v200906151043) "EMF XML/XMI Persistence" [Starting]
                                org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit" [Starting]
                                org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI" [Starting]
                                org.eclipse.emf.exporter (2.5.0.v200906151043) "EMF Model Exporter" [Starting]
                                org.eclipse.emf.importer (2.5.0.v200906151043) "EMF Model Importer" [Starting]
                                org.eclipse.emf.importer.ecore (2.4.0.v200906151043) "EMF Ecore Importer" [Starting]
                                org.eclipse.emf.importer.java (2.5.0.v200906151043) "EMF Annotated Java Importer" [Starting]
                                org.eclipse.emf.importer.rose (2.5.0.v200906151043) "EMF Rose Importer" [Starting]
                                org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping" [Starting]
                                org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping" [Starting]
                                org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore Mapping Editor" [Starting]
                                org.eclipse.emf.mapping.ecore2ecore (2.5.0.v200906151043) "EMF Ecore to Ecore Mapping" [Starting]
                                org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200906151043) "EMF Ecore to Ecore Mapping Editor" [Starting]
                                org.eclipse.emf.mapping.ecore2xml (2.5.0.v200906151043) "EMF Ecore to XML Mapping" [Starting]
                                org.eclipse.emf.mapping.ecore2xml.ui (2.5.0.v200906151043) "EMF Ecore to XML Mapping Editor" [Starting]
                                org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI" [Starting]
                                org.eclipse.equinox.app (1.2.0.v20090520-1800) "Equinox Application Container" [Active]
                                org.eclipse.equinox.common (3.5.1.R35x_v20090807-1100) "Common Eclipse Runtime" [Active]
                                org.eclipse.equinox.common.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.concurrent (1.0.1.R35x_v20100209) "Equinox Concurrent API" [Starting]
                                org.eclipse.equinox.ds (1.1.1.R35x_v20090806) "Declarative Services" [Active]
                                org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.frameworkadmin (1.0.100.v20090520-1905) "Equinox Framework Admin" [Active]
                                org.eclipse.equinox.frameworkadmin.equinox (1.0.100.v20090520-1905) "Equinox Framework Admin for Equinox" [Active]
                                org.eclipse.equinox.http.jetty (2.0.0.v20090520-1800) "Jetty Http Service" [Starting]
                                org.eclipse.equinox.http.registry (1.0.200.v20090520-1800) "Http Service Registry Extensions" [Resolved]
                                org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.http.servlet (1.0.200.v20090520-1800) "Http Services Servlet" [Starting]
                                org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.jsp.jasper (1.0.200.v20090520-1800) "Jasper Jsp Support Bundle" [Starting]
                                org.eclipse.equinox.jsp.jasper.registry (1.0.100.v20090520-1800) "Jasper Jsp Registry Support Plug-in" [Starting]
                                org.eclipse.equinox.launcher (1.0.201.R35x_v20090715) "Equinox Launcher" [Resolved]
                                org.eclipse.equinox.launcher.win32.win32.x86 (1.0.200.v20090519) "Equinox Launcher Win32 X86 Fragment" [Resolved]
                                org.eclipse.equinox.p2.artifact.repository (1.0.101.R35x_v20090721) "Equinox Provisioning Artifact Repository Support" [Active]
                                org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.console (1.0.100.v20090520-1905) "Equinox Provisioning Console" [Starting]
                                org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.core (1.0.101.R35x_v20090819) "Equinox Provisioning Core" [Active]
                                org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.director (1.0.100.v20090520-1905) "Equinox Provisioning Director" [Active]
                                org.eclipse.equinox.p2.director.app (1.0.100.v20090521-1912) "Equinox Provisioning Director Application" [Starting]
                                org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.directorywatcher (1.0.100.v20090525) "Equinox Provisioning Directory Watcher" [Active]
                                org.eclipse.equinox.p2.engine (1.0.101.R35x_v20090825) "Equinox Provisioning Engine" [Active]
                                org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.exemplarysetup (1.0.100.v20090520-1905) "Equinox Provisioning Exemplary Setup" [Active]
                                org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.extensionlocation (1.0.100.v20090520-1905) "Extension Location Repository Support" [Active]
                                org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.garbagecollector (1.0.100.v20090520-1905) "Provisioning Garbage Collector" [Active]
                                org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.jarprocessor (1.0.100.v20090520-1905) "Equinox Provisioning JAR Processor" [Resolved]
                                org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.metadata (1.0.100.v20090525) "Equinox Provisioning Metadata" [Active]
                                org.eclipse.equinox.p2.metadata.generator (1.0.100.v20090520-1905) "Equinox Provisioning Metadata Generator" [Starting]
                                org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.metadata.repository (1.0.101.R35x_v20090812) "Equinox Provisioning Metadata Repository" [Active]
                                org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.publisher (1.0.0.v20090527-1812) "Equinox Provisioning Publisher" [Active]
                                org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.reconciler.dropins (1.0.100.v20090520-1905) "Dropin Reconciler Plug-in" [Active]
                                org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.repository (1.0.1.v20090901-1041) "Equinox Provisioning Repository" [Active]
                                org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.repository.tools (1.0.1.R35x_v20090806) "Equinox p2 repository tools." [Starting]
                                org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.touchpoint.eclipse (1.0.101.R35x_20090820-1821) "Equinox Provisioning Eclipse Touchpoint" [Active]
                                org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.touchpoint.natives (1.0.101.R35x_v20090806) "Equinox Provisioning Native Touchpoint" [Starting]
                                org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.ui (1.0.101.R35x_v20090819) "Equinox Provisioning UI Support" [Active]
                                org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.ui.sdk (1.0.100.v20090520-1905) "Equinox Provisioning Platform Update Support" [Active]
                                org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20090520-1905) "Equinox Provisioning Platform Automatic Update Support" [Active]
                                org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.updatechecker (1.1.0.v20090520-1905) "Equinox Provisioning Update Checker" [Active]
                                org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.p2.updatesite (1.0.100.v20090525) "Update site repository adapter bundle (Incubation)" [Active]
                                org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.preferences (3.2.300.v20090520-1800) "Eclipse Preferences Mechanism" [Active]
                                org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.registry (3.4.100.v20090520-1800) "Extension Registry Support" [Active]
                                org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.security (1.0.100.v20090520-1800) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
                                org.eclipse.equinox.security.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.security.ui (1.0.100.v20090520-1800) "Equinox Security Default UI" [Starting]
                                org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.equinox.security.win32.x86 (1.0.100.v20090520-1800) "Windows Data Protection services integration" [Resolved]
                                org.eclipse.equinox.simpleconfigurator (1.0.101.R35x_v20090807-1100) "Simple Configurator" [Active]
                                org.eclipse.equinox.simpleconfigurator.manipulator (1.0.100.v20090520-1905) "Simple Configurator Manipulator" [Active]
                                org.eclipse.equinox.util (1.0.100.v20090520-1800) "Equinox Util Bundle" [Active]
                                org.eclipse.gef (3.5.1.v20090910-2020) "Graphical Editing Framework GEF" [Starting]
                                org.eclipse.help (3.4.1.v20090805_35x) "Help System Core" [Active]
                                org.eclipse.help.appserver (3.1.400.v20090429_1800) "Help Application Server" [Starting]
                                org.eclipse.help.appserver.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.help.base (3.4.0.v200909170800) "Help System Base" [Starting]
                                org.eclipse.help.base.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.help.ui (3.4.1.v20090819_35x) "Help System UI" [Starting]
                                org.eclipse.help.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.help.webapp (3.4.1.v20090819_35x) "Help System Webapp" [Starting]
                                org.eclipse.help.webapp.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jdt (3.5.2.v201002111343) "Eclipse Java Development Tools" [Resolved]
                                org.eclipse.jdt.apt.core (3.3.202.R35x_v20091130-2300) "Java Annotation Processing Core" [Starting]
                                org.eclipse.jdt.apt.pluggable.core (1.0.201.R35x_v20090925-1100) "Java Compiler Apt IDE" [Starting]
                                org.eclipse.jdt.apt.ui (3.3.200.v20090930-2100_R35x) "Java Annotation Processing UI" [Starting]
                                org.eclipse.jdt.compiler.apt (1.0.201.R35x_v20090925-1100) "Java Compiler Apt" [Resolved]
                                org.eclipse.jdt.compiler.tool (1.0.100.v_981_R35x) "Java Compiler Tool Support" [Resolved]
                                org.eclipse.jdt.core (3.5.2.v_981_R35x) "Java Development Tools Core" [Active]
                                org.eclipse.jdt.core.manipulation (1.3.0.v20090603) "Java Code Manipulation Functionality" [Starting]
                                org.eclipse.jdt.debug (3.5.0.v20090526) "JDI Debug Model" [Active]
                                org.eclipse.jdt.debug.ui (3.4.1.v20090811_r351) "JDI Debug UI" [Starting]
                                org.eclipse.jdt.doc.user (3.5.2.r352_v20091015) "Eclipse Java development user guide" [Resolved]
                                org.eclipse.jdt.junit (3.5.2.r352_v20100113-0800) "Java Development Tools JUnit support" [Starting]
                                org.eclipse.jdt.junit.runtime (3.4.100.v20090513-2000) "Java Development Tools JUnit runtime support" [Resolved]
                                org.eclipse.jdt.junit4.runtime (1.1.0.v20090513-2000) "Java Development Tools JUnit4 runtime support" [Resolved]
                                org.eclipse.jdt.launching (3.5.1.v20100108_r352) "Java Development Tools Launching Support" [Active]
                                org.eclipse.jdt.ui (3.5.2.r352_v20100106-0800) "Java Development Tools UI" [Starting]
                                org.eclipse.jem (2.0.301.v201001252130) "Java EMF Model" [Starting]
                                org.eclipse.jem.proxy (2.0.201.v200908101600) "Java EMF Model Proxy Support" [Starting]
                                org.eclipse.jem.util (2.0.201.v201001252130) "Java EMF Model Utilities" [Active]
                                org.eclipse.jem.workbench (2.0.201.v200911302230) "Java EMF Model Workbench Support" [Starting]
                                org.eclipse.jface (3.5.1.M20090826-0800) "JFace" [Active]
                                org.eclipse.jface.databinding (1.3.1.M20090826-0800) "JFace Data Binding for SWT and JFace" [Resolved]
                                org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jface.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jface.text (3.5.1.r351_v20090708-0800) "JFace Text" [Resolved]
                                org.eclipse.jface.text.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jpt.branding (2.2.2.v200911250220) "Dali Java Persistence Tools" [Resolved]
                                org.eclipse.jpt.core (2.2.1.v200908270220) "Dali Java Persistence Tools - Core" [Starting]
                                org.eclipse.jpt.db (1.2.102.v200911250220) "Dali Java Persistence Tools - DB" [Starting]
                                org.eclipse.jpt.db.ui (1.1.100.v200906070220) "Dali Java Persistence Tools - DB UI" [Resolved]
                                org.eclipse.jpt.doc.isv (1.2.0.v200906050220) "Dali Java Persistence Tools Doc - ISV" [Starting]
                                org.eclipse.jpt.doc.user (1.1.1.v200908270220) "Java Persistence Documentation - Doc" [Resolved]
                                org.eclipse.jpt.eclipselink.branding (2.2.2.v200911250220) "Dali Java Persistence Tools - EclipseLink Support" [Resolved]
                                org.eclipse.jpt.eclipselink.core (1.2.0.v200905310000) "Dali Java Persistence Tools - EclipseLink Support - Core" [Starting]
                                org.eclipse.jpt.eclipselink.core.ddlgen (1.0.200.v200906070220) "Dali Java Persistence Tools - EclipseLink Support - DDL Generation" [Resolved]
                                org.eclipse.jpt.eclipselink.ui (1.2.0.v200905310000) "Dali Java Persistence Tools - EclipseLink Support - UI" [Starting]
                                org.eclipse.jpt.gen (1.3.2.v201001290220) "Dali Java Persistence Tools - Entity Gen" [Resolved]
                                org.eclipse.jpt.ui (2.2.2.v200911250220) "Dali Java Persistence Tools - UI" [Starting]
                                org.eclipse.jpt.utility (1.4.0.v200905310000) "Dali Java Persistence Tools - Utility" [Resolved]
                                org.eclipse.jsch.core (1.1.100.I20090430-0408) "JSch Core" [Starting]
                                org.eclipse.jsch.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jsch.ui (1.1.200.I20090430-0408) "JSch UI" [Starting]
                                org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.jst.common.annotations.controller (1.1.100.v200805140020) "Annotation Controller Plug-in" [Resolved]
                                org.eclipse.jst.common.annotations.core (1.1.200.v201001272230) "Annotation Core Plug-in" [Resolved]
                                org.eclipse.jst.common.frameworks (1.1.301.v201001252130) "Integration Plug-in" [Starting]
                                org.eclipse.jst.common.project.facet.core (1.4.1.v200911141836) "Eclipse Faceted Project Framework JDT Enablement" [Starting]
                                org.eclipse.jst.common.project.facet.ui (1.4.1.v200912011928) "Eclipse Faceted Project Framework JDT Enablement UI" [Starting]
                                org.eclipse.jst.ejb.doc.user (1.1.100.v200810092245) "EJB docs" [Starting]
                                org.eclipse.jst.ejb.ui (1.1.301.v200908131325) "WTP EJB UI Plug-in" [Starting]
                                org.eclipse.jst.ejb.ui.infopop (1.0.200.v200905141725) "EJB infopop" [Starting]
                                org.eclipse.jst.j2ee (1.1.302.v201004131604) "Java EE Component" [Starting]
                                org.eclipse.jst.j2ee.core (1.1.301.v200911302230) "J2EE Core Component" [Starting]
                                org.eclipse.jst.j2ee.doc.user (1.1.100.v200810071436) "J2EE tools documentation" [Resolved]
                                org.eclipse.jst.j2ee.ejb (1.1.301.v201001252130) "EJB component Plug-in" [Starting]
                                org.eclipse.jst.j2ee.ejb.annotation.model (1.1.102.v200805140020) "EJB Annotation Model Plug-in" [Starting]
                                org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.102.v200805140135) "EJB Emitter Plug-in" [Starting]
                                org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.102.v200805140020) "EJB Annotations Ui Plug-in" [Starting]
                                org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.2.0.v200805140020) "Xdoclet Annotations Plug-in" [Starting]
                                org.eclipse.jst.j2ee.infopop (1.0.300.v200805140415) "J2EE tools infopops" [Resolved]
                                org.eclipse.jst.j2ee.jca (1.1.301.v201001252130) "JCA Plug-in" [Starting]
                                org.eclipse.jst.j2ee.jca.ui (1.1.300.v200809052300) "WTP JCA UI Plug-in" [Starting]
                                org.eclipse.jst.j2ee.navigator.ui (1.1.301.v201001252130) "J2EE Extensions to Common Navigator" [Starting]
                                org.eclipse.jst.j2ee.ui (1.1.301.v201001252130) "WTP J2EE UI Plug-in" [Starting]
                                org.eclipse.jst.j2ee.web (1.1.301.v200911302230) "Web Plug-in" [Starting]
                                org.eclipse.jst.j2ee.webservice (1.1.300.v200901220600) "Web Service Plug-in" [Starting]
                                org.eclipse.jst.j2ee.webservice.ui (1.1.300.v200902052230) "WTP Webservice UI Plug-in" [Starting]
                                org.eclipse.jst.j2ee.xdoclet.runtime (1.1.102.v200805140135) "XDocletRuntime Plug-in" [Starting]
                                org.eclipse.jst.jee (1.0.201.v201002021055) "JEE common Plug-in" [Starting]
                                org.eclipse.jst.jee.ejb (1.0.201.v201002021057) "JEE Ejb Plug-in" [Starting]
                                org.eclipse.jst.jee.ui (1.0.201.v201002021208) "Eclipse Java EE Developer Tools" [Starting]
                                org.eclipse.jst.jsf.apache.trinidad.tagsupport (1.1.0.v20090525) "JavaServer Faces Tools - Taglibrary Metadata (Apache Trinidad)" [Starting]
                                org.eclipse.jst.jsf.common (1.1.9.v201001271707) "JavaServer Faces Tools - Common" [Active]
                                org.eclipse.jst.jsf.common.runtime (1.0.201.v20090205) "JavaServer Faces Tools - Common Runtime" [Starting]
                                org.eclipse.jst.jsf.common.ui (1.1.1.v20081209) "JavaServer Faces Tools - Common UI" [Starting]
                                org.eclipse.jst.jsf.core (1.2.5.v201001271707) "JavaServer Faces Tools - Core" [Active]
                                org.eclipse.jst.jsf.facesconfig (1.1.3.v20090902) "JavaServer Faces Tools - FacesConfig Model" [Starting]
                                org.eclipse.jst.jsp.core (1.2.204.v201001270045) "Structured Source JSP Model" [Starting]
                                org.eclipse.jst.jsp.ui (1.1.401.v200908111935) "SSE JSP Source Editor" [Starting]
                                org.eclipse.jst.jsp.ui.infopop (1.0.100.v200805301545) "JSP tools infopops" [Resolved]
                                org.eclipse.jst.pagedesigner (1.2.3.v20100211) "JavaServer Faces Tools - Web Page Editor" [Starting]
                                org.eclipse.jst.pagedesigner.jsf.ui (1.1.4.v20100203) "JavaServer Faces Tools - Pagedesigner UI" [Starting]
                                org.eclipse.jst.pagedesigner.jsp.core (1.1.3.v201002111131) "JavaServer Faces Tools - JSP Core Pagedesigner" [Starting]
                                org.eclipse.jst.server.core (1.2.1.v20100127) "Java Server Support" [Starting]
                                org.eclipse.jst.servlet.ui (1.1.301.v200908101600) "WTP Servlet UI Plug-in" [Starting]
                                org.eclipse.jst.servlet.ui.infopop (1.0.300.v200805140415) "Servlet infopop" [Starting]
                                org.eclipse.jst.ws (1.0.407.v200905191120) "Web Services" [Starting]
                                org.eclipse.jst.ws.axis.consumption.core (1.0.306.v200810082309) "Web service Axis Consumption Core" [Starting]
                                org.eclipse.jst.ws.axis.consumption.ui (1.0.405.v200901261650) "Webservice Axis Consumption UI" [Starting]
                                org.eclipse.jst.ws.axis.creation.ui (1.0.406.v200903031852) "Webservice Axis Creation UI" [Starting]
                                org.eclipse.jst.ws.axis.infopop (1.0.300.v200805140230) "Web services Axis context sensitive help" [Starting]
                                org.eclipse.jst.ws.axis.ui.doc.user (1.1.0.v200806092139) "Axis Web services documentation" [Resolved]
                                org.eclipse.jst.ws.axis2.consumption.core (1.0.104.v200810151442) "Webservice Axis2 Consumption Core Plug-in" [Starting]
                                org.eclipse.jst.ws.axis2.consumption.ui (1.0.102.v200807232000) "Webservice Axis2 Consumption UI Plug-in" [Starting]
                                org.eclipse.jst.ws.axis2.core (1.0.104.v200810151442) "Webservice Axis2 Core Plug-in" [Starting]
                                org.eclipse.jst.ws.axis2.creation.core (1.0.105.v200901220134) "Webservice Axis2 Creation Core Plug-in" [Starting]
                                org.eclipse.jst.ws.axis2.creation.ui (1.0.103.v200807162242) "Webservice Axis2 Creation UI Plug-in" [Starting]
                                org.eclipse.jst.ws.axis2.ui (1.0.302.v200905260749) "Axis2 Tools" [Starting]
                                org.eclipse.jst.ws.axis2.ui.doc.user (1.0.1.v200807302329) "Axis2 Web services documentation" [Resolved]
                                org.eclipse.jst.ws.consumption (1.0.408.v200911241817) "Web Services Consumption" [Starting]
                                org.eclipse.jst.ws.consumption.infopop (1.0.300.v200805140230) "Web services UI" [Resolved]
                                org.eclipse.jst.ws.consumption.ui (1.1.106.v200911241851) "Web Services Consumption Graphical User Interface" [Starting]
                                org.eclipse.jst.ws.consumption.ui.doc.user (1.0.550.v200901232040) "Web service consumption documentation" [Starting]
                                org.eclipse.jst.ws.creation.ejb.ui (1.0.200.v200805140230) "Web Services Creation EJB Graphical User Interface" [Resolved]
                                org.eclipse.jst.ws.creation.ui (1.0.409.v200911241856) "Web Services Creation Graphical User Interface" [Starting]
                                org.eclipse.jst.ws.doc.user (1.0.500.v200809092107) "Web Services UI" [Resolved]
                                org.eclipse.jst.ws.infopop (1.0.300.v200805140230) "Web services UI" [Resolved]
                                org.eclipse.jst.ws.uddiregistry (1.0.400.v200901261650) "Web Services Universal Description Discovery and Integration Registry" [Starting]
                                org.eclipse.jst.ws.ui (1.0.402.v200903111822) "Web Services Graphical User Interface" [Starting]
                                org.eclipse.ltk.core.refactoring (3.5.0.v20090513-2000) "Refactoring Core" [Starting]
                                org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ltk.ui.refactoring (3.4.100.v20090604) "Refactoring UI" [Starting]
                                org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.osgi (3.5.1.R35x_v20090827) "OSGi System Bundle" [Active]
                                org.eclipse.osgi.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.osgi.services (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Services" [Resolved]
                                org.eclipse.osgi.services.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.osgi.util (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Utility Classes" [Resolved]
                                org.eclipse.osgi.util.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.pde (3.4.100.v201002111343) "PDE" [Resolved]
                                org.eclipse.pde.api.tools (1.0.101.v20090714) "API Tools" [Starting]
                                org.eclipse.pde.api.tools.ee.javase16 (1.0.0.v20090407-1030) "Environment Description for JavaSE-1.6" [Resolved]
                                org.eclipse.pde.api.tools.ui (1.0.101.v20090820) "API Tools UI" [Starting]
                                org.eclipse.pde.build (3.5.2.R35x_20100114) "Plug-in Development Environment Build Support" [Starting]
                                org.eclipse.pde.core (3.5.101.v20100104) "PDE Core" [Starting]
                                org.eclipse.pde.doc.user (3.5.0.v20090818) "PDE User Guide" [Resolved]
                                org.eclipse.pde.ds.core (1.0.1.v20100118) "PDE DS Core" [Starting]
                                org.eclipse.pde.ds.ui (1.0.0.v20100209-maintenance) "PDE DS UI" [Starting]
                                org.eclipse.pde.junit.runtime (3.4.0.v20090527) "PDE JUnit Plug-in Test" [Resolved]
                                org.eclipse.pde.runtime (3.4.100.v20090731) "PDE Runtime" [Starting]
                                org.eclipse.pde.ua.core (1.0.0.v20090429-1800) "PDE UA Core" [Starting]
                                org.eclipse.pde.ua.ui (1.0.0.v20090511) "PDE UA UI" [Starting]
                                org.eclipse.pde.ui (3.5.1.v201001121200) "PDE UI" [Starting]
                                org.eclipse.pde.ui.templates (3.4.100.v20090527) "PDE Templates" [Starting]
                                org.eclipse.platform (3.3.201.v200909170800) "Eclipse Platform" [Resolved]
                                org.eclipse.platform.doc.user (3.5.1.r351_v20090821-0800) "Eclipse Workbench User Guide" [Resolved]
                                org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.platform.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.rcp (3.5.0.v200909170800) "Eclipse RCP" [Starting]
                                org.eclipse.search (3.5.1.r351_v20090708-0800) "Search Support" [Active]
                                org.eclipse.search.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.servertools.doc.isv (1.0.100.v20090414) "Server Tools - Developer Guide" [Starting]
                                org.eclipse.swt (3.5.1.v3555a) "Standard Widget Toolkit" [Resolved]
                                org.eclipse.swt.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.swt.win32.win32.x86 (3.5.1.v3555a) "Standard Widget Toolkit for Windows" [Resolved]
                                org.eclipse.team.core (3.5.0.I20090527-0620) "Team Support Core" [Active]
                                org.eclipse.team.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.team.cvs.core (3.3.200.I20090430-0408) "CVS Team Provider Core" [Starting]
                                org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.team.cvs.ssh (3.2.100.I20090508-2000) "CVS SSH Core" [Starting]
                                org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.team.cvs.ssh2 (3.2.200.I20090508-2000) "CVS SSH2" [Starting]
                                org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.team.cvs.ui (3.3.201.R35x_v20090826-0905) "CVS Team Provider UI" [Starting]
                                org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.team.ui (3.5.0.I20090430-0408) "Team Support UI" [Starting]
                                org.eclipse.team.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.text (3.5.0.v20090513-2000) "Text" [Resolved]
                                org.eclipse.text.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui (3.5.1.M20090902-1000) "Eclipse UI" [Active]
                                org.eclipse.ui.browser (3.2.300.v20090526) "Browser Support" [Starting]
                                org.eclipse.ui.browser.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.cheatsheets (3.3.200.v20090526) "Cheat Sheets" [Starting]
                                org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.console (3.4.0.v20090513) "Console" [Starting]
                                org.eclipse.ui.console.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.editors (3.5.0.v20090527-2000) "Default Text Editor" [Active]
                                org.eclipse.ui.editors.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.externaltools (3.2.0.v20090504) "External Tools" [Starting]
                                org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.forms (3.4.1.v20090714_35x) "Eclipse Forms" [Starting]
                                org.eclipse.ui.forms.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.ide (3.5.1.M20090826-0800) "Eclipse IDE UI" [Active]
                                org.eclipse.ui.ide.application (1.0.101.M20090826-0800) "Eclipse IDE UI Application" [Resolved]
                                org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.ide.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.intro (3.3.1.v20090805_35x) "Welcome Framework" [Starting]
                                org.eclipse.ui.intro.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.intro.universal (3.2.300.v20090526) "Universal Welcome" [Starting]
                                org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.navigator (3.4.1.M20090911-1550) "Common Navigator View" [Active]
                                org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.navigator.resources (3.4.1.M20090826-0800) "Navigator Workbench Components" [Starting]
                                org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.net (1.2.1.r35x_20090812-1200) "Internet Connection Management UI" [Active]
                                org.eclipse.ui.net.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.presentations.r21 (3.2.100.I20081007-0800) "R21 Presentation Plug-in" [Starting]
                                org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.views (3.4.1.M20090826-0800) "Views" [Active]
                                org.eclipse.ui.views.log (1.0.100.v20090731) "Log View" [Active]
                                org.eclipse.ui.views.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.views.properties.tabbed (3.5.0.I20090429-1800) "Tabbed Properties View" [Active]
                                org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.win32 (3.2.100.v20090429-1800) "Eclipse UI Win32 Enhancements" [Resolved]
                                org.eclipse.ui.workbench (3.5.1.M20090826-0800a) "Workbench" [Active]
                                org.eclipse.ui.workbench.compatibility (3.2.0.I20090429-1800) "Workbench Compatibility" [Resolved]
                                org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.ui.workbench.texteditor (3.5.0.v20090603) "Text Editor Framework" [Active]
                                org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.update.configurator (3.3.0.v20090312) "Install/Update Configurator" [Active]
                                org.eclipse.update.configurator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.update.core (3.2.300.v20090525) "Install/Update Core" [Active]
                                org.eclipse.update.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.update.core.win32 (3.2.100.v20080107) "Install/Update Core for Windows" [Resolved]
                                org.eclipse.update.scheduler (3.2.200.v20081127) "Automatic Updates Scheduler" [Active]
                                org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.update.ui (3.2.201.R35x_v20090813) "Install/Update UI" [Starting]
                                org.eclipse.update.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
                                org.eclipse.wst.command.env (1.0.408.v200903110045) "Environment Command Framework (headless)" [Starting]
                                org.eclipse.wst.command.env.core (1.0.204.v200805140020) "Environment Command Framework (core)" [Resolved]
                                org.eclipse.wst.command.env.doc.user (1.5.200.v200806092138) "Web services Axis Ant task documentation" [Starting]
                                org.eclipse.wst.command.env.infopop (1.0.100.v200805301544) "Web services UI" [Starting]
                                org.eclipse.wst.command.env.ui (1.1.2.v200811200248) "Environment Command Framework (GUI)" [Starting]
                                org.eclipse.wst.common.api.doc (1.0.1.v200807181737) "Environment API Documentation" [Starting]
                                org.eclipse.wst.common.core (1.1.201.v200806010600) "WST Common Core Plug-in" [Starting]
                                org.eclipse.wst.common.emf (1.1.301.v200908181930) "EMF Utilities" [Starting]
                                org.eclipse.wst.common.emfworkbench.integration (1.1.301.v200908101600) "EMF Workbench Edit Plug-in" [Starting]
                                org.eclipse.wst.common.environment (1.0.301.v200908101600) "Enviornment Plug-in" [Starting]
                                org.eclipse.wst.common.frameworks (1.1.300.v200904160730) "Common Frameworks" [Active]
                                org.eclipse.wst.common.frameworks.ui (1.1.301.v200908101600) "WTP UI Plug-in" [Starting]
                                org.eclipse.wst.common.infopop (1.0.100.v200805301550) "Common WST infopops" [Starting]
                                org.eclipse.wst.common.modulecore (1.1.301.v201001252130) "Modulecore Plug-in" [Starting]
                                org.eclipse.wst.common.project.facet.core (1.4.1.v200911141735) "Eclipse Faceted Project Framework" [Active]
                                org.eclipse.wst.common.project.facet.ui (1.4.1.v200908111817) "Eclipse Faceted Project Framework UI" [Starting]
                                org.eclipse.wst.common.snippets (1.1.301.v201001280015) "Snippets View" [Starting]
                                org.eclipse.wst.common.ui (1.1.402.v200901262305) "Eclipse Base UI extensions" [Starting]
                                org.eclipse.wst.common.uriresolver (1.1.301.v200805140415) "Common URI Resolver Framework" [Starting]
                                org.eclipse.wst.css.core (1.1.301.v200910161432) "Structured Source CSS Model" [Starting]
                                org.eclipse.wst.css.ui (1.0.401.v200907171457) "SSE CSS Source Editor" [Starting]
                                org.eclipse.wst.doc.user (1.2.0.v200806052254) "Master User Doc TOC" [Starting]
                                org.eclipse.wst.dtd.core (1.1.300.v200904181727) "Structured Source DTD Core" [Starting]
                                org.eclipse.wst.dtd.ui (1.0.400.v200904300717) "SSE DTD Source Editor" [Starting]
                                org.eclipse.wst.dtd.ui.infopop (1.0.300.v200805140200) "DTD Editor infopops" [Resolved]
                                org.eclipse.wst.dtdeditor.doc.user (1.0.500.v200904292308) "DTD Editor documentation" [Resolved]
                                org.eclipse.wst.html.core (1.1.300.v200903120608) "Structured Source HTML Model" [Starting]
                                org.eclipse.wst.html.ui (1.0.401.v200908111935) "HTML UI Source Editor" [Starting]
                                org.eclipse.wst.html.ui.infopop (1.0.100.v200805301545) "HTML editor infopops" [Resolved]
                                org.eclipse.wst.internet.cache (1.0.301.v200805140020) "Cache URI Resolver Plug-in" [Starting]
                                org.eclipse.wst.internet.monitor.core (1.0.404.v20090609) "Monitor" [Starting]
                                org.eclipse.wst.internet.monitor.ui (1.0.305.v20100123) "TCP/IP Monitor" [Starting]
                                org.eclipse.wst.jsdt.core (1.0.201.v2010012803) "JavaScript Development Tools Core" [Starting]
                                org.eclipse.wst.jsdt.doc (1.0.200.v200903120608) "JSDT Doc Plugin" [Resolved]
                                org.eclipse.wst.jsdt.manipulation (1.0.100.v200809240707) "JavaScript Code Manipulation Functionality" [Starting]
                                org.eclipse.wst.jsdt.support.firefox (1.0.200.v200904290357) "FireFox Support for JSDT Plugin" [Starting]
                                org.eclipse.wst.jsdt.support.ie (1.0.200.v200904290539) "JSDT Support for Internet Explorer" [Resolved]
                                org.eclipse.wst.jsdt.ui (1.0.201.v2010012803) "JavaScript Developer Tools" [Starting]
                                org.eclipse.wst.jsdt.web.core (1.0.201.v201001221931) "JSDT Web Support Core" [Starting]
                                org.eclipse.wst.jsdt.web.ui (1.0.201.v2010012803) "JSDT Web Support UI" [Starting]
                                org.eclipse.wst.server.core (1.1.102.v20100123) "Server Core" [Starting]
                                org.eclipse.wst.server.discovery (1.0.1.v20100210) "Plug-in Discovery Plug-in" [Starting]
                                org.eclipse.wst.server.ui (1.1.103.v20100123) "Server UI" [Starting]
                                org.eclipse.wst.server.ui.doc.user (1.1.150.v200901232034) "Server Tools documentation for Web Standard Tools" [Starting]
                                org.eclipse.wst.server.ui.infopop (1.1.0.v200805140145) "Server Tools infopops for Web Standard Tools" [Resolved]
                                org.eclipse.wst.sse.core (1.1.402.v201001251516) "Structured Text Model" [Starting]
                                org.eclipse.wst.sse.doc.user (1.1.0.v200805211530) "Structured text editor and snippets documentation" [Resolved]
                                org.eclipse.wst.sse.ui (1.1.102.v200910200227) "Structured Source Editor" [Starting]
                                org.eclipse.wst.sse.ui.infopop (1.0.200.v200805301545) "SSE infopops" [Resolved]
                                org.eclipse.wst.standard.schemas (1.0.200.v200902270215) "Standard Schemas and DTDs" [Resolved]
                                org.eclipse.wst.validation (1.2.104.v200911120201) "Validation Framework" [Starting]
                                org.eclipse.wst.validation.doc.isv (1.2.101.v200906031420) "Validation Framework - Developer Guide" [Resolved]
                                org.eclipse.wst.validation.infopop (1.0.300.v200806041506) "WST validation infopop plug-in" [Resolved]
                                org.eclipse.wst.validation.ui (1.2.104.v200904232035) "Validation Framework UI" [Starting]
                                org.eclipse.wst.web (1.1.301.v200911302230) "Simple Web Plug-in" [Active]
                                org.eclipse.wst.web.ui (1.1.301.v201001252130) "Eclipse Web Developer Tools" [Starting]
                                org.eclipse.wst.web.ui.infopop (1.0.300.v200805140415) "Static Web infopop" [Starting]
                                org.eclipse.wst.webtools.doc.user (1.0.400.v200805150134) "Web tools documentation" [Starting]
                                org.eclipse.wst.ws (1.1.103.v200903111822) "Web Services" [Starting]
                                org.eclipse.wst.ws.api.doc (1.0.1.v200807181721) "Web Services API Documentation" [Starting]
                                org.eclipse.wst.ws.explorer (1.0.408.v200911241806) "Web Services Explorer" [Starting]
                                org.eclipse.wst.ws.infopop (1.0.300.v200805140230) "Web Services UI" [Starting]
                                org.eclipse.wst.ws.parser (1.0.402.v200901220107) "Web Services Description Parser" [Starting]
                                org.eclipse.wst.ws.service.policy (1.0.103.v200905151848) "Service policy" [Starting]
                                org.eclipse.wst.ws.service.policy.ui (1.0.102.v200903070248) "Service policy" [Active]
                                org.eclipse.wst.ws.ui (1.1.100.v200903112221) "Web Services UI" [Starting]
                                org.eclipse.wst.wsdl (1.2.2.v200911111930) "WSDL Model" [Starting]
                                org.eclipse.wst.wsdl.doc.isv (1.0.100.v200811240723) "WSDL EMF Model Javadoc Documentation" [Starting]
                                org.eclipse.wst.wsdl.ui (1.2.202.v200904271449) "WSDL UI" [Starting]
                                org.eclipse.wst.wsdl.ui.doc.user (1.0.550.v200901232040) "WSDL Editor Documentation" [Starting]
                                org.eclipse.wst.wsdl.validation (1.1.402.v200911251542) "WSDL Validator" [Starting]
                                org.eclipse.wst.wsi (1.0.305.v200902181431) "WSI Conformance Tools" [Starting]
                                org.eclipse.wst.wsi.ui (1.0.500.v200901141851) "Soap Monitor" [Starting]
                                org.eclipse.wst.wsi.ui.doc.user (1.0.401.v200809171927) "WS-I Validation Documentation" [Resolved]
                                org.eclipse.wst.xml.core (1.1.402.v201001222130) "Structured Source XML Model" [Starting]
                                org.eclipse.wst.xml.ui (1.1.2.v201001222130) "Eclipse XML Editors and Tools" [Starting]
                                org.eclipse.wst.xml.ui.infopop (1.0.300.v200805140200) "XML infopops" [Resolved]
                                org.eclipse.wst.xml.xpath.core (1.0.0.v200904240436) "XPath Core" [Resolved]
                                org.eclipse.wst.xml.xpath.ui (1.0.0.v200904240436) "XPath UI" [Starting]
                                org.eclipse.wst.xml.xpath2.processor (1.0.0.v200905300355) "PsychoPath XPath 2.0 Processor" [Starting]
                                org.eclipse.wst.xmleditor.doc.user (1.0.600.v200901231300) "XML editor" [Resolved]
                                org.eclipse.wst.xsd.core (1.1.401.v200903020335) "XSD Core Plugin" [Starting]
                                org.eclipse.wst.xsd.ui (1.2.204.v200909021537) "XML Schema Editor" [Starting]
                                org.eclipse.wst.xsdeditor.doc.user (1.0.700.v200905182240) "XML schema editor" [Resolved]
                                org.eclipse.wst.xsl (1.0.0.v200905250058) "Eclipse XSL Developer Tools" [Resolved]
                                org.eclipse.wst.xsl.core (1.0.1.v200908101420) "XSL Core" [Starting]
                                org.eclipse.wst.xsl.debug.ui (1.0.0.v200904240436) "XSL Debugger UI" [Starting]
                                org.eclipse.wst.xsl.doc (1.0.0.v200905071815) "XSL User Documentation (Incubating)" [Resolved]
                                org.eclipse.wst.xsl.jaxp.debug (1.0.0.v200904240436) "XSL JAXP Debugger" [Resolved]
                                org.eclipse.wst.xsl.jaxp.debug.ui (1.0.0.v200904240436) "XSL JAXP Debug UI" [Starting]
                                org.eclipse.wst.xsl.jaxp.launching (1.0.0.v200904240436) "XSL JAXP Launching" [Starting]
                                org.eclipse.wst.xsl.launching (1.0.0.v200904241348) "XSL Transform Launching" [Starting]
                                org.eclipse.wst.xsl.saxon (1.0.0.v200904240436) "XSL Saxon Support" [Resolved]
                                org.eclipse.wst.xsl.sdk.documentation (1.0.0.v200904240436) "pluginName" [Starting]
                                org.eclipse.wst.xsl.ui (1.0.100.v200907172129) "XSL Editor and Validation" [Starting]
                                org.eclipse.wst.xsl.xalan (1.0.0.v200904240436) "XSL Xalan Support" [Resolved]
                                org.eclipse.xsd (2.5.0.v200906151043) "XSD Model" [Starting]
                                org.eclipse.xsd.edit (2.5.0.v200906151043) "XSD Edit" [Starting]
                                org.hamcrest.core (1.1.0.v20090501071000) "Hamcrest Core Library of Matchers" [Starting]
                                org.jdom (1.0.0.v200806100616) "JDOM" [Resolved]
                                org.junit (3.8.2.v20090203-1005) "JUnit Testing Framework" [Resolved]
                                org.junit4 (4.5.0.v20090824) "JUnit Testing Framework Version 4" [Resolved]
                                org.mortbay.jetty.server (6.1.15.v200905151201) "Jetty Server" [Resolved]
                                org.mortbay.jetty.util (6.1.15.v200905182336) "Jetty Utilities" [Resolved]
                                org.objectweb.asm (3.1.0.v200803061910) "ASM" [Resolved]
                                org.sat4j.core (2.1.0.v20090520) "SAT4J Core" [Resolved]
                                org.sat4j.pb (2.1.0.v20090520) "SAT4J Pseudo" [Resolved]
                                org.tigris.subversion.clientadapter (1.6.12) "Subversion Client Adapter" [Starting]
                                org.tigris.subversion.clientadapter.javahl (1.6.12) "Subversion JavaHL" [Starting]
                                org.tigris.subversion.clientadapter.javahl.win32 (1.6.12) "Win32 JavaHL Binaries" [Resolved]
                                org.tigris.subversion.clientadapter.svnkit (1.6.12) "SVNKit Client Adapter" [Starting]
                                org.tigris.subversion.subclipse.core (1.6.12) "SVN Team Provider Core" [Starting]
                                org.tigris.subversion.subclipse.doc (1.3.0) "Subclipse Documentation" [Resolved]
                                org.tigris.subversion.subclipse.ui (1.6.12) "SVN Team Provider UI" [Starting]
                                org.tmatesoft.svnkit (1.3.3.6648) "SVNKit Library Plug-in" [Starting]
                                org.uddi4j (2.0.5.v200805270300) "UDDI4J" [Resolved]
