4 Replies Latest reply on Jul 1, 2010 5:28 AM by rootsounds
    Radio Button to Filter Datagrid, buggy
    djh88ukwb Level 1
      Hello All.
      I have a datagrid being poplated by data form a mysql database,  the data is stored in an Array Collection.
      Here is my datagrid
                  <mx:DataGrid x="1" y="20" width="296" dataProvider="{YourCandidatesArr}" height="325" itemClick="itemClickHandler(event)">
                      <mx:columns>
                          <mx:DataGridColumn headerText="ID:" width="35" dataField="ref"/>
                          <mx:DataGridColumn headerText="Firstname" dataField="firstname"/>
                          <mx:DataGridColumn headerText="Surname" dataField="secondname"/>
                      </mx:columns>
                  </mx:DataGrid>
      Here are my radio buttons
              <s:RadioButton x="447" y="180" label="Live" groupName="radiogroup1" id="CB_live" change="GetYourCandidates_filterFunc(event)"/>
              <s:RadioButton x="447" y="206" label="Archieved" groupName="radiogroup1" id="CB_Archieved" change="GetYourCandidates_filterFunc(event)"/>
              <s:RadioButton x="447" y="232" label="All" groupName="radiogroup1" id="CB_All" change="GetYourCandidates_filterFunc(event)"/>
      And finally my script
                  protected function GetYourCandidates_filterFunc(item:Object):void
                      if (CB_live.selected )
                      output.text="a";
                      YourCandidatesArr.filterFunction = case_a_filterFunc;
                      YourCandidatesArr.refresh();
                      else if (CB_Archieved.selected)
                      output.text="b";
                      YourCandidatesArr.filterFunction = case_b_filterFunc;
                      else if (CB_All.selected)
                      output.text="c";
                      YourCandidatesArr.filterFunction = case_c_filterFunc;
                  //Filters
                  protected function case_a_filterFunc(item:Object):Boolean
                      if (item.locked == 'no')
                          return true
                      else
                          return false;
                  protected function case_b_filterFunc(item:Object):Boolean
                      if (item.locked == 'yes')
                          return true
                      else
                          return false;
                  protected function case_c_filterFunc(item:Object):Boolean
                          return true
                      else if (item.locked =='no')
                          return true
                      else
                          return false;
      Now my problem is, the buttons do filter correctly when i click them first, however if i click thru them in a random order they dont work as they should.
        • 1. Re: Radio Button to Filter Datagrid, buggy
          David_F57 Level 5
          hi,
          try doing the code like below, it should sort your problem
          David
          ps: sorry about last night got back to Canberra really late and just sorta crashed for a few of hours
          (600km of travel and an aggressive meeting in the same day has that affect ).
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.ItemClickEvent;
          [Bindable] private var isLocked:String = "All";
          [Bindable] private var myArray:ArrayCollection = new ArrayCollection();
          protected function radiogroup1_itemClickHandler(event:ItemClickEvent):void
          isLocked =event.label;
          myArray.filterFunction = lockFilter;
          myArray.refresh();
          protected function lockFilter(item:Object):Boolean
          switch(isLocked)
          case "Live" : if (item.locked == 'no') return true else return false;
            break;
          case "Archive" : if (item.locked == 'yes') return true else return false;
            break;
          case "All" : if (item.locked == 'yes' || item.locked == "no") return true else return false;
            break;
          </fx:Script>
          <fx:Declarations>
          <s:RadioButtonGroup id="radiogroup1" itemClick="radiogroup1_itemClickHandler(event)"/>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:RadioButton x="175" y="100" label="Live" groupName="radiogroup1"/>
          <s:RadioButton x="175" y="126" label="Archive" groupName="radiogroup1"/>
          <s:RadioButton x="175" y="152" label="All" groupName="radiogroup1"/>
          </s:Application>
          • 2. Re: Radio Button to Filter Datagrid, buggy
            djh88ukwb Level 1
            Thanks for this
            ALthough i get an error on
                            switch(isLocked)
                                    break;
                                    break;
                                    break;
            The error is 1170 Function dose not return a value.
            ANy ideas why ?
            • 3. Re: Radio Button to Filter Datagrid, buggy
              rootsounds Level 4
              That's because it is possible to make it through the switch without returning a value. It needs a default case.
              • 4. Re: Radio Button to Filter Datagrid, buggy
                David_F57 Level 5
                hi,
                You only have 3 states, Live Archive All, so unless the radiobutton label isn't matching one of those three you should always get a result, just add a default value to make the compiler happy.
                                        break;
                                        break;
                                        break;
                                    default : return false;
