29 Replies Latest reply on Mar 22, 2011 2:31 AM by Author care
    Dissapearing paragraphs
    Author care Level 2
      Since upgrading to RH8 and having to modify the styles I get a problem where if a paragraph is inserted some of the content below vanishes. I have to undo the insert and fiddle around with paragraphs to get things to work,
      Any ideas anyone?
        • 1. Re: Dissapearing paragraphs
          Willam van Weelden Adobe Community Professional & MVP
          Does this happen with all paragraphs, specific paragraphs or does it happen completely random?
          What happens in html view? Do you see the code for the paragraph and doesn't is simply show in WYSIWYG? Or is the other paragraph completely removed, also from html view?
          Second, exactly what do you do to get your old paragraph back and to insert the extra paragraph?
          Greet,
          Willam
          • 2. Re: Dissapearing paragraphs
            Amebr Level 4
            Have you installed all the patches? There were some vanishing text/topics bugs fixed in both although I can't remember the exact details.
            • 3. Re: Dissapearing paragraphs
              Author care Level 2
              Folks,
              Here is a typical sequence of screens to illustrate the problem:
              Here we have a segment of a help topic...
              I now add a paragraph...
              I decide I don't want it and delete it. As a result the paragraph a couple of paras below vanishes!!
              • 4. Re: Dissapearing paragraphs
                Author care Level 2
                My copy of RH8 has been updated to 8.0.2 at the time it was announced...
                • 5. Re: Dissapearing paragraphs
                  Author care Level 2
                  In HTML view no apparent change in the code. Seems to be in and around step follow on paragaphs bewteen numbered steps..
                  • 6. Re: Dissapearing paragraphs
                    RoboColum(n) Level 5
                    Could you tell us a bit more about the styles you are using in these paragraphs and how they are set-up. I ask because from your example your paragraphs are numbered yet when you are adding an additional paragraph you are adding a carriage return which should continue the numbering. Yours doesn't.
                    • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
                    • Follow the RoboColum(n) on Twitter
                    • 7. Re: Dissapearing paragraphs
                      Out of interest, what happens if you perform a soft carriage return (Shift + Enter) and then add the links to your images. When you've done that, perform a hard carriage return (Enter) to start your new paragraph and continue the numbering.
                      • 8. Re: Dissapearing paragraphs
                        Author care Level 2
                        Hi Colum,
                        Tried the soft carraige return thing - no impact on the problem. One thing I did notice though was this seems to only happen when there are screen shots a few paras below the paragraphs being added and deleted. The paras being added and deleted are not numbered and have very basic formatting as follows:
                        I've not had this problem with RH6 but it seems to be a RH8 thing despite the fact that nothing fancy is being used in the styles and BTW the step numbered paara were created using Peter Grainges guidelines as I had to re-work these following conversion to RH8...
                        • 9. Re: Dissapearing paragraphs
                          RoboAsh Level 2
                          Can you share a sample small project which could reproduce this issue even a 1 topic project will do
                          Ashish
                          • 10. Re: Dissapearing paragraphs
                            Author care Level 2
                            I have prepared a small test project, please can you advise me on how best to share this with you..
                            If you follow the steps given in my post Dissapearing paragraphs you will be able to see the problem first hand.
                            Steve
                            • 11. Re: Dissapearing paragraphs
                              RoboAsh Level 2
                              You can share it through "acrobat.com" you can create a free account and do a public share if you want or share me only at zajjy_iet@yahoo.co.in
                              Ashsih
                              • 12. Re: Dissapearing paragraphs
                                Author care Level 2
                                Thanks, test project on it's way to you.
                                • 13. Re: Dissapearing paragraphs
                                  RoboAsh Level 2
                                  Hi Author,
                                              Have you shared the project because I could not find it on my acrobat.com account!
                                  Ashish
                                  • 14. Re: Dissapearing paragraphs
                                    Author care Level 2
                                    When I clicked on the link an email was generated and I attached a zip file to that. Please can you give me a proper link and specific instructions on how to upload this to you. I presume this will be some sort of web address?
                                    Or put another way, please can you tell me how to access the appropriate area of your acrobat.com account?
                                    Do I have to open an account myself to do this?
                                    • 15. Re: Dissapearing paragraphs
                                      You would have to open your own acrobat.com account (it's free) or trying using something like cutesendit.com using the email address given.
                                      @petergrainge
                                      • 16. Re: Dissapearing paragraphs
                                        Author care Level 2
                                        Peter I have a problem here, both adobe and cute sendit are blocked by our web secuirty software any other suggestions?
                                        • 17. Re: Dissapearing paragraphs
                                          Buy the IT guys a beer?
                                          More seriously can you put it on a memory stick and send it from home.
                                          @petergrainge
                                          • 18. Re: Dissapearing paragraphs
                                            Author care Level 2
                                            Have sent exmaple project through again to thje email address supplied
                                            using cutesendit as kindly suggested by Peter. delivery notified as successful.
                                            Project has a single topic and can be used to test the problem documented in this thread.