                                *** User Preferences:
                                #Fri Jul 02 09:43:03 CEST 2010
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.pr ofiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-de bug/TestBed.swf=10
                                @org.eclipse.ui.editors=3.5.0.v20090527-2000
                                /instance/FlexPrettyPrintCommand/Actionscript.dontIndentPackageItems=false
                                @org.eclipse.debug.ui=3.5.1.v20090811_r351
                                @org.eclipse.core.net=1.2.1.r35x_20090812-1200
                                /profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/autoUpdateInit=true
                                /instance/FlexPrettyPrintCommand/MXML.sortExtraAttrs=false
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortMetatags=false
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
                                /instance/com.adobe.flexbuilder.project/workspaceFXPUUID=ad8fd946-e426-480f-8880-319a04396 885
                                /instance/com.collabnet.subversion.merge/merge_provider_set=true
                                @org.eclipse.wst.jsdt.ui=1.0.201.v2010012803
                                /instance/org.eclipse.ui.workbench/ColorsAndFontsPreferencePage.selectedElement=Torg.eclip se.ui.workbenchMisc
                                /instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.VariableView.org.eclipse.jdt.debug .ui.show_null_entries=true
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/org.eclipse.jdt.ui/spelling_ignore_sentence=true
                                /instance/org.eclipse.ui.views.log/groupBy=0
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortImports=true
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.6
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideLiteralBraces=0
                                /instance/com.adobe.flexbuilder.project/flexBuilderVersion=4.0.1.277662
                                @org.eclipse.jst.j2ee.webservice.ui=1.1.300.v200902052230
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideArrayDeclBrackets=0
                                @com.adobe.flexbuilder.mxml.editor=4.0.1.277662
                                /instance/org.eclipse.ui.browser/internalWebBrowserHistory=file\://D\:/flashBuilder_worksp ace/tina/bayron-man.html|*|file\:/D\:/flashBuilder_workspace/tina/bayron-man.html|*|file\: //D\:/Tine/html/tina/Archiv/einkehren.html|*|file\:/D\:/Tine/html/tina/Archiv/einkehren.ht ml|*|http\://www.eclipse.org|*|file\:/C\:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/com.adobe.flexbuilder.ui_4.0.0.272416/welcome/welcome.html?firstLaunch\=false&e dition\=prem&version\=400|*|
                                /instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=always
                                @com.adobe.flexbuilder.flexunit=4.0.1.277662
                                /instance/org.eclipse.wst.html.core/elemCoexistence=2
                                /configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false
                                /instance/org.eclipse.wst.jsdt.ui/spelling_locale_initialized=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/isSystem=true
                                /instance/com.adobe.flexbuilder.launching.ui/com.adobe.flexbuilder.launching.ui.warnLaunch ingWillTerminateExistingLaunch=false
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/enabled=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/name=artifact listener dropins
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/enabled=true
                                /instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
                                /instance/org.eclipse.ui.editors/occurrenceIndicationColor=0,255,255
                                /instance/org.eclipse.wst.html.core/elemDuplicate=2
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/description=
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/provider=
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/name=C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4\\.eclipseextension
                                /instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.ExpressionView=<?xm l version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.ExpressionView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="PRESENTATION_SHOW_LOGICAL_STRUCTURES"/>\r\n</PRESENTATION_CONTEXT_ PROPERTIES>\r\n</VariablesViewMemento>
                                /instance/FlexPrettyPrintCommand/Actionscript.blankLinesToKeep=0
                                /instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
                                @com.adobe.flexbuilder.standalone=4.0.1.277662
                                /instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeFunctions=1
                                /instance/org.eclipse.core.resources/pathvariable.DOCUMENTS=D\:/flashBuilder_workspace
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAfterLabel=0
                                /instance/org.eclipse.core.resources/version=1
                                /instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
                                /instance/FlexPrettyPrintCommand/Actionscript.doRearrangeWhileFormatting=true
                                @org.eclipse.ui=3.5.1.M20090902-1000
                                /instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeClasses=1
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=ena bled
                                /instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeProperties=1
                                /instance/FlexPrettyPrintCommand/MXML.sortAttrData=
                                /instance/FlexPrettyPrintCommand/MXML.alwaysUseMaxLineLength=false
                                @org.eclipse.wst.server.core=1.1.102.v20100123
                                /instance/FlexPrettyPrintCommand/ASRearr_RemoveExistingSectionHeaders=false
                                /instance/FlexPrettyPrintCommand/ASRearr_MinorSectionHeader=style\=1|width\=40|blankLines\ =0|fillChar\=-|text\=|linesBefore\=1|
                                /instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizing_default_participant_sec_id= 1274887787363
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.internal.ui.navigator.layout=1
                                /instance/org.eclipse.wst.html.core/piInvalidContent=2
                                /instance/FlexPrettyPrintCommand/MXML.tagsWithASContent=.*\:add,.*\:added,.*\:activate,.*\ :addedToStage,.*\:buttonDown,.*\:change,.*\:childAdd,.*\:childIndexChange,.*\:childRemove, .*\:clickHandler,.*\:clear,.*\:click,.*\:complete,.*\:contextMenu,.*\:copy,.*\:creationCom plete,.*\:currentStateChange,.*\:currentStateChanging,.*\:cut,.*\:dataChange,.*\:deactivat e,.*\:doubleClick,.*\:dragComplete,.*\:dragDrop,.*\:dragEnter,.*\:dragExit,.*\:dragOver,.* \:dragStart,.*\:effectEnd,.*\:effectStart,.*\:enterFrame,.*\:enterState,.*\:exitFrame,.*\: exitState,.*\:focusIn,.*\:focusOut,.*\:frameConstructed,.*\:hide,.*\:httpStatus,.*\:init,. *\:initialize,.*\:invalid,.*\:ioError,.*\:itemClick,.*\:itemRollOut,.*\:itemRollOver,.*\:k eyDown,.*\:keyFocusChange,.*\:keyUp,.*\:menuHide,.*\:menuShow,.*\:middleClick,.*\:middleMo useDown,.*\:middleMouseUp,.*\:mouseDown,.*\:mouseUp,.*\:mouseOver,.*\:mouseMove,.*\:mouseO ut,.*\:mouseFocusChange,.*\:mouseWheel,.*\:mouseDownOutside,.*\:mouseWheelOutside,.*\:move ,.*\:nativeDragComplete,.*\:nativeDragDrop,.*\:nativeDragEnter,.*\:nativeDragExit,.*\:nati veDragOver,.*\:nativeDragStart,.*\:nativeDragUpdate,.*\:open,.*\:paste,.*\:preinitialize,. *\:progress,.*\:record,.*\:remove,.*\:removed,.*\:removedFromStage,.*\:render,.*\:resize,. *\:rightClick,.*\:rightMouseDown,.*\:rightMouseUp,.*\:rollOut,.*\:rollOver,.*\:scroll,.*\: securityError,.*\:selectAll,.*\:show,.*\:tabChildrenChange,.*\:tabEnabledChange,.*\:tabInd exChange,.*\:thumbDrag,.*\:thumbPress,.*\:thumbRelease,.*\:toolTipCreate,.*\:toolTipEnd,.* \:toolTipHide,.*\:toolTipShow,.*\:toolTipShown,.*\:toolTipStart,.*\:updateComplete,.*\:unl oad,.*\:valid,.*\:valueCommit,.*\:Script,
                                /instance/com.adobe.flexide.mxml.core/expandStateFiltered=_custom_\:controls\:layout\:navi gators\:z_charts\:
                                /instance/com.adobe.flexide.mxml.core/com.adobe.flexide.mxml.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/org.eclipse.wst.html.core/attrValueMismatch=1
                                /instance/org.eclipse.debug.ui/preferredTargets=default\:default|
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/enabled=true
                                @com.adobe.flexbuilder.css.editor=4.0.1.277662
                                @com.adobe.flexbuilder.project=4.0.1.277662
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/type=org.eclipse.eq uinox.p2.artifact.repository.simpleRepository
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/isSystem=true
                                /instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
                                /instance/FlexPrettyPrintCommand/MXML.parentTagsToHaveBlankLinesAddedAfterThem=
                                /instance/FlexPrettyPrintCommand/MXML.spacesBeforeEmptyTagEnd=0
                                /instance/com.crispico.flower.mp.eclipse/useFlowerModelingPerspective=always
                                /instance/org.eclipse.wst.html.core/attrNameMismatch=2
                                /instance/org.eclipse.wst.html.core/attrDuplicate=2
                                /instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeControlStatements=1
                                /instance/org.eclipse.wst.html.core/elemUnclosedStartTag=1
                                /instance/FlexPrettyPrintCommand/ASRearr_CopyrightHeader=style\=1|width\=80|blankLines\=2| fillChar\=-|text\=   Copyright 2010\n   All rights reserved.|linesBefore\=1|
                                /instance/com.adobe.flexbuilder.mxml.editor/compViewSize=400 x 300;300 x 200
                                /instance/FlexPrettyPrintCommand/Actionscript.useGlobalSpacesInsideParens=true
                                /instance/org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/isSystem=true
                                @org.eclipse.jdt.debug.ui=3.4.1.v20090811_r351
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/enabled=true
                                /instance/org.eclipse.jdt.ui/spelling_ignore_single_letters=true
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/isSystem=true
                                /instance/org.eclipse.wst.html.core/elemMissingStart=2
                                /instance/FlexPrettyPrintCommand/Flex.autoSyncLocalChangesFlag=true
                                /instance/FlexPrettyPrintCommand/MXML.attrsPerLine=1
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.pr ofiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/M ain.swf=10
                                /instance/com.adobe.flash.profiler//Avg.\ Self\ Time\ (ms),com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_wor kspace/KinderPingui/bin-debug/Main.swf=123
                                /instance/FlexPrettyPrintCommand/MXML.wrapIndentStyle=1001
                                /instance/org.eclipse.wst.html.core/attrUndefValue=2
                                /configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=D\:\\flashBuilder_workspace\nC\:\\User s\\Tine\\Adobe Flash Builder 4
                                /instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizing_default_participant=org.tig ris.subversion.subclipse.participant
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/uri=file\:/C\:/User s/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortNamespaces=true
                                /instance/com.adobe.flexbuilder.mxml.editor/appViewSizes=1024 x 768;800 x 600
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/suffix=eclipse
                                /instance/FlexPrettyPrintCommand/MXML.useAttrsToKeepOnSameLine=false
                                /instance/com.adobe.flash.profiler/saveViewIDs=com.adobe.flash.profiler.ui.LiveObjects,0,c om.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.LiveObjects, 1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.LiveObjec ts,2,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,2,com.adobe.flash.profiler.ui.LiveOb jects,19,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,19,com.adobe.flash.profiler.ui.P erformanceProfile,Performance Profile (Apr 20, 2010 3 17 24 PM - Apr 20, 2010 3 17 58 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 20, 2010 3 17 24 PM - Apr 20, 2010 3 17 58 PM),com.adobe.flash.profiler.ui.LiveObjects,20,com.adobe.flash.profiler.ext.ui.MemoryUsag eGraph,20,com.adobe.flash.profiler.ui.LiveObjects,21,com.adobe.flash.profiler.ext.ui.Memor yUsageGraph,21,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 20, 2010 3 19 53 PM - Apr 20, 2010 3 20 21 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 20, 2010 3 19 53 PM - Apr 20, 2010 3 20 21 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.LiveObjects,4,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,4,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 12 06 24 PM - Apr 26, 2010 12 07 12 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 26, 2010 12 06 24 PM - Apr 26, 2010 12 07 12 PM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 12 09 30 PM - Apr 26, 2010 12 09 50 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 26, 2010 12 09 30 PM - Apr 26, 2010 12 09 50 PM),com.adobe.flash.profiler.ui.LiveObjects,2,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,2,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 2 21 29 PM - Apr 26, 2010 2 21 42 PM),com.adobe.flash.profiler.ui.LiveObjects,3,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,3,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 2 22 01 PM - Apr 26, 2010 2 22 09 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,0,com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUs ageGraph,0,com.adobe.flash.profiler.ui.LiveObjects,11,com.adobe.flash.profiler.ext.ui.Memo ryUsageGraph,11,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 17, 2010 5 25 17 PM - Jun 17, 2010 5 25 31 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 17, 2010 5 25 17 PM - Jun 17, 2010 5 25 31 PM),com.adobe.flash.profiler.ui.LiveObjects,12,com.adobe.flash.profiler.ext.ui.MemoryUsag eGraph,12,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 18, 2010 4 19 24 PM - Jun 18, 2010 4 21 25 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 18, 2010 4 19 24 PM - Jun 18, 2010 4 21 25 PM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 19, 2010 2 49 46 PM - Jun 19, 2010 2 51 19 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Life/bin-debug/Life.swf (Jun 19, 2010 2 49 46 PM - Jun 19, 2010 2 51 19 PM),com.adobe.flash.profiler.ui.LiveObjects,2,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,2,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.LiveObjects,3,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,3,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.LiveObjects,4,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,4,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 45 21 PM - Jun 25, 2010 4 46 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 45 21 PM - Jun 25, 2010 4 46 18 PM),com.adobe.flash.profiler.ui.LiveObjects,5,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,5,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 5 03 56 PM - Jun 25, 2010 5 04 37 PM),com.adobe.flash.profiler.ui.LiveObjects,6,com.adobe.flash.profiler.ext.ui.MemoryUsage Graph,6,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),
                                /instance/org.eclipse.wst.html.core/docDoctypeUnclosed=1
                                @FlexPrettyPrintCommand=0.7.4
                                /instance/FlexPrettyPrintCommand/ASRearr_UseSectionHeadersInMXML=false
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/name=download cache
                                /instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core.taglib.TaglibIndex=CLEAN
                                /instance/org.eclipse.wst.html.core/docInvalidChar=2
                                /instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands>\r\n<keyBinding commandId\="org.eclipse.search.ui.performTextSearchWorkspace" contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+SHIFT+F"/>\r\n<keyBinding contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="ALT+CTRL+G"/>\r\n<keyBinding commandId\="com.adobe.flexbuilder.as.editor.generate.gettersetter" contextId\="com.adobe.flexide.as.core.flexEditorScope.actionscript" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+G"/>\r\n</org.eclipse.ui.commands>
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortIncludes=true
                                /instance/FlexPrettyPrintCommand/Actionscript.tabCountForHangingIndent=1
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortProperties=true
                                /instance/FlexPrettyPrintCommand/ASRearr_RemoveExistingCopyrightHeaders=false
                                /instance/org.eclipse.ui.views.log/orderValue=-1
                                /instance/FlexPrettyPrintCommand/ASRearr_BlankLinesBeforeElement=
                                /instance/org.eclipse.wst.html.core/elemMissingEnd=2
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/version=1.0.0
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.prof iler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-de bug/Main.swf=,flash.*.*,mx.*.*,spark.*.*,
                                /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=alway s
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/description=
                                /instance/FlexPrettyPrintCommand/MXML.blankLinesBeforeTags=0
                                /instance/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=true
                                @com.adobe.flexide.editorcore=4.0.1.277662
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.navigator.layout=2
                                /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=always
                                @com.adobe.flexide.mxml.core=4.0.1.277662
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
                                @org.eclipse.team.cvs.ui=3.3.201.R35x_v20090826-0905
                                /instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1.6
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapExpressionMode=1
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/isSystem=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/uri=file\:/C\:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.prod uct_4.0.1_1084004438/p2/org.eclipse.equinox.p2.core/cache/
                                /instance/org.eclipse.jdt.ui/content_assist_number_of_computers=14
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeComma=0
                                /instance/com.adobe.flash.profiler//Method,com.adobe.flash.profiler.ui.PerformanceProfile, localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=476
                                /instance/FlexPrettyPrintCommand/MXML.blankLinesBetweenSiblingTags=0
                                /instance/FlexPrettyPrintCommand/Actionscript.putCatchOnNewLine=false
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/provider=
                                /instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="sql" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<editor id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info>\r\n<info extension\="xslt" name\="*">\r\n<editor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n</info>\r\n<info extension\="tag" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="xfl" name\="*">\r\n<editor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n</info>\r\n<info extension\="jpage" name\="*">\r\n<editor id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info>\r\n<info extension\="shtml" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n<info extension\="xsl" name\="*">\r\n<editor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n</info>\r\n<info extension\="ddl" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n</info>\r\n<inf o extension\="fla" name\="*">\r\n<editor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n</info>\r\n<info extension\="html" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="htm" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="tagf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="jsf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="js" name\="*">\r\n<editor id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n</info>\r\n<info extension\="uml4as" name\="*">\r\n<editor id\="com.crispico.flower.mp.eclipse.part.FlowerDiagramEditorLauncher"/>\r\n</info>\r\n<in fo extension\="sqlpage" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n</info>\r\n<inf o extension\="jsp" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="xhtml" name\="*">\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="tagx" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="jspx" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="properties" name\="sample">\r\n<editor id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info extension\="jspf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="rdsquery" name\="*">\r\n<editor id\="com.adobe.rds.QueryEditor"/>\r\n</info>\r\n<info extension\="mxml" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor"/>\r\n</info>\r\n<info extension\="jardesc" name\="*">\r\n<editor id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n<info extension\="css" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.css.editors.CSSEditor"/>\r\n</info>\r\n<info extension\="as" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor"/>\r\n</info>\r\n<info extension\="server" name\="*">\r\n<editor id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n<info extension\="fxg" name\="*">\r\n<editor id\="com.adobe.flexbuilder.mxml.editor.FXGEditor"/>\r\n</info>\r\n</editors>
                                /instance/FlexPrettyPrintCommand/Actionscript.keepSLCommentsOnColumn1=false
                                /instance/FlexPrettyPrintCommand/ASRearr_MajorSectionHeader=style\=1|width\=60|blankLines\ =2|fillChar\=-|text\=|linesBefore\=1|
                                /instance/org.eclipse.wst.html.core/elemUnclosedEndTag=1
                                /instance/org.eclipse.wst.html.core/elemStartInvalidCase=2
                                /instance/org.eclipse.wst.html.core/refInvalidContent=2
                                /instance/org.eclipse.wst.html.core/elemInvalidContent=2
                                /instance/FlexPrettyPrintCommand/ASRearr_SortGettersAndSettersWithAssociatedStaticProperti es=true
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.pr ofiler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/M ain.swf=10
                                @com.adobe.flexbuilder.launching.ui=4.0.1.277662
                                /instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Class=true
                                /profile/_SELF_/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
                                @com.crispico.flower.mp.eclipse=1.0.0.M0_2010-06-11
                                @org.eclipse.ant.ui=3.4.2.v20091204_r352
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.prof iler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestB ed.swf=,
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/description=
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.prof iler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debu g/TestBed.swf=,
                                /instance/FlexPrettyPrintCommand/Flex.useTabs=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/uri=file\:/C\:/Users/Tine/.eclipse/com.ad obe.flexbuilder.standalone.product_4.0.1_1084004438/configuration/org.eclipse.osgi/bundles /190/data/listener_1925729951/
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/enabled=true
                                /instance/org.eclipse.ui.views.log/activate=true
                                /instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingEnforceMax=false
                                /instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideArrayRefBrackets=0
                                @org.eclipse.jdt.core=3.5.2.v_981_R35x
                                /instance/org.eclipse.ui.views.log/show_filter_text=true
                                /instance/org.eclipse.jdt.ui/spelling_ignore_java_strings=true
                                /instance/FlexPrettyPrintCommand/MXML.blankLinesAfterParentTags=0
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.assertIdentifier=erro r
                                /instance/org.tigris.subversion.subclipse.ui/pref_merge_provider=CollabNet Desktop
                                /instance/FlexPrettyPrintCommand/ASRearr_ImportOrder=adobe,com,flash,mx,
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/type=org.eclipse.equi nox.p2.extensionlocation.metadataRepository
                                @org.eclipse.debug.core=3.5.0.v20090526-1600
                                /instance/org.eclipse.jdt.ui/spelling_ignore_digits=true
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapMethodCallMode=4
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/name=Bundle pool
                                /instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServices=false
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementFunctionVisibilityOrder=public\:true,prote cted\:true,internal\:true,private\:true,
                                /instance/FlexPrettyPrintCommand/Actionscript.putEmptyStatementsOnNewLine=true
                                /instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
                                @com.adobe.flexide.as.core=4.0.1.277662
                                @org.eclipse.team.ui=3.5.0.I20090430-0408
                                /instance/com.adobe.flexbuilder.project/fbBuildID=277662
                                /instance/FlexPrettyPrintCommand/ASRearr_UseSectionHeaders=true
                                /configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
                                @org.eclipse.core.resources=3.5.1.R35x_v20090826-0451
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/type=org.eclipse.equinox.internal.p2.meta data.repository.LocalMetadataRepository
                                /instance/org.eclipse.wst.html.ui/declBoder=\#004000 | null | false | false | false | false
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAfterColons=0
                                /instance/FlexPrettyPrintCommand/Actionscript.maxLineLength=200
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefac tory.com_update/enabled=false
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates><template autoinsert\="true" context\="jsdoc" deleted\="false" description\="author name" enabled\="true" id\="org.eclipse.wst.jsdt.ui.templates.author" name\="@author">@author Christine Emrich</template></templates>
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedCRBeforeBraceSettings=2047
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/version=1.0.0
                                /instance/FlexPrettyPrintCommand/ASRearr_UseCopyrightGeneration=false
                                /instance/org.eclipse.ui.workbench/PLUGINS_NOT_ACTIVATED_ON_STARTUP=
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefac tory.com_update/uri=http\://www.idefactory.com/update
                                /instance/org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_XML=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings defaultVM\="57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType13,1270719219389" defaultVMConnector\="">\r\n<vmType id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType">\r\n<vm id\="1270719219389" javadocURL\="http\://java.sun.com/javase/6/docs/api/" name\="Adobe Flash Builder 4" path\="C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4"/>\r\n</vmType>\r\n</vmSettings>\r\n
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/version=1
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/version=1
                                /instance/org.eclipse.wst.html.core/elemInvalidDirective=1
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/type=org.eclipse.equinox.p2.artifact.re pository.simpleRepository
                                /instance/FlexPrettyPrintCommand/MXML.keepBlankLines=true
                                @org.tigris.subversion.subclipse.ui=1.6.12
                                /instance/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground=255,128,192
                                /instance/com.adobe.flexbuilder.mxml.editor/lastEditorView=Source
                                @org.eclipse.wst.html.core=1.1.300.v200903120608
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.code_templates_migrated=tru e
                                /instance/org.eclipse.wst.html.core/cdataUnclosed=1
                                /instance/com.adobe.flexbuilder.css.editor/LastCSSEditorView=Source
                                /instance/FlexPrettyPrintCommand/ASRearr_MetatagOrder=ArrayElementType,Bindable,DefaultPro perty,Deprecated,Effect,Embed,Event,Exclude,ExcludeClass,IconFile,Inspectable,InstanceType ,NonCommittingChangeEvent,RemoteClass,Style,SWF,Transient,
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/suffix=artifacts.xml
                                /instance/org.eclipse.ui.views.log/orderType=2
                                /configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
                                @org.eclipse.ui.ide=3.5.1.M20090826-0800
                                /instance/FlexPrettyPrintCommand/ActionScript.metatagsOnSameLineAsTargetFunction=Bindable
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
                                @org.eclipse.wst.html.ui=1.0.401.v200908111935
                                /instance/FlexPrettyPrintCommand/Actionscript.alwaysGenerateIndent=false
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/uri=file\:/C\:/Progra m%20Files%20(x86)/Adobe/Adobe%20Flash%20Builder%204/.eclipseextension
                                /instance/com.adobe.flexbuilder.editorcore/autoViewIDs=com.adobe.flexbuilder.mxml.editor.s tates.StatesViewer\=design-mxml\=0\=true,com.adobe.flexbuilder.mxml.editor.components.Comp onentsView\=design-mxml\=0\=true,com.adobe.flexbuilder.mxml.editor.inspector.view.Properti esView\=design-mxml;design-css\=0\=true,com.adobe.flexbuilder.as.editor.asdocviewer\=code\ =0\=false,com.adobe.flexbuilder.mxml.editor.AppearanceView\=design-mxml\=1\=false
                                /instance/FlexPrettyPrintCommand/MXML.attrGroups=name\=properties|sort\=11|includeStates\= true|wrap\=54|attrs\=allowDisjointSelection,allowMultipleSelection,allowThumbOverlap,allow TrackClick,autoLayout,autoRepeat,automationName,cachePolicy,class,clipContent,condenseWhit e,conversion,creationIndex,creationPolicy,currentState,data,dataDescriptor,dataProvider,da taTipFormatFunction,dayNames,defaultButton,direction,disabledDays,disabledRanges,displayed Month,displayedYear,doubleClickEnabled,emphasized,enabled,explicitHeight,explicitMaxHeight ,explicitMaxWidth,explicitMinHeight,explicitMinWidth,explicitWidth,firstDayOfWeek,focusEna bled,fontContext,height,horizontalLineScrollSize,horizontalPageScrollSize,horizontalScroll Bar,horizontalScrollPolicy,horizontalScrollPosition,htmlText,icon,iconField,id,imeMode,inc ludeInLayout,indeterminate,label,labelField,labelFunction,labelPlacement,labels,layout,lin eScrollSize,listData,liveDragging,maxChars,maxHeight,maxScrollPosition,maxWidth,maxYear,ma ximum,measuredHeight,measuredMinHeight,measuredMinWidth,measuredWidth,menuBarItemRenderer, menuBarItems,menus,minHeight,minScrollPosition,minWidth,minYear,minimum,mode,monthNames,mo nthSymbol,mouseFocusEnabled,pageScrollSize,pageSize,percentHeight,percentWidth,scaleX,scal eY,scrollPosition,selectable,selectableRange,selected,selectedDate,selectedField,selectedI ndex,selectedRanges,showDataTip,showRoot,showToday,sliderDataTipClass,sliderThumbClass,sna pInterval,source,states,stepSize,stickyHighlighting,styleName,text,text,thumbCount,tickInt erval,tickValues,toggle,toolTip,transitions,truncateToFit,validationSubField,value,value,v erticalLineScrollSize,verticalPageScrollSize,verticalScrollBar,verticalScrollPolicy,vertic alScrollPosition,width,x,y,yearNavigationEnabled,yearSymbol,|data\=-1|\nname\=xml_namespac es|sort\=11|includeStates\=true|wrap\=54|attrs\=xmlns,xmlns\:.*,|data\=-1|\nname\=events|s ort\=11|includeStates\=true|wrap\=54|attrs\=add,added,activate,addedToStage,buttonDown,cha nge,childAdd,childIndexChange,childRemove,clickHandler,clear,click,complete,contextMenu,co py,creationComplete,currentStateChange,currentStateChanging,cut,dataChange,deactivate,doub leClick,dragComplete,dragDrop,dragEnter,dragExit,dragOver,dragStart,effectEnd,effectStart, enterFrame,enterState,exitFrame,exitState,focusIn,focusOut,frameConstructed,hide,httpStatu s,init,initialize,invalid,ioError,itemClick,itemRollOut,itemRollOver,keyDown,keyFocusChang e,keyUp,menuHide,menuShow,middleClick,middleMouseDown,middleMouseUp,mouseDown,mouseUp,mous eOver,mouseMove,mouseOut,mouseFocusChange,mouseWheel,mouseDownOutside,mouseWheelOutside,mo ve,nativeDragComplete,nativeDragDrop,nativeDragEnter,nativeDragExit,nativeDragOver,nativeD ragStart,nativeDragUpdate,open,paste,preinitialize,progress,record,remove,removed,removedF romStage,render,resize,rightClick,rightMouseDown,rightMouseUp,rollOut,rollOver,scroll,secu rityError,selectAll,show,tabChildrenChange,tabEnabledChange,tabIndexChange,thumbDrag,thumb Press,thumbRelease,toolTipCreate,toolTipEnd,toolTipHide,toolTipShow,toolTipShown,toolTipSt art,updateComplete,unload,valid,valueCommit,|data\=-1|\nname\=styles|sort\=11|includeState s\=true|wrap\=54|attrs\=backgroundAlpha,backgroundAttachment,backgroundColor,backgroundDis abledColor,backgroundImage,backgroundSize,backgroundSkin,barColor,barSkin,borderColor,bord erSides,borderSkin,borderStyle,borderThickness,bottom,color,cornerRadius,dataTipOffset,dat aTipPrecision,dataTipStyleName,disabledColor,disabledIcon,disabledIconColor,disabledSkin,d isbledOverlayAlpha,downArrowDisabledSkin,downArrowDownSkin,downArrowOverSkin,downArrowUpSk in,downIcon,downSkin,dropShadowColor,dropShadowEnabled,errorColor,fillAlphas,fillColors,fo cusAlpha,focusBlendMode,focusRoundedCorners,focusSkin,focusThickness,fontAntiAliasType,fon tFamily,fontGridFitType,fontSharpness,fontSize,fontStyle,fontThickness,fontWeight,fontfami ly,headerColors,headerStyleName,highlightAlphas,horizontalAlign,horizontalCenter,horizonta lGap,horizontalScrollBarStyleName,icon,iconColor,indeterminateMoveInterval,indeterminateSk in,itemDownSkin,itemOverSkin,itemUpSkin,kerning,labelOffset,labelStyleName,labelWidth,lead ing,left,letterSpacing,maskSkin,menuStyleName,nextMonthDisabledSkin,nextMonthDownSkin,next MonthOverSkin,nextMonthSkin,nextMonthUpSkin,nextYearDisabledSkin,nextYearDownSkin,nextYear OverSkin,nextYearSkin,nextYearUpSkin,overIcon,overSkin,paddingBottom,paddingLeft,paddingRi ght,paddingTop,prevMonthDisabledSkin,prevMonthDownSkin,prevMonthOverSkin,prevMonthSkin,pre vMonthUpSkin,prevYearDisabledSkin,prevYearDownSkin,prevYearOverSkin,prevYearSkin,prevYearU pSkin,repeatDelay,repeatInterval,right,rollOverColor,rollOverIndicatorSkin,selectedDisable dIcon,selectedDisabledSkin,selectedDownIcon,selectedDownSkin,selectedOverIcon,selectedOver Skin,selectedUpIcon,selectedUpSkin,selectionColor,selectionIndicatorSkin,shadowColor,shado wDirection,shadowDistance,showTrackHighlight,skin,slideDuration,slideEasingFunction,stroke Color,strokeWidth,textAlign,textDecoration,textIndent,textRollOverColor,textSelectedColor, themeColor,thumbDisabledSkin,thumbDownSkin,thumbIcon,thumbOffset,thumbOverSkin,thumbUpSkin ,tickColor,tickLength,tickOffset,tickThickness,todayColor,todayIndicatorSkin,todayStyleNam e,top,tracHighlightSkin,trackColors,trackHeight,trackMargin,trackSkin,upArrowDisabledSkin, upArrowDownSkin,upArrowOverSkin,upArrowUpSkin,upIcon,upSkin,verticalAlign,verticalCenter,v erticalGap,verticalScrollBarStyleName,weekDayStyleName,|data\=-1|\nname\=effects|sort\=11| includeStates\=true|wrap\=54|attrs\=addedEffect,completeEffect,creationCompleteEffect,focu sInEffect,focusOutEffect,hideEffect,mouseDownEffect,mouseUpEffect,moveEffect,removedEffect ,resizeEffect,rollOutEffect,rollOverEffect,showEffect,|data\=-1|\n
                                /instance/FlexPrettyPrintCommand/ActionScript.metatagsOnSameLineAsTargetProperty=Bindable
                                @org.eclipse.ui.browser=3.2.300.v20090526
                                /instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/suffix=content.xml
                                /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.To ggleObjectBrowsersAction=true
                                /instance/FlexPrettyPrintCommand/ASRearr_UseElementStaticPropertyVisibilityOrder=true
                                /instance/org.eclipse.ui.workbench/ColorsAndFontsPreferencePage.expandedCategories=Tcom.ad obe.flexide.editorcore.flexbuilder
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/provider=
                                /instance/org.eclipse.wst.html.core/attrUndefName=2
                                /instance/org.eclipse.jdt.ui/spelling_locale_initialized=true
                                /instance/org.eclipse.jdt.ui/spelling_ignore_upper=true
                                @com.collabnet.subversion.merge=2.1.0
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/provider=
                                /instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor class\="org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor.SQLScrapbookEditor" id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor" image\="images/qrydoc.gif" internal\="true" label\="SQL File Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.datatools.sqltools.sqlscrapbook"/>\r\n<descriptor class\="org.eclipse.datatools.sqltools.sqlbuilder.SQLBuilderEditor" id\="org.eclipse.datatools.sqltools.sqlbuilder" image\="images/qrydoc.gif" internal\="true" label\="SQL Query Builder" openMode\="1" open_in_place\="false" plugin\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<descriptor class\="org.eclipse.wst.xsl.ui.internal.editor.XSLEditor" id\="org.eclipse.wst.xsl.ui.XSLEditor" image\="$nl$/icons/full/xslt_file.gif" internal\="true" label\="XSL Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.xsl.ui"/>\r\n<descriptor class\="org.eclipse.wst.sse.ui.StructuredTextEditor" id\="org.eclipse.jst.jsp.core.jspsource.source" image\="$nl$/icons//full/obj16/sourceEditor.gif" internal\="true" label\="JSP Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jst.jsp.ui"/>\r\n<descriptor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor" image\="icons/fb_fla_16x16.png" internal\="false" label\="Adobe Flash Editor" launcher\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor" openMode\="4" open_in_place\="false" plugin\="com.adobe.flexbuilder.ui"/>\r\n<descriptor class\="org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetEditor" id\="org.eclipse.jdt.debug.ui.SnippetEditor" image\="$nl$/icons/full/obj16/jsbook_obj.gif" internal\="true" label\="Scrapbook" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jdt.debug.ui"/>\r\n<descriptor id\="org.eclipse.ui.browser.editorSupport" image\="$nl$/icons/obj16/internal_browser.gif" internal\="false" label\="Web Browser" launcher\="org.eclipse.ui.internal.browser.BrowserLauncher" openMode\="4" open_in_place\="false" plugin\="org.eclipse.ui.browser"/>\r\n<descriptor class\="org.eclipse.jst.pagedesigner.editors.HTMLEditor" id\="org.eclipse.jst.pagedesigner.PageDesignerEditor" image\="icons/PD_Plugin.gif" internal\="true" label\="Web Page Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jst.pagedesigner"/>\r\n<descriptor class\="org.eclipse.wst.jsdt.internal.ui.javaeditor.CompilationUnitEditor" id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor" image\="$nl$/icons/full/obj16/jcu_obj.gif" internal\="true" label\="JavaScript Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.jsdt.ui"/>\r\n<descriptor id\="com.crispico.flower.mp.eclipse.part.FlowerDiagramEditorLauncher" internal\="false" label\="Flower Modeling Platform" launcher\="com.crispico.flower.mp.eclipse.part.o" openMode\="4" open_in_place\="false" plugin\="com.crispico.flower.mp.eclipse"/>\r\n<descriptor class\="org.eclipse.pde.internal.ui.samples.SampleEditor" id\="org.eclipse.pde.ui.sampleEditor" image\="$nl$/icons/obj16/build_exec.gif" internal\="true" label\="Code Sample Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.pde.ui"/>\r\n<descriptor class\="com.adobe.rds.client.eclipse.editors.query.QueryEditor" id\="com.adobe.rds.QueryEditor" image\="src/com/adobe/rds/client/eclipse/views/P_RDSQuery_Sm_N.png" internal\="true" label\="RDS Query Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.coldfusion.rds.client"/>\r\n<descriptor class\="com.adobe.flexbuilder.mxml.editor.MXMLEditor" id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor" image\="icons/fb_mxml_16x16.png" internal\="true" label\="MXML Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.mxml.editor"/>\r\n<descriptor id\="org.eclipse.jdt.ui.JARDescEditor" image\="$nl$/icons/full/obj16/jar_desc_obj.gif" internal\="false" label\="JAR Export Wizard" launcher\="org.eclipse.jdt.internal.ui.jarpackager.OpenJarExportWizardEditorLauncher" openMode\="4" open_in_place\="false" plugin\="org.eclipse.jdt.ui"/>\r\n<descriptor class\="com.adobe.flexbuilder.css.editor.CSSEditor" id\="com.adobe.flexbuilder.editors.css.editors.CSSEditor" image\="icons/C_CSSFile_md.png" internal\="true" label\="CSS Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.css.editor"/>\r\n<descriptor class\="com.adobe.flexbuilder.as.editor.ActionScriptEditor" id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor" image\="icons/fb_as_16x16.png" internal\="true" label\="ActionScript Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.as.editor"/>\r\n<descriptor class\="org.eclipse.wst.server.ui.internal.editor.ServerEditor" id\="org.eclipse.wst.server.ui.editor" image\="icons/obj16/server.gif" internal\="true" label\="Server Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.server.ui"/>\r\n<descriptor class\="com.adobe.flexide.fxg.core.editor.FXGCoreEditor" id\="com.adobe.flexbuilder.mxml.editor.FXGEditor" image\="icons/fb_mxml_16x16.png" internal\="true" label\="FXG Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.mxml.editor"/>\r\n</editors>
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesAroundEqualsInOptionalParamete rs=4
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/version=1.0.0
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementOrder=Import,Include,Namespace Definition,Default Namespace,Namespace Use,Static Property,Static Function,Static Initializer,Constructor,Property,Function,
                                /instance/org.eclipse.ui.editors/asOccurencesTextStyle=NONE
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementStaticFunctionVisibilityOrder=public\:true ,protected\:true,internal\:true,private\:true,
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/uri=file\:/C\:/Program%20Files%20(x86)/ Adobe/Adobe%20Flash%20Builder%204/
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedUseSpacesAroundEqualsInOptionalParam eters=false
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapEmbeddedXMLMode=2
                                @org.eclipse.wst.jsdt.core=1.0.201.v2010012803
                                /instance/org.eclipse.wst.xml.ui/lastActivePage=1
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.editor.tab.width=
                                /instance/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=0,255,255
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.prof iler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Mai n.swf=,
                                /instance/org.eclipse.wst.html.core/docDuplicateTag=1
                                /instance/FlexPrettyPrintCommand/Actionscript.useGlobalCRBeforeBrace=true
                                /instance/org.eclipse.wst.html.ui/org.eclipse.wst.sse.ui.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                @com.adobe.flexbuilder.editorcore=4.0.1.277662
                                /instance/FlexPrettyPrintCommand/ASRearr_UseElementFunctionVisibilityOrder=true
                                /instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.formatterprofiles.version=11
                                /instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Function=<Namespace>,override,nativ e,public,private,protected,internal,static,dynamic,final
                                @com.adobe.flexide.css.core=4.0.1.277662
                                /instance/org.eclipse.jdt.ui/spelling_ignore_urls=true
                                /instance/FlexPrettyPrintCommand/Actionscript.putOpenBraceOnNewLine=true
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/suffix=eclipse
                                /instance/com.adobe.flexide.css.core/com.adobe.flexide.css.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=true
                                /instance/FlexPrettyPrintCommand/ASRearr_GroupGettersAndSettersWithProperties=false
                                /instance/org.eclipse.wst.html.core/elemInvalidEmptyTag=2
                                /instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Property=<Namespace>,override,nativ e,public,private,protected,internal,static,dynamic,final
                                /instance/com.adobe.flexbuilder.editorcore/activeViewIDs3=org.eclipse.ui.console.ConsoleVi ew,com.adobe.flexbuilder.packageexplorer,org.eclipse.ui.views.ContentOutline,com.adobe.fle xbuilder.mxml.editor.states.StatesViewer,com.adobe.flexbuilder.mxml.editor.components.Comp onentsView,com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView
                                /instance/com.adobe.flexbuilder.editorcore/activeViewIDs2=com.adobe.flexbuilder.packageexp lorer,org.eclipse.ui.views.ProgressView,org.eclipse.ui.views.ContentOutline
                                /instance/org.eclipse.wst.html.core/elemUnknownName=2
                                @org.eclipse.ui.views.log=1.0.100.v20090731
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAroundColons=0
                                /instance/com.adobe.flexide.mxml.core/newAppLayout=absolute
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/isSystem=true
                                /instance/FlexPrettyPrintCommand/Actionscript.leaveExtraWhitespaceAroundVarDecls=false
                                /instance/FlexPrettyPrintCommand/Actionscript.breakLinesBeforeComma=false
                                /profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/migrated34Prefs=true
                                /instance/com.crispico.flower.mp.eclipse/toolbarSizePreferences=214
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/uri=file\:/C\:/Users/Tine/.eclipse/com.ad obe.flexbuilder.standalone.product_4.0.1_1084004438/configuration/org.eclipse.osgi/bundles /190/data/listener_1925729951/
                                /instance/org.eclipse.jdt.ui/tabWidthPropagated=true
                                /instance/FlexPrettyPrintCommand/MXML.onlyFormatASIfCDATABlock=false
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingPreservePhrases=true
                                /instance/org.eclipse.wst.html.core/elemInvalidName=1
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/name=C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4\\.eclipseextension
                                /instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=com.adobe.flexbuilder.flashbridge.ap plicationDecorator\:true,com.adobe.flexbuilder.project.ui.applicationDecorator\:true,com.a dobe.flexbuilder.project.ui.classpathDecorator\:true,org.eclipse.wst.server.ui.decorator\: false,org.eclipse.jdt.ui.override.decorator\:true,org.eclipse.jdt.ui.interface.decorator\: false,org.eclipse.jdt.ui.buildpath.decorator\:true,org.eclipse.team.cvs.ui.decorator\:true ,org.eclipse.ui.LinkedResourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:true,or g.eclipse.wst.jsdt.ui.override.decorator\:true,org.eclipse.wst.jsdt.ui.interface.decorator \:false,org.eclipse.wst.server.ui.navigatorDecorator\:true,org.tigris.subversion.subclipse .ui.decorator\:true,
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideParens=1
                                /instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.core.codeComplete.visibilityCheck =enabled
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.prof iler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Mai n.swf=,flash.*.*,mx.*.*,spark.*.*,
                                /instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Property=true
                                /instance/org.eclipse.ui.editors/asOccurencesIndicationColor=255,128,255
                                /instance/org.eclipse.wst.jsdt.ui/tabWidthPropagated=true
                                /instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Class=<Namespace>,override,native,p ublic,private,protected,internal,static,dynamic,final
                                /instance/FlexPrettyPrintCommand/ASRearr_AddDefaultHeaderForStaticProperties=1
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortFunctions=true
                                /instance/org.eclipse.wst.html.core/cdataInvalidContent=2
                                /instance/FlexPrettyPrintCommand/MXML.sortAttrMode=0
                                /instance/org.eclipse.wst.html.core/elemUnnecessaryEnd=2
                                /instance/org.eclipse.wst.sse.core/task-tag-projects-already-scanned=Hyphenator,KinderPing ui,c&m_animatedText,fBolo,SpellChecker_prototype,Flash_Audio_Player,pageflip,pageflip - Kopie,app_template,map-projection,MemoryLoops,MemoryLoops_trunk,UMLTest,AudioPlayer,event TagTest,Untitled_1,content_assets,Applet,GuessTheNumber,InteraceTest,Life,GameOfLife,ivg_p resentation,Test
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/name=metadata listener dropins
                                /instance/com.adobe.flexbuilder.standalone/flexbuilder.afterFirstLaunch=true
                                /instance/org.eclipse.ant.ui/org.eclipse.ant.ui.customtemplates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.prof iler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Mai n.swf=,
                                /instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/isSystem=true
                                @org.eclipse.wst.xml.ui=1.1.2.v201001222130
                                /instance/FlexPrettyPrintCommand/MXML.spacesAroundEquals=0
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/name=Bundle pool
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/provider=
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templates_migrated=true
                                /instance/com.adobe.flash.profiler//Avg.\ Cumulative\ Time\ (ms),com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_wor kspace/KinderPingui/bin-debug/Main.swf=204
                                /instance/org.eclipse.jdt.ui/content_assist_proposals_foreground=0,0,0
                                /instance/FlexPrettyPrintCommand/Actionscript.braceStyle=5
                                /instance/FlexPrettyPrintCommand/Actionscript.putWhileOnNewLine=true
                                /instance/FlexPrettyPrintCommand/MXML.tagsCannotFormat=mx\:String,fx\:String,
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.visibilityCheck=enabled
                                /instance/org.eclipse.wst.jsdt.web.core/jspIndexState=1
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementPropertyVisibilityOrder=public\:true,prote cted\:true,internal\:true,private\:true,
                                /profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=11
                                /instance/FlexPrettyPrintCommand/Actionscript.keepBlankLines=true
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.pr ofiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin- debug/Main.swf=10
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/version=1.0.0
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapMethodDeclMode=4
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingGraceColumns=5
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/description=
                                @org.eclipse.wst.sse.core=1.1.402.v201001251516
                                /instance/org.eclipse.jdt.ui/content_assist_lru_history=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><history maxLHS\="100" maxRHS\="10"><lhs name\="java.awt.Paint"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.awt.Transparency"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.awt.Color"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.lang.Runnable"><rhs name\="java.lang.Thread"/></lhs><lhs name\="java.lang.Thread"><rhs name\="java.lang.Thread"/></lhs><lhs name\="java.lang.Exception"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="java.lang.Throwable"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="java.lang.InterruptedException"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="Ball"><rhs name\="Ball"/></lhs><lhs name\="org.wiigee.device.Device"><rhs name\="org.wiigee.device.Wiimote"/></lhs><lhs name\="org.wiigee.device.Wiimote"><rhs name\="org.wiigee.device.Wiimote"/></lhs></history>
                                @org.eclipse.wst.jsdt.web.core=1.0.201.v201001221931
                                /instance/org.eclipse.debug.ui/preferredDetailPanes=DefaultDetailPane\:DefaultDetailPane|
                                /instance/com.adobe.flexide.editorcore/prefDialogNoProject=false
                                @org.eclipse.ui.workbench=3.5.1.M20090826-0800a
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAroundAssignment=1
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeColons=1
                                /instance/com.adobe.flexbuilder.flexunit/com.adobe.flexbuilder.flexunit.filetemplates.=<?x ml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/org.eclipse.debug.core/prefWatchExpressions=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<watchExpressions/>\r\n
                                /instance/FlexPrettyPrintCommand/MXML.attrsToKeepOnSameLine=4
                                /instance/FlexPrettyPrintCommand/ASRearr_AddDefaultHeaderForProperties=1
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.pr ofiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/Tes tBed.swf=10
                                /instance/org.eclipse.ui.views.log/column4=150
                                /instance/org.eclipse.ui.views.log/column3=150
                                /instance/org.eclipse.ui.views.log/column2=497
                                @org.eclipse.jdt.ui=3.5.2.r352_v20100106-0800
                                /instance/org.eclipse.jdt.ui/spelling_user_dictionary_encoding=Cp1252
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_templates_migrated=true
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.prof iler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Mai n.swf=,flash.*.*,mx.*.*,spark.*.*,
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.prof iler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-de bug/Main.swf=,
                                /instance/org.eclipse.wst.html.core/attrInvalidValue=2
                                /instance/com.adobe.flexide.as.core/com.adobe.flexide.as.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
                                /instance/com.adobe.flexide.editorcore/autoDelay=0
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.templates_migrated=true
                                /instance/FlexPrettyPrintCommand/ASRearr_MoveImportsOutsideClass=true
                                /instance/FlexPrettyPrintCommand/MXML.blankLinesAfterSpecificParentTags=0
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates><template autoinsert\="false" context\="typecomment_context" deleted\="false" description\="Comment for created types" enabled\="true" id\="org.eclipse.jdt.ui.text.codetemplates.typecomment" name\="typecomment">/**\r\n * @author Christine Emrich\r\n *\r\n * ${tags}\r\n */</template><template autoinsert\="false" context\="typecomment_context" deleted\="false" description\="Comment for created types" enabled\="true" id\="org.eclipse.wst.jsdt.ui.text.codetemplates.typecomment" name\="typecomment">/**\r\n * @author Christine Emrich\r\n *\r\n * ${tags}\r\n */</template></templates>
                                /instance/org.eclipse.wst.html.core/attrValueUnclosed=2
                                /instance/org.eclipse.wst.html.core/attrInvalidName=2
                                /instance/FlexPrettyPrintCommand/MXML.attrWrapMode=52
                                /instance/org.eclipse.ui.workbench/perspectives=tine_flex
                                /instance/org.eclipse.wst.html.core/docInvalidContent=2
                                /instance/FlexPrettyPrintCommand/Actionscript.putElseOnNewLine=true
                                /instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
                                /instance/FlexPrettyPrintCommand/Actionscript.collapseSpacesForAdjacentParens=true
                                /configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
                                /instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time=false
                                /instance/org.eclipse.search/org.eclipse.search.defaultPerspective=org.eclipse.search.defa ultPerspective.none
                                /instance/FlexPrettyPrintCommand/ASRearr_UseImportOrder=true
                                /instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe" name\="Internet Explorer"/>\r\n</web-browsers>
                                file_export_version=3.0
                                /instance/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false
                                @org.eclipse.jdt.launching=3.5.1.v20100108_r352
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equi nox.p2.core_cache/suffix=artifacts.xml
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/version=1.0.0
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.prof iler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debu g/TestBed.swf=,
                                /instance/FlexPrettyPrintCommand/Actionscript.useGlobalSpacesAroundColons=true
                                /instance/org.eclipse.wst.html.core/piUndefined=2
                                /instance/FlexPrettyPrintCommand/ASRearr_SortGettersAndSettersWithAssociatedProperties=tru e
                                /instance/org.eclipse.ui.workbench/overridepresentation=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_T ine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.e clipse.osgi_bundles_190_data_listener_1925729951/type=org.eclipse.equinox.p2.artifact.repo sitory.simpleRepository
                                /instance/org.eclipse.core.resources/pathvariable.FLASHPRO_APPCONFIG=C\:/Program Files (x86)/Adobe/Adobe Flash CS5/Common/Configuration
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.javadoclocations.migrated=true
                                /instance/FlexPrettyPrintCommand/ASRearr_UseMetatagOrder=false
                                /instance/FlexPrettyPrintCommand/ASRearr_GroupGettersAndSettersWithStaticProperties=false
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/type=org.eclipse.equi nox.p2.extensionlocation.artifactRepository
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapIndentStyle=1001
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementStaticPropertyVisibilityOrder=public\:true ,protected\:true,internal\:true,private\:true,
                                /instance/org.eclipse.jdt.ui/fontPropagated=true
                                /profile/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
                                /instance/org.eclipse.wst.html.core/piUnclosed=1
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortStaticProperties=true
                                /instance/com.crispico.flower.mp.eclipse/flatPackagePresentationPreferences=true
                                @org.eclipse.wst.sse.ui=1.1.102.v200910200227
                                /instance/org.eclipse.ui.workbench/tine_flex_persp=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<perspective editorAreaTrimState\="2" editorAreaVisible\="1" fixed\="0" version\="0.016">\r\n<descriptor descriptor\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" id\="tine_flex" label\="tine_flex"/>\r\n<window height\="876" width\="1616" x\="-8" y\="-8"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.editorcore.modeswitch"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.standalone.navigate"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.openFiles"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.standalone.launch"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.debug.ui.flexDebuggingActionSet"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.zzz.editors.common.ui.project.publish"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.as.editor.ui.NavigationActions"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.dcrad.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.debugActionSet"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.AppearanceView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.components.ComponentsView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.packageexplorer"/>\r\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView"/>\r\n<show_view_act ion id\="com.adobe.flexbuilder.mxml.editor.states.StatesViewer"/>\r\n<show_view_action id\="com.adobe.flexbuilder.dcrad.views.DataServicesView"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.editorcore.ui.project.wizards.newproject"/>\r\n<new_wizard_act ion id\="com.adobe.flexbuilder.project.ui.wizards.FlexLibraryProjectWizard"/>\r\n<new_wizard_ action id\="com.adobe.flexbuilder.flashbridge.NewFlashProProjectWizard"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.project.ui.wizards.NewActionScriptProjectWizard"/>\r\n<new_wiz ard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLApplication"/>\r\n<new_wizard_ac tion id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLComponent"/>\r\n<new_wizard_acti on id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLItemRenderer"/>\r\n<new_wizard_a ction id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLModule"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLSkin"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.wizards.NewActionScriptFile.flex"/>\r\n<new_wizard_a ction id\="com.adobe.flexbuilder.as.editor.classWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.interfaceWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.css.editor.wizards.NewCSSFile"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.flexUnitClassWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.flexUnitTestSuiteClassWizard.flex"/>\r\n<new_wizard_ action id\="com.adobe.flexbuilder.as.editor.packageWizard.flex"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\r\n<perspective_action id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development"/>\r\n<perspective_ac tion id\="com.adobe.flexbuilder.debug.ui.perspectives.debug"/>\r\n<perspective_action id\="com.adobe.flash.profiler.ui.ProfilingPerspective"/>\r\n<hide_toolbar_item_id id\="org.eclipse.ui.edit.text.toggleShowSelectedElementOnly"/>\r\n<view id\="org.eclipse.ui.views.ProblemView"/>\r\n<view id\="com.adobe.flexbuilder.dcrad.views.DataServicesView"/>\r\n<view id\="com.adobe.flexbuilder.monitors.network.view.NetworkMonitorView"/>\r\n<view id\="org.eclipse.search.ui.views.SearchView"/>\r\n<view id\="org.eclipse.debug.ui.DebugView"/>\r\n<view id\="com.collabnet.subversion.merge.views.MergeResultsView"/>\r\n<view id\="org.eclipse.team.ui.GenericHistoryView"/>\r\n<view id\="com.adobe.flash.profiler.ui.Monitor"/>\r\n<view id\="com.adobe.flexbuilder.as.editor.asdocviewer"/>\r\n<view id\="org.eclipse.debug.ui.VariableView"/>\r\n<view id\="com.adobe.flexbuilder.packageexplorer"/>\r\n<view id\="org.eclipse.ui.views.ContentOutline"/>\r\n<view id\="org.eclipse.ui.console.ConsoleView"/>\r\n<fastViewBars/>\r\n<layout>\r\n<mainWindow> \r\n<info folder\="true" part\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder activePageID\="com.adobe.flexbuilder.packageexplorer" appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.packageexplorer" label\="Package Explorer"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="stickyFolderRight" ratio\="0.75" ratioLeft\="750" ratioRight\="250" relationship\="2" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.cheatsheets.views.CheatSheetView" label\="LabelNotFound"/>\r\n</folder>\r\n</info>\r\n<info part\="org.eclipse.ui.editorss" ratio\="0.2410321" ratioLeft\="383" ratioRight\="1206" relationship\="2" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc"/>\r\n<info folder\="true" part\="statesViewHolder" ratio\="0.65" ratioLeft\="520" ratioRight\="280" relationship\="2" relative\="org.eclipse.ui.editorss">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.states.StatesViewer" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info> \r\n<info folder\="true" part\="propertiesHolder" ratio\="0.24884081" ratioLeft\="161" ratioRight\="486" relationship\="4" relative\="statesViewHolder">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView" label\="LabelNotFound"/>\r\n<page content\="com.adobe.flexbuilder.mxml.editor.AppearanceView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info> \r\n<info folder\="true" part\="bottomLayout" ratio\="0.7549889" ratioLeft\="681" ratioRight\="221" relationship\="4" relative\="org.eclipse.ui.editorss">\r\n<folder activePageID\="org.eclipse.debug.ui.VariableView" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\r\n<page content\="com.adobe.flexbuilder.dcrad.views.DataServicesView" label\="Data/Services"/>\r\n<page content\="com.adobe.flexbuilder.monitors.network.view.NetworkMonitorView" label\="Network Monitor"/>\r\n<page content\="org.eclipse.search.ui.views.SearchView" label\="Search"/>\r\n<page content\="org.eclipse.debug.ui.DebugView" label\="Debug"/>\r\n<page content\="com.collabnet.subversion.merge.views.MergeResultsView" label\="Merge Results"/>\r\n<page content\="org.eclipse.team.ui.GenericHistoryView" label\="History"/>\r\n<page content\="com.adobe.flash.profiler.ui.Monitor" label\="Profile"/>\r\n<page content\="com.adobe.flexbuilder.as.editor.asdocviewer" label\="ASDoc"/>\r\n<page content\="org.eclipse.debug.ui.VariableView" label\="Variables"/>\r\n<page content\="org.eclipse.ui.views.TaskList" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n<part id\="1"/>\r\n<part id\="2"/>\r\n<part id\="3"/>\r\n<part id\="4"/>\r\n<part id\="5"/>\r\n<part id\="6"/>\r\n<part id\="7"/>\r\n<part id\="8"/>\r\n<part id\="9"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="outlineHolder" ratio\="0.4992272" ratioLeft\="323" ratioRight\="324" relationship\="4" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.components.ComponentsView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info> \r\n<info folder\="true" part\="org.eclipse.ui.internal.ViewStack@5445a6" ratio\="0.6019956" ratioLeft\="543" ratioRight\="359" relationship\="4" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ContentOutline" label\="Outline"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n</mainWindow>\r\n<detachedWindow height\="781" width\="853" x\="-914" y\="79">\r\n<folder activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</detachedWindow>\r\n</layout>\r\n</perspect ive>
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefac tory.com_update/uri=http\://www.idefactory.com/update
                                /instance/FlexPrettyPrintCommand/Actionscript.wrapArrayDeclMode=4
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAfterComma=1
                                /instance/org.eclipse.jdt.ui/spelling_ignore_non_letters=true
                                /instance/FlexPrettyPrintCommand/ASRearr_UseElementPropertyVisibilityOrder=true
                                /instance/org.eclipse.wst.html.core/commentInvalidContent=2
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeControlOpenParen=1
                                /instance/org.eclipse.jdt.ui/content_assist_proposals_background=255,255,255
                                /instance/org.eclipse.wst.jsdt.ui/org.eclipse.jface.textfont=1|Courier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
                                /instance/FlexPrettyPrintCommand/ASRearr_ElementSortStaticFunctions=true
                                /instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.DebugVieworg.eclips e.debug.ui.DebugView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<DebugViewMemento org.eclipse.debug.ui.BREADCRUMB_DROPDOWN_AUTO_EXPAND\="false"/>
                                /instance/FlexPrettyPrintCommand/MXML.tagsToHaveBlankLinesAddedBeforeThem=
                                /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives/>\r\n
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefac tory.com_update/isSystem=false
                                /instance/FlexPrettyPrintCommand/ASRearr_UseElementStaticFunctionVisibilityOrder=true
                                @org.eclipse.jst.jsp.core=1.2.204.v201001270045
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefac tory.com_update/enabled=false
                                /instance/org.eclipse.wst.html.core/commentUnclosed=1
                                /instance/FlexPrettyPrintCommand/Actionscript.newLineBeforeBindableFunction=true
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/description=
                                /instance/org.eclipse.jdt.ui/spelling_ignore_ampersand_in_properties=true
                                /instance/FlexPrettyPrintCommand/ActionScript.spacesBeforeFormalParameters=0
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.prof iler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestB ed.swf=,
                                /instance/FlexPrettyPrintCommand/ASRearr_UseElementOrder=true
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/provider=
                                @org.eclipse.search=3.5.1.r351_v20090708-0800
                                /instance/FlexPrettyPrintCommand/Actionscript.newLineBeforeBindableProperty=true
                                /profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefac tory.com_update/isSystem=false
                                /instance/FlexPrettyPrintCommand/MXML.addNewlineAfterLastAttr=false
                                /instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Function=true
                                /instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
                                /instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Builtins,com.adobe.flash.prof iler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Mai n.swf=true
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesAroundBinarySymbolicOperator=1
                                /instance/FlexPrettyPrintCommand/Actionscript.useAdvancedWrapping=false
                                /instance/org.eclipse.team.cvs.ui/pref_first_startup=false
                                @com.adobe.flash.profiler=4.0.1.277662
                                /instance/org.eclipse.jdt.ui/spelling_ignore_mixed=true
                                /instance/FlexPrettyPrintCommand/ASRearr_UseGlobalModifierOrder=true
                                /instance/FlexPrettyPrintCommand/Actionscript.useBraceStyle=true
                                /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.6
                                /instance/FlexPrettyPrintCommand/Actionscript.spacesInsideParens=0
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/description=
                                /instance/org.eclipse.wst.jsdt.ui/fontPropagated=true
                                /instance/com.adobe.flash.profiler/com.adobe.flash.profiler.Builtins=false
                                /instance/FlexPrettyPrintCommand/MXML.tagsCanFormat=mx\:List,fx\:List,
                                /instance/FlexPrettyPrintCommand/MXML.maxLineLength=200
                                /profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program %20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/uri=file\:/C\:/Progra m%20Files%20(x86)/Adobe/Adobe%20Flash%20Builder%204/.eclipseextension
                                /instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.VariableView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.VariableView"/>\r\n</VariablesViewMemento>
                                /instance/com.crispico.flower.mp.eclipse/automaticSynchronizationPreferance=true
                                /instance/FlexPrettyPrintCommand/Actionscript.keepElseIfOnSameLine=false
                                /instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingElements=165
                                /instance/org.eclipse.wst.html.core/elemEndInvalidCase=1
                                /instance/FlexPrettyPrintCommand/ASRearr_SectionHeaderMap=\#\r\n\#Sat Jun 05 00\:42\:26 CEST 2010\r\nFunction\=type\\\=1|id\\\=Function|enabled\\\=true|text\\\= internal methods|endID\\\=Function|\r\nStatic\\ Function\=type\\\=1|id\\\=Static Function|enabled\\\=true|text\\\=   Static mathods|endID\\\=Static Function|\r\n
                                /instance/org.eclipse.wst.server.core/module-start-timeout=300000
                                /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
                                /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_view_bindings=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<viewBindings>\r\n<view id\="org.eclipse.debug.ui.VariableView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n</view>\r\n<view id\="org.eclipse.debug.ui.ExpressionView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n</view>\r\n<view id\="org.eclipse.ui.console.ConsoleView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n<perspective id\="org.tigris.subversion.subclipse.ui.svnPerspective" userAction\="opened"/>\r\n<perspective id\="org.eclipse.jdt.ui.JavaPerspective" userAction\="opened"/>\r\n<perspective id\="com.adobe.flash.profiler.ui.ProfilingPerspective" userAction\="closed"/>\r\n</view>\r\n</viewBindings>\r\n
                                *** Current Install Configuration:
                                Install configuration:
                                Last changed on Jul 1, 2010
                                Location: C:\Program Files (x86)\Adobe\Adobe Flash Builder 4
                                Profile timestamp: 1277972070339
                                Installable Units in the profile:
                                Id: ActionscriptInfoCollector, Version: 0.7.4
                                Id: FlexASDocGenCommand, Version: 0.7.4
                                Id: FlexPrettyPrintCommand, Version: 0.7.4
                                Id: FlexPrettyPrintCommandFeature.feature.group, Version: 0.7.4
                                Id: FlexPrettyPrintCommandFeature.feature.jar, Version: 0.7.4
                                Id: a.jre.javase, Version: 1.6.0
                                Id: com.adobe.coldfusion.rds.client, Version: 1.0.272885
                                Id: com.adobe.coldfusion.rds.client.nl1, Version: 1.0.1.v20100112266797
                                Id: com.adobe.flash.codemodel.core, Version: 4.0.1.277662
                                Id: com.adobe.flash.codemodel.osgi, Version: 4.0.1.277662
                                Id: com.adobe.flash.profiler, Version: 4.0.1.277662
                                Id: com.adobe.flash.profiler.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.DCDService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.DCDService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.ajaxbridge, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.ajaxbridge.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.as.editor, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.as.editor.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.axis2, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.axis2.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.codemodel, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.codemodel.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.crimson, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.crimson.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.css.editor, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.css.editor.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.dcrad, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.dcrad.derived, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.dcrad.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug.e33, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug.ui, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug.ui.actions, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.debug.ui.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.designview, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.designview.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.editorcore, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.editorcore.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.editors.derived, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.editors.derived.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.exportimport, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.exportimport.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.core.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.core.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.core.nl1.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.core.nl1.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.standalone.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.standalone.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.standalone.nl1.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.feature.standalone.nl1.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flashbridge, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flashbridge.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flex, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flexunit, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flexunit.derived, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.flexunit.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.help, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.help.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.importartwork, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.importartwork.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.json, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.launching.ui, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.launching.ui.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.monitors.network, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.monitors.network.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.multisdk, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.mxml.editor, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.mxml.editor.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.mxmlmodel, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.project, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.project.e35, Version: 1.0.0.201001080934
                                Id: com.adobe.flexbuilder.project.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.project.ui, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.project.ui.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.BlazeDSService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.CFService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.CFService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.HTTPService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.HTTPService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.J2EEService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.J2EEService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.LCDSService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.PHPService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.PHPService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.StaticContentService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.StaticContentService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.WEBService, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.WEBService.derived, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.services.WEBService.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.standalone, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.standalone.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.standalone.product, Version: 4.0.1
                                Id: com.adobe.flexbuilder.standalone.product_root.win32.win32.x86, Version: 4.0.1
                                Id: com.adobe.flexbuilder.tengine, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.tengine.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.ui, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.ui.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.utils.osnative, Version: 4.0.1.277662
                                Id: com.adobe.flexbuilder.utils.osnative.win, Version: 4.0.1.277662
                                Id: com.adobe.flexide.amt, Version: 4.0.1.277662
                                Id: com.adobe.flexide.as.core, Version: 4.0.1.277662
                                Id: com.adobe.flexide.as.core.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.communityhelp, Version: 4.0.1.277662
                                Id: com.adobe.flexide.communityhelp.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.css.core, Version: 4.0.1.277662
                                Id: com.adobe.flexide.css.core.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.designitems, Version: 4.0.1.277662
                                Id: com.adobe.flexide.editorcore, Version: 4.0.1.277662
                                Id: com.adobe.flexide.editorcore.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.embeddedplayer, Version: 4.0.1.277662
                                Id: com.adobe.flexide.exportimport, Version: 4.0.1.277662
                                Id: com.adobe.flexide.exportimport.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.externaleditors, Version: 4.0.1.277662
                                Id: com.adobe.flexide.externaleditors.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.feature.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexide.feature.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexide.feature.nl1.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexide.feature.nl1.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.flexide.fonts, Version: 4.0.1.277662
                                Id: com.adobe.flexide.launching, Version: 4.0.1.277662
                                Id: com.adobe.flexide.launching.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.multisdk.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.mxml.core, Version: 4.0.1.277662
                                Id: com.adobe.flexide.mxml.core.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.nativelibs, Version: 4.0.1.277662
                                Id: com.adobe.flexide.playerview, Version: 4.0.1.277662
                                Id: com.adobe.flexide.refactoring.core, Version: 4.0.1.277662
                                Id: com.adobe.flexide.refactoring.core.nl1, Version: 4.0.1.277662
                                Id: com.adobe.flexide.utils.feature.feature.group, Version: 4.0.1.277662
                                Id: com.adobe.flexide.utils.feature.feature.jar, Version: 4.0.1.277662
                                Id: com.adobe.model.core, Version: 1.0.2.v20100315273147
                                Id: com.collabnet.subversion.merge, Version: 2.1.0
                                Id: com.collabnet.subversion.merge.feature.feature.group, Version: 2.1.0
                                Id: com.collabnet.subversion.merge.feature.feature.jar, Version: 2.1.0
                                Id: com.crispico.flexbridge, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.dependencies.internal, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse.compare.base, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse.compare.codesync, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse.feature.feature.group, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse.feature.feature.jar, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.eclipse.uml4as, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.metamodel.classmetamodel, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.metamodel.codesync, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.metamodel.codesyncas, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.metamodelset.uml4asfile, Version: 1.0.0.M0_2010-06-11
                                Id: com.crispico.flower.mp.propertieseditor, Version: 1.0.0.M0_2010-06-11
                                Id: com.ibm.icu, Version: 4.0.1.v20090822
                                Id: com.idefactory.enterprisehelp, Version: 1.0.8.beta
                                Id: com.idefactory.enterpriseide.feature.jar, Version: 1.0.8.beta3
                                Id: com.idefactory.fxsdk, Version: 1.0.1
                                Id: com.idefactory.rhino, Version: 1.0.0
                                Id: com.jcraft.jsch, Version: 0.1.41.v200903070017
                                Id: com.sun.jna, Version: 3.2.3
                                Id: com.sun.jna.feature.group, Version: 3.2.3
                                Id: com.sun.jna.feature.jar, Version: 3.2.3
                                Id: config.a.jre.javase, Version: 1.6.0
                                Id: java_cup.runtime, Version: 0.10.0.v200803061811
                                Id: javax.activation, Version: 1.1.0.v200906290531
                                Id: javax.mail, Version: 1.4.0.v200905040518
                                Id: javax.servlet, Version: 2.5.0.v200806031605
                                Id: javax.servlet.jsp, Version: 2.0.0.v200806031607
                                Id: javax.wsdl, Version: 1.5.1.v200806030408
                                Id: javax.xml, Version: 1.3.4.v200902170245
                                Id: javax.xml.rpc, Version: 1.1.0.v200905122109
                                Id: javax.xml.soap, Version: 1.2.0.v200905122109
                                Id: net.sourceforge.lpg.lpgjavaruntime, Version: 1.1.0.v200803061910
                                Id: org.apache.ant, Version: 1.7.1.v20090120-1145
                                Id: org.apache.axis, Version: 1.4.0.v200905122109
                                Id: org.apache.bcel, Version: 5.2.0.v200803061811
                                Id: org.apache.commons.codec, Version: 1.3.0.v20080530-1600
                                Id: org.apache.commons.collections, Version: 3.2.0.v200803061811
                                Id: org.apache.commons.discovery, Version: 0.2.0.v200905122109
                                Id: org.apache.commons.el, Version: 1.0.0.v200806031608
                                Id: org.apache.commons.httpclient, Version: 3.1.0.v20080605-1935
                                Id: org.apache.commons.jxpath, Version: 1.2.0.v20080604-1500
                                Id: org.apache.commons.lang, Version: 2.1.0.v200803061811
                                Id: org.apache.commons.lang, Version: 2.4.0.v20081016-1030
                                Id: org.apache.commons.logging, Version: 1.0.4.v200904062259
                                Id: org.apache.jasper, Version: 5.5.17.v200903231320
                                Id: org.apache.log4j, Version: 1.2.13.v200903072027
                                Id: org.apache.lucene, Version: 1.9.1.v20080530-1600
                                Id: org.apache.lucene.analysis, Version: 1.9.1.v20080530-1600
                                Id: org.apache.oro, Version: 2.0.8.v200903061218
                                Id: org.apache.velocity, Version: 1.5.0.v200905192330
                                Id: org.apache.wsil4j, Version: 1.0.0.v200901211807
                                Id: org.apache.xalan, Version: 2.7.1.v200905122109
                                Id: org.apache.xerces, Version: 2.9.0.v200909240008
                                Id: org.apache.xml.resolver, Version: 1.2.0.v200902170519
                                Id: org.apache.xml.serializer, Version: 2.7.1.v200902170519
                                Id: org.eclipse.ant.core, Version: 3.2.100.v20090817_r351
                                Id: org.eclipse.ant.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ant.ui, Version: 3.4.2.v20091204_r352
                                Id: org.eclipse.compare, Version: 3.5.0.I20090514-0808
                                Id: org.eclipse.compare.core, Version: 3.5.0.I20090430-0408
                                Id: org.eclipse.compare.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.compare.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.compare.win32, Version: 1.0.0.I20090430-0408
                                Id: org.eclipse.compare.win32.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.boot, Version: 3.1.100.v20080218
                                Id: org.eclipse.core.boot.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.commands, Version: 3.5.0.I20090525-2000
                                Id: org.eclipse.core.commands.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.contenttype, Version: 3.4.1.R35x_v20090826-0451
                                Id: org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.databinding, Version: 1.2.0.M20090819-0800
                                Id: org.eclipse.core.databinding.beans, Version: 1.2.0.I20090525-2000
                                Id: org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.databinding.observable, Version: 1.2.0.M20090902-0800
                                Id: org.eclipse.core.databinding.property, Version: 1.2.0.M20090819-0800
                                Id: org.eclipse.core.expressions, Version: 3.4.100.v20090429-1800
                                Id: org.eclipse.core.expressions.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.filebuffers, Version: 3.5.0.v20090526-2000
                                Id: org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.filesystem, Version: 1.2.0.v20090507
                                Id: org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.filesystem.win32.x86, Version: 1.1.0.v20080604-1400