                                            Steve
                                            • 19. Re: Dissapearing paragraphs
                                              RoboAsh Level 2
                                              HI Author Care,
                                                       Yes you need to open an account on acrobat.com, its free
                                              then after you log in you will get an option to upload and after selecting the file you need to upload
                                              after uploade you get an option of Share and on selcting it in the bottom left corner you will see an option of Publish
                                              after Publish you will get an option to Copy link - which is the URL you can mail to the person you need to share the uloaded file
                                              the URL looks like https://acrobat.com/#d=3juUTrKlTyQAxrZztWn5Kw
                                              Please mail the shared project @ ashishchandra.gupta@gmail.com
                                              Ashish
                                              • 20. Re: Dissapearing paragraphs
                                                Author care Level 2
                                                I've now opened an acrobat.com account and shared the example project as directed. Please let me know if further info is required.
                                                • 21. Re: Dissapearing paragraphs
                                                  Author care Level 2
                                                  Hi Ashish,
                                                  Please can you confirm receipt of the sample project and update on the status of resolving this issue?
                                                  Steve
                                                  • 22. Re: Dissapearing paragraphs
                                                    RoboAsh Level 2
                                                    Hi Steve,
                                                             Thanks for your patience and apologies for the delay.
                                                    Yup I do have the project "Test disappearing paragraph.zip" but apologies that I could not look into it because of other tasks at hand, I will look into it ASAP, please elaborate specific steps to reproduce the issue with this sample project.
                                                    Need some clarity on the snapshots that you attached related to the problem, the third screen shows the right bullet and text only there is a extra line and the image is missing below the link - is this is the issue that the image is gone missing and a extra line appears?
                                                    for the time being I came across a new finding, did you upgraded your project with both the RH updates installed, as I came to know that upgrading any older version project with just RH 8.0.1 installed and then updating with the RH patch 8.0.2 and then working on the upgraded project with RH 8.0.2 causes issue!
                                                    I would suggest you to do just one more experiment, If you have the older version RH project and have fully updated RH 8.0.2 then do try upgrading this older version project through RH 8.0.2, this might solve your issue.
                                                    just wanted to know if you are using CBTs with UDV, table or lists in such topics which are showing up this issue !
                                                    Hope this will help
                                                    Ashish
                                                    • 23. Re: Dissapearing paragraphs
                                                      Author care Level 2
                                                      Hi Ashish and thanks for your reply,
                                                      Answers to questions inline below:
                                                      Yes, the image dissappears for no reason.
                                                      The test project I sent you was created under RH 8.0.2 and this problem has consistently occurred under 8.0.2 so is not related to the problem you mentioned.
                                                      See comments above I have already tested this and this does not solve the problem.
                                                      No this problem is not releated to conditional build tags.
                                                      Steve
                                                      • 24. Re: Dissapearing paragraphs
                                                        RoboAsh Level 2
                                                        HI Steve,
        I am just going through your Sample project I need more information related to that
                                                        1. The First topic seems to be created based on the master page but the content shown here in the topic does not show most of the content of the master page in this topic
                                                        2. I created another topic with the same master page and did tried to Press cariage return at random places but nothing was lost due to this process!, I even tried it in the master page itself but nothing got lost!!
                                                        3. Does you problem occurs while editing the master page ? or topics based on the master page?
                                                        4. Can you please give some specific steps to reproduce your problem in the sample project (Test disapearing paragraph) provided to me
                                                        Please help me with these specific question so that I can help you
                                                        Ashish
                                                        • 25. Re: Dissapearing paragraphs
                                                          Author care Level 2
                                                          This problem occurs in topic pages where the topics have the master page applied. In other words normal operating methods with RoboHELP.
                                                          The specific steps are those listed earlier in the post.
                                                          • 26. Re: Dissapearing paragraphs
                                                            RoboAsh Level 2
                                                            Hi Steve,
        I was able to reproduce the problem and it is not related to Master page, you can also reproduce the issue by creating a new topic without any master page,
                                                            and then copy & paste the list into it and then delete any of the blank line after list item 2.
                                                            Just give me some time to decode the issue and I will get back to you on this !
                                                            Ashish
                                                            • 27. Re: Dissapearing paragraphs
                                                              RoboAsh Level 2
                                                              Hi Steve,
        I require a little more information related to this issue!
                                                              How were the topic created? Was the topics created with some other editor or through import.
                                                              If Imported was the import done in the older version RH project or after the upgrade and what was imported means the original file (e.g. Word, FrameMaker or PDF)
                                                              from where and how the list has been created (which is applied at the paragraph level)
                                                              Please provide me with these specifics to help me explore this issue
                                                              Ashish
                                                              • 28. Re: Dissapearing paragraphs
        RoboAsh Level 2
        Hi Steve,
        Some good news for you, I was just able to discover something new in this issue.
        The loss of content is not real, what I saw was that for some reason or other it just stops showing up in the RH Design editor the solution to show it back is
        1. After any delete Save the project (even if it shows some loses don't worry)
        2. Switch to the HTML view (code view of RH)
        3. Switch back to the Design view and you will see all the content with all the list levels and content correctly
        so you are not losing anything is real because of this and even if you reopen the topic of project you will find all the contents correctly in the topic
        Hope this will help
        Ashish
        • 29. Re: Dissapearing paragraphs
        Author care Level 2
        Hi Ashish,
        In answer to your questions:
        No, the topics were created in RoboHELP 8.0.2 using it's own html editor.
        No see above
        All items in the topics under created were done the proper way using paragraph styles as per the original post.
        Data loss is not real
        Re the other point, I am already aware that the loss of data is "not real" but there is still a problem and that problem is with RoboHELP.
        It's not acceptable for material you are working on to dissapear just because you added a paragraph or performed what should be a routine normal action.
        Hope that helps..
        Steve