                                Id: org.eclipse.core.jobs, Version: 3.4.100.v20090429-1800
                                Id: org.eclipse.core.jobs.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.net, Version: 1.2.1.r35x_20090812-1200
                                Id: org.eclipse.core.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.net.win32.x86, Version: 1.0.0.I20080909
                                Id: org.eclipse.core.resources, Version: 3.5.1.R35x_v20090826-0451
                                Id: org.eclipse.core.resources.compatibility, Version: 3.4.0.v20090505
                                Id: org.eclipse.core.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.resources.win32.x86, Version: 3.5.0.v20081020
                                Id: org.eclipse.core.runtime, Version: 3.5.0.v20090525
                                Id: org.eclipse.core.runtime.compatibility, Version: 3.2.0.v20090413
                                Id: org.eclipse.core.runtime.compatibility.auth, Version: 3.2.100.v20090413
                                Id: org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.2.200.v20090429-1800
                                Id: org.eclipse.core.runtime.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.core.variables, Version: 3.2.200.v20090521
                                Id: org.eclipse.core.variables.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.cvs, Version: 1.0.300.v200909170800
                                Id: org.eclipse.cvs.feature.group, Version: 1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16
                                Id: org.eclipse.cvs.feature.jar, Version: 1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16
                                Id: org.eclipse.datatools.connectivity, Version: 1.1.3.v201001230803
                                Id: org.eclipse.datatools.connectivity.apache.derby, Version: 1.0.100.v200906020900
                                Id: org.eclipse.datatools.connectivity.apache.derby.dbdefinition, Version: 1.0.2.v200906161815
                                Id: org.eclipse.datatools.connectivity.apache.derby.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.connectivity.console.profile, Version: 1.0.0.v200906020553
                                Id: org.eclipse.datatools.connectivity.db.generic, Version: 1.0.1.v200908130547
                                Id: org.eclipse.datatools.connectivity.db.generic.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.connectivity.dbdefinition.genericJDBC, Version: 1.0.1.v200906161815
                                Id: org.eclipse.datatools.connectivity.feature.feature.group, Version: 1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q
                                Id: org.eclipse.datatools.connectivity.feature.feature.jar, Version: 1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q
                                Id: org.eclipse.datatools.connectivity.oda, Version: 3.2.2.v201001270833
                                Id: org.eclipse.datatools.connectivity.oda.consumer, Version: 3.2.2.v201001261113
                                Id: org.eclipse.datatools.connectivity.oda.design, Version: 3.2.2.v201001210350
                                Id: org.eclipse.datatools.connectivity.oda.design.ui, Version: 3.2.2.v201001210350
                                Id: org.eclipse.datatools.connectivity.oda.designer.feature.feature.group, Version: 1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU
                                Id: org.eclipse.datatools.connectivity.oda.designer.feature.feature.jar, Version: 1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU
                                Id: org.eclipse.datatools.connectivity.oda.feature.feature.group, Version: 1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK
                                Id: org.eclipse.datatools.connectivity.oda.feature.feature.jar, Version: 1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK
                                Id: org.eclipse.datatools.connectivity.oda.flatfile, Version: 3.1.1.v201001131420
                                Id: org.eclipse.datatools.connectivity.oda.flatfile.ui, Version: 3.1.1.v201001131420
                                Id: org.eclipse.datatools.connectivity.oda.profile, Version: 3.2.2.v201001210350
                                Id: org.eclipse.datatools.connectivity.oda.template.ui, Version: 3.2.0.v200906020553
                                Id: org.eclipse.datatools.connectivity.sqm.core, Version: 1.1.1.v201001180200
                                Id: org.eclipse.datatools.connectivity.sqm.core.ui, Version: 1.1.100.v200910270525
                                Id: org.eclipse.datatools.connectivity.sqm.server.ui, Version: 1.1.100.v200910270503
                                Id: org.eclipse.datatools.connectivity.ui, Version: 1.1.5.v201001190218
                                Id: org.eclipse.datatools.connectivity.ui.dse, Version: 1.1.3.v201001270323
                                Id: org.eclipse.datatools.doc.user, Version: 1.7.0.20090521092446
                                Id: org.eclipse.datatools.doc.user.feature.group, Version: 1.7.2.v200909251450-47C08w95ENAK6AFDFK7
                                Id: org.eclipse.datatools.doc.user.feature.jar, Version: 1.7.2.v200909251450-47C08w95ENAK6AFDFK7
                                Id: org.eclipse.datatools.enablement.apache.derby.feature.feature.group, Version: 1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI
                                Id: org.eclipse.datatools.enablement.apache.derby.feature.feature.jar, Version: 1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI
                                Id: org.eclipse.datatools.enablement.feature.feature.group, Version: 1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t
                                Id: org.eclipse.datatools.enablement.feature.feature.jar, Version: 1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t
                                Id: org.eclipse.datatools.enablement.finfo, Version: 1.5.1.v200906161800
                                Id: org.eclipse.datatools.enablement.hsqldb, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.hsqldb.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.hsqldb.feature.feature.group, Version: 1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI
                                Id: org.eclipse.datatools.enablement.hsqldb.feature.feature.jar, Version: 1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI
                                Id: org.eclipse.datatools.enablement.hsqldb.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition, Version: 1.0.3.v200906161800
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition, Version: 1.0.3.v200906161800
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition, Version: 1.0.3.v200906161800
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.feature.feature.group, Version: 1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR
                                Id: org.eclipse.datatools.enablement.ibm.feature.feature.jar, Version: 1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR
                                Id: org.eclipse.datatools.enablement.ibm.informix, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.informix.dbdefinition, Version: 1.0.3.v200906161800
                                Id: org.eclipse.datatools.enablement.ibm.informix.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.ibm.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.ingres, Version: 1.0.0.v200906111150
                                Id: org.eclipse.datatools.enablement.ingres.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.ingres.feature.feature.group, Version: 1.7.2.v200909251450-540AkF77g7VBLBPH7
                                Id: org.eclipse.datatools.enablement.ingres.feature.feature.jar, Version: 1.7.2.v200909251450-540AkF77g7VBLBPH7
                                Id: org.eclipse.datatools.enablement.ingres.ui, Version: 1.0.0.v200906111150
                                Id: org.eclipse.datatools.enablement.jdbc.feature.feature.group, Version: 1.7.2.v200909251450-4-29oB55W5P7G6RAH
                                Id: org.eclipse.datatools.enablement.jdbc.feature.feature.jar, Version: 1.7.2.v200909251450-4-29oB55W5P7G6RAH
                                Id: org.eclipse.datatools.enablement.jdt.classpath, Version: 1.0.1.v200909240342
                                Id: org.eclipse.datatools.enablement.jdt.feature.feature.group, Version: 1.7.2.v200909251450-2-07w311A1A351453
                                Id: org.eclipse.datatools.enablement.jdt.feature.feature.jar, Version: 1.7.2.v200909251450-2-07w311A1A351453
                                Id: org.eclipse.datatools.enablement.msft.feature.feature.group, Version: 1.7.2.v200909251450-542AkF78Y7SBU9UAB
                                Id: org.eclipse.datatools.enablement.msft.feature.feature.jar, Version: 1.7.2.v200909251450-542AkF78Y7SBU9UAB
                                Id: org.eclipse.datatools.enablement.msft.sqlserver, Version: 1.0.1.v201001180222
                                Id: org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.msft.sqlserver.ui, Version: 1.0.1.v200908130512
                                Id: org.eclipse.datatools.enablement.mysql, Version: 1.0.2.v201002041110
                                Id: org.eclipse.datatools.enablement.mysql.dbdefinition, Version: 1.0.4.v200906161800
                                Id: org.eclipse.datatools.enablement.mysql.feature.feature.group, Version: 1.7.2.v200909251450-546AkF78Y7R9PAX87
                                Id: org.eclipse.datatools.enablement.mysql.feature.feature.jar, Version: 1.7.2.v200909251450-546AkF78Y7R9PAX87
                                Id: org.eclipse.datatools.enablement.mysql.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.oda.designer.feature.feature.group, Version: 1.7.2.v200909251450-3328s7353356I4F53
                                Id: org.eclipse.datatools.enablement.oda.designer.feature.feature.jar, Version: 1.7.2.v200909251450-3328s7353356I4F53
                                Id: org.eclipse.datatools.enablement.oda.feature.feature.group, Version: 1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp
                                Id: org.eclipse.datatools.enablement.oda.feature.feature.jar, Version: 1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp
                                Id: org.eclipse.datatools.enablement.oda.ws, Version: 1.2.2.v201001131420
                                Id: org.eclipse.datatools.enablement.oda.ws.ui, Version: 1.2.2.v201001260400
                                Id: org.eclipse.datatools.enablement.oda.xml, Version: 1.2.1.v201001151620
                                Id: org.eclipse.datatools.enablement.oda.xml.ui, Version: 1.2.1.v201001191820
                                Id: org.eclipse.datatools.enablement.oracle, Version: 1.0.0.v200908130544
                                Id: org.eclipse.datatools.enablement.oracle.dbdefinition, Version: 1.0.100.v200906161800
                                Id: org.eclipse.datatools.enablement.oracle.feature.feature.group, Version: 1.7.2.v200909251450-548aAkF77g7XAO9aBB
                                Id: org.eclipse.datatools.enablement.oracle.feature.feature.jar, Version: 1.7.2.v200909251450-548aAkF77g7XAO9aBB
                                Id: org.eclipse.datatools.enablement.oracle.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.postgresql, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.postgresql.dbdefinition, Version: 1.0.1.v200906161800
                                Id: org.eclipse.datatools.enablement.postgresql.feature.feature.group, Version: 1.7.2.v200909251450-542AkF77g7V9N9e77
                                Id: org.eclipse.datatools.enablement.postgresql.feature.feature.jar, Version: 1.7.2.v200909251450-542AkF77g7V9N9e77
                                Id: org.eclipse.datatools.enablement.postgresql.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sap.feature.feature.group, Version: 1.7.2.v200909251450-540AkF77g7V9N9e77
                                Id: org.eclipse.datatools.enablement.sap.feature.feature.jar, Version: 1.7.2.v200909251450-540AkF77g7V9N9e77
                                Id: org.eclipse.datatools.enablement.sap.maxdb, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sap.maxdb.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.sap.maxdb.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sqlite, Version: 1.0.0.v201002041110
                                Id: org.eclipse.datatools.enablement.sqlite.dbdefinition, Version: 1.0.1.v201002041110
                                Id: org.eclipse.datatools.enablement.sqlite.feature.feature.group, Version: 1.7.2.v200909251450-541AkF79P7N8NAQ97
                                Id: org.eclipse.datatools.enablement.sqlite.feature.feature.jar, Version: 1.7.2.v200909251450-541AkF79P7N8NAQ97
                                Id: org.eclipse.datatools.enablement.sqlite.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.asa, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.asa.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.sybase.asa.models, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples, Version: 2.5.0.200810071
                                Id: org.eclipse.datatools.enablement.sybase.asa.ui, Version: 1.0.1.v200906111150
                                Id: org.eclipse.datatools.enablement.sybase.ase, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.ase.dbdefinition, Version: 1.0.0.v200906161800
                                Id: org.eclipse.datatools.enablement.sybase.ase.models, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.ase.ui, Version: 1.0.1.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.feature.feature.group, Version: 1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT
                                Id: org.eclipse.datatools.enablement.sybase.feature.feature.jar, Version: 1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT
                                Id: org.eclipse.datatools.enablement.sybase.models, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.enablement.sybase.ui, Version: 1.0.0.v200906090458
                                Id: org.eclipse.datatools.help, Version: 1.5.0.v200906020553
                                Id: org.eclipse.datatools.modelbase.dbdefinition, Version: 1.0.1.v200906022249
                                Id: org.eclipse.datatools.modelbase.derby, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.modelbase.feature.feature.group, Version: 1.7.2.v200909251450-77-5CcNBCtCcCQJYZl
                                Id: org.eclipse.datatools.modelbase.feature.feature.jar, Version: 1.7.2.v200909251450-77-5CcNBCtCcCQJYZl
                                Id: org.eclipse.datatools.modelbase.sql, Version: 1.0.3.v200912150851
                                Id: org.eclipse.datatools.modelbase.sql.edit, Version: 1.0.0.v200906022249
                                Id: org.eclipse.datatools.modelbase.sql.query, Version: 1.0.2.v201002020730
                                Id: org.eclipse.datatools.modelbase.sql.query.edit, Version: 1.0.0.v200906022249
                                Id: org.eclipse.datatools.modelbase.sql.xml.query, Version: 1.0.0.v200906022249
                                Id: org.eclipse.datatools.oda.cshelp, Version: 1.1.1.v200907031118
                                Id: org.eclipse.datatools.sqldevtools.data.feature.feature.group, Version: 1.7.2.v200909251450-613BgJ9AiBPASF_KN
                                Id: org.eclipse.datatools.sqldevtools.data.feature.feature.jar, Version: 1.7.2.v200909251450-613BgJ9AiBPASF_KN
                                Id: org.eclipse.datatools.sqldevtools.ddl.feature.feature.group, Version: 1.7.2.v200909251450-26178B02G8S_ILGJxNiTuSn
                                Id: org.eclipse.datatools.sqldevtools.ddl.feature.feature.jar, Version: 1.7.2.v200909251450-26178B02G8S_ILGJxNiTuSn
                                Id: org.eclipse.datatools.sqldevtools.ddlgen.feature.feature.group, Version: 1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm
                                Id: org.eclipse.datatools.sqldevtools.ddlgen.feature.feature.jar, Version: 1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm
                                Id: org.eclipse.datatools.sqldevtools.feature.feature.group, Version: 1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU
                                Id: org.eclipse.datatools.sqldevtools.feature.feature.jar, Version: 1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU
                                Id: org.eclipse.datatools.sqldevtools.parsers.feature.feature.group, Version: 1.7.2.v200909251450-602BgJ99q9_9OGXFJ
                                Id: org.eclipse.datatools.sqldevtools.parsers.feature.feature.jar, Version: 1.7.2.v200909251450-602BgJ99q9_9OGXFJ
                                Id: org.eclipse.datatools.sqldevtools.results.feature.feature.group, Version: 1.7.2.v200909251450-4029oB56N5I7C9J5C
                                Id: org.eclipse.datatools.sqldevtools.results.feature.feature.jar, Version: 1.7.2.v200909251450-4029oB56N5I7C9J5C
                                Id: org.eclipse.datatools.sqldevtools.schemaobjecteditor.feature.feature.group, Version: 1.7.2.v200909251450-42-8375LG5BJ93413
                                Id: org.eclipse.datatools.sqldevtools.schemaobjecteditor.feature.feature.jar, Version: 1.7.2.v200909251450-42-8375LG5BJ93413
                                Id: org.eclipse.datatools.sqldevtools.sqlbuilder.feature.feature.group, Version: 1.7.2.v200909251450-79-0EVVFIxGhLaMvL_
                                Id: org.eclipse.datatools.sqldevtools.sqlbuilder.feature.feature.jar, Version: 1.7.2.v200909251450-79-0EVVFIxGhLaMvL_
                                Id: org.eclipse.datatools.sqltools.common.ui, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.data.core, Version: 1.1.0.v200910161545
                                Id: org.eclipse.datatools.sqltools.data.ui, Version: 1.1.2.v200912080845
                                Id: org.eclipse.datatools.sqltools.db.derby, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.sqltools.db.derby.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.sqltools.db.generic, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.sqltools.db.generic.ui, Version: 1.0.0.v200906020900
                                Id: org.eclipse.datatools.sqltools.ddlgen.ui, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.debugger.core, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.debugger.core.ui, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.editor.core, Version: 1.0.0.v201001150815
                                Id: org.eclipse.datatools.sqltools.editor.core.ui, Version: 1.0.0.v201001150815
                                Id: org.eclipse.datatools.sqltools.parsers.sql, Version: 1.0.1.v200906022302
                                Id: org.eclipse.datatools.sqltools.parsers.sql.lexer, Version: 1.0.1.v200906030654
                                Id: org.eclipse.datatools.sqltools.parsers.sql.query, Version: 1.0.1.v200906022302
                                Id: org.eclipse.datatools.sqltools.parsers.sql.xml.query, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.plan, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.result, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.result.ui, Version: 1.0.2.v201002011830
                                Id: org.eclipse.datatools.sqltools.routineeditor, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.routineeditor.ui, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor, Version: 1.1.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui, Version: 1.1.0.200810071
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages, Version: 1.1.0.200810071
                                Id: org.eclipse.datatools.sqltools.sql, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.sql.ui, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.sqlbuilder, Version: 1.0.0.v201001200600
                                Id: org.eclipse.datatools.sqltools.sqleditor, Version: 1.0.1.v200912241345
                                Id: org.eclipse.datatools.sqltools.sqlscrapbook, Version: 1.0.0.v200906022302
                                Id: org.eclipse.datatools.sqltools.tabledataeditor, Version: 1.0.0.v200906022302
                                Id: org.eclipse.debug.core, Version: 3.5.0.v20090526-1600
                                Id: org.eclipse.debug.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.debug.ui, Version: 3.5.1.v20090811_r351
                                Id: org.eclipse.debug.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.draw2d, Version: 3.5.2.v20091126-1908
                                Id: org.eclipse.draw2d.feature.group, Version: 3.5.2.v20100111-1352-4417w311A223702A19
                                Id: org.eclipse.draw2d.feature.jar, Version: 3.5.2.v20100111-1352-4417w311A223702A19
                                Id: org.eclipse.ecf, Version: 3.0.0.v20090831-1906
                                Id: org.eclipse.ecf.filetransfer, Version: 3.0.0.v20090831-1906
                                Id: org.eclipse.ecf.identity, Version: 3.0.0.v20090831-1906
                                Id: org.eclipse.ecf.provider.filetransfer, Version: 3.0.1.v20090831-1906
                                Id: org.eclipse.ecf.provider.filetransfer.httpclient, Version: 3.0.1.v20090831-1906
                                Id: org.eclipse.ecf.provider.filetransfer.httpclient.ssl, Version: 1.0.0.v20090831-1906
                                Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20090831-1906
                                Id: org.eclipse.ecf.ssl, Version: 1.0.0.v20090831-1906
                                Id: org.eclipse.emf, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ant, Version: 2.4.0.v200906151043
                                Id: org.eclipse.emf.codegen, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore.ui.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ecore.ui.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.codegen.ui.feature.group, Version: 2.4.0.v200906151043
                                Id: org.eclipse.emf.codegen.ui.feature.jar, Version: 2.4.0.v200906151043
                                Id: org.eclipse.emf.common, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.common.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.common.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.common.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.common.ui.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.common.ui.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.converter, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.converter.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.converter.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.databinding, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.databinding.edit, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.databinding.edit.feature.group, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.databinding.edit.feature.jar, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.databinding.feature.group, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.databinding.feature.jar, Version: 1.1.0.v200906151043
                                Id: org.eclipse.emf.ecore, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.change, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.change.edit, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.edit, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.edit.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.edit.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.editor, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.editor.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.editor.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.ecore.xmi, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit.ui.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.edit.ui.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.exporter, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.importer, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.importer.ecore, Version: 2.4.0.v200906151043
                                Id: org.eclipse.emf.importer.java, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.importer.rose, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore.editor, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore.editor.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore.editor.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore2ecore, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore2ecore.editor, Version: 2.4.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore2xml, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ecore2xml.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ui, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ui.feature.group, Version: 2.5.0.v200906151043
                                Id: org.eclipse.emf.mapping.ui.feature.jar, Version: 2.5.0.v200906151043
                                Id: org.eclipse.equinox.app, Version: 1.2.0.v20090520-1800
                                Id: org.eclipse.equinox.common, Version: 3.5.1.R35x_v20090807-1100
                                Id: org.eclipse.equinox.common.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.concurrent, Version: 1.0.1.R35x_v20100209
                                Id: org.eclipse.equinox.ds, Version: 1.1.1.R35x_v20090806
                                Id: org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.frameworkadmin, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.http.jetty, Version: 2.0.0.v20090520-1800
                                Id: org.eclipse.equinox.http.registry, Version: 1.0.200.v20090520-1800
                                Id: org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.http.servlet, Version: 1.0.200.v20090520-1800
                                Id: org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.200.v20090520-1800
                                Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.100.v20090520-1800
                                Id: org.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715
                                Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519
                                Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.0.101.R35x_v20090721
                                Id: org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.console, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.core, Version: 1.0.101.R35x_v20090819
                                Id: org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.director, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.director.app, Version: 1.0.100.v20090521-1912
                                Id: org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.0.100.v20090525
                                Id: org.eclipse.equinox.p2.engine, Version: 1.0.101.R35x_v20090825
                                Id: org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.exemplarysetup, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.metadata, Version: 1.0.100.v20090525
                                Id: org.eclipse.equinox.p2.metadata.generator, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.0.101.R35x_v20090812
                                Id: org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.publisher, Version: 1.0.0.v20090527-1812
                                Id: org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.repository, Version: 1.0.1.v20090901-1041
                                Id: org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.repository.tools, Version: 1.0.1.R35x_v20090806
                                Id: org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 1.0.101.R35x_20090820-1821
                                Id: org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.0.101.R35x_v20090806
                                Id: org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.ui, Version: 1.0.101.R35x_v20090819
                                Id: org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.0.0.v20090520-1905
                                Id: org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.0.v20090520-1905
                                Id: org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.100.v20090525
                                Id: org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.p2.user.ui.feature.group, Version: 1.1.1.R35x_v20090811-7u6FbEFYXk1qWdbS0gnpRg2932
                                Id: org.eclipse.equinox.p2.user.ui.feature.jar, Version: 1.1.1.R35x_v20090811-7u6FbEFYXk1qWdbS0gnpRg2932
                                Id: org.eclipse.equinox.preferences, Version: 3.2.300.v20090520-1800
                                Id: org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.registry, Version: 3.4.100.v20090520-1800
                                Id: org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.security, Version: 1.0.100.v20090520-1800
                                Id: org.eclipse.equinox.security.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.security.ui, Version: 1.0.100.v20090520-1800
                                Id: org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.100.v20090520-1800
                                Id: org.eclipse.equinox.simpleconfigurator, Version: 1.0.101.R35x_v20090807-1100
                                Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 1.0.100.v20090520-1905
                                Id: org.eclipse.equinox.util, Version: 1.0.100.v20090520-1800
                                Id: org.eclipse.gef, Version: 3.5.1.v20090910-2020
                                Id: org.eclipse.gef.feature.group, Version: 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
                                Id: org.eclipse.gef.feature.jar, Version: 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
                                Id: org.eclipse.help, Version: 3.4.1.v20090805_35x
                                Id: org.eclipse.help.appserver, Version: 3.1.400.v20090429_1800
                                Id: org.eclipse.help.appserver.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.help.base, Version: 3.4.0.v200909170800
                                Id: org.eclipse.help.base.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.help.feature.group, Version: 1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD
                                Id: org.eclipse.help.feature.jar, Version: 1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD
                                Id: org.eclipse.help.ui, Version: 3.4.1.v20090819_35x
                                Id: org.eclipse.help.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.help.webapp, Version: 3.4.1.v20090819_35x
                                Id: org.eclipse.help.webapp.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jdt, Version: 3.5.2.v201002111343
                                Id: org.eclipse.jdt.apt.core, Version: 3.3.202.R35x_v20091130-2300
                                Id: org.eclipse.jdt.apt.pluggable.core, Version: 1.0.201.R35x_v20090925-1100
                                Id: org.eclipse.jdt.apt.ui, Version: 3.3.200.v20090930-2100_R35x
                                Id: org.eclipse.jdt.compiler.apt, Version: 1.0.201.R35x_v20090925-1100
                                Id: org.eclipse.jdt.compiler.tool, Version: 1.0.100.v_981_R35x
                                Id: org.eclipse.jdt.core, Version: 3.5.2.v_981_R35x
                                Id: org.eclipse.jdt.core.manipulation, Version: 1.3.0.v20090603
                                Id: org.eclipse.jdt.debug, Version: 3.5.0.v20090526
                                Id: org.eclipse.jdt.debug.ui, Version: 3.4.1.v20090811_r351
                                Id: org.eclipse.jdt.doc.user, Version: 3.5.2.r352_v20091015
                                Id: org.eclipse.jdt.feature.group, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
                                Id: org.eclipse.jdt.feature.jar, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
                                Id: org.eclipse.jdt.junit, Version: 3.5.2.r352_v20100113-0800
                                Id: org.eclipse.jdt.junit.runtime, Version: 3.4.100.v20090513-2000
                                Id: org.eclipse.jdt.junit4.runtime, Version: 1.1.0.v20090513-2000
                                Id: org.eclipse.jdt.launching, Version: 3.5.1.v20100108_r352
                                Id: org.eclipse.jdt.ui, Version: 3.5.2.r352_v20100106-0800
                                Id: org.eclipse.jdt_root, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
                                Id: org.eclipse.jem, Version: 2.0.301.v201001252130
                                Id: org.eclipse.jem.proxy, Version: 2.0.201.v200908101600
                                Id: org.eclipse.jem.util, Version: 2.0.201.v201001252130
                                Id: org.eclipse.jem.util.source, Version: 2.0.201.v201001252130
                                Id: org.eclipse.jem.workbench, Version: 2.0.201.v200911302230
                                Id: org.eclipse.jface, Version: 3.5.1.M20090826-0800
                                Id: org.eclipse.jface.databinding, Version: 1.3.1.M20090826-0800
                                Id: org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jface.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jface.text, Version: 3.5.1.r351_v20090708-0800
                                Id: org.eclipse.jface.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jpt.branding, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.branding.source, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.core, Version: 2.2.1.v200908270220
                                Id: org.eclipse.jpt.core.source, Version: 2.2.1.v200908270220
                                Id: org.eclipse.jpt.db, Version: 1.2.102.v200911250220
                                Id: org.eclipse.jpt.db.source, Version: 1.2.102.v200911250220
                                Id: org.eclipse.jpt.db.ui, Version: 1.1.100.v200906070220
                                Id: org.eclipse.jpt.db.ui.source, Version: 1.1.100.v200906070220
                                Id: org.eclipse.jpt.doc.isv, Version: 1.2.0.v200906050220
                                Id: org.eclipse.jpt.doc.user, Version: 1.1.1.v200908270220
                                Id: org.eclipse.jpt.eclipselink.branding, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.eclipselink.branding.source, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.eclipselink.core, Version: 1.2.0.v200905310000
                                Id: org.eclipse.jpt.eclipselink.core.ddlgen, Version: 1.0.200.v200906070220
                                Id: org.eclipse.jpt.eclipselink.core.ddlgen.source, Version: 1.0.200.v200906070220
                                Id: org.eclipse.jpt.eclipselink.core.source, Version: 1.2.0.v200905310000
                                Id: org.eclipse.jpt.eclipselink.feature.feature.group, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
                                Id: org.eclipse.jpt.eclipselink.feature.feature.jar, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
                                Id: org.eclipse.jpt.eclipselink.feature.source.feature.group, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
                                Id: org.eclipse.jpt.eclipselink.feature.source.feature.jar, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
                                Id: org.eclipse.jpt.eclipselink.ui, Version: 1.2.0.v200905310000
                                Id: org.eclipse.jpt.eclipselink.ui.source, Version: 1.2.0.v200905310000
                                Id: org.eclipse.jpt.eclipselink_sdk.feature.feature.group, Version: 2.2.2.v200911250220-53383ADCMoJCFjDTINGJOJBlG88h
                                Id: org.eclipse.jpt.eclipselink_sdk.feature.feature.jar, Version: 2.2.2.v200911250220-53383ADCMoJCFjDTINGJOJBlG88h
                                Id: org.eclipse.jpt.feature.feature.group, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
                                Id: org.eclipse.jpt.feature.feature.jar, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
                                Id: org.eclipse.jpt.feature.source.feature.group, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
                                Id: org.eclipse.jpt.feature.source.feature.jar, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
                                Id: org.eclipse.jpt.gen, Version: 1.3.2.v201001290220
                                Id: org.eclipse.jpt.gen.source, Version: 1.3.2.v201001290220
                                Id: org.eclipse.jpt.ui, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.ui.source, Version: 2.2.2.v200911250220
                                Id: org.eclipse.jpt.utility, Version: 1.4.0.v200905310000
                                Id: org.eclipse.jpt.utility.source, Version: 1.4.0.v200905310000
                                Id: org.eclipse.jpt_sdk.feature.feature.group, Version: 2.2.2.v200911250220-65390UCTXVRIQtYa5VM2gvF9wCCp
                                Id: org.eclipse.jpt_sdk.feature.feature.jar, Version: 2.2.2.v200911250220-65390UCTXVRIQtYa5VM2gvF9wCCp
                                Id: org.eclipse.jsch.core, Version: 1.1.100.I20090430-0408
                                Id: org.eclipse.jsch.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jsch.ui, Version: 1.1.200.I20090430-0408
                                Id: org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.jst.common.annotations.controller, Version: 1.1.100.v200805140020
                                Id: org.eclipse.jst.common.annotations.core, Version: 1.1.200.v201001272230
                                Id: org.eclipse.jst.common.frameworks, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.common.project.facet.core, Version: 1.4.1.v200911141836
                                Id: org.eclipse.jst.common.project.facet.ui, Version: 1.4.1.v200912011928
                                Id: org.eclipse.jst.ejb.doc.user, Version: 1.1.100.v200810092245
                                Id: org.eclipse.jst.ejb.ui, Version: 1.1.301.v200908131325
                                Id: org.eclipse.jst.ejb.ui.infopop, Version: 1.0.200.v200905141725
                                Id: org.eclipse.jst.ejb.ui.source, Version: 1.1.301.v200908131325
                                Id: org.eclipse.jst.enterprise_core.feature.feature.group, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
                                Id: org.eclipse.jst.enterprise_core.feature.feature.jar, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
                                Id: org.eclipse.jst.enterprise_core.feature.source.feature.group, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
                                Id: org.eclipse.jst.enterprise_core.feature.source.feature.jar, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
                                Id: org.eclipse.jst.enterprise_sdk.feature.feature.group, Version: 3.1.1.v200908101600-771184eAHSuuJTW3Ue6ZhBIyV8tu
                                Id: org.eclipse.jst.enterprise_sdk.feature.feature.jar, Version: 3.1.1.v200908101600-771184eAHSuuJTW3Ue6ZhBIyV8tu
                                Id: org.eclipse.jst.enterprise_ui.feature.feature.group, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
                                Id: org.eclipse.jst.enterprise_ui.feature.feature.jar, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
                                Id: org.eclipse.jst.enterprise_ui.feature.source.feature.group, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
                                Id: org.eclipse.jst.enterprise_ui.feature.source.feature.jar, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
                                Id: org.eclipse.jst.enterprise_userdoc.feature.feature.group, Version: 3.1.0.v200809051357-62FIXBgJ99nBPBjIHN_
                                Id: org.eclipse.jst.enterprise_userdoc.feature.feature.jar, Version: 3.1.0.v200809051357-62FIXBgJ99nBPBjIHN_
                                Id: org.eclipse.jst.j2ee, Version: 1.1.302.v201004131604
                                Id: org.eclipse.jst.j2ee.core, Version: 1.1.301.v200911302230
                                Id: org.eclipse.jst.j2ee.doc.user, Version: 1.1.100.v200810071436
                                Id: org.eclipse.jst.j2ee.ejb, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.ejb.annotation.model, Version: 1.1.102.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.annotation.model.source, Version: 1.1.102.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.annotations.emitter, Version: 1.1.102.v200805140135
                                Id: org.eclipse.jst.j2ee.ejb.annotations.emitter.source, Version: 1.1.102.v200805140135
                                Id: org.eclipse.jst.j2ee.ejb.annotations.ui, Version: 1.1.102.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.annotations.ui.source, Version: 1.1.102.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet, Version: 1.2.0.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet.source, Version: 1.2.0.v200805140020
                                Id: org.eclipse.jst.j2ee.ejb.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.infopop, Version: 1.0.300.v200805140415
                                Id: org.eclipse.jst.j2ee.jca, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.jca.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.jca.ui, Version: 1.1.300.v200809052300
                                Id: org.eclipse.jst.j2ee.jca.ui.source, Version: 1.1.300.v200809052300
                                Id: org.eclipse.jst.j2ee.navigator.ui, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.navigator.ui.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.ui, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.ui.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.jst.j2ee.web, Version: 1.1.301.v200911302230
                                Id: org.eclipse.jst.j2ee.webservice, Version: 1.1.300.v200901220600
                                Id: org.eclipse.jst.j2ee.webservice.source, Version: 1.1.300.v200901220600
                                Id: org.eclipse.jst.j2ee.webservice.ui, Version: 1.1.300.v200902052230
                                Id: org.eclipse.jst.j2ee.webservice.ui.source, Version: 1.1.300.v200902052230
                                Id: org.eclipse.jst.j2ee.xdoclet.runtime, Version: 1.1.102.v200805140135
                                Id: org.eclipse.jst.j2ee.xdoclet.runtime.source, Version: 1.1.102.v200805140135
                                Id: org.eclipse.jst.jee, Version: 1.0.201.v201002021055
                                Id: org.eclipse.jst.jee.ejb, Version: 1.0.201.v201002021057
                                Id: org.eclipse.jst.jee.ejb.source, Version: 1.0.201.v201002021057
                                Id: org.eclipse.jst.jee.ui, Version: 1.0.201.v201002021208
                                Id: org.eclipse.jst.jee.ui.source, Version: 1.0.201.v201002021208
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport, Version: 1.1.0.v20090525
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.group, Version: 2.2.0.v20090517-20-7w311A1636
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.jar, Version: 2.2.0.v20090517-20-7w311A1636
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.source.feature.group, Version: 2.2.0.v20090517-20-7w311A1636
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.source.feature.jar, Version: 2.2.0.v20090517-20-7w311A1636
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.source, Version: 1.1.0.v20090525
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport_sdk.feature.feature.group, Version: 2.2.0.v20090310-53-8-52B6695K3B688x422B2747
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport_sdk.feature.feature.jar, Version: 2.2.0.v20090310-53-8-52B6695K3B688x422B2747
                                Id: org.eclipse.jst.jsf.common, Version: 1.1.9.v201001271707
                                Id: org.eclipse.jst.jsf.common.runtime, Version: 1.0.201.v20090205
                                Id: org.eclipse.jst.jsf.common.ui, Version: 1.1.1.v20081209
                                Id: org.eclipse.jst.jsf.core, Version: 1.2.5.v201001271707
                                Id: org.eclipse.jst.jsf.facesconfig, Version: 1.1.3.v20090902
                                Id: org.eclipse.jst.jsp.core, Version: 1.2.204.v201001270045
                                Id: org.eclipse.jst.jsp.ui, Version: 1.1.401.v200908111935
                                Id: org.eclipse.jst.jsp.ui.infopop, Version: 1.0.100.v200805301545
                                Id: org.eclipse.jst.pagedesigner, Version: 1.2.3.v20100211
                                Id: org.eclipse.jst.pagedesigner.jsf.ui, Version: 1.1.4.v20100203
                                Id: org.eclipse.jst.pagedesigner.jsf.ui.source, Version: 1.1.4.v20100203
                                Id: org.eclipse.jst.pagedesigner.jsp.core, Version: 1.1.3.v201002111131
                                Id: org.eclipse.jst.pagedesigner.jsp.core.source, Version: 1.1.3.v201002111131
                                Id: org.eclipse.jst.pagedesigner.source, Version: 1.2.3.v20100211
                                Id: org.eclipse.jst.server.core, Version: 1.2.1.v20100127
                                Id: org.eclipse.jst.servlet.ui, Version: 1.1.301.v200908101600
                                Id: org.eclipse.jst.servlet.ui.infopop, Version: 1.0.300.v200805140415
                                Id: org.eclipse.jst.servlet.ui.source, Version: 1.1.301.v200908101600
                                Id: org.eclipse.jst.webpageeditor.feature.feature.group, Version: 2.2.2.v201001271707-43799oB5855B7A2242
                                Id: org.eclipse.jst.webpageeditor.feature.feature.jar, Version: 2.2.2.v201001271707-43799oB5855B7A2242
                                Id: org.eclipse.jst.webpageeditor.feature.source.feature.group, Version: 2.2.2.v201001271707-43799oB5855B7A2242
                                Id: org.eclipse.jst.webpageeditor.feature.source.feature.jar, Version: 2.2.2.v201001271707-43799oB5855B7A2242
                                Id: org.eclipse.jst.webpageeditor_sdk.feature.feature.group, Version: 2.2.2.v201001271707-533818ADCrFAI9FEHC98EEApC696
                                Id: org.eclipse.jst.webpageeditor_sdk.feature.feature.jar, Version: 2.2.2.v201001271707-533818ADCrFAI9FEHC98EEApC696
                                Id: org.eclipse.jst.ws, Version: 1.0.407.v200905191120
                                Id: org.eclipse.jst.ws.axis.consumption.core, Version: 1.0.306.v200810082309
                                Id: org.eclipse.jst.ws.axis.consumption.core.source, Version: 1.0.306.v200810082309
                                Id: org.eclipse.jst.ws.axis.consumption.ui, Version: 1.0.405.v200901261650
                                Id: org.eclipse.jst.ws.axis.consumption.ui.source, Version: 1.0.405.v200901261650
                                Id: org.eclipse.jst.ws.axis.creation.ui, Version: 1.0.406.v200903031852
                                Id: org.eclipse.jst.ws.axis.creation.ui.source, Version: 1.0.406.v200903031852
                                Id: org.eclipse.jst.ws.axis.infopop, Version: 1.0.300.v200805140230
                                Id: org.eclipse.jst.ws.axis.ui.doc.user, Version: 1.1.0.v200806092139
                                Id: org.eclipse.jst.ws.axis2.consumption.core, Version: 1.0.104.v200810151442
                                Id: org.eclipse.jst.ws.axis2.consumption.core.source, Version: 1.0.104.v200810151442
                                Id: org.eclipse.jst.ws.axis2.consumption.ui, Version: 1.0.102.v200807232000
                                Id: org.eclipse.jst.ws.axis2.consumption.ui.source, Version: 1.0.102.v200807232000
                                Id: org.eclipse.jst.ws.axis2.core, Version: 1.0.104.v200810151442
                                Id: org.eclipse.jst.ws.axis2.core.source, Version: 1.0.104.v200810151442
                                Id: org.eclipse.jst.ws.axis2.creation.core, Version: 1.0.105.v200901220134
                                Id: org.eclipse.jst.ws.axis2.creation.core.source, Version: 1.0.105.v200901220134
                                Id: org.eclipse.jst.ws.axis2.creation.ui, Version: 1.0.103.v200807162242
                                Id: org.eclipse.jst.ws.axis2.creation.ui.source, Version: 1.0.103.v200807162242
                                Id: org.eclipse.jst.ws.axis2.ui, Version: 1.0.302.v200905260749
                                Id: org.eclipse.jst.ws.axis2.ui.doc.user, Version: 1.0.1.v200807302329
                                Id: org.eclipse.jst.ws.axis2.ui.source, Version: 1.0.302.v200905260749
                                Id: org.eclipse.jst.ws.axis2tools.feature.feature.group, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
                                Id: org.eclipse.jst.ws.axis2tools.feature.feature.jar, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
                                Id: org.eclipse.jst.ws.axis2tools.feature.source.feature.group, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
                                Id: org.eclipse.jst.ws.axis2tools.feature.source.feature.jar, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
                                Id: org.eclipse.jst.ws.axis2tools_sdk.feature.feature.group, Version: 1.1.0.v200905242110-31-84D2INsLdYIIAIfZoNpmVE_SE
                                Id: org.eclipse.jst.ws.axis2tools_sdk.feature.feature.jar, Version: 1.1.0.v200905242110-31-84D2INsLdYIIAIfZoNpmVE_SE
                                Id: org.eclipse.jst.ws.consumption, Version: 1.0.408.v200911241817
                                Id: org.eclipse.jst.ws.consumption.infopop, Version: 1.0.300.v200805140230
                                Id: org.eclipse.jst.ws.consumption.source, Version: 1.0.408.v200911241817
                                Id: org.eclipse.jst.ws.consumption.ui, Version: 1.1.106.v200911241851
                                Id: org.eclipse.jst.ws.consumption.ui.doc.user, Version: 1.0.550.v200901232040
                                Id: org.eclipse.jst.ws.consumption.ui.source, Version: 1.1.106.v200911241851
                                Id: org.eclipse.jst.ws.creation.ejb.ui, Version: 1.0.200.v200805140230
                                Id: org.eclipse.jst.ws.creation.ejb.ui.source, Version: 1.0.200.v200805140230
                                Id: org.eclipse.jst.ws.creation.ui, Version: 1.0.409.v200911241856
                                Id: org.eclipse.jst.ws.creation.ui.source, Version: 1.0.409.v200911241856
                                Id: org.eclipse.jst.ws.doc.user, Version: 1.0.500.v200809092107
                                Id: org.eclipse.jst.ws.infopop, Version: 1.0.300.v200805140230
                                Id: org.eclipse.jst.ws.source, Version: 1.0.407.v200905191120
                                Id: org.eclipse.jst.ws.uddiregistry, Version: 1.0.400.v200901261650
                                Id: org.eclipse.jst.ws.uddiregistry.source, Version: 1.0.400.v200901261650
                                Id: org.eclipse.jst.ws.ui, Version: 1.0.402.v200903111822
                                Id: org.eclipse.jst.ws.ui.source, Version: 1.0.402.v200903111822
                                Id: org.eclipse.ltk.core.refactoring, Version: 3.5.0.v20090513-2000
                                Id: org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ltk.ui.refactoring, Version: 3.4.100.v20090604
                                Id: org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.osgi, Version: 3.5.1.R35x_v20090827
                                Id: org.eclipse.osgi.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.osgi.services, Version: 3.2.0.v20090520-1800
                                Id: org.eclipse.osgi.services.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.osgi.util, Version: 3.2.0.v20090520-1800
                                Id: org.eclipse.osgi.util.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.pde, Version: 3.4.100.v201002111343
                                Id: org.eclipse.pde.api.tools, Version: 1.0.101.v20090714
                                Id: org.eclipse.pde.api.tools.ee.javase16, Version: 1.0.0.v20090407-1030
                                Id: org.eclipse.pde.api.tools.ui, Version: 1.0.101.v20090820
                                Id: org.eclipse.pde.build, Version: 3.5.2.R35x_20100114
                                Id: org.eclipse.pde.core, Version: 3.5.101.v20100104
                                Id: org.eclipse.pde.doc.user, Version: 3.5.0.v20090818
                                Id: org.eclipse.pde.ds.core, Version: 1.0.1.v20100118
                                Id: org.eclipse.pde.ds.ui, Version: 1.0.0.v20100209-maintenance
                                Id: org.eclipse.pde.feature.group, Version: 3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo
                                Id: org.eclipse.pde.feature.jar, Version: 3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo
                                Id: org.eclipse.pde.junit.runtime, Version: 3.4.0.v20090527
                                Id: org.eclipse.pde.runtime, Version: 3.4.100.v20090731
                                Id: org.eclipse.pde.ua.core, Version: 1.0.0.v20090429-1800
                                Id: org.eclipse.pde.ua.ui, Version: 1.0.0.v20090511
                                Id: org.eclipse.pde.ui, Version: 3.5.1.v201001121200
                                Id: org.eclipse.pde.ui.templates, Version: 3.4.100.v20090527
                                Id: org.eclipse.platform, Version: 3.3.201.v200909170800
                                Id: org.eclipse.platform.doc.user, Version: 3.5.1.r351_v20090821-0800
                                Id: org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.platform.feature.group, Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
                                Id: org.eclipse.platform.feature.jar, Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
                                Id: org.eclipse.platform.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.rcp, Version: 3.5.0.v200909170800
                                Id: org.eclipse.rcp.feature.group, Version: 3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6
                                Id: org.eclipse.rcp.feature.jar, Version: 3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6
                                Id: org.eclipse.search, Version: 3.5.1.r351_v20090708-0800
                                Id: org.eclipse.search.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.servertools.doc.isv, Version: 1.0.100.v20090414
                                Id: org.eclipse.swt, Version: 3.5.1.v3555a
                                Id: org.eclipse.swt.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.swt.win32.win32.x86, Version: 3.5.1.v3555a
                                Id: org.eclipse.team.core, Version: 3.5.0.I20090527-0620
                                Id: org.eclipse.team.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.team.cvs.core, Version: 3.3.200.I20090430-0408
                                Id: org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.team.cvs.ssh, Version: 3.2.100.I20090508-2000
                                Id: org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.team.cvs.ssh2, Version: 3.2.200.I20090508-2000
                                Id: org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.team.cvs.ui, Version: 3.3.201.R35x_v20090826-0905
                                Id: org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.team.ui, Version: 3.5.0.I20090430-0408
                                Id: org.eclipse.team.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.text, Version: 3.5.0.v20090513-2000
                                Id: org.eclipse.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui, Version: 3.5.1.M20090902-1000
                                Id: org.eclipse.ui.browser, Version: 3.2.300.v20090526
                                Id: org.eclipse.ui.browser.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.cheatsheets, Version: 3.3.200.v20090526
                                Id: org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.console, Version: 3.4.0.v20090513
                                Id: org.eclipse.ui.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.editors, Version: 3.5.0.v20090527-2000
                                Id: org.eclipse.ui.editors.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.externaltools, Version: 3.2.0.v20090504
                                Id: org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.forms, Version: 3.4.1.v20090714_35x
                                Id: org.eclipse.ui.forms.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.ide, Version: 3.5.1.M20090826-0800
                                Id: org.eclipse.ui.ide.application, Version: 1.0.101.M20090826-0800
                                Id: org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.ide.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.intro, Version: 3.3.1.v20090805_35x
                                Id: org.eclipse.ui.intro.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.intro.universal, Version: 3.2.300.v20090526
                                Id: org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.navigator, Version: 3.4.1.M20090911-1550
                                Id: org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.navigator.resources, Version: 3.4.1.M20090826-0800
                                Id: org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.net, Version: 1.2.1.r35x_20090812-1200
                                Id: org.eclipse.ui.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.presentations.r21, Version: 3.2.100.I20081007-0800
                                Id: org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.views, Version: 3.4.1.M20090826-0800
                                Id: org.eclipse.ui.views.log, Version: 1.0.100.v20090731
                                Id: org.eclipse.ui.views.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.views.properties.tabbed, Version: 3.5.0.I20090429-1800
                                Id: org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.win32, Version: 3.2.100.v20090429-1800
                                Id: org.eclipse.ui.workbench, Version: 3.5.1.M20090826-0800a
                                Id: org.eclipse.ui.workbench.compatibility, Version: 3.2.0.I20090429-1800
                                Id: org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.ui.workbench.texteditor, Version: 3.5.0.v20090603
                                Id: org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.update.configurator, Version: 3.3.0.v20090312
                                Id: org.eclipse.update.configurator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.update.core, Version: 3.2.300.v20090525
                                Id: org.eclipse.update.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.update.core.win32, Version: 3.2.100.v20080107
                                Id: org.eclipse.update.scheduler, Version: 3.2.200.v20081127
                                Id: org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.update.ui, Version: 3.2.201.R35x_v20090813
                                Id: org.eclipse.update.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
                                Id: org.eclipse.wst.command.env, Version: 1.0.408.v200903110045
                                Id: org.eclipse.wst.command.env.core, Version: 1.0.204.v200805140020
                                Id: org.eclipse.wst.command.env.core.source, Version: 1.0.204.v200805140020
                                Id: org.eclipse.wst.command.env.doc.user, Version: 1.5.200.v200806092138
                                Id: org.eclipse.wst.command.env.infopop, Version: 1.0.100.v200805301544
                                Id: org.eclipse.wst.command.env.source, Version: 1.0.408.v200903110045
                                Id: org.eclipse.wst.command.env.ui, Version: 1.1.2.v200811200248
                                Id: org.eclipse.wst.command.env.ui.source, Version: 1.1.2.v200811200248
                                Id: org.eclipse.wst.common.api.doc, Version: 1.0.1.v200807181737
                                Id: org.eclipse.wst.common.core, Version: 1.1.201.v200806010600
                                Id: org.eclipse.wst.common.core.source, Version: 1.1.201.v200806010600
                                Id: org.eclipse.wst.common.emf, Version: 1.1.301.v200908181930
                                Id: org.eclipse.wst.common.emf.source, Version: 1.1.301.v200908181930
                                Id: org.eclipse.wst.common.emfworkbench.integration, Version: 1.1.301.v200908101600
                                Id: org.eclipse.wst.common.emfworkbench.integration.source, Version: 1.1.301.v200908101600
                                Id: org.eclipse.wst.common.environment, Version: 1.0.301.v200908101600
                                Id: org.eclipse.wst.common.environment.source, Version: 1.0.301.v200908101600
                                Id: org.eclipse.wst.common.frameworks, Version: 1.1.300.v200904160730
                                Id: org.eclipse.wst.common.frameworks.source, Version: 1.1.300.v200904160730
                                Id: org.eclipse.wst.common.frameworks.ui, Version: 1.1.301.v200908101600
                                Id: org.eclipse.wst.common.frameworks.ui.source, Version: 1.1.301.v200908101600
                                Id: org.eclipse.wst.common.infopop, Version: 1.0.100.v200805301550
                                Id: org.eclipse.wst.common.infopop.source, Version: 1.0.100.v200805301550
                                Id: org.eclipse.wst.common.modulecore, Version: 1.1.301.v201001252130
                                Id: org.eclipse.wst.common.modulecore.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.wst.common.project.facet.core, Version: 1.4.1.v200911141735
                                Id: org.eclipse.wst.common.project.facet.ui, Version: 1.4.1.v200908111817
                                Id: org.eclipse.wst.common.snippets, Version: 1.1.301.v201001280015
                                Id: org.eclipse.wst.common.snippets.source, Version: 1.1.301.v201001280015
                                Id: org.eclipse.wst.common.ui, Version: 1.1.402.v200901262305
                                Id: org.eclipse.wst.common.ui.source, Version: 1.1.402.v200901262305
                                Id: org.eclipse.wst.common.uriresolver, Version: 1.1.301.v200805140415
                                Id: org.eclipse.wst.common.uriresolver.source, Version: 1.1.301.v200805140415
                                Id: org.eclipse.wst.common_core.feature.feature.group, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
                                Id: org.eclipse.wst.common_core.feature.feature.jar, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
                                Id: org.eclipse.wst.common_core.feature.source.feature.group, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
                                Id: org.eclipse.wst.common_core.feature.source.feature.jar, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
                                Id: org.eclipse.wst.common_sdk.feature.feature.group, Version: 3.1.1.v200908102300-7938c9xOCMxOeqvXiT-qoyvN9BV2
                                Id: org.eclipse.wst.common_sdk.feature.feature.jar, Version: 3.1.1.v200908102300-7938c9xOCMxOeqvXiT-qoyvN9BV2
                                Id: org.eclipse.wst.common_ui.feature.feature.group, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
                                Id: org.eclipse.wst.common_ui.feature.feature.jar, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
                                Id: org.eclipse.wst.common_ui.feature.source.feature.group, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
                                Id: org.eclipse.wst.common_ui.feature.source.feature.jar, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
                                Id: org.eclipse.wst.css.core, Version: 1.1.301.v200910161432
                                Id: org.eclipse.wst.css.core.source, Version: 1.1.301.v200910161432
                                Id: org.eclipse.wst.css.ui, Version: 1.0.401.v200907171457
                                Id: org.eclipse.wst.css.ui.source, Version: 1.0.401.v200907171457
                                Id: org.eclipse.wst.doc.user, Version: 1.2.0.v200806052254
                                Id: org.eclipse.wst.dtd.core, Version: 1.1.300.v200904181727
                                Id: org.eclipse.wst.dtd.core.source, Version: 1.1.300.v200904181727
                                Id: org.eclipse.wst.dtd.ui, Version: 1.0.400.v200904300717
                                Id: org.eclipse.wst.dtd.ui.infopop, Version: 1.0.300.v200805140200
                                Id: org.eclipse.wst.dtd.ui.source, Version: 1.0.400.v200904300717
                                Id: org.eclipse.wst.dtdeditor.doc.user, Version: 1.0.500.v200904292308
                                Id: org.eclipse.wst.html.core, Version: 1.1.300.v200903120608
                                Id: org.eclipse.wst.html.core.source, Version: 1.1.300.v200903120608
                                Id: org.eclipse.wst.html.ui, Version: 1.0.401.v200908111935
                                Id: org.eclipse.wst.html.ui.infopop, Version: 1.0.100.v200805301545
                                Id: org.eclipse.wst.html.ui.source, Version: 1.0.401.v200908111935
                                Id: org.eclipse.wst.internet.cache, Version: 1.0.301.v200805140020
                                Id: org.eclipse.wst.internet.cache.source, Version: 1.0.301.v200805140020
                                Id: org.eclipse.wst.internet.monitor.core, Version: 1.0.404.v20090609
                                Id: org.eclipse.wst.internet.monitor.core.source, Version: 1.0.404.v20090609
                                Id: org.eclipse.wst.internet.monitor.ui, Version: 1.0.305.v20100123
                                Id: org.eclipse.wst.internet.monitor.ui.source, Version: 1.0.305.v20100123
                                Id: org.eclipse.wst.jsdt.core, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt.core.source, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt.doc, Version: 1.0.200.v200903120608
                                Id: org.eclipse.wst.jsdt.feature.feature.group, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
                                Id: org.eclipse.wst.jsdt.feature.feature.jar, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
                                Id: org.eclipse.wst.jsdt.feature.source.feature.group, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
                                Id: org.eclipse.wst.jsdt.feature.source.feature.jar, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
                                Id: org.eclipse.wst.jsdt.manipulation, Version: 1.0.100.v200809240707
                                Id: org.eclipse.wst.jsdt.manipulation.source, Version: 1.0.100.v200809240707
                                Id: org.eclipse.wst.jsdt.support.firefox, Version: 1.0.200.v200904290357
                                Id: org.eclipse.wst.jsdt.support.firefox.source, Version: 1.0.200.v200904290357
                                Id: org.eclipse.wst.jsdt.support.ie, Version: 1.0.200.v200904290539
                                Id: org.eclipse.wst.jsdt.support.ie.source, Version: 1.0.200.v200904290539
                                Id: org.eclipse.wst.jsdt.ui, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt.ui.source, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt.web.core, Version: 1.0.201.v201001221931
                                Id: org.eclipse.wst.jsdt.web.core.source, Version: 1.0.201.v201001221931
                                Id: org.eclipse.wst.jsdt.web.ui, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt.web.ui.source, Version: 1.0.201.v2010012803
                                Id: org.eclipse.wst.jsdt_sdk.feature.feature.group, Version: 1.1.2.v200908101420-31384C2ISGNgQFKoEZWyDtYrDdOC
                                Id: org.eclipse.wst.jsdt_sdk.feature.feature.jar, Version: 1.1.2.v200908101420-31384C2ISGNgQFKoEZWyDtYrDdOC
                                Id: org.eclipse.wst.server.core, Version: 1.1.102.v20100123
                                Id: org.eclipse.wst.server.core.source, Version: 1.1.102.v20100123
                                Id: org.eclipse.wst.server.discovery, Version: 1.0.1.v20100210
                                Id: org.eclipse.wst.server.discovery.source, Version: 1.0.1.v20100210
                                Id: org.eclipse.wst.server.ui, Version: 1.1.103.v20100123
                                Id: org.eclipse.wst.server.ui.doc.user, Version: 1.1.150.v200901232034
                                Id: org.eclipse.wst.server.ui.infopop, Version: 1.1.0.v200805140145
                                Id: org.eclipse.wst.server.ui.source, Version: 1.1.103.v20100123
                                Id: org.eclipse.wst.server_core.feature.feature.group, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
                                Id: org.eclipse.wst.server_core.feature.feature.jar, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
                                Id: org.eclipse.wst.server_core.feature.source.feature.group, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
                                Id: org.eclipse.wst.server_core.feature.source.feature.jar, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
                                Id: org.eclipse.wst.server_sdk.feature.feature.group, Version: 3.1.1.v20090728b-7818a90K8IlG7Rp3b5hRfsOFdxYe
                                Id: org.eclipse.wst.server_sdk.feature.feature.jar, Version: 3.1.1.v20090728b-7818a90K8IlG7Rp3b5hRfsOFdxYe
                                Id: org.eclipse.wst.server_ui.feature.feature.group, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
                                Id: org.eclipse.wst.server_ui.feature.feature.jar, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
                                Id: org.eclipse.wst.server_ui.feature.source.feature.group, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
                                Id: org.eclipse.wst.server_ui.feature.source.feature.jar, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
                                Id: org.eclipse.wst.server_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-209L7w311A12343145
                                Id: org.eclipse.wst.server_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-209L7w311A12343145
                                Id: org.eclipse.wst.sse.core, Version: 1.1.402.v201001251516
                                Id: org.eclipse.wst.sse.core.source, Version: 1.1.402.v201001251516
                                Id: org.eclipse.wst.sse.doc.user, Version: 1.1.0.v200805211530
                                Id: org.eclipse.wst.sse.ui, Version: 1.1.102.v200910200227
                                Id: org.eclipse.wst.sse.ui.infopop, Version: 1.0.200.v200805301545
                                Id: org.eclipse.wst.sse.ui.source, Version: 1.1.102.v200910200227
                                Id: org.eclipse.wst.standard.schemas, Version: 1.0.200.v200902270215
                                Id: org.eclipse.wst.validation, Version: 1.2.104.v200911120201
                                Id: org.eclipse.wst.validation.doc.isv, Version: 1.2.101.v200906031420
                                Id: org.eclipse.wst.validation.infopop, Version: 1.0.300.v200806041506
                                Id: org.eclipse.wst.validation.source, Version: 1.2.104.v200911120201
                                Id: org.eclipse.wst.validation.ui, Version: 1.2.104.v200904232035
                                Id: org.eclipse.wst.validation.ui.source, Version: 1.2.104.v200904232035
                                Id: org.eclipse.wst.web, Version: 1.1.301.v200911302230
                                Id: org.eclipse.wst.web.source, Version: 1.1.301.v200911302230
                                Id: org.eclipse.wst.web.ui, Version: 1.1.301.v201001252130
                                Id: org.eclipse.wst.web.ui.infopop, Version: 1.0.300.v200805140415
                                Id: org.eclipse.wst.web.ui.source, Version: 1.1.301.v201001252130
                                Id: org.eclipse.wst.web_core.feature.feature.group, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
                                Id: org.eclipse.wst.web_core.feature.feature.jar, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
                                Id: org.eclipse.wst.web_core.feature.source.feature.group, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
                                Id: org.eclipse.wst.web_core.feature.source.feature.jar, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
                                Id: org.eclipse.wst.web_sdk.feature.feature.group, Version: 3.1.1.v200908120400-7H5778a3PixJeiw96KaEgaNvfKgN
                                Id: org.eclipse.wst.web_sdk.feature.feature.jar, Version: 3.1.1.v200908120400-7H5778a3PixJeiw96KaEgaNvfKgN
                                Id: org.eclipse.wst.web_ui.feature.feature.group, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
                                Id: org.eclipse.wst.web_ui.feature.feature.jar, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
                                Id: org.eclipse.wst.web_ui.feature.source.feature.group, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
                                Id: org.eclipse.wst.web_ui.feature.source.feature.jar, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
                                Id: org.eclipse.wst.web_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-31DF8s733J3E4D56BB
                                Id: org.eclipse.wst.web_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-31DF8s733J3E4D56BB
                                Id: org.eclipse.wst.webtools.doc.user, Version: 1.0.400.v200805150134
                                Id: org.eclipse.wst.ws, Version: 1.1.103.v200903111822
                                Id: org.eclipse.wst.ws.api.doc, Version: 1.0.1.v200807181721
                                Id: org.eclipse.wst.ws.explorer, Version: 1.0.408.v200911241806
                                Id: org.eclipse.wst.ws.explorer.source, Version: 1.0.408.v200911241806
                                Id: org.eclipse.wst.ws.infopop, Version: 1.0.300.v200805140230
                                Id: org.eclipse.wst.ws.parser, Version: 1.0.402.v200901220107
                                Id: org.eclipse.wst.ws.parser.source, Version: 1.0.402.v200901220107
                                Id: org.eclipse.wst.ws.service.policy, Version: 1.0.103.v200905151848
                                Id: org.eclipse.wst.ws.service.policy.source, Version: 1.0.103.v200905151848
                                Id: org.eclipse.wst.ws.service.policy.ui, Version: 1.0.102.v200903070248
                                Id: org.eclipse.wst.ws.service.policy.ui.source, Version: 1.0.102.v200903070248
                                Id: org.eclipse.wst.ws.source, Version: 1.1.103.v200903111822
                                Id: org.eclipse.wst.ws.ui, Version: 1.1.100.v200903112221
                                Id: org.eclipse.wst.ws.ui.source, Version: 1.1.100.v200903112221
                                Id: org.eclipse.wst.ws_core.feature.feature.group, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
                                Id: org.eclipse.wst.ws_core.feature.feature.jar, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
                                Id: org.eclipse.wst.ws_core.feature.source.feature.group, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
                                Id: org.eclipse.wst.ws_core.feature.source.feature.jar, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
                                Id: org.eclipse.wst.ws_sdk.feature.feature.group, Version: 3.1.2.v200911241834-7918d9xVDMuyV3awj9oF1I8PN8Qc
                                Id: org.eclipse.wst.ws_sdk.feature.feature.jar, Version: 3.1.2.v200911241834-7918d9xVDMuyV3awj9oF1I8PN8Qc
                                Id: org.eclipse.wst.ws_ui.feature.feature.group, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
                                Id: org.eclipse.wst.ws_ui.feature.feature.jar, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
                                Id: org.eclipse.wst.ws_ui.feature.source.feature.group, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
                                Id: org.eclipse.wst.ws_ui.feature.source.feature.jar, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
                                Id: org.eclipse.wst.ws_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK
                                Id: org.eclipse.wst.ws_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK
                                Id: org.eclipse.wst.ws_wsdl15.feature.feature.group, Version: 1.5.3.v200903071919-2407w311917141519
                                Id: org.eclipse.wst.ws_wsdl15.feature.feature.jar, Version: 1.5.3.v200903071919-2407w311917141519
                                Id: org.eclipse.wst.wsdl, Version: 1.2.2.v200911111930
                                Id: org.eclipse.wst.wsdl.doc.isv, Version: 1.0.100.v200811240723
                                Id: org.eclipse.wst.wsdl.source, Version: 1.2.2.v200911111930
                                Id: org.eclipse.wst.wsdl.ui, Version: 1.2.202.v200904271449
                                Id: org.eclipse.wst.wsdl.ui.doc.user, Version: 1.0.550.v200901232040
                                Id: org.eclipse.wst.wsdl.ui.source, Version: 1.2.202.v200904271449
                                Id: org.eclipse.wst.wsdl.validation, Version: 1.1.402.v200911251542
                                Id: org.eclipse.wst.wsdl.validation.source, Version: 1.1.402.v200911251542
                                Id: org.eclipse.wst.wsi, Version: 1.0.305.v200902181431
                                Id: org.eclipse.wst.wsi.source, Version: 1.0.305.v200902181431
                                Id: org.eclipse.wst.wsi.ui, Version: 1.0.500.v200901141851
                                Id: org.eclipse.wst.wsi.ui.doc.user, Version: 1.0.401.v200809171927
                                Id: org.eclipse.wst.wsi.ui.source, Version: 1.0.500.v200901141851
                                Id: org.eclipse.wst.xml.core, Version: 1.1.402.v201001222130
                                Id: org.eclipse.wst.xml.core.source, Version: 1.1.402.v201001222130
                                Id: org.eclipse.wst.xml.ui, Version: 1.1.2.v201001222130
                                Id: org.eclipse.wst.xml.ui.infopop, Version: 1.0.300.v200805140200
                                Id: org.eclipse.wst.xml.ui.source, Version: 1.1.2.v201001222130
                                Id: org.eclipse.wst.xml.xpath.core, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xml.xpath.core.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xml.xpath.ui, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xml.xpath.ui.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xml.xpath2.processor, Version: 1.0.0.v200905300355
                                Id: org.eclipse.wst.xml.xpath2.processor.source, Version: 1.0.0.v200905300355
                                Id: org.eclipse.wst.xml_core.feature.feature.group, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
                                Id: org.eclipse.wst.xml_core.feature.feature.jar, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
                                Id: org.eclipse.wst.xml_core.feature.source.feature.group, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
                                Id: org.eclipse.wst.xml_core.feature.source.feature.jar, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
                                Id: org.eclipse.wst.xml_sdk.feature.feature.group, Version: 3.1.1.v200907161031-7A228DXETAqLQFBNMuHkC8-_dRPY
                                Id: org.eclipse.wst.xml_sdk.feature.feature.jar, Version: 3.1.1.v200907161031-7A228DXETAqLQFBNMuHkC8-_dRPY
                                Id: org.eclipse.wst.xml_ui.feature.feature.group, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
                                Id: org.eclipse.wst.xml_ui.feature.feature.jar, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
                                Id: org.eclipse.wst.xml_ui.feature.source.feature.group, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
                                Id: org.eclipse.wst.xml_ui.feature.source.feature.jar, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
                                Id: org.eclipse.wst.xml_userdoc.feature.feature.group, Version: 3.1.1.v200906020459-50FR7AkF77f7MESDKEF
                                Id: org.eclipse.wst.xml_userdoc.feature.feature.jar, Version: 3.1.1.v200906020459-50FR7AkF77f7MESDKEF
                                Id: org.eclipse.wst.xmleditor.doc.user, Version: 1.0.600.v200901231300
                                Id: org.eclipse.wst.xsd.core, Version: 1.1.401.v200903020335
                                Id: org.eclipse.wst.xsd.core.source, Version: 1.1.401.v200903020335
                                Id: org.eclipse.wst.xsd.ui, Version: 1.2.204.v200909021537
                                Id: org.eclipse.wst.xsd.ui.source, Version: 1.2.204.v200909021537
                                Id: org.eclipse.wst.xsdeditor.doc.user, Version: 1.0.700.v200905182240
                                Id: org.eclipse.wst.xsl, Version: 1.0.0.v200905250058
                                Id: org.eclipse.wst.xsl.core, Version: 1.0.1.v200908101420
                                Id: org.eclipse.wst.xsl.core.source, Version: 1.0.1.v200908101420
                                Id: org.eclipse.wst.xsl.debug.ui, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.debug.ui.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.doc, Version: 1.0.0.v200905071815
                                Id: org.eclipse.wst.xsl.feature.feature.group, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
                                Id: org.eclipse.wst.xsl.feature.feature.jar, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
                                Id: org.eclipse.wst.xsl.feature.source.feature.group, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
                                Id: org.eclipse.wst.xsl.feature.source.feature.jar, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
                                Id: org.eclipse.wst.xsl.jaxp.debug, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.jaxp.debug.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.jaxp.debug.ui, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.jaxp.debug.ui.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.jaxp.launching, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.jaxp.launching.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.launching, Version: 1.0.0.v200904241348
                                Id: org.eclipse.wst.xsl.launching.source, Version: 1.0.0.v200904241348
                                Id: org.eclipse.wst.xsl.saxon, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.saxon.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.sdk.documentation, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.source, Version: 1.0.0.v200905250058
                                Id: org.eclipse.wst.xsl.ui, Version: 1.0.100.v200907172129
                                Id: org.eclipse.wst.xsl.ui.source, Version: 1.0.100.v200907172129
                                Id: org.eclipse.wst.xsl.xalan, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl.xalan.source, Version: 1.0.0.v200904240436
                                Id: org.eclipse.wst.xsl_sdk.feature.feature.group, Version: 1.0.2.v200908271520-4-390_CYVxWRxOsrgiEZFM0TlMiJ
                                Id: org.eclipse.wst.xsl_sdk.feature.feature.jar, Version: 1.0.2.v200908271520-4-390_CYVxWRxOsrgiEZFM0TlMiJ
                                Id: org.eclipse.xsd, Version: 2.5.0.v200906151043
                                Id: org.eclipse.xsd.edit, Version: 2.5.0.v200906151043
                                Id: org.hamcrest.core, Version: 1.1.0.v20090501071000
                                Id: org.jdom, Version: 1.0.0.v200806100616
                                Id: org.junit, Version: 3.8.2.v20090203-1005
                                Id: org.junit4, Version: 4.5.0.v20090824
                                Id: org.mortbay.jetty.server, Version: 6.1.15.v200905151201
                                Id: org.mortbay.jetty.util, Version: 6.1.15.v200905182336
                                Id: org.objectweb.asm, Version: 3.1.0.v200803061910
                                Id: org.sat4j.core, Version: 2.1.0.v20090520
                                Id: org.sat4j.pb, Version: 2.1.0.v20090520
                                Id: org.tigris.subversion.clientadapter, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.feature.feature.group, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.feature.feature.jar, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.javahl, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.javahl.feature.feature.group, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.javahl.feature.feature.jar, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.javahl.win32, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.svnkit, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.svnkit.feature.feature.group, Version: 1.6.12
                                Id: org.tigris.subversion.clientadapter.svnkit.feature.feature.jar, Version: 1.6.12
                                Id: org.tigris.subversion.subclipse.core, Version: 1.6.12
                                Id: org.tigris.subversion.subclipse.doc, Version: 1.3.0
                                Id: org.tigris.subversion.subclipse.feature.group, Version: 1.6.12
                                Id: org.tigris.subversion.subclipse.feature.jar, Version: 1.6.12
                                Id: org.tigris.subversion.subclipse.ui, Version: 1.6.12
                                Id: org.tmatesoft.svnkit, Version: 1.3.3.6648
                                Id: org.tmatesoft.svnkit.feature.group, Version: 1.3.3.6648
                                Id: org.tmatesoft.svnkit.feature.jar, Version: 1.3.3.6648
                                Id: org.uddi4j, Version: 2.0.5.v200805270300
                                Id: tooling.org.eclipse.update.feature.default, Version: 1.0.0
                                Id: tooling.osgi.bundle.default, Version: 1.0.0
                                Id: tooling.source.default, Version: 1.0.0
                                Id: toolingcom.adobe.flexbuilder.standalone.product.config.win32.win32.x86, Version: 4.0.1
                                Id: toolingcom.adobe.flexbuilder.standalone.product.configuration, Version: 4.0.1
                                Id: toolingcom.adobe.flexbuilder.standalone.product.ini.win32.win32.x86, Version: 4.0.1
                                Id: toolingcom.adobe.flexbuilder.standalone.product_root.win32.win32.x86, Version: 4.0.1
                                Id: toolingorg.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715
                                Id: toolingorg.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519
                                Id: toolingwin32.win32.x86org.eclipse.core.runtime, Version: 4.0.1
                                Id: toolingwin32.win32.x86org.eclipse.equinox.common, Version: 4.0.1
                                Id: toolingwin32.win32.x86org.eclipse.equinox.ds, Version: 4.0.1
                                Id: toolingwin32.win32.x86org.eclipse.equinox.p2.reconciler.dropins, Version: 4.0.1
                                Id: toolingwin32.win32.x86org.eclipse.equinox.simpleconfigurator, Version: 4.0.1
                                Id: toolingwin32.win32.x86org.eclipse.update.configurator, Version: 4.0.1
                                Bundles in the system:
                                Id: ActionscriptInfoCollector, Version: 0.7.4, Location: reference:file:plugins/ActionscriptInfoCollector_0.7.4.jar
                                Id: FlexASDocGenCommand, Version: 0.7.4, Location: reference:file:plugins/FlexASDocGenCommand_0.7.4.jar
                                Id: FlexPrettyPrintCommand, Version: 0.7.4, Location: reference:file:plugins/FlexPrettyPrintCommand_0.7.4.jar
                                Id: com.adobe.coldfusion.rds.client, Version: 1.0.272885, Location: reference:file:plugins/com.adobe.coldfusion.rds.client_1.0.272885.jar
                                Id: com.adobe.coldfusion.rds.client.nl1, Version: 1.0.1.v20100112266797, Location: reference:file:plugins/com.adobe.coldfusion.rds.client.nl1_1.0.1.v20100112266797.jar
                                Id: com.adobe.flash.codemodel.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.codemodel.core_4.0.1.277662/
                                Id: com.adobe.flash.codemodel.osgi, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.codemodel.osgi_4.0.1.277662/
                                Id: com.adobe.flash.profiler, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.profiler_4.0.1.277662/
                                Id: com.adobe.flash.profiler.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.profiler.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.DCDService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.DCDService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.DCDService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.DCDService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.ajaxbridge, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ajaxbridge_4.0.1.277662/
                                Id: com.adobe.flexbuilder.ajaxbridge.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ajaxbridge.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.as.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.as.editor_4.0.1.277662/
                                Id: com.adobe.flexbuilder.as.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.as.editor.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.axis2, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.axis2_4.0.1.277662/
                                Id: com.adobe.flexbuilder.axis2.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.axis2.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.codemodel, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.codemodel_4.0.1.277662/
                                Id: com.adobe.flexbuilder.codemodel.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.codemodel.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.crimson, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.crimson_4.0.1.277662/
                                Id: com.adobe.flexbuilder.crimson.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.crimson.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.css.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.css.editor_4.0.1.277662/
                                Id: com.adobe.flexbuilder.css.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.css.editor.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.dcrad, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad_4.0.1.277662/
                                Id: com.adobe.flexbuilder.dcrad.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad.derived_4.0.1.277662/
                                Id: com.adobe.flexbuilder.dcrad.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug.e33, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.e33_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug.ui.actions, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui.actions_4.0.1.277662/
                                Id: com.adobe.flexbuilder.debug.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.designview, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.designview_4.0.1.277662/
                                Id: com.adobe.flexbuilder.designview.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.designview.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.editorcore, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editorcore_4.0.1.277662/
                                Id: com.adobe.flexbuilder.editorcore.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editorcore.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.editors.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editors.derived_4.0.1.277662/
                                Id: com.adobe.flexbuilder.editors.derived.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editors.derived.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.exportimport, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.exportimport_4.0.1.277662/
                                Id: com.adobe.flexbuilder.exportimport.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.exportimport.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flashbridge, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flashbridge_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flashbridge.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flashbridge.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flex, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flex_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flexunit, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flexunit.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit.derived_4.0.1.277662/
                                Id: com.adobe.flexbuilder.flexunit.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.help, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.help_4.0.1.277662/
                                Id: com.adobe.flexbuilder.help.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.help.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.importartwork, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.importartwork_4.0.1.277662/
                                Id: com.adobe.flexbuilder.importartwork.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.importartwork.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.json, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.json_4.0.1.277662/
                                Id: com.adobe.flexbuilder.launching.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.launching.ui_4.0.1.277662/
                                Id: com.adobe.flexbuilder.launching.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.launching.ui.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.monitors.network, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.monitors.network_4.0.1.277662/
                                Id: com.adobe.flexbuilder.monitors.network.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.monitors.network.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.multisdk, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.multisdk_4.0.1.277662/
                                Id: com.adobe.flexbuilder.mxml.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxml.editor_4.0.1.277662/
                                Id: com.adobe.flexbuilder.mxml.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxml.editor.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.mxmlmodel, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxmlmodel_4.0.1.277662/
                                Id: com.adobe.flexbuilder.project, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project_4.0.1.277662/
                                Id: com.adobe.flexbuilder.project.e35, Version: 1.0.0.201001080934, Location: reference:file:plugins/com.adobe.flexbuilder.project.e35_1.0.0.201001080934.jar
                                Id: com.adobe.flexbuilder.project.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.project.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.ui_4.0.1.277662/
                                Id: com.adobe.flexbuilder.project.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.ui.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.BlazeDSService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.BlazeDSService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.CFService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.CFService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.CFService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.CFService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.HTTPService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.HTTPService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.HTTPService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.HTTPService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.J2EEService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.J2EEService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.J2EEService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.J2EEService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.LCDSService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.LCDSService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.PHPService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.PHPService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.PHPService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.PHPService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.StaticContentService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.StaticContentService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.StaticContentService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.StaticContentService.nl1_4.0.1.2776 62/
                                Id: com.adobe.flexbuilder.services.WEBService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.WEBService.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService.derived_4.0.1.277662/
                                Id: com.adobe.flexbuilder.services.WEBService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.standalone, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.standalone_4.0.1.277662/
                                Id: com.adobe.flexbuilder.standalone.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.standalone.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.tengine, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.tengine_4.0.1.277662/
                                Id: com.adobe.flexbuilder.tengine.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.tengine.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ui_4.0.1.277662/
                                Id: com.adobe.flexbuilder.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ui.nl1_4.0.1.277662/
                                Id: com.adobe.flexbuilder.utils.osnative, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.utils.osnative_4.0.1.277662/
                                Id: com.adobe.flexbuilder.utils.osnative.win, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.utils.osnative.win_4.0.1.277662/
                                Id: com.adobe.flexide.amt, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.amt_4.0.1.277662/
                                Id: com.adobe.flexide.as.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.as.core_4.0.1.277662/
                                Id: com.adobe.flexide.as.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.as.core.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.communityhelp, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.communityhelp_4.0.1.277662/
                                Id: com.adobe.flexide.communityhelp.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.communityhelp.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.css.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.css.core_4.0.1.277662/
                                Id: com.adobe.flexide.css.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.css.core.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.designitems, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.designitems_4.0.1.277662/
                                Id: com.adobe.flexide.editorcore, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.editorcore_4.0.1.277662/
                                Id: com.adobe.flexide.editorcore.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.editorcore.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.embeddedplayer, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.embeddedplayer_4.0.1.277662/
                                Id: com.adobe.flexide.exportimport, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.exportimport_4.0.1.277662/
                                Id: com.adobe.flexide.exportimport.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.exportimport.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.externaleditors, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.externaleditors_4.0.1.277662/
                                Id: com.adobe.flexide.externaleditors.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.externaleditors.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.fonts, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.fonts_4.0.1.277662/
                                Id: com.adobe.flexide.launching, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.launching_4.0.1.277662/
                                Id: com.adobe.flexide.launching.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.launching.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.multisdk.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.multisdk.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.mxml.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.mxml.core_4.0.1.277662/
                                Id: com.adobe.flexide.mxml.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.mxml.core.nl1_4.0.1.277662/
                                Id: com.adobe.flexide.nativelibs, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.nativelibs_4.0.1.277662/
                                Id: com.adobe.flexide.playerview, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.playerview_4.0.1.277662/
                                Id: com.adobe.flexide.refactoring.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.refactoring.core_4.0.1.277662/
                                Id: com.adobe.flexide.refactoring.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.refactoring.core.nl1_4.0.1.277662/
                                Id: com.adobe.model.core, Version: 1.0.2.v20100315273147, Location: reference:file:plugins/com.adobe.model.core_1.0.2.v20100315273147.jar
                                Id: com.collabnet.subversion.merge, Version: 2.1.0, Location: reference:file:plugins/com.collabnet.subversion.merge_2.1.0.jar
                                Id: com.crispico.flexbridge, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flexbridge_1.0.0.M0_2010-06-11.jar
                                Id: com.crispico.flower.mp, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp_1.0.0.M0_2010-06-11.jar
                                Id: com.crispico.flower.mp.dependencies.internal, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.dependencies.internal_1.0.0.M0_2010-06-11.j ar
                                Id: com.crispico.flower.mp.eclipse, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse_1.0.0.M0_2010-06-11/
                                Id: com.crispico.flower.mp.eclipse.compare.base, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.compare.base_1.0.0.M0_2010-06-11.ja r
                                Id: com.crispico.flower.mp.eclipse.compare.codesync, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.compare.codesync_1.0.0.M0_2010-06-1 1.jar
                                Id: com.crispico.flower.mp.eclipse.uml4as, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.uml4as_1.0.0.M0_2010-06-11.jar
                                Id: com.crispico.flower.mp.metamodel.classmetamodel, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.classmetamodel_1.0.0.M0_2010-06-1 1.jar
                                Id: com.crispico.flower.mp.metamodel.codesync, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.codesync_1.0.0.M0_2010-06-11.jar
                                Id: com.crispico.flower.mp.metamodel.codesyncas, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.codesyncas_1.0.0.M0_2010-06-11.ja r
                                Id: com.crispico.flower.mp.metamodelset.uml4asfile, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodelset.uml4asfile_1.0.0.M0_2010-06-11 .jar
                                Id: com.crispico.flower.mp.propertieseditor, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.propertieseditor_1.0.0.M0_2010-06-11/
                                Id: com.ibm.icu, Version: 4.0.1.v20090822, Location: reference:file:plugins/com.ibm.icu_4.0.1.v20090822.jar
                                Id: com.idefactory.enterprisehelp, Version: 1.0.8.beta, Location: reference:file:plugins/com.idefactory.enterprisehelp_1.0.8.beta.jar
                                Id: com.idefactory.fxsdk, Version: 1.0.1, Location: reference:file:plugins/com.idefactory.fxsdk_1.0.1.jar
                                Id: com.idefactory.rhino, Version: 1.0.0, Location: reference:file:plugins/com.idefactory.rhino_1.0.0.jar
                                Id: com.jcraft.jsch, Version: 0.1.41.v200903070017, Location: reference:file:plugins/com.jcraft.jsch_0.1.41.v200903070017.jar
                                Id: com.sun.jna, Version: 3.2.3, Location: reference:file:plugins/com.sun.jna_3.2.3.jar
                                Id: java_cup.runtime, Version: 0.10.0.v200803061811, Location: reference:file:plugins/java_cup.runtime_0.10.0.v200803061811.jar
                                Id: javax.activation, Version: 1.1.0.v200906290531, Location: reference:file:plugins/javax.activation_1.1.0.v200906290531.jar
                                Id: javax.mail, Version: 1.4.0.v200905040518, Location: reference:file:plugins/javax.mail_1.4.0.v200905040518.jar
                                Id: javax.servlet, Version: 2.5.0.v200806031605, Location: reference:file:plugins/javax.servlet_2.5.0.v200806031605.jar
                                Id: javax.servlet.jsp, Version: 2.0.0.v200806031607, Location: reference:file:plugins/javax.servlet.jsp_2.0.0.v200806031607.jar
                                Id: javax.wsdl, Version: 1.5.1.v200806030408, Location: reference:file:plugins/javax.wsdl_1.5.1.v200806030408.jar
                                Id: javax.xml, Version: 1.3.4.v200902170245, Location: reference:file:plugins/javax.xml_1.3.4.v200902170245.jar
                                Id: javax.xml.rpc, Version: 1.1.0.v200905122109, Location: reference:file:plugins/javax.xml.rpc_1.1.0.v200905122109/
                                Id: javax.xml.soap, Version: 1.2.0.v200905122109, Location: reference:file:plugins/javax.xml.soap_1.2.0.v200905122109/
                                Id: net.sourceforge.lpg.lpgjavaruntime, Version: 1.1.0.v200803061910, Location: reference:file:plugins/net.sourceforge.lpg.lpgjavaruntime_1.1.0.v200803061910.jar
                                Id: org.apache.ant, Version: 1.7.1.v20090120-1145, Location: reference:file:plugins/org.apache.ant_1.7.1.v20090120-1145/
                                Id: org.apache.axis, Version: 1.4.0.v200905122109, Location: reference:file:plugins/org.apache.axis_1.4.0.v200905122109/
                                Id: org.apache.bcel, Version: 5.2.0.v200803061811, Location: reference:file:plugins/org.apache.bcel_5.2.0.v200803061811.jar
                                Id: org.apache.commons.codec, Version: 1.3.0.v20080530-1600, Location: reference:file:plugins/org.apache.commons.codec_1.3.0.v20080530-1600.jar
                                Id: org.apache.commons.collections, Version: 3.2.0.v200803061811, Location: reference:file:plugins/org.apache.commons.collections_3.2.0.v200803061811.jar
                                Id: org.apache.commons.discovery, Version: 0.2.0.v200905122109, Location: reference:file:plugins/org.apache.commons.discovery_0.2.0.v200905122109/
                                Id: org.apache.commons.el, Version: 1.0.0.v200806031608, Location: reference:file:plugins/org.apache.commons.el_1.0.0.v200806031608.jar
                                Id: org.apache.commons.httpclient, Version: 3.1.0.v20080605-1935, Location: reference:file:plugins/org.apache.commons.httpclient_3.1.0.v20080605-1935.jar
                                Id: org.apache.commons.jxpath, Version: 1.2.0.v20080604-1500, Location: reference:file:plugins/org.apache.commons.jxpath_1.2.0.v20080604-1500.jar
                                Id: org.apache.commons.lang, Version: 2.1.0.v200803061811, Location: reference:file:plugins/org.apache.commons.lang_2.1.0.v200803061811.jar
                                Id: org.apache.commons.lang, Version: 2.4.0.v20081016-1030, Location: reference:file:plugins/org.apache.commons.lang_2.4.0.v20081016-1030.jar
                                Id: org.apache.commons.logging, Version: 1.0.4.v200904062259, Location: reference:file:plugins/org.apache.commons.logging_1.0.4.v200904062259.jar
                                Id: org.apache.jasper, Version: 5.5.17.v200903231320, Location: reference:file:plugins/org.apache.jasper_5.5.17.v200903231320.jar
                                Id: org.apache.log4j, Version: 1.2.13.v200903072027, Location: reference:file:plugins/org.apache.log4j_1.2.13.v200903072027.jar
                                Id: org.apache.lucene, Version: 1.9.1.v20080530-1600, Location: reference:file:plugins/org.apache.lucene_1.9.1.v20080530-1600.jar
                                Id: org.apache.lucene.analysis, Version: 1.9.1.v20080530-1600, Location: reference:file:plugins/org.apache.lucene.analysis_1.9.1.v20080530-1600.jar
                                Id: org.apache.oro, Version: 2.0.8.v200903061218, Location: reference:file:plugins/org.apache.oro_2.0.8.v200903061218.jar
                                Id: org.apache.velocity, Version: 1.5.0.v200905192330, Location: reference:file:plugins/org.apache.velocity_1.5.0.v200905192330.jar
                                Id: org.apache.wsil4j, Version: 1.0.0.v200901211807, Location: reference:file:plugins/org.apache.wsil4j_1.0.0.v200901211807.jar
                                Id: org.apache.xalan, Version: 2.7.1.v200905122109, Location: reference:file:plugins/org.apache.xalan_2.7.1.v200905122109.jar
                                Id: org.apache.xerces, Version: 2.9.0.v200909240008, Location: reference:file:plugins/org.apache.xerces_2.9.0.v200909240008.jar
                                Id: org.apache.xml.resolver, Version: 1.2.0.v200902170519, Location: reference:file:plugins/org.apache.xml.resolver_1.2.0.v200902170519.jar
                                Id: org.apache.xml.serializer, Version: 2.7.1.v200902170519, Location: reference:file:plugins/org.apache.xml.serializer_2.7.1.v200902170519.jar
                                Id: org.eclipse.ant.core, Version: 3.2.100.v20090817_r351, Location: reference:file:plugins/org.eclipse.ant.core_3.2.100.v20090817_r351.jar
                                Id: org.eclipse.ant.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ant.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ant.ui, Version: 3.4.2.v20091204_r352, Location: reference:file:plugins/org.eclipse.ant.ui_3.4.2.v20091204_r352.jar
                                Id: org.eclipse.compare, Version: 3.5.0.I20090514-0808, Location: reference:file:plugins/org.eclipse.compare_3.5.0.I20090514-0808.jar
                                Id: org.eclipse.compare.core, Version: 3.5.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.compare.core_3.5.0.I20090430-0408.jar
                                Id: org.eclipse.compare.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.compare.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.compare.win32, Version: 1.0.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.compare.win32_1.0.0.I20090430-0408.jar
                                Id: org.eclipse.compare.win32.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.win32.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.boot, Version: 3.1.100.v20080218, Location: reference:file:plugins/org.eclipse.core.boot_3.1.100.v20080218.jar
                                Id: org.eclipse.core.boot.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.boot.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.commands, Version: 3.5.0.I20090525-2000, Location: reference:file:plugins/org.eclipse.core.commands_3.5.0.I20090525-2000.jar
                                Id: org.eclipse.core.commands.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.commands.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.contenttype, Version: 3.4.1.R35x_v20090826-0451, Location: reference:file:plugins/org.eclipse.core.contenttype_3.4.1.R35x_v20090826-0451.jar
                                Id: org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.databinding, Version: 1.2.0.M20090819-0800, Location: reference:file:plugins/org.eclipse.core.databinding_1.2.0.M20090819-0800.jar
                                Id: org.eclipse.core.databinding.beans, Version: 1.2.0.I20090525-2000, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.2.0.I20090525-2000.jar
                                Id: org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.databinding.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.databinding.observable, Version: 1.2.0.M20090902-0800, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.2.0.M20090902-0800.jar
                                Id: org.eclipse.core.databinding.property, Version: 1.2.0.M20090819-0800, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.2.0.M20090819-0800.jar
                                Id: org.eclipse.core.expressions, Version: 3.4.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.expressions_3.4.100.v20090429-1800.jar
                                Id: org.eclipse.core.expressions.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.expressions.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.filebuffers, Version: 3.5.0.v20090526-2000, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.5.0.v20090526-2000.jar
                                Id: org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.filesystem, Version: 1.2.0.v20090507, Location: reference:file:plugins/org.eclipse.core.filesystem_1.2.0.v20090507.jar
                                Id: org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.filesystem.win32.x86, Version: 1.1.0.v20080604-1400, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-1400.jar
                                Id: org.eclipse.core.jobs, Version: 3.4.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.jobs_3.4.100.v20090429-1800.jar
                                Id: org.eclipse.core.jobs.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.jobs.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.net, Version: 1.2.1.r35x_20090812-1200, Location: reference:file:plugins/org.eclipse.core.net_1.2.1.r35x_20090812-1200.jar
                                Id: org.eclipse.core.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.net.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.net.win32.x86, Version: 1.0.0.I20080909, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.0.I20080909.jar
                                Id: org.eclipse.core.resources, Version: 3.5.1.R35x_v20090826-0451, Location: reference:file:plugins/org.eclipse.core.resources_3.5.1.R35x_v20090826-0451.jar
                                Id: org.eclipse.core.resources.compatibility, Version: 3.4.0.v20090505, Location: reference:file:plugins/org.eclipse.core.resources.compatibility_3.4.0.v20090505.jar
                                Id: org.eclipse.core.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.resources.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.resources.win32.x86, Version: 3.5.0.v20081020, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_3.5.0.v20081020.jar
                                Id: org.eclipse.core.runtime, Version: 3.5.0.v20090525, Location: reference:file:plugins/org.eclipse.core.runtime_3.5.0.v20090525.jar
                                Id: org.eclipse.core.runtime.compatibility, Version: 3.2.0.v20090413, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility_3.2.0.v20090413.jar
                                Id: org.eclipse.core.runtime.compatibility.auth, Version: 3.2.100.v20090413, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.auth_3.2.100.v20090413.jar
                                Id: org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043 401.jar
                                Id: org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401.j ar
                                Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.2.200.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.2.200.v20090429- 1800/
                                Id: org.eclipse.core.runtime.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.core.variables, Version: 3.2.200.v20090521, Location: reference:file:plugins/org.eclipse.core.variables_3.2.200.v20090521.jar
                                Id: org.eclipse.core.variables.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.variables.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.cvs, Version: 1.0.300.v200909170800, Location: reference:file:plugins/org.eclipse.cvs_1.0.300.v200909170800.jar
                                Id: org.eclipse.datatools.connectivity, Version: 1.1.3.v201001230803, Location: reference:file:plugins/org.eclipse.datatools.connectivity_1.1.3.v201001230803.jar
                                Id: org.eclipse.datatools.connectivity.apache.derby, Version: 1.0.100.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby_1.0.100.v200906020 900.jar
                                Id: org.eclipse.datatools.connectivity.apache.derby.dbdefinition, Version: 1.0.2.v200906161815, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby.dbdefinition_1.0.2 .v200906161815.jar
                                Id: org.eclipse.datatools.connectivity.apache.derby.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby.ui_1.0.1.v20090602 0900.jar
                                Id: org.eclipse.datatools.connectivity.console.profile, Version: 1.0.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.connectivity.console.profile_1.0.0.v20090602 0553.jar
                                Id: org.eclipse.datatools.connectivity.db.generic, Version: 1.0.1.v200908130547, Location: reference:file:plugins/org.eclipse.datatools.connectivity.db.generic_1.0.1.v200908130547. jar
                                Id: org.eclipse.datatools.connectivity.db.generic.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.db.generic.ui_1.0.1.v2009060209 00.jar
                                Id: org.eclipse.datatools.connectivity.dbdefinition.genericJDBC, Version: 1.0.1.v200906161815, Location: reference:file:plugins/org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_1.0.1. v200906161815.jar
                                Id: org.eclipse.datatools.connectivity.oda, Version: 3.2.2.v201001270833, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda_3.2.2.v201001270833.jar
                                Id: org.eclipse.datatools.connectivity.oda.consumer, Version: 3.2.2.v201001261113, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.consumer_3.2.2.v20100126111 3.jar
                                Id: org.eclipse.datatools.connectivity.oda.design, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.design_3.2.2.v201001210350. jar
                                Id: org.eclipse.datatools.connectivity.oda.design.ui, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.design.ui_3.2.2.v2010012103 50.jar
                                Id: org.eclipse.datatools.connectivity.oda.flatfile, Version: 3.1.1.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.flatfile_3.1.1.v20100113142 0.jar
                                Id: org.eclipse.datatools.connectivity.oda.flatfile.ui, Version: 3.1.1.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.flatfile.ui_3.1.1.v20100113 1420.jar
                                Id: org.eclipse.datatools.connectivity.oda.profile, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.profile_3.2.2.v201001210350 .jar
                                Id: org.eclipse.datatools.connectivity.oda.template.ui, Version: 3.2.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.2.0.v20090602 0553.jar
                                Id: org.eclipse.datatools.connectivity.sqm.core, Version: 1.1.1.v201001180200, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.core_1.1.1.v201001180200.ja r
                                Id: org.eclipse.datatools.connectivity.sqm.core.ui, Version: 1.1.100.v200910270525, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.core.ui_1.1.100.v2009102705 25.jar
                                Id: org.eclipse.datatools.connectivity.sqm.server.ui, Version: 1.1.100.v200910270503, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.server.ui_1.1.100.v20091027 0503.jar
                                Id: org.eclipse.datatools.connectivity.ui, Version: 1.1.5.v201001190218, Location: reference:file:plugins/org.eclipse.datatools.connectivity.ui_1.1.5.v201001190218.jar
                                Id: org.eclipse.datatools.connectivity.ui.dse, Version: 1.1.3.v201001270323, Location: reference:file:plugins/org.eclipse.datatools.connectivity.ui.dse_1.1.3.v201001270323.jar
                                Id: org.eclipse.datatools.doc.user, Version: 1.7.0.20090521092446, Location: reference:file:plugins/org.eclipse.datatools.doc.user_1.7.0.20090521092446.jar
                                Id: org.eclipse.datatools.enablement.finfo, Version: 1.5.1.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.finfo_1.5.1.v200906161800.jar
                                Id: org.eclipse.datatools.enablement.hsqldb, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.hsqldb.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb.dbdefinition_1.0.0.v200906 161800.jar
                                Id: org.eclipse.datatools.enablement.hsqldb.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb.ui_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries_1.0.1.v2009060209 00.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition_1.0. 3.v200906161800.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.iseries.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries.ui_1.0.0.v2009060 20900.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw_1.0.1.v200906020900.j ar
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition_1.0.3.v2 00906161800.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.luw.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw.ui_1.0.1.v20090602090 0.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries_1.0.1.v2009060209 00.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition_1.0. 3.v200906161800.jar
                                Id: org.eclipse.datatools.enablement.ibm.db2.zseries.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries.ui_1.0.0.v2009060 20900.jar
                                Id: org.eclipse.datatools.enablement.ibm.informix, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix_1.0.0.v200906020900. jar
                                Id: org.eclipse.datatools.enablement.ibm.informix.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix.dbdefinition_1.0.3.v 200906161800.jar
                                Id: org.eclipse.datatools.enablement.ibm.informix.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix.ui_1.0.1.v2009060209 00.jar
                                Id: org.eclipse.datatools.enablement.ibm.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.ui_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.ingres, Version: 1.0.0.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres_1.0.0.v200906111150.jar
                                Id: org.eclipse.datatools.enablement.ingres.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres.dbdefinition_1.0.0.v200906 161800.jar
                                Id: org.eclipse.datatools.enablement.ingres.ui, Version: 1.0.0.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres.ui_1.0.0.v200906111150.jar
                                Id: org.eclipse.datatools.enablement.jdt.classpath, Version: 1.0.1.v200909240342, Location: reference:file:plugins/org.eclipse.datatools.enablement.jdt.classpath_1.0.1.v200909240342 .jar
                                Id: org.eclipse.datatools.enablement.msft.sqlserver, Version: 1.0.1.v201001180222, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver_1.0.1.v20100118022 2.jar
                                Id: org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition_1.0.0 .v200906161800.jar
                                Id: org.eclipse.datatools.enablement.msft.sqlserver.ui, Version: 1.0.1.v200908130512, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver.ui_1.0.1.v20090813 0512.jar
                                Id: org.eclipse.datatools.enablement.mysql, Version: 1.0.2.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql_1.0.2.v201002041110.jar
                                Id: org.eclipse.datatools.enablement.mysql.dbdefinition, Version: 1.0.4.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql.dbdefinition_1.0.4.v2009061 61800.jar
                                Id: org.eclipse.datatools.enablement.mysql.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql.ui_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.oda.ws, Version: 1.2.2.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.ws_1.2.2.v201001131420.jar
                                Id: org.eclipse.datatools.enablement.oda.ws.ui, Version: 1.2.2.v201001260400, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.ws.ui_1.2.2.v201001260400.jar
                                Id: org.eclipse.datatools.enablement.oda.xml, Version: 1.2.1.v201001151620, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.xml_1.2.1.v201001151620.jar
                                Id: org.eclipse.datatools.enablement.oda.xml.ui, Version: 1.2.1.v201001191820, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.xml.ui_1.2.1.v201001191820.ja r
                                Id: org.eclipse.datatools.enablement.oracle, Version: 1.0.0.v200908130544, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle_1.0.0.v200908130544.jar
                                Id: org.eclipse.datatools.enablement.oracle.dbdefinition, Version: 1.0.100.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle.dbdefinition_1.0.100.v2009 06161800.jar
                                Id: org.eclipse.datatools.enablement.oracle.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle.ui_1.0.1.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.postgresql, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql_1.0.1.v200906020900.ja r
                                Id: org.eclipse.datatools.enablement.postgresql.dbdefinition, Version: 1.0.1.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql.dbdefinition_1.0.1.v20 0906161800.jar
                                Id: org.eclipse.datatools.enablement.postgresql.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql.ui_1.0.0.v200906020900 .jar
                                Id: org.eclipse.datatools.enablement.sap.maxdb, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.sap.maxdb.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb.dbdefinition_1.0.0.v200 906161800.jar
                                Id: org.eclipse.datatools.enablement.sap.maxdb.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb.ui_1.0.0.v200906020900. jar
                                Id: org.eclipse.datatools.enablement.sqlite, Version: 1.0.0.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite_1.0.0.v201002041110.jar
                                Id: org.eclipse.datatools.enablement.sqlite.dbdefinition, Version: 1.0.1.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite.dbdefinition_1.0.1.v201002 041110.jar
                                Id: org.eclipse.datatools.enablement.sqlite.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite.ui_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.sybase, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase_1.0.1.v200906020900.jar
                                Id: org.eclipse.datatools.enablement.sybase.asa, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa_1.0.1.v200906020900.ja r
                                Id: org.eclipse.datatools.enablement.sybase.asa.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.dbdefinition_1.0.0.v20 0906161800.jar
                                Id: org.eclipse.datatools.enablement.sybase.asa.models, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.models_1.0.0.v20090602 0900.jar
                                Id: org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples, Version: 2.5.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.exa mples_2.5.0.200810071.jar
                                Id: org.eclipse.datatools.enablement.sybase.asa.ui, Version: 1.0.1.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.ui_1.0.1.v200906111150 .jar
                                Id: org.eclipse.datatools.enablement.sybase.ase, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase_1.0.1.v200906020900.ja r
                                Id: org.eclipse.datatools.enablement.sybase.ase.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.dbdefinition_1.0.0.v20 0906161800.jar
                                Id: org.eclipse.datatools.enablement.sybase.ase.models, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.models_1.0.1.v20090602 0900.jar
                                Id: org.eclipse.datatools.enablement.sybase.ase.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.ui_1.0.1.v200906020900 .jar
                                Id: org.eclipse.datatools.enablement.sybase.models, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.models_1.0.0.v200906020900 .jar
                                Id: org.eclipse.datatools.enablement.sybase.ui, Version: 1.0.0.v200906090458, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ui_1.0.0.v200906090458.jar
                                Id: org.eclipse.datatools.help, Version: 1.5.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.help_1.5.0.v200906020553.jar
                                Id: org.eclipse.datatools.modelbase.dbdefinition, Version: 1.0.1.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.dbdefinition_1.0.1.v200906022249.j ar
                                Id: org.eclipse.datatools.modelbase.derby, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.modelbase.derby_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.modelbase.sql, Version: 1.0.3.v200912150851, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql_1.0.3.v200912150851.jar
                                Id: org.eclipse.datatools.modelbase.sql.edit, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.edit_1.0.0.v200906022249.jar
                                Id: org.eclipse.datatools.modelbase.sql.query, Version: 1.0.2.v201002020730, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.query_1.0.2.v201002020730.jar
                                Id: org.eclipse.datatools.modelbase.sql.query.edit, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.query.edit_1.0.0.v200906022249 .jar
                                Id: org.eclipse.datatools.modelbase.sql.xml.query, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.xml.query_1.0.0.v200906022249. jar
                                Id: org.eclipse.datatools.oda.cshelp, Version: 1.1.1.v200907031118, Location: reference:file:plugins/org.eclipse.datatools.oda.cshelp_1.1.1.v200907031118.jar
                                Id: org.eclipse.datatools.sqltools.common.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.common.ui_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.data.core, Version: 1.1.0.v200910161545, Location: reference:file:plugins/org.eclipse.datatools.sqltools.data.core_1.1.0.v200910161545.jar
                                Id: org.eclipse.datatools.sqltools.data.ui, Version: 1.1.2.v200912080845, Location: reference:file:plugins/org.eclipse.datatools.sqltools.data.ui_1.1.2.v200912080845.jar
                                Id: org.eclipse.datatools.sqltools.db.derby, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.derby_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.sqltools.db.derby.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.derby.ui_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.sqltools.db.generic, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.generic_1.0.0.v200906020900.jar
                                Id: org.eclipse.datatools.sqltools.db.generic.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.generic.ui_1.0.0.v200906020900.j ar
                                Id: org.eclipse.datatools.sqltools.ddlgen.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.ddlgen.ui_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.debugger.core, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.debugger.core_1.0.0.v200906022302.j ar
                                Id: org.eclipse.datatools.sqltools.debugger.core.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.debugger.core.ui_1.0.0.v20090602230 2.jar
                                Id: org.eclipse.datatools.sqltools.editor.core, Version: 1.0.0.v201001150815, Location: reference:file:plugins/org.eclipse.datatools.sqltools.editor.core_1.0.0.v201001150815.jar
                                Id: org.eclipse.datatools.sqltools.editor.core.ui, Version: 1.0.0.v201001150815, Location: reference:file:plugins/org.eclipse.datatools.sqltools.editor.core.ui_1.0.0.v201001150815. jar
                                Id: org.eclipse.datatools.sqltools.parsers.sql, Version: 1.0.1.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql_1.0.1.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.parsers.sql.lexer, Version: 1.0.1.v200906030654, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.lexer_1.0.1.v2009060306 54.jar
                                Id: org.eclipse.datatools.sqltools.parsers.sql.query, Version: 1.0.1.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.query_1.0.1.v2009060223 02.jar
                                Id: org.eclipse.datatools.sqltools.parsers.sql.xml.query, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.xml.query_1.0.0.v200906 022302.jar
                                Id: org.eclipse.datatools.sqltools.plan, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.plan_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.result, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.result_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.result.ui, Version: 1.0.2.v201002011830, Location: reference:file:plugins/org.eclipse.datatools.sqltools.result.ui_1.0.2.v201002011830.jar
                                Id: org.eclipse.datatools.sqltools.routineeditor, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.routineeditor_1.0.0.v200906022302.j ar
                                Id: org.eclipse.datatools.sqltools.routineeditor.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.routineeditor.ui_1.0.0.v20090602230 2.jar
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor, Version: 1.1.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor_1.1.0.v200906022 302.jar
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui, Version: 1.1.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor.ui_1.1.0.2008100 71.jar
                                Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages, Version: 1.1.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages_1.1.0.2 00810071.jar
                                Id: org.eclipse.datatools.sqltools.sql, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sql_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.sql.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sql.ui_1.0.0.v200906022302.jar
                                Id: org.eclipse.datatools.sqltools.sqlbuilder, Version: 1.0.0.v201001200600, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqlbuilder_1.0.0.v201001200600.jar
                                Id: org.eclipse.datatools.sqltools.sqleditor, Version: 1.0.1.v200912241345, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqleditor_1.0.1.v200912241345.jar
                                Id: org.eclipse.datatools.sqltools.sqlscrapbook, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqlscrapbook_1.0.0.v200906022302.ja r
                                Id: org.eclipse.datatools.sqltools.tabledataeditor, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.tabledataeditor_1.0.0.v200906022302 .jar
                                Id: org.eclipse.debug.core, Version: 3.5.0.v20090526-1600, Location: reference:file:plugins/org.eclipse.debug.core_3.5.0.v20090526-1600.jar
                                Id: org.eclipse.debug.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.debug.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.debug.ui, Version: 3.5.1.v20090811_r351, Location: reference:file:plugins/org.eclipse.debug.ui_3.5.1.v20090811_r351.jar
                                Id: org.eclipse.debug.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.debug.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.draw2d, Version: 3.5.2.v20091126-1908, Location: reference:file:plugins/org.eclipse.draw2d_3.5.2.v20091126-1908.jar
                                Id: org.eclipse.ecf, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf_3.0.0.v20090831-1906.jar
                                Id: org.eclipse.ecf.filetransfer, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_3.0.0.v20090831-1906.jar
                                Id: org.eclipse.ecf.identity, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.identity_3.0.0.v20090831-1906.jar
                                Id: org.eclipse.ecf.provider.filetransfer, Version: 3.0.1.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.jar
                                Id: org.eclipse.ecf.provider.filetransfer.httpclient, Version: 3.0.1.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient_3.0.1.v20090831-1 906.jar
                                Id: org.eclipse.ecf.provider.filetransfer.httpclient.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v200908 31-1906.jar
                                Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20090831-1906.jar
                                Id: org.eclipse.ecf.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.0.0.v20090831-1906.jar
                                Id: org.eclipse.emf, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ant, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ant_2.4.0.v200906151043.jar
                                Id: org.eclipse.emf.codegen, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.codegen.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ecore_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.codegen.ecore.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ecore.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.codegen.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.common, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.common_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.common.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.common.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.converter, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.converter_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.databinding, Version: 1.1.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.databinding_1.1.0.v200906151043.jar
                                Id: org.eclipse.emf.databinding.edit, Version: 1.1.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.databinding.edit_1.1.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore.change, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore.change.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.change.edit_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.edit_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore.editor, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.editor_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.ecore.xmi, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.edit_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.edit.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.edit.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.exporter, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.exporter_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.importer, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.importer.ecore, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.ecore_2.4.0.v200906151043.jar
                                Id: org.eclipse.emf.importer.java, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.java_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.importer.rose, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.rose_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore.editor, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore.editor_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore2ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2ecore_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore2ecore.editor, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2.4.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore2xml, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2xml_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ecore2xml.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.emf.mapping.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ui_2.5.0.v200906151043.jar
                                Id: org.eclipse.equinox.app, Version: 1.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.app_1.2.0.v20090520-1800.jar
                                Id: org.eclipse.equinox.common, Version: 3.5.1.R35x_v20090807-1100, Location: reference:file:plugins/org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100.jar
                                Id: org.eclipse.equinox.common.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.common.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.concurrent, Version: 1.0.1.R35x_v20100209, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.0.1.R35x_v20100209.jar
                                Id: org.eclipse.equinox.ds, Version: 1.1.1.R35x_v20090806, Location: initial@reference:file:plugins/org.eclipse.equinox.ds_1.1.1.R35x_v20090806.jar/
                                Id: org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.frameworkadmin, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.100.v20090520-1905. jar
                                Id: org.eclipse.equinox.http.jetty, Version: 2.0.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar
                                Id: org.eclipse.equinox.http.registry, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar
                                Id: org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.http.servlet, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar
                                Id: org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.200.v20090520-1800.jar
                                Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.100.v20090520-1800.jar
                                Id: org.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
                                Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519/
                                Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.0.101.R35x_v20090721, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v20090721. jar
                                Id: org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v200911210434 01.jar
                                Id: org.eclipse.equinox.p2.console, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.core, Version: 1.0.101.R35x_v20090819, Location: reference:file:plugins/org.eclipse.equinox.p2.core_1.0.101.R35x_v20090819.jar
                                Id: org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.director, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.director_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.director.app, Version: 1.0.100.v20090521-1912, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.0.100.v20090521-1912.jar
                                Id: org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.0.100.v20090525.jar
                                Id: org.eclipse.equinox.p2.engine, Version: 1.0.101.R35x_v20090825, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_1.0.101.R35x_v20090825.jar
                                Id: org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.exemplarysetup, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.exemplarysetup_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401.ja r
                                Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.0.100.v20090520-1905.ja r
                                Id: org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401 .jar
                                Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401. jar
                                Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.metadata, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_1.0.100.v20090525.jar
                                Id: org.eclipse.equinox.p2.metadata.generator, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.generator_1.0.100.v20090520-1905.j ar
                                Id: org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v2009112104340 1.jar
                                Id: org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.0.101.R35x_v20090812, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v20090812. jar
                                Id: org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v200911210434 01.jar
                                Id: org.eclipse.equinox.p2.publisher, Version: 1.0.0.v20090527-1812, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.0.0.v20090527-1812.jar
                                Id: org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.0.100.v20090520-1905.j ar
                                Id: org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v2009112104340 1.jar
                                Id: org.eclipse.equinox.p2.repository, Version: 1.0.1.v20090901-1041, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_1.0.1.v20090901-1041.jar
                                Id: org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.repository.tools, Version: 1.0.1.R35x_v20090806, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_1.0.1.R35x_v20090806.jar
                                Id: org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401. jar
                                Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 1.0.101.R35x_20090820-1821, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_1.0.101.R35x_20090820-18 21.jar
                                Id: org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v2009112104340 1.jar
                                Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.0.101.R35x_v20090806, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.0.101.R35x_v20090806.j ar
                                Id: org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v2009112104340 1.jar
                                Id: org.eclipse.equinox.p2.ui, Version: 1.0.101.R35x_v20090819, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_1.0.101.R35x_v20090819.jar
                                Id: org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.100.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.0.0.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.0.0.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401. jar
                                Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.0.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.1.0.v20090520-1905.jar
                                Id: org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0.100.v20090525.jar
                                Id: org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.preferences, Version: 3.2.300.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.2.300.v20090520-1800.jar
                                Id: org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.registry, Version: 3.4.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.registry_3.4.100.v20090520-1800.jar
                                Id: org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.security, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security_1.0.100.v20090520-1800.jar
                                Id: org.eclipse.equinox.security.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.security.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.security.ui, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.0.100.v20090520-1800.jar
                                Id: org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_1.0.100.v20090520-1800.jar
                                Id: org.eclipse.equinox.simpleconfigurator, Version: 1.0.101.R35x_v20090807-1100, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v20090 807-1100.jar/
                                Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_1.0.100.v200905 20-1905.jar
                                Id: org.eclipse.equinox.util, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.util_1.0.100.v20090520-1800.jar
                                Id: org.eclipse.gef, Version: 3.5.1.v20090910-2020, Location: reference:file:plugins/org.eclipse.gef_3.5.1.v20090910-2020.jar
                                Id: org.eclipse.help, Version: 3.4.1.v20090805_35x, Location: reference:file:plugins/org.eclipse.help_3.4.1.v20090805_35x.jar
                                Id: org.eclipse.help.appserver, Version: 3.1.400.v20090429_1800, Location: reference:file:plugins/org.eclipse.help.appserver_3.1.400.v20090429_1800.jar
                                Id: org.eclipse.help.appserver.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.appserver.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.help.base, Version: 3.4.0.v200909170800, Location: reference:file:plugins/org.eclipse.help.base_3.4.0.v200909170800.jar
                                Id: org.eclipse.help.base.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.base.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.help.ui, Version: 3.4.1.v20090819_35x, Location: reference:file:plugins/org.eclipse.help.ui_3.4.1.v20090819_35x.jar
                                Id: org.eclipse.help.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.help.webapp, Version: 3.4.1.v20090819_35x, Location: reference:file:plugins/org.eclipse.help.webapp_3.4.1.v20090819_35x.jar
                                Id: org.eclipse.help.webapp.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.webapp.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jdt, Version: 3.5.2.v201002111343, Location: reference:file:plugins/org.eclipse.jdt_3.5.2.v201002111343.jar
                                Id: org.eclipse.jdt.apt.core, Version: 3.3.202.R35x_v20091130-2300, Location: reference:file:plugins/org.eclipse.jdt.apt.core_3.3.202.R35x_v20091130-2300.jar
                                Id: org.eclipse.jdt.apt.pluggable.core, Version: 1.0.201.R35x_v20090925-1100, Location: reference:file:plugins/org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090925-1100.jar
                                Id: org.eclipse.jdt.apt.ui, Version: 3.3.200.v20090930-2100_R35x, Location: reference:file:plugins/org.eclipse.jdt.apt.ui_3.3.200.v20090930-2100_R35x.jar
                                Id: org.eclipse.jdt.compiler.apt, Version: 1.0.201.R35x_v20090925-1100, Location: reference:file:plugins/org.eclipse.jdt.compiler.apt_1.0.201.R35x_v20090925-1100.jar
                                Id: org.eclipse.jdt.compiler.tool, Version: 1.0.100.v_981_R35x, Location: reference:file:plugins/org.eclipse.jdt.compiler.tool_1.0.100.v_981_R35x.jar
                                Id: org.eclipse.jdt.core, Version: 3.5.2.v_981_R35x, Location: reference:file:plugins/org.eclipse.jdt.core_3.5.2.v_981_R35x.jar
                                Id: org.eclipse.jdt.core.manipulation, Version: 1.3.0.v20090603, Location: reference:file:plugins/org.eclipse.jdt.core.manipulation_1.3.0.v20090603.jar
                                Id: org.eclipse.jdt.debug, Version: 3.5.0.v20090526, Location: reference:file:plugins/org.eclipse.jdt.debug_3.5.0.v20090526/
                                Id: org.eclipse.jdt.debug.ui, Version: 3.4.1.v20090811_r351, Location: reference:file:plugins/org.eclipse.jdt.debug.ui_3.4.1.v20090811_r351.jar
                                Id: org.eclipse.jdt.doc.user, Version: 3.5.2.r352_v20091015, Location: reference:file:plugins/org.eclipse.jdt.doc.user_3.5.2.r352_v20091015.jar
                                Id: org.eclipse.jdt.junit, Version: 3.5.2.r352_v20100113-0800, Location: reference:file:plugins/org.eclipse.jdt.junit_3.5.2.r352_v20100113-0800.jar
                                Id: org.eclipse.jdt.junit.runtime, Version: 3.4.100.v20090513-2000, Location: reference:file:plugins/org.eclipse.jdt.junit.runtime_3.4.100.v20090513-2000.jar
                                Id: org.eclipse.jdt.junit4.runtime, Version: 1.1.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.jdt.junit4.runtime_1.1.0.v20090513-2000.jar
                                Id: org.eclipse.jdt.launching, Version: 3.5.1.v20100108_r352, Location: reference:file:plugins/org.eclipse.jdt.launching_3.5.1.v20100108_r352.jar
                                Id: org.eclipse.jdt.ui, Version: 3.5.2.r352_v20100106-0800, Location: reference:file:plugins/org.eclipse.jdt.ui_3.5.2.r352_v20100106-0800.jar
                                Id: org.eclipse.jem, Version: 2.0.301.v201001252130, Location: reference:file:plugins/org.eclipse.jem_2.0.301.v201001252130.jar
                                Id: org.eclipse.jem.proxy, Version: 2.0.201.v200908101600, Location: reference:file:plugins/org.eclipse.jem.proxy_2.0.201.v200908101600.jar
                                Id: org.eclipse.jem.util, Version: 2.0.201.v201001252130, Location: reference:file:plugins/org.eclipse.jem.util_2.0.201.v201001252130.jar
                                Id: org.eclipse.jem.workbench, Version: 2.0.201.v200911302230, Location: reference:file:plugins/org.eclipse.jem.workbench_2.0.201.v200911302230.jar
                                Id: org.eclipse.jface, Version: 3.5.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.jface_3.5.1.M20090826-0800.jar
                                Id: org.eclipse.jface.databinding, Version: 1.3.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.jface.databinding_1.3.1.M20090826-0800.jar
                                Id: org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jface.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jface.text, Version: 3.5.1.r351_v20090708-0800, Location: reference:file:plugins/org.eclipse.jface.text_3.5.1.r351_v20090708-0800.jar
                                Id: org.eclipse.jface.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.text.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jpt.branding, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.branding_2.2.2.v200911250220.jar
                                Id: org.eclipse.jpt.core, Version: 2.2.1.v200908270220, Location: reference:file:plugins/org.eclipse.jpt.core_2.2.1.v200908270220.jar
                                Id: org.eclipse.jpt.db, Version: 1.2.102.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.db_1.2.102.v200911250220.jar
                                Id: org.eclipse.jpt.db.ui, Version: 1.1.100.v200906070220, Location: reference:file:plugins/org.eclipse.jpt.db.ui_1.1.100.v200906070220.jar
                                Id: org.eclipse.jpt.doc.isv, Version: 1.2.0.v200906050220, Location: reference:file:plugins/org.eclipse.jpt.doc.isv_1.2.0.v200906050220.jar
                                Id: org.eclipse.jpt.doc.user, Version: 1.1.1.v200908270220, Location: reference:file:plugins/org.eclipse.jpt.doc.user_1.1.1.v200908270220.jar
                                Id: org.eclipse.jpt.eclipselink.branding, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.branding_2.2.2.v200911250220.jar
                                Id: org.eclipse.jpt.eclipselink.core, Version: 1.2.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.core_1.2.0.v200905310000.jar
                                Id: org.eclipse.jpt.eclipselink.core.ddlgen, Version: 1.0.200.v200906070220, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.core.ddlgen_1.0.200.v200906070220.jar
                                Id: org.eclipse.jpt.eclipselink.ui, Version: 1.2.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.ui_1.2.0.v200905310000.jar
                                Id: org.eclipse.jpt.gen, Version: 1.3.2.v201001290220, Location: reference:file:plugins/org.eclipse.jpt.gen_1.3.2.v201001290220.jar
                                Id: org.eclipse.jpt.ui, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.ui_2.2.2.v200911250220.jar
                                Id: org.eclipse.jpt.utility, Version: 1.4.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.utility_1.4.0.v200905310000.jar
                                Id: org.eclipse.jsch.core, Version: 1.1.100.I20090430-0408, Location: reference:file:plugins/org.eclipse.jsch.core_1.1.100.I20090430-0408.jar
                                Id: org.eclipse.jsch.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jsch.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jsch.ui, Version: 1.1.200.I20090430-0408, Location: reference:file:plugins/org.eclipse.jsch.ui_1.1.200.I20090430-0408.jar
                                Id: org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.jst.common.annotations.controller, Version: 1.1.100.v200805140020, Location: reference:file:plugins/org.eclipse.jst.common.annotations.controller_1.1.100.v20080514002 0.jar
                                Id: org.eclipse.jst.common.annotations.core, Version: 1.1.200.v201001272230, Location: reference:file:plugins/org.eclipse.jst.common.annotations.core_1.1.200.v201001272230.jar
                                Id: org.eclipse.jst.common.frameworks, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.common.frameworks_1.1.301.v201001252130.jar
                                Id: org.eclipse.jst.common.project.facet.core, Version: 1.4.1.v200911141836, Location: reference:file:plugins/org.eclipse.jst.common.project.facet.core_1.4.1.v200911141836.jar
                                Id: org.eclipse.jst.common.project.facet.ui, Version: 1.4.1.v200912011928, Location: reference:file:plugins/org.eclipse.jst.common.project.facet.ui_1.4.1.v200912011928.jar
                                Id: org.eclipse.jst.ejb.doc.user, Version: 1.1.100.v200810092245, Location: reference:file:plugins/org.eclipse.jst.ejb.doc.user_1.1.100.v200810092245.jar
                                Id: org.eclipse.jst.ejb.ui, Version: 1.1.301.v200908131325, Location: reference:file:plugins/org.eclipse.jst.ejb.ui_1.1.301.v200908131325.jar
                                Id: org.eclipse.jst.ejb.ui.infopop, Version: 1.0.200.v200905141725, Location: reference:file:plugins/org.eclipse.jst.ejb.ui.infopop_1.0.200.v200905141725.jar
                                Id: org.eclipse.jst.j2ee, Version: 1.1.302.v201004131604, Location: reference:file:plugins/org.eclipse.jst.j2ee_1.1.302.v201004131604.jar
                                Id: org.eclipse.jst.j2ee.core, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.jst.j2ee.core_1.1.301.v200911302230.jar
                                Id: org.eclipse.jst.j2ee.doc.user, Version: 1.1.100.v200810071436, Location: reference:file:plugins/org.eclipse.jst.j2ee.doc.user_1.1.100.v200810071436.jar
                                Id: org.eclipse.jst.j2ee.ejb, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb_1.1.301.v201001252130.jar
                                Id: org.eclipse.jst.j2ee.ejb.annotation.model, Version: 1.1.102.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotation.model_1.1.102.v200805140020.ja r
                                Id: org.eclipse.jst.j2ee.ejb.annotations.emitter, Version: 1.1.102.v200805140135, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.emitter_1.1.102.v200805140135 .jar
                                Id: org.eclipse.jst.j2ee.ejb.annotations.ui, Version: 1.1.102.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.ui_1.1.102.v200805140020.jar
                                Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet, Version: 1.2.0.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.xdoclet_1.2.0.v200805140020.j ar
                                Id: org.eclipse.jst.j2ee.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.jst.j2ee.infopop_1.0.300.v200805140415.jar
                                Id: org.eclipse.jst.j2ee.jca, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.jca_1.1.301.v201001252130.jar
                                Id: org.eclipse.jst.j2ee.jca.ui, Version: 1.1.300.v200809052300, Location: reference:file:plugins/org.eclipse.jst.j2ee.jca.ui_1.1.300.v200809052300.jar
                                Id: org.eclipse.jst.j2ee.navigator.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.navigator.ui_1.1.301.v201001252130.jar
                                Id: org.eclipse.jst.j2ee.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.ui_1.1.301.v201001252130.jar
                                Id: org.eclipse.jst.j2ee.web, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.jst.j2ee.web_1.1.301.v200911302230.jar
                                Id: org.eclipse.jst.j2ee.webservice, Version: 1.1.300.v200901220600, Location: reference:file:plugins/org.eclipse.jst.j2ee.webservice_1.1.300.v200901220600.jar
                                Id: org.eclipse.jst.j2ee.webservice.ui, Version: 1.1.300.v200902052230, Location: reference:file:plugins/org.eclipse.jst.j2ee.webservice.ui_1.1.300.v200902052230.jar
                                Id: org.eclipse.jst.j2ee.xdoclet.runtime, Version: 1.1.102.v200805140135, Location: reference:file:plugins/org.eclipse.jst.j2ee.xdoclet.runtime_1.1.102.v200805140135.jar
                                Id: org.eclipse.jst.jee, Version: 1.0.201.v201002021055, Location: reference:file:plugins/org.eclipse.jst.jee_1.0.201.v201002021055.jar
                                Id: org.eclipse.jst.jee.ejb, Version: 1.0.201.v201002021057, Location: reference:file:plugins/org.eclipse.jst.jee.ejb_1.0.201.v201002021057.jar
                                Id: org.eclipse.jst.jee.ui, Version: 1.0.201.v201002021208, Location: reference:file:plugins/org.eclipse.jst.jee.ui_1.0.201.v201002021208.jar
                                Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport, Version: 1.1.0.v20090525, Location: reference:file:plugins/org.eclipse.jst.jsf.apache.trinidad.tagsupport_1.1.0.v20090525.jar
                                Id: org.eclipse.jst.jsf.common, Version: 1.1.9.v201001271707, Location: reference:file:plugins/org.eclipse.jst.jsf.common_1.1.9.v201001271707.jar
                                Id: org.eclipse.jst.jsf.common.runtime, Version: 1.0.201.v20090205, Location: reference:file:plugins/org.eclipse.jst.jsf.common.runtime_1.0.201.v20090205.jar
                                Id: org.eclipse.jst.jsf.common.ui, Version: 1.1.1.v20081209, Location: reference:file:plugins/org.eclipse.jst.jsf.common.ui_1.1.1.v20081209.jar
                                Id: org.eclipse.jst.jsf.core, Version: 1.2.5.v201001271707, Location: reference:file:plugins/org.eclipse.jst.jsf.core_1.2.5.v201001271707.jar
                                Id: org.eclipse.jst.jsf.facesconfig, Version: 1.1.3.v20090902, Location: reference:file:plugins/org.eclipse.jst.jsf.facesconfig_1.1.3.v20090902.jar
                                Id: org.eclipse.jst.jsp.core, Version: 1.2.204.v201001270045, Location: reference:file:plugins/org.eclipse.jst.jsp.core_1.2.204.v201001270045.jar
                                Id: org.eclipse.jst.jsp.ui, Version: 1.1.401.v200908111935, Location: reference:file:plugins/org.eclipse.jst.jsp.ui_1.1.401.v200908111935.jar
                                Id: org.eclipse.jst.jsp.ui.infopop, Version: 1.0.100.v200805301545, Location: reference:file:plugins/org.eclipse.jst.jsp.ui.infopop_1.0.100.v200805301545.jar
                                Id: org.eclipse.jst.pagedesigner, Version: 1.2.3.v20100211, Location: reference:file:plugins/org.eclipse.jst.pagedesigner_1.2.3.v20100211.jar
                                Id: org.eclipse.jst.pagedesigner.jsf.ui, Version: 1.1.4.v20100203, Location: reference:file:plugins/org.eclipse.jst.pagedesigner.jsf.ui_1.1.4.v20100203.jar
                                Id: org.eclipse.jst.pagedesigner.jsp.core, Version: 1.1.3.v201002111131, Location: reference:file:plugins/org.eclipse.jst.pagedesigner.jsp.core_1.1.3.v201002111131.jar
                                Id: org.eclipse.jst.server.core, Version: 1.2.1.v20100127, Location: reference:file:plugins/org.eclipse.jst.server.core_1.2.1.v20100127.jar
                                Id: org.eclipse.jst.servlet.ui, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.jst.servlet.ui_1.1.301.v200908101600.jar
                                Id: org.eclipse.jst.servlet.ui.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.jst.servlet.ui.infopop_1.0.300.v200805140415.jar
                                Id: org.eclipse.jst.ws, Version: 1.0.407.v200905191120, Location: reference:file:plugins/org.eclipse.jst.ws_1.0.407.v200905191120.jar
                                Id: org.eclipse.jst.ws.axis.consumption.core, Version: 1.0.306.v200810082309, Location: reference:file:plugins/org.eclipse.jst.ws.axis.consumption.core_1.0.306.v200810082309.jar
                                Id: org.eclipse.jst.ws.axis.consumption.ui, Version: 1.0.405.v200901261650, Location: reference:file:plugins/org.eclipse.jst.ws.axis.consumption.ui_1.0.405.v200901261650.jar
                                Id: org.eclipse.jst.ws.axis.creation.ui, Version: 1.0.406.v200903031852, Location: reference:file:plugins/org.eclipse.jst.ws.axis.creation.ui_1.0.406.v200903031852.jar
                                Id: org.eclipse.jst.ws.axis.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.axis.infopop_1.0.300.v200805140230.jar
                                Id: org.eclipse.jst.ws.axis.ui.doc.user, Version: 1.1.0.v200806092139, Location: reference:file:plugins/org.eclipse.jst.ws.axis.ui.doc.user_1.1.0.v200806092139.jar
                                Id: org.eclipse.jst.ws.axis2.consumption.core, Version: 1.0.104.v200810151442, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.consumption.core_1.0.104.v200810151442.ja r
                                Id: org.eclipse.jst.ws.axis2.consumption.ui, Version: 1.0.102.v200807232000, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.consumption.ui_1.0.102.v200807232000.jar
                                Id: org.eclipse.jst.ws.axis2.core, Version: 1.0.104.v200810151442, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.core_1.0.104.v200810151442.jar
                                Id: org.eclipse.jst.ws.axis2.creation.core, Version: 1.0.105.v200901220134, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.creation.core_1.0.105.v200901220134.jar
                                Id: org.eclipse.jst.ws.axis2.creation.ui, Version: 1.0.103.v200807162242, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.creation.ui_1.0.103.v200807162242.jar
                                Id: org.eclipse.jst.ws.axis2.ui, Version: 1.0.302.v200905260749, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.ui_1.0.302.v200905260749.jar
                                Id: org.eclipse.jst.ws.axis2.ui.doc.user, Version: 1.0.1.v200807302329, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.ui.doc.user_1.0.1.v200807302329.jar
                                Id: org.eclipse.jst.ws.consumption, Version: 1.0.408.v200911241817, Location: reference:file:plugins/org.eclipse.jst.ws.consumption_1.0.408.v200911241817.jar
                                Id: org.eclipse.jst.ws.consumption.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.infopop_1.0.300.v200805140230.jar
                                Id: org.eclipse.jst.ws.consumption.ui, Version: 1.1.106.v200911241851, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.ui_1.1.106.v200911241851.jar
                                Id: org.eclipse.jst.ws.consumption.ui.doc.user, Version: 1.0.550.v200901232040, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.ui.doc.user_1.0.550.v200901232040.j ar
                                Id: org.eclipse.jst.ws.creation.ejb.ui, Version: 1.0.200.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.creation.ejb.ui_1.0.200.v200805140230.jar
                                Id: org.eclipse.jst.ws.creation.ui, Version: 1.0.409.v200911241856, Location: reference:file:plugins/org.eclipse.jst.ws.creation.ui_1.0.409.v200911241856.jar
                                Id: org.eclipse.jst.ws.doc.user, Version: 1.0.500.v200809092107, Location: reference:file:plugins/org.eclipse.jst.ws.doc.user_1.0.500.v200809092107.jar
                                Id: org.eclipse.jst.ws.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.infopop_1.0.300.v200805140230.jar
                                Id: org.eclipse.jst.ws.uddiregistry, Version: 1.0.400.v200901261650, Location: reference:file:plugins/org.eclipse.jst.ws.uddiregistry_1.0.400.v200901261650.jar
                                Id: org.eclipse.jst.ws.ui, Version: 1.0.402.v200903111822, Location: reference:file:plugins/org.eclipse.jst.ws.ui_1.0.402.v200903111822.jar
                                Id: org.eclipse.ltk.core.refactoring, Version: 3.5.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.5.0.v20090513-2000.jar
                                Id: org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ltk.ui.refactoring, Version: 3.4.100.v20090604, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.4.100.v20090604.jar
                                Id: org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.osgi, Version: 3.5.1.R35x_v20090827, Location: System Bundle
                                Id: org.eclipse.osgi.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.osgi.services, Version: 3.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.osgi.services_3.2.0.v20090520-1800.jar
                                Id: org.eclipse.osgi.services.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.services.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.osgi.util, Version: 3.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.osgi.util_3.2.0.v20090520-1800.jar
                                Id: org.eclipse.osgi.util.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.util.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.pde, Version: 3.4.100.v201002111343, Location: reference:file:plugins/org.eclipse.pde_3.4.100.v201002111343.jar
                                Id: org.eclipse.pde.api.tools, Version: 1.0.101.v20090714, Location: reference:file:plugins/org.eclipse.pde.api.tools_1.0.101.v20090714.jar
                                Id: org.eclipse.pde.api.tools.ee.javase16, Version: 1.0.0.v20090407-1030, Location: reference:file:plugins/org.eclipse.pde.api.tools.ee.javase16_1.0.0.v20090407-1030/
                                Id: org.eclipse.pde.api.tools.ui, Version: 1.0.101.v20090820, Location: reference:file:plugins/org.eclipse.pde.api.tools.ui_1.0.101.v20090820.jar
                                Id: org.eclipse.pde.build, Version: 3.5.2.R35x_20100114, Location: reference:file:plugins/org.eclipse.pde.build_3.5.2.R35x_20100114/
                                Id: org.eclipse.pde.core, Version: 3.5.101.v20100104, Location: reference:file:plugins/org.eclipse.pde.core_3.5.101.v20100104.jar
                                Id: org.eclipse.pde.doc.user, Version: 3.5.0.v20090818, Location: reference:file:plugins/org.eclipse.pde.doc.user_3.5.0.v20090818.jar
                                Id: org.eclipse.pde.ds.core, Version: 1.0.1.v20100118, Location: reference:file:plugins/org.eclipse.pde.ds.core_1.0.1.v20100118.jar
                                Id: org.eclipse.pde.ds.ui, Version: 1.0.0.v20100209-maintenance, Location: reference:file:plugins/org.eclipse.pde.ds.ui_1.0.0.v20100209-maintenance.jar
                                Id: org.eclipse.pde.junit.runtime, Version: 3.4.0.v20090527, Location: reference:file:plugins/org.eclipse.pde.junit.runtime_3.4.0.v20090527.jar
                                Id: org.eclipse.pde.runtime, Version: 3.4.100.v20090731, Location: reference:file:plugins/org.eclipse.pde.runtime_3.4.100.v20090731.jar
                                Id: org.eclipse.pde.ua.core, Version: 1.0.0.v20090429-1800, Location: reference:file:plugins/org.eclipse.pde.ua.core_1.0.0.v20090429-1800.jar
                                Id: org.eclipse.pde.ua.ui, Version: 1.0.0.v20090511, Location: reference:file:plugins/org.eclipse.pde.ua.ui_1.0.0.v20090511.jar
                                Id: org.eclipse.pde.ui, Version: 3.5.1.v201001121200, Location: reference:file:plugins/org.eclipse.pde.ui_3.5.1.v201001121200.jar
                                Id: org.eclipse.pde.ui.templates, Version: 3.4.100.v20090527, Location: reference:file:plugins/org.eclipse.pde.ui.templates_3.4.100.v20090527.jar
                                Id: org.eclipse.platform, Version: 3.3.201.v200909170800, Location: reference:file:plugins/org.eclipse.platform_3.3.201.v200909170800/
                                Id: org.eclipse.platform.doc.user, Version: 3.5.1.r351_v20090821-0800, Location: reference:file:plugins/org.eclipse.platform.doc.user_3.5.1.r351_v20090821-0800.jar
                                Id: org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.platform.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.platform.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.rcp, Version: 3.5.0.v200909170800, Location: reference:file:plugins/org.eclipse.rcp_3.5.0.v200909170800.jar
                                Id: org.eclipse.search, Version: 3.5.1.r351_v20090708-0800, Location: reference:file:plugins/org.eclipse.search_3.5.1.r351_v20090708-0800.jar
                                Id: org.eclipse.search.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.search.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.servertools.doc.isv, Version: 1.0.100.v20090414, Location: reference:file:plugins/org.eclipse.servertools.doc.isv_1.0.100.v20090414.jar
                                Id: org.eclipse.swt, Version: 3.5.1.v3555a, Location: reference:file:plugins/org.eclipse.swt_3.5.1.v3555a.jar
                                Id: org.eclipse.swt.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.swt.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.swt.win32.win32.x86, Version: 3.5.1.v3555a, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.5.1.v3555a.jar
                                Id: org.eclipse.team.core, Version: 3.5.0.I20090527-0620, Location: reference:file:plugins/org.eclipse.team.core_3.5.0.I20090527-0620.jar
                                Id: org.eclipse.team.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.team.cvs.core, Version: 3.3.200.I20090430-0408, Location: reference:file:plugins/org.eclipse.team.cvs.core_3.3.200.I20090430-0408.jar
                                Id: org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.team.cvs.ssh, Version: 3.2.100.I20090508-2000, Location: reference:file:plugins/org.eclipse.team.cvs.ssh_3.2.100.I20090508-2000.jar
                                Id: org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.team.cvs.ssh2, Version: 3.2.200.I20090508-2000, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2_3.2.200.I20090508-2000.jar
                                Id: org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.team.cvs.ui, Version: 3.3.201.R35x_v20090826-0905, Location: reference:file:plugins/org.eclipse.team.cvs.ui_3.3.201.R35x_v20090826-0905.jar
                                Id: org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.team.ui, Version: 3.5.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.team.ui_3.5.0.I20090430-0408.jar
                                Id: org.eclipse.team.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.text, Version: 3.5.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.text_3.5.0.v20090513-2000.jar
                                Id: org.eclipse.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.text.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui, Version: 3.5.1.M20090902-1000, Location: reference:file:plugins/org.eclipse.ui_3.5.1.M20090902-1000.jar
                                Id: org.eclipse.ui.browser, Version: 3.2.300.v20090526, Location: reference:file:plugins/org.eclipse.ui.browser_3.2.300.v20090526.jar
                                Id: org.eclipse.ui.browser.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.browser.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.cheatsheets, Version: 3.3.200.v20090526, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.3.200.v20090526.jar
                                Id: org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.console, Version: 3.4.0.v20090513, Location: reference:file:plugins/org.eclipse.ui.console_3.4.0.v20090513.jar
                                Id: org.eclipse.ui.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.console.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.editors, Version: 3.5.0.v20090527-2000, Location: reference:file:plugins/org.eclipse.ui.editors_3.5.0.v20090527-2000.jar
                                Id: org.eclipse.ui.editors.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.editors.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.externaltools, Version: 3.2.0.v20090504, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.2.0.v20090504.jar
                                Id: org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.forms, Version: 3.4.1.v20090714_35x, Location: reference:file:plugins/org.eclipse.ui.forms_3.4.1.v20090714_35x.jar
                                Id: org.eclipse.ui.forms.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.forms.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.ide, Version: 3.5.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.ide_3.5.1.M20090826-0800.jar
                                Id: org.eclipse.ui.ide.application, Version: 1.0.101.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.0.101.M20090826-0800.jar
                                Id: org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.ide.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.ide.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.intro, Version: 3.3.1.v20090805_35x, Location: reference:file:plugins/org.eclipse.ui.intro_3.3.1.v20090805_35x.jar
                                Id: org.eclipse.ui.intro.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.intro.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.intro.universal, Version: 3.2.300.v20090526, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.300.v20090526/
                                Id: org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.navigator, Version: 3.4.1.M20090911-1550, Location: reference:file:plugins/org.eclipse.ui.navigator_3.4.1.M20090911-1550.jar
                                Id: org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.navigator.resources, Version: 3.4.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.4.1.M20090826-0800.jar
                                Id: org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.net, Version: 1.2.1.r35x_20090812-1200, Location: reference:file:plugins/org.eclipse.ui.net_1.2.1.r35x_20090812-1200.jar
                                Id: org.eclipse.ui.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.net.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.presentations.r21, Version: 3.2.100.I20081007-0800, Location: reference:file:plugins/org.eclipse.ui.presentations.r21_3.2.100.I20081007-0800.jar
                                Id: org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.views, Version: 3.4.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.views_3.4.1.M20090826-0800.jar
                                Id: org.eclipse.ui.views.log, Version: 1.0.100.v20090731, Location: reference:file:plugins/org.eclipse.ui.views.log_1.0.100.v20090731.jar
                                Id: org.eclipse.ui.views.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.views.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.views.properties.tabbed, Version: 3.5.0.I20090429-1800, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.5.0.I20090429-1800.jar
                                Id: org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401.j ar
                                Id: org.eclipse.ui.win32, Version: 3.2.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.ui.win32_3.2.100.v20090429-1800.jar
                                Id: org.eclipse.ui.workbench, Version: 3.5.1.M20090826-0800a, Location: reference:file:plugins/org.eclipse.ui.workbench_3.5.1.M20090826-0800a.jar
                                Id: org.eclipse.ui.workbench.compatibility, Version: 3.2.0.I20090429-1800, Location: reference:file:plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20090429-1800/
                                Id: org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.ui.workbench.texteditor, Version: 3.5.0.v20090603, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.5.0.v20090603.jar
                                Id: org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.update.configurator, Version: 3.3.0.v20090312, Location: reference:file:plugins/org.eclipse.update.configurator_3.3.0.v20090312.jar
                                Id: org.eclipse.update.configurator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.configurator.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.update.core, Version: 3.2.300.v20090525, Location: reference:file:plugins/org.eclipse.update.core_3.2.300.v20090525.jar
                                Id: org.eclipse.update.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.core.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.update.core.win32, Version: 3.2.100.v20080107, Location: reference:file:plugins/org.eclipse.update.core.win32_3.2.100.v20080107.jar
                                Id: org.eclipse.update.scheduler, Version: 3.2.200.v20081127, Location: reference:file:plugins/org.eclipse.update.scheduler_3.2.200.v20081127.jar
                                Id: org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.update.ui, Version: 3.2.201.R35x_v20090813, Location: reference:file:plugins/org.eclipse.update.ui_3.2.201.R35x_v20090813.jar
                                Id: org.eclipse.update.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.ui.nl1_3.5.0.v20091121043401.jar
                                Id: org.eclipse.wst.command.env, Version: 1.0.408.v200903110045, Location: reference:file:plugins/org.eclipse.wst.command.env_1.0.408.v200903110045.jar
                                Id: org.eclipse.wst.command.env.core, Version: 1.0.204.v200805140020, Location: reference:file:plugins/org.eclipse.wst.command.env.core_1.0.204.v200805140020.jar
                                Id: org.eclipse.wst.command.env.doc.user, Version: 1.5.200.v200806092138, Location: reference:file:plugins/org.eclipse.wst.command.env.doc.user_1.5.200.v200806092138.jar
                                Id: org.eclipse.wst.command.env.infopop, Version: 1.0.100.v200805301544, Location: reference:file:plugins/org.eclipse.wst.command.env.infopop_1.0.100.v200805301544.jar
                                Id: org.eclipse.wst.command.env.ui, Version: 1.1.2.v200811200248, Location: reference:file:plugins/org.eclipse.wst.command.env.ui_1.1.2.v200811200248.jar
                                Id: org.eclipse.wst.common.api.doc, Version: 1.0.1.v200807181737, Location: reference:file:plugins/org.eclipse.wst.common.api.doc_1.0.1.v200807181737.jar
                                Id: org.eclipse.wst.common.core, Version: 1.1.201.v200806010600, Location: reference:file:plugins/org.eclipse.wst.common.core_1.1.201.v200806010600.jar
                                Id: org.eclipse.wst.common.emf, Version: 1.1.301.v200908181930, Location: reference:file:plugins/org.eclipse.wst.common.emf_1.1.301.v200908181930.jar
                                Id: org.eclipse.wst.common.emfworkbench.integration, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.emfworkbench.integration_1.1.301.v200908101 600.jar
                                Id: org.eclipse.wst.common.environment, Version: 1.0.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.environment_1.0.301.v200908101600.jar
                                Id: org.eclipse.wst.common.frameworks, Version: 1.1.300.v200904160730, Location: reference:file:plugins/org.eclipse.wst.common.frameworks_1.1.300.v200904160730.jar
                                Id: org.eclipse.wst.common.frameworks.ui, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.frameworks.ui_1.1.301.v200908101600.jar
                                Id: org.eclipse.wst.common.infopop, Version: 1.0.100.v200805301550, Location: reference:file:plugins/org.eclipse.wst.common.infopop_1.0.100.v200805301550.jar
                                Id: org.eclipse.wst.common.modulecore, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.wst.common.modulecore_1.1.301.v201001252130.jar
                                Id: org.eclipse.wst.common.project.facet.core, Version: 1.4.1.v200911141735, Location: reference:file:plugins/org.eclipse.wst.common.project.facet.core_1.4.1.v200911141735.jar
                                Id: org.eclipse.wst.common.project.facet.ui, Version: 1.4.1.v200908111817, Location: reference:file:plugins/org.eclipse.wst.common.project.facet.ui_1.4.1.v200908111817.jar
                                Id: org.eclipse.wst.common.snippets, Version: 1.1.301.v201001280015, Location: reference:file:plugins/org.eclipse.wst.common.snippets_1.1.301.v201001280015.jar
                                Id: org.eclipse.wst.common.ui, Version: 1.1.402.v200901262305, Location: reference:file:plugins/org.eclipse.wst.common.ui_1.1.402.v200901262305.jar
                                Id: org.eclipse.wst.common.uriresolver, Version: 1.1.301.v200805140415, Location: reference:file:plugins/org.eclipse.wst.common.uriresolver_1.1.301.v200805140415.jar
                                Id: org.eclipse.wst.css.core, Version: 1.1.301.v200910161432, Location: reference:file:plugins/org.eclipse.wst.css.core_1.1.301.v200910161432.jar
                                Id: org.eclipse.wst.css.ui, Version: 1.0.401.v200907171457, Location: reference:file:plugins/org.eclipse.wst.css.ui_1.0.401.v200907171457.jar
                                Id: org.eclipse.wst.doc.user, Version: 1.2.0.v200806052254, Location: reference:file:plugins/org.eclipse.wst.doc.user_1.2.0.v200806052254.jar
                                Id: org.eclipse.wst.dtd.core, Version: 1.1.300.v200904181727, Location: reference:file:plugins/org.eclipse.wst.dtd.core_1.1.300.v200904181727.jar
                                Id: org.eclipse.wst.dtd.ui, Version: 1.0.400.v200904300717, Location: reference:file:plugins/org.eclipse.wst.dtd.ui_1.0.400.v200904300717.jar
                                Id: org.eclipse.wst.dtd.ui.infopop, Version: 1.0.300.v200805140200, Location: reference:file:plugins/org.eclipse.wst.dtd.ui.infopop_1.0.300.v200805140200.jar
                                Id: org.eclipse.wst.dtdeditor.doc.user, Version: 1.0.500.v200904292308, Location: reference:file:plugins/org.eclipse.wst.dtdeditor.doc.user_1.0.500.v200904292308.jar
                                Id: org.eclipse.wst.html.core, Version: 1.1.300.v200903120608, Location: reference:file:plugins/org.eclipse.wst.html.core_1.1.300.v200903120608.jar
                                Id: org.eclipse.wst.html.ui, Version: 1.0.401.v200908111935, Location: reference:file:plugins/org.eclipse.wst.html.ui_1.0.401.v200908111935.jar
                                Id: org.eclipse.wst.html.ui.infopop, Version: 1.0.100.v200805301545, Location: reference:file:plugins/org.eclipse.wst.html.ui.infopop_1.0.100.v200805301545.jar
                                Id: org.eclipse.wst.internet.cache, Version: 1.0.301.v200805140020, Location: reference:file:plugins/org.eclipse.wst.internet.cache_1.0.301.v200805140020.jar
                                Id: org.eclipse.wst.internet.monitor.core, Version: 1.0.404.v20090609, Location: reference:file:plugins/org.eclipse.wst.internet.monitor.core_1.0.404.v20090609.jar
                                Id: org.eclipse.wst.internet.monitor.ui, Version: 1.0.305.v20100123, Location: reference:file:plugins/org.eclipse.wst.internet.monitor.ui_1.0.305.v20100123.jar
                                Id: org.eclipse.wst.jsdt.core, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.core_1.0.201.v2010012803.jar
                                Id: org.eclipse.wst.jsdt.doc, Version: 1.0.200.v200903120608, Location: reference:file:plugins/org.eclipse.wst.jsdt.doc_1.0.200.v200903120608.jar
                                Id: org.eclipse.wst.jsdt.manipulation, Version: 1.0.100.v200809240707, Location: reference:file:plugins/org.eclipse.wst.jsdt.manipulation_1.0.100.v200809240707.jar
                                Id: org.eclipse.wst.jsdt.support.firefox, Version: 1.0.200.v200904290357, Location: reference:file:plugins/org.eclipse.wst.jsdt.support.firefox_1.0.200.v200904290357.jar
                                Id: org.eclipse.wst.jsdt.support.ie, Version: 1.0.200.v200904290539, Location: reference:file:plugins/org.eclipse.wst.jsdt.support.ie_1.0.200.v200904290539.jar
                                Id: org.eclipse.wst.jsdt.ui, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.ui_1.0.201.v2010012803.jar
                                Id: org.eclipse.wst.jsdt.web.core, Version: 1.0.201.v201001221931, Location: reference:file:plugins/org.eclipse.wst.jsdt.web.core_1.0.201.v201001221931.jar
                                Id: org.eclipse.wst.jsdt.web.ui, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.web.ui_1.0.201.v2010012803.jar
                                Id: org.eclipse.wst.server.core, Version: 1.1.102.v20100123, Location: reference:file:plugins/org.eclipse.wst.server.core_1.1.102.v20100123.jar
                                Id: org.eclipse.wst.server.discovery, Version: 1.0.1.v20100210, Location: reference:file:plugins/org.eclipse.wst.server.discovery_1.0.1.v20100210.jar
                                Id: org.eclipse.wst.server.ui, Version: 1.1.103.v20100123, Location: reference:file:plugins/org.eclipse.wst.server.ui_1.1.103.v20100123.jar
                                Id: org.eclipse.wst.server.ui.doc.user, Version: 1.1.150.v200901232034, Location: reference:file:plugins/org.eclipse.wst.server.ui.doc.user_1.1.150.v200901232034.jar
                                Id: org.eclipse.wst.server.ui.infopop, Version: 1.1.0.v200805140145, Location: reference:file:plugins/org.eclipse.wst.server.ui.infopop_1.1.0.v200805140145.jar
                                Id: org.eclipse.wst.sse.core, Version: 1.1.402.v201001251516, Location: reference:file:plugins/org.eclipse.wst.sse.core_1.1.402.v201001251516.jar
                                Id: org.eclipse.wst.sse.doc.user, Version: 1.1.0.v200805211530, Location: reference:file:plugins/org.eclipse.wst.sse.doc.user_1.1.0.v200805211530.jar
                                Id: org.eclipse.wst.sse.ui, Version: 1.1.102.v200910200227, Location: reference:file:plugins/org.eclipse.wst.sse.ui_1.1.102.v200910200227.jar
                                Id: org.eclipse.wst.sse.ui.infopop, Version: 1.0.200.v200805301545, Location: reference:file:plugins/org.eclipse.wst.sse.ui.infopop_1.0.200.v200805301545.jar
                                Id: org.eclipse.wst.standard.schemas, Version: 1.0.200.v200902270215, Location: reference:file:plugins/org.eclipse.wst.standard.schemas_1.0.200.v200902270215.jar
                                Id: org.eclipse.wst.validation, Version: 1.2.104.v200911120201, Location: reference:file:plugins/org.eclipse.wst.validation_1.2.104.v200911120201.jar
                                Id: org.eclipse.wst.validation.doc.isv, Version: 1.2.101.v200906031420, Location: reference:file:plugins/org.eclipse.wst.validation.doc.isv_1.2.101.v200906031420.jar
                                Id: org.eclipse.wst.validation.infopop, Version: 1.0.300.v200806041506, Location: reference:file:plugins/org.eclipse.wst.validation.infopop_1.0.300.v200806041506.jar
                                Id: org.eclipse.wst.validation.ui, Version: 1.2.104.v200904232035, Location: reference:file:plugins/org.eclipse.wst.validation.ui_1.2.104.v200904232035.jar
                                Id: org.eclipse.wst.web, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.wst.web_1.1.301.v200911302230.jar
                                Id: org.eclipse.wst.web.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.wst.web.ui_1.1.301.v201001252130.jar
                                Id: org.eclipse.wst.web.ui.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.wst.web.ui.infopop_1.0.300.v200805140415.jar
                                Id: org.eclipse.wst.webtools.doc.user, Version: 1.0.400.v200805150134, Location: reference:file:plugins/org.eclipse.wst.webtools.doc.user_1.0.400.v200805150134.jar
                                Id: org.eclipse.wst.ws, Version: 1.1.103.v200903111822, Location: reference:file:plugins/org.eclipse.wst.ws_1.1.103.v200903111822.jar
                                Id: org.eclipse.wst.ws.api.doc, Version: 1.0.1.v200807181721, Location: reference:file:plugins/org.eclipse.wst.ws.api.doc_1.0.1.v200807181721.jar
                                Id: org.eclipse.wst.ws.explorer, Version: 1.0.408.v200911241806, Location: reference:file:plugins/org.eclipse.wst.ws.explorer_1.0.408.v200911241806.jar
                                Id: org.eclipse.wst.ws.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.wst.ws.infopop_1.0.300.v200805140230.jar
                                Id: org.eclipse.wst.ws.parser, Version: 1.0.402.v200901220107, Location: reference:file:plugins/org.eclipse.wst.ws.parser_1.0.402.v200901220107.jar
                                Id: org.eclipse.wst.ws.service.policy, Version: 1.0.103.v200905151848, Location: reference:file:plugins/org.eclipse.wst.ws.service.policy_1.0.103.v200905151848.jar
                                Id: org.eclipse.wst.ws.service.policy.ui, Version: 1.0.102.v200903070248, Location: reference:file:plugins/org.eclipse.wst.ws.service.policy.ui_1.0.102.v200903070248.jar
                                Id: org.eclipse.wst.ws.ui, Version: 1.1.100.v200903112221, Location: reference:file:plugins/org.eclipse.wst.ws.ui_1.1.100.v200903112221.jar
                                Id: org.eclipse.wst.wsdl, Version: 1.2.2.v200911111930, Location: reference:file:plugins/org.eclipse.wst.wsdl_1.2.2.v200911111930.jar
                                Id: org.eclipse.wst.wsdl.doc.isv, Version: 1.0.100.v200811240723, Location: reference:file:plugins/org.eclipse.wst.wsdl.doc.isv_1.0.100.v200811240723.jar
                                Id: org.eclipse.wst.wsdl.ui, Version: 1.2.202.v200904271449, Location: reference:file:plugins/org.eclipse.wst.wsdl.ui_1.2.202.v200904271449.jar
                                Id: org.eclipse.wst.wsdl.ui.doc.user, Version: 1.0.550.v200901232040, Location: reference:file:plugins/org.eclipse.wst.wsdl.ui.doc.user_1.0.550.v200901232040.jar
                                Id: org.eclipse.wst.wsdl.validation, Version: 1.1.402.v200911251542, Location: reference:file:plugins/org.eclipse.wst.wsdl.validation_1.1.402.v200911251542.jar
                                Id: org.eclipse.wst.wsi, Version: 1.0.305.v200902181431, Location: reference:file:plugins/org.eclipse.wst.wsi_1.0.305.v200902181431.jar
                                Id: org.eclipse.wst.wsi.ui, Version: 1.0.500.v200901141851, Location: reference:file:plugins/org.eclipse.wst.wsi.ui_1.0.500.v200901141851.jar
                                Id: org.eclipse.wst.wsi.ui.doc.user, Version: 1.0.401.v200809171927, Location: reference:file:plugins/org.eclipse.wst.wsi.ui.doc.user_1.0.401.v200809171927.jar
                                Id: org.eclipse.wst.xml.core, Version: 1.1.402.v201001222130, Location: reference:file:plugins/org.eclipse.wst.xml.core_1.1.402.v201001222130.jar
                                Id: org.eclipse.wst.xml.ui, Version: 1.1.2.v201001222130, Location: reference:file:plugins/org.eclipse.wst.xml.ui_1.1.2.v201001222130.jar
                                Id: org.eclipse.wst.xml.ui.infopop, Version: 1.0.300.v200805140200, Location: reference:file:plugins/org.eclipse.wst.xml.ui.infopop_1.0.300.v200805140200.jar
                                Id: org.eclipse.wst.xml.xpath.core, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xml.xpath.core_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xml.xpath.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xml.xpath.ui_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xml.xpath2.processor, Version: 1.0.0.v200905300355, Location: reference:file:plugins/org.eclipse.wst.xml.xpath2.processor_1.0.0.v200905300355.jar
                                Id: org.eclipse.wst.xmleditor.doc.user, Version: 1.0.600.v200901231300, Location: reference:file:plugins/org.eclipse.wst.xmleditor.doc.user_1.0.600.v200901231300.jar
                                Id: org.eclipse.wst.xsd.core, Version: 1.1.401.v200903020335, Location: reference:file:plugins/org.eclipse.wst.xsd.core_1.1.401.v200903020335.jar
                                Id: org.eclipse.wst.xsd.ui, Version: 1.2.204.v200909021537, Location: reference:file:plugins/org.eclipse.wst.xsd.ui_1.2.204.v200909021537.jar
                                Id: org.eclipse.wst.xsdeditor.doc.user, Version: 1.0.700.v200905182240, Location: reference:file:plugins/org.eclipse.wst.xsdeditor.doc.user_1.0.700.v200905182240.jar
                                Id: org.eclipse.wst.xsl, Version: 1.0.0.v200905250058, Location: reference:file:plugins/org.eclipse.wst.xsl_1.0.0.v200905250058.jar
                                Id: org.eclipse.wst.xsl.core, Version: 1.0.1.v200908101420, Location: reference:file:plugins/org.eclipse.wst.xsl.core_1.0.1.v200908101420.jar
                                Id: org.eclipse.wst.xsl.debug.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.debug.ui_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.doc, Version: 1.0.0.v200905071815, Location: reference:file:plugins/org.eclipse.wst.xsl.doc_1.0.0.v200905071815.jar
                                Id: org.eclipse.wst.xsl.jaxp.debug, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.debug_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.jaxp.debug.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.debug.ui_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.jaxp.launching, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.launching_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.launching, Version: 1.0.0.v200904241348, Location: reference:file:plugins/org.eclipse.wst.xsl.launching_1.0.0.v200904241348.jar
                                Id: org.eclipse.wst.xsl.saxon, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.saxon_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.sdk.documentation, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.sdk.documentation_1.0.0.v200904240436.jar
                                Id: org.eclipse.wst.xsl.ui, Version: 1.0.100.v200907172129, Location: reference:file:plugins/org.eclipse.wst.xsl.ui_1.0.100.v200907172129.jar
                                Id: org.eclipse.wst.xsl.xalan, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.xalan_1.0.0.v200904240436.jar
                                Id: org.eclipse.xsd, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.xsd_2.5.0.v200906151043.jar
                                Id: org.eclipse.xsd.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.xsd.edit_2.5.0.v200906151043.jar
                                Id: org.hamcrest.core, Version: 1.1.0.v20090501071000, Location: reference:file:plugins/org.hamcrest.core_1.1.0.v20090501071000.jar
                                Id: org.jdom, Version: 1.0.0.v200806100616, Location: reference:file:plugins/org.jdom_1.0.0.v200806100616.jar
                                Id: org.junit, Version: 3.8.2.v20090203-1005, Location: reference:file:plugins/org.junit_3.8.2.v20090203-1005/
                                Id: org.junit4, Version: 4.5.0.v20090824, Location: reference:file:plugins/org.junit4_4.5.0.v20090824/
                                Id: org.mortbay.jetty.server, Version: 6.1.15.v200905151201, Location: reference:file:plugins/org.mortbay.jetty.server_6.1.15.v200905151201.jar
                                Id: org.mortbay.jetty.util, Version: 6.1.15.v200905182336, Location: reference:file:plugins/org.mortbay.jetty.util_6.1.15.v200905182336.jar
                                Id: org.objectweb.asm, Version: 3.1.0.v200803061910, Location: reference:file:plugins/org.objectweb.asm_3.1.0.v200803061910.jar
                                Id: org.sat4j.core, Version: 2.1.0.v20090520, Location: reference:file:plugins/org.sat4j.core_2.1.0.v20090520.jar
                                Id: org.sat4j.pb, Version: 2.1.0.v20090520, Location: reference:file:plugins/org.sat4j.pb_2.1.0.v20090520.jar
                                Id: org.tigris.subversion.clientadapter, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter_1.6.12.jar
                                Id: org.tigris.subversion.clientadapter.javahl, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.javahl_1.6.12.jar
                                Id: org.tigris.subversion.clientadapter.javahl.win32, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.javahl.win32_1.6.12/
                                Id: org.tigris.subversion.clientadapter.svnkit, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.svnkit_1.6.12.jar
                                Id: org.tigris.subversion.subclipse.core, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.subclipse.core_1.6.12.jar
                                Id: org.tigris.subversion.subclipse.doc, Version: 1.3.0, Location: reference:file:plugins/org.tigris.subversion.subclipse.doc_1.3.0.jar
                                Id: org.tigris.subversion.subclipse.ui, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.subclipse.ui_1.6.12.jar
                                Id: org.tmatesoft.svnkit, Version: 1.3.3.6648, Location: reference:file:plugins/org.tmatesoft.svnkit_1.3.3.6648.jar
                                Id: org.uddi4j, Version: 2.0.5.v200805270300, Location: reference:file:plugins/org.uddi4j_2.0.5.v200805270300.jar
                                *** Security Configuration:
                                Providers (9):
                                Provider: SUN, Version: 1.6, Class: sun.security.provider.Sun
                                  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
                                  Services (23):
                                   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
                                   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigSpiFile
                                   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
                                    Aliases: RawDSA
                                    Attributes:
                                      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
                                   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
                                    Attributes:
                                      ImplementedIn: Software
                                      ValidationAlgorithm: RFC3280
                                   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.LDAPCertStore
                                    Attributes:
                                      LDAPSchema: RFC2587
                                   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
                                    Aliases: SHA1
                                    Attributes:
                                   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
                                    Aliases: X509
                                    Attributes:
                                   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
                                   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator
                                    Aliases: OID.1.2.840.10040.4.1
                                    Attributes:
                                      KeySize: 1024
                                   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$JKS
                                    Attributes:
                                   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
                                   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2
                                   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
                                    Attributes:
                                   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
                                    Attributes:
                                   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
                                    Attributes:
                                   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
                                    Attributes:
                                   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
                                    Attributes:
                                   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
                                    Attributes:
                                   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
                                    Attributes:
                                   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
                                   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
                                   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
                                    Aliases: DSAWithSHA1
                                    Attributes:
                                      KeySize: 1024
                                   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
                                    Attributes:
                                      KeySize: 1024
                                Provider: SunRsaSign, Version: 1.5, Class: sun.security.rsa.SunRsaSign
                                  Description: Sun RSA signature provider
                                  Services (8):
                                   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
                                    Aliases: OID.1.2.840.113549.1.1.13
                                    Attributes:
                                      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
                                   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
                                    Aliases: 1.2.840.113549.1.1.4
                                    Attributes:
                                   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory
                                   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
                                    Aliases: OID.1.2.840.113549.1.1.5
                                    Attributes:
                                   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
                                    Aliases: OID.1.2.840.113549.1.1.12
                                    Attributes:
                                   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
                                    Aliases: 1.2.840.113549.1.1.2
                                    Attributes:
                                   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator
                                   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
                                    Aliases: OID.1.2.840.113549.1.1.11
                                    Attributes:
                                Provider: SunJSSE, Version: 1.6, Class: com.sun.net.ssl.internal.ssl.Provider
                                  Description: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
                                  Services (16):
                                   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: com.sun.net.ssl.internal.ssl.RSASignature
                                   Service: SSLContext, Algorithm: Default, Class: com.sun.net.ssl.internal.ssl.DefaultSSLContextImpl
                                   Service: KeyManagerFactory, Algorithm: SunX509, Class: com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$SunX509
                                   Service: SSLContext, Algorithm: SSL, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
                                   Service: TrustManagerFactory, Algorithm: SunX509, Class: com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$SimpleFactory
                                   Service: SSLContext, Algorithm: SSLv3, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
                                   Service: KeyStore, Algorithm: PKCS12, Class: com.sun.net.ssl.internal.pkcs12.PKCS12KeyStore
                                   Service: SSLContext, Algorithm: TLS, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
                                   Service: SSLContext, Algorithm: TLSv1, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
                                   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$X509
                                   Service: TrustManagerFactory, Algorithm: PKIX, Class: com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$PKIXFactory
                                    Aliases: X.509
                                Provider: SunJCE, Version: 1.6, Class: com.sun.crypto.provider.SunJCE
                                  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
                                  Services (60):
                                   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
                                    Aliases: TripleDES
                                   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA384KG
                                   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
                                   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
                                    Aliases: RC4
                                   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher
                                    Attributes:
                                      SupportedPaddings: NOPADDING
                                      SupportedKeyFormats: RAW
                                      SupportedModes: ECB
                                   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA256KG
                                   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA512KG
                                   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
                                    Aliases: Rijndael
                                   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
                                   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
                                   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
                                   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator
                                   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
                                    Attributes:
                                      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
                                      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OF B24|OFB32|OFB40|OFB48|OFB56|OFB64
                                   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
                                    Attributes:
                                      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1 ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512 ANDMGF1PADDING
                                      SupportedModes: ECB
                                   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
                                    Aliases: DH
                                   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
                                    Aliases: OID.1.2.840.113549.1.12.1.3
                                   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
                                    Aliases: DH
                                   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
                                    Attributes:
                                      SupportedModes: CBC
                                   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
                                   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
                                    Aliases: TripleDES
                                   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
                                   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
                                    Aliases: 1.2.840.113549.1.5.3
                                   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
                                    Aliases: OID.1.2.840.113549.1.12.1.6
                                   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
                                    Attributes:
                                   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
                                    Aliases: TripleDES
                                   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
                                    Attributes:
                                   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
                                   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
                                   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
                                   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
                                   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
                                    Aliases: RC4
                                    Attributes:
                                      SupportedModes: ECB
                                   Service: AlgorithmParameters, Algorithm: PBE, Class: com.sun.crypto.provider.PBEParameters
                                   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
                                   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBESHA1
                                    Attributes:
                                   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher
                                    Aliases: Rijndael
                                    Attributes:
                                      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OF B24|OFB32|OFB40|OFB48|OFB56|OFB64|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB7 2|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
                                   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
                                   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
                                    Attributes:
                                   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
                                   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
                                    Aliases: DH
                                    Attributes:
                                      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
                                   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
                                   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
                                    Aliases: DH
                                   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
                                   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
                                    Attributes:
                                   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
                                   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
                                    Aliases: Rijndael
                                   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
                                   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2HmacSHA1Factory
                                    Aliases: OID.1.2.840.113549.1.5.12
                                   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
                                   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
                                    Attributes:
                                   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
                                   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
                                    Aliases: DH
                                   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
                                    Attributes:
                                   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
                                    Attributes:
                                   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
                                   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
                                   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
                                    Attributes:
                                   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
                                   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
                                    Attributes:
                                   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
                                   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
                                    Aliases: TripleDES
                                    Attributes:
                                Provider: SunJGSS, Version: 1.0, Class: sun.security.jgss.SunProvider
                                  Description: Sun (Kerberos v5, SPNEGO)
                                  Services (2):
                                   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
                                   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
                                Provider: SunSASL, Version: 1.5, Class: com.sun.security.sasl.Provider
                                  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
                                  Services (8):
                                   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
                                   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
                                   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
                                   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
                                   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
                                   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
                                   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
                                   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
                                Provider: XMLDSig, Version: 1.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
                                  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
                                  Services (11):
                                   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
                                   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
                                    Aliases: XPATH
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
                                    Aliases: INCLUSIVE_WITH_COMMENTS
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
                                    Aliases: BASE64
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
                                    Aliases: ENVELOPED
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
                                    Aliases: INCLUSIVE
                                    Attributes:
                                      MechanismType: DOM
                                   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
                                   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
                                    Aliases: XPATH2
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
                                    Aliases: EXCLUSIVE
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
                                    Aliases: XSLT
                                    Attributes:
                                      MechanismType: DOM
                                   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
                                    Aliases: EXCLUSIVE_WITH_COMMENTS
                                    Attributes:
                                      MechanismType: DOM
                                Provider: SunPCSC, Version: 1.6, Class: sun.security.smartcardio.SunPCSC
                                  Description: Sun PC/SC provider
                                  Services (1):
                                   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
                                Provider: SunMSCAPI, Version: 1.6, Class: sun.security.mscapi.SunMSCAPI
                                  Description: Sun's Microsoft Crypto API provider
                                  Services (9):
                                   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.RSASignature$MD5
                                    Attributes:
                                      SupportedKeyClasses: sun.security.mscapi.Key
                                   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.RSASignature$SHA1
                                    Attributes:
                                   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.RSACipher
                                    Attributes:
                                      SupportedPaddings: PKCS1PADDING
                                      SupportedModes: ECB
                                   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
                                   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.KeyStore$ROOT
                                   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.RSAKeyPairGenerator
                                    Attributes:
                                      KeySize: 1024
                                   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.RSACipher
                                   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.RSASignature$MD2
                                    Attributes:
                                   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.KeyStore$MY
                                • 14. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                  C. Agruss (Adobe) Level 3
                                  Thanks for the info about the Flex project versions you've been using.
                                  That leads to a related question: if you open the Preferences dialog after updating to 4.0.1, were all 3 SDKs showing as available?
                                  - 3.5
                                  - 4.0
                                  - 4.5
                                  Also, which SDK is configured as the default in the Preferences dialog: 3.5, 4.0, or 4.5?
                                  -Chris
                                  • 15. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                    Miracula.42 Level 1
                                    Hi Chris,
                                    here is a screenshot of the preferences screen with the installed SDKs. Is the "Flex 4.1"-entry okay?!
                                    I removed Flex 4.1 from this list and set 4.0 as default value, but the errors are not gone.
                                    Miracula
                                    • 16. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                      Yes, the Flex 4.1 SDK entry is correct.
                                      That was a typo (4.5) on my part above, but the expected list is what's showing in your screenshot:
                                      - 3.5
                                      - 4.0
                                      - 4.1 (default)
                                      I don't think removing the 4.1 SDK from the list is a good idea - you should probably put it back for future use (sorry for confusing). It's fine to change the default though, if you're mostly using 3.5 currently.
                                      -Chris
                                      • 17. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                        Miracula.42 Level 1
                                        Hi Chris,
                                        I didn't broke anything and restored the defaults, so nothing happened
                                        Miracula
                                        • 18. Re: Flash Builder 4 standalone on win7 64bit is broken after update
                                          pinnamur Level 1
                                          Rewriting the same update as in http://bugs.adobe.com/jira/browse/FB-27100 for wider audience :
                                          It appears that mxmlc.jar file in the path - C:\Program Files  (x86)\Adobe\Adobe Flash Builder  4\plugins\com.adobe.flexbuilder.flex_4.0.1.277662\lib\ is replaced with  an older version (Flex SDK v3.5), due to which Flash bulider code was  not able to find the required (new) method.
                                          Please shutdown Flash Builder and then, replace that mxmlc.jar (in  com.adobe.flexbuilder.flex_4.0.1.277662\lib\) file from the path -  C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\sdks\4.1.0\lib.  Restarting Flash Builder should eliminate the NoSuchMethodError  exception and the it should come up normally.
                                          In any case of any failure, please send the entire .metadata folder  zipped.
